My sister has a Radeon 8450G video card in her laptop on Windows 10. Is that video card supported in 7.6.9, and if so, how would I get it to show up (I've tried adding a slot manually, but it doesn't seem to stick)?
Thanks!
Is the Radeon HD 8450G on Windows 10 supported?
Re: Is the Radeon HD 8450G on Windows 10 supported?
Yes, the Trinity [Radeon HD 8450G] is supported on WIndows or Linux.
Thanks for writing back. I eventually had to manually inject the GPU configuration into the XML, but it did recognize the slot (the Configure button no longer works in FAHControl though, but when was I ever afraid of XML?).
So far the GPU has handed back two work units with "No compatible OpenCL platform is available" on version 0.0.5 of Core22. I'm going to let the laptop vege overnight and see if it can actually get the GPU going; if not, I'll post the log.
Since the GPU can't run as a service, is it possible to have a service running with one of CPU cores (the laptop has a whopping two cores) and then a separate configuration to run on user login for the GPU?
Thanks!
Thanks!
If the HD 8450G is this one - https://www.techpowerup.com/gpu-specs/r ... -igp.c2187 - as part of an APU, then no, as it does not list support for Double Precision (FP64). Even the desktop HD 8450 card did not support DP, in the desktop series that shows up in the HD 8500 and above.
FireFox-89
- Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FG
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X | Corsair H100i V2 with 2 Corsair SP120 120mm fans
ASRock B450M/ac R2.0 | BIOS version p3.10
G.Skill Trident RGB 2x8GB DDR4-3000 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+ Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Need Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.4.9 - Location: Lincolnshire, UK
If it is supported and you get it working I would make sure the vents and heatsinks are clear of dust and monitor the tempertures thoroughly. I wouldn't recommend folding on any laptop because the cooling really isn't that great especially for long periods of time.
Do you even fold bro?
I also suspect that the video card drivers no longer support OpenCL.
