updates on linux?
harry747
Hardware configuration: quadcore i7, 16GB, ubuntu 19.10.
updates on linux?
Post by harry747 »
hi.
is there a way to update FAH using the software updater? if so, what do i have to do? i ask because i couldn't find anything about updating on the FAH website.
I TNO, therefore I am.
HaloJones
Re: updates on linux?
Post by HaloJones »
download the packages from the folding website, double click on the downloaded packages. that's all I did on Mint 18 and 19.
4070 super
harry747
Post by harry747 »
Double-click? I'm not sure that works on Ubuntu, but I'll give it a go.
HaloJones
Post by HaloJones »
does in Mint
4070 super
TPL
Post by TPL »
Yes it does and Mint is based on Ubuntu. But no experience on Ubuntu.
MeeLee
Post by MeeLee »
It works in Ubuntu as well.
.deb packages are opened with a package maintainer.
harry747
Post by harry747 »
Yes, it does work. But my question was about the software updater. Is there a repository that I can add to software updater to make updating easier?
AFAIK, there isn't any repository for Linux :(
harry747
Post by harry747 »
MeeLee
Post by MeeLee »
For that to work, you normally would need to import a PPA, which FAH doesn't have.
They could easily create one on Github, but since the last client was active for more than half a decade, it makes little sense to do so.
You can easily uninstall the client, and install the new client after download.
As long as Control is installed, I believe your personal data is still in tact (meaning you don't have to re-set up your account).
Do correct me if I'm wrong here, since it's been a while since I've done this.
berndinger
Post by berndinger »
Your personal data is in etc/fahclient/config.xml. Linux, of course... So save this file for using in a new distibution, if you install one...
Im using Mint 20 pre alpha, and there fahcontrol doesnt work, because of the ubuntu 20.04 base.
Via webinterface and by editing config.xml you can control the client.
cheers,
Bernd
Darth_Peter_dualxeon
Hardware configuration: EVGA SR-2 motherboard
2x Xeon x5670 CPU
64 GB ECC DDR3
Nvidia RTX 2070
Post by Darth_Peter_dualxeon »
I have updated my installation (all the components, client, control, viewer too). Also, I don't want to mess up running WUs by other system updates.
First, click "finish" on the FAHControl.
Wait to finish and upload all the currently running stuff.
Install new version of the packages. (system will handle the update properly, i didn't need to care to uninstall the old version in Mint)
Install the system updates and reboot if required (i.e. kernel or gpu driver update)
peterjammo
Post by peterjammo »
I updated my 3 x 18.3 and 1 x 19.3 Mint laptops just downloading and installing over the top with no problems. That included one 18.3 where I decided to reboot before updating as it had been running for days, not realising that the "Finish" feature pause wouldn't survive the reboot. When I opened FAHControl on the updated system I was already part way through a WU which must have downloaded and started during the upgrade. No problems at all. I'd still suggest using "finish" before upgrading.
