Need some opinion, used GTX 1070 or new GTX 1660 Super
absolut_zero
Post by absolut_zero »
Hi. I need some opinions and recommendations between a used GTX 1070 and a new GTX 1660 Super. Which of the two GPU is better?
Thanks.
Re: Need some opinion, used GTX 1070 or new GTX 1660 Super
Welcome to the F@H Forum absolut_zero,
Please note that you may want to state that the primary purpose is of your GPU. Reason is that it can impact our suggestions. F@H aims to use your unused computer power so you build a system that suits you best. Of course, there are enthusiasts Donors who build dedicated rigs which are appreciated too. Assuming that you are after a GPU that will function as a dedicated folding GPU, then have a look at this topic: viewtopic.php?f=38&t=34510 and the post for some information: viewtopic.php?p=333014#p333014
Post by foldy »
I guess both habe same PPD in FAH but GTX 1660 uses less power.
HaloJones
Post by HaloJones »
lower power draw will equate to lower fan speeds potentially. any purchase for fah needs to consider the inherent cooling so don't skimp.
my 1070s are (so far) very reliable and produce (looking this moment across them) from 777512-881984 ppd.
4070 super
FireFox-89
Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FG
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X | Corsair H100i V2 with 2 Corsair SP120 120mm fans
ASRock B450M/ac R2.0 | BIOS version p3.10
G.Skill Trident RGB 2x8GB DDR4-3000 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+ Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Need Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.4.9
Post by FireFox-89 »
I have no experience with either GPU but even though the 1070 is a bit of a beast I think I would lean towards the 1660 due to being a newer architecture which also has an updated version of CUDA (no idea if that makes a difference to folding though). But if they perform about the same then go with which ever one is the best price since they'll both be decent :)
HaloJones wrote:very reliable and produce (looking this moment across them) from 777512-881984 ppd.
Is that PPD range from a single card?
Do you even fold bro?
MeeLee
Post by MeeLee »
I would second, third, fourth the 1660 Super.
It's memory is a lot faster. The 1070 has more cores (100 more) but it runs at a lower speed (100Mhz lower). Comes down to identical PPD, but the 1660 Super will run cooler, and less watts.
Avoid the single fan (both open and blower style) designs, but dual fan designs are good enough for this GPU.
If you can get a 1660Ti, get that one. It costs about the same price, but has a slight edge on the Super.
If the price difference is too much, go with the 1660 Super.
HaloJones
Post by HaloJones »
no, I have five running.
my highest is 1.1m, lowest around 700K
all the cards are aggressively cooled so run over 2000MHz. I always buy used and have picked up some great bargains although prices are noticeably up since lockdown.
this comparison shows the 1070 as faster and the current analysis being done on this forum of ppd shows the 1070 significantly ahead of a 1660Super.
the 1660Super has 1408 Cuda cores while the 1070 has 1920, the 1660Super might clock slightly higher (about 5%).
But even though I love the 1070, unless you can get one for less than a 1660Super you should get the newer card. warranty and lower power draw but it depends on your risk appetite :)
4070 super
HaloJones
Post by HaloJones »
MeeLee wrote:I would second, third, fourth the 1660 Super.
1070 has 512 more cores not 100.
4070 super
MeeLee
Post by MeeLee »
GTX 1070: 1920 cores.
GTX 1660 Super: 1408.
You're correct.
I'd still take the 1660, though the 1660Ti. The price is almost the same as the 1660Super.
