Cant Add GPU
nickjames2006
Cant Add GPU
Post by nickjames2006 »
Hi All,
Been folding ok for the past month all good.
I updated my gfx drivers yesterday and since then GPU wont work. Its an AMD Radeon RX Vega 56.
I have uninstall folding and installed the new client and its now removed it completely.
When I go to add it again in just closes the screen and dumps me back to the main folding screen here is the log
*********************** Log Started 2020-04-30T10:22:10Z ***********************
10:22:10:****************************** FAHClient ******************************
10:22:10:        Version: 7.6.9
10:22:10:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:22:10:      Copyright: 2020 foldingathome.org
10:22:10:       Homepage: https://foldingathome.org/
10:22:10:           Date: Apr 17 2020
10:22:10:           Time: 11:13:06
10:22:10:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
10:22:10:         Branch: master
10:22:10:       Compiler: Visual C++ 2008
10:22:10:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:22:10:       Platform: win32 10
10:22:10:           Bits: 32
10:22:10:           Mode: Release
10:22:10:           Args: --open-web-control
10:22:10:******************************** CBang ********************************
10:22:10:           Time: 11:10:09
10:22:10:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
10:22:10:           Bits: 32
10:22:10:******************************* System ********************************
10:22:10:            CPU: AMD Ryzen 7 2700 Eight-Core Processor
10:22:10:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:22:10:           CPUs: 16
10:22:10:         Memory: 15.94GiB
10:22:10:    Free Memory: 8.64GiB
10:22:10:        Threads: WINDOWS_THREADS
10:22:10:     OS Version: 6.2
10:22:10:    Has Battery: false
10:22:10:     On Battery: false
10:22:10:     UTC Offset: 1
10:22:10:            PID: 2376
10:22:10:            CWD: E:\FoldData
10:22:10:             OS: Windows 10 Enterprise
10:22:10:        OS Arch: AMD64
10:22:10:           GPUs: 0
10:22:10:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:22:10:                 specified module could not be found.
10:22:10:
10:22:10:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:1.2 Driver:3004.8
10:22:10:  Win32 Service: false
10:22:10:******************************* libFAH ********************************
10:22:10:           Date: Apr 15 2020
10:22:10:           Time: 14:53:14
10:22:10:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:22:10:           Bits: 32
10:22:10:***********************************************************************
10:22:10:<config>
10:22:10:  <!-- Folding Slots -->
10:22:10:</config>
10:22:10:Trying to access database...
10:22:11:Successfully acquired database lock
10:22:11:Enabled folding slot 00: PAUSED cpu:15 (not configured)
10:22:13:WARNING:10:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_highlight-soft_75_cccccc_1x100.png
10:22:13:WARNING:14:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_55_fbf9ee_1x400.png
10:22:14:15:127.0.0.1:New Web session
10:22:14:WARNING:16:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_95_fef1ec_1x400.png
10:22:14:WARNING:17:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_222222_256x240.png
10:22:14:WARNING:20:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_2e83ff_256x240.png
10:22:14:WARNING:21:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_cd0a0a_256x240.png
10:22:15:WARNING:24:127.0.0.1:404 HTTP NOT FOUND /images/ui-bg_flat_0_aaaaaa_40x100.png
10:23:12:Saving configuration to config.xml
10:23:12:<config>
10:23:12:  <!-- Folding Slots -->
10:23:12:  <slot id='0' type='CPU'/>
10:23:12:</config>
10:23:12:Set client configured
10:23:12:WU00:FS00:Connecting to 65.254.110.245:80
10:23:13:WU00:FS00:Connecting to 65.254.110.245:80
10:23:13:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
10:23:13:WU00:FS00:Connecting to 18.218.241.186:80
10:23:14:WU00:FS00:Assigned to work server 155.247.164.214
10:23:14:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 155.247.164.214
10:23:14:WU00:FS00:Connecting to 155.247.164.214:8080
10:23:14:WU00:FS00:Downloading 2.83MiB
10:23:15:WU00:FS00:Download complete
10:23:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14625 run:526 clone:2 gen:73 core:0xa7 unit:0x000000519bf7a4d65e88df55bf9578d4
10:23:15:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
10:23:15:WU00:FS00:Connecting to cores.foldingathome.org:80
10:23:16:WU00:FS00:FahCore a7: Downloading 6.71MiB
10:23:21:WU00:FS00:FahCore a7: Download complete
10:23:21:WU00:FS00:Valid core signature
10:23:21:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
10:23:21:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
10:23:21:WU00:FS00:Starting
10:23:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:\FoldData\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 2376 -checkpoint 15 -np 15
10:23:21:WU00:FS00:Started FahCore on PID 22876
10:23:22:WU00:FS00:Core PID:3828
10:23:22:WU00:FS00:FahCore 0xa7 started
10:23:22:WU00:FS00:0xa7:*********************** Log Started 2020-04-30T10:23:22Z ***********************
10:23:22:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:23:22:WU00:FS00:0xa7:       Type: 0xa7
10:23:22:WU00:FS00:0xa7:       Core: Gromacs
10:23:22:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 22876 -checkpoint 15 -np
10:23:22:WU00:FS00:0xa7:             15
10:23:22:WU00:FS00:0xa7:************************************ CBang *************************************
10:23:22:WU00:FS00:0xa7:       Date: Oct 26 2019
10:23:22:WU00:FS00:0xa7:       Time: 01:38:25
10:23:22:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:23:22:WU00:FS00:0xa7:     Branch: master
10:23:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:23:22:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:23:22:WU00:FS00:0xa7:   Platform: win32 10
10:23:22:WU00:FS00:0xa7:       Bits: 64
10:23:22:WU00:FS00:0xa7:       Mode: Release
10:23:22:WU00:FS00:0xa7:************************************ System ************************************
10:23:22:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700 Eight-Core Processor
10:23:22:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:23:22:WU00:FS00:0xa7:       CPUs: 16
10:23:22:WU00:FS00:0xa7:     Memory: 15.94GiB
10:23:22:WU00:FS00:0xa7:Free Memory: 8.51GiB
10:23:22:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:23:22:WU00:FS00:0xa7: OS Version: 6.2
10:23:22:WU00:FS00:0xa7:Has Battery: false
10:23:22:WU00:FS00:0xa7: On Battery: false
10:23:22:WU00:FS00:0xa7: UTC Offset: 1
10:23:22:WU00:FS00:0xa7:        PID: 3828
10:23:22:WU00:FS00:0xa7:        CWD: E:\FoldData\work
10:23:22:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:23:22:WU00:FS00:0xa7:    Version: 0.0.18
10:23:22:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:23:22:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:23:22:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:23:22:WU00:FS00:0xa7:       Time: 01:52:30
10:23:22:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:23:22:WU00:FS00:0xa7:************************************ Build *************************************
10:23:22:WU00:FS00:0xa7:       SIMD: avx_256
10:23:22:WU00:FS00:0xa7:********************************************************************************
10:23:22:WU00:FS00:0xa7:Project: 14625 (Run 526, Clone 2, Gen 73)
10:23:22:WU00:FS00:0xa7:Unit: 0x000000519bf7a4d65e88df55bf9578d4
10:23:22:WU00:FS00:0xa7:Reading tar file core.xml
10:23:22:WU00:FS00:0xa7:Reading tar file frame73.tpr
10:23:22:WU00:FS00:0xa7:Digital signatures verified
10:23:22:WU00:FS00:0xa7:Calling: mdrun -s frame73.tpr -o frame73.trr -cpt 15 -nt 15
10:23:22:WU00:FS00:0xa7:Steps: first=0 total=250000
10:23:24:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
10:24:52:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
10:25:14:Saving configuration to config.xml
10:25:14:<config>
10:25:14:  <!-- Network -->
10:25:14:  <proxy v=':8080'/>
10:25:14:
10:25:14:  <!-- User Information -->
10:25:14:  <passkey v='*****'/>
10:25:14:  <team v='224497'/>
10:25:14:  <user v='NickJames_FLDC_1HzWXEewvDfhazr65wD461r7r29rgJC8xt'/>
10:25:14:
10:25:14:  <!-- Folding Slots -->
10:25:14:  <slot id='0' type='CPU'/>
10:25:14:</config>
10:26:15:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
10:26:17:FS00:Shutting core down
10:26:17:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 3828
10:26:17:WU00:FS00:0xa7:Exiting, please wait. . .
10:26:18:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:26:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:26:19:WU00:FS00:Starting
10:26:19:WARNING:WU00:FS00:Changed SMP threads from 15 to 16 this can cause some work units to fail
10:26:19:WARNING:WU00:FS00:AS lowered CPUs from 16 to 15
10:26:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:\FoldData\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 2376 -checkpoint 15 -np 15
10:26:19:WU00:FS00:Started FahCore on PID 23184
10:26:19:WU00:FS00:Core PID:8548
10:26:19:WU00:FS00:FahCore 0xa7 started
10:26:19:WU00:FS00:0xa7:*********************** Log Started 2020-04-30T10:26:19Z ***********************
10:26:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:26:19:WU00:FS00:0xa7:       Type: 0xa7
10:26:19:WU00:FS00:0xa7:       Core: Gromacs
10:26:19:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 23184 -checkpoint 15 -np
10:26:19:WU00:FS00:0xa7:             15
10:26:19:WU00:FS00:0xa7:************************************ CBang *************************************
10:26:19:WU00:FS00:0xa7:       Date: Oct 26 2019
10:26:19:WU00:FS00:0xa7:       Time: 01:38:25
10:26:19:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:26:19:WU00:FS00:0xa7:     Branch: master
10:26:19:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:26:19:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:26:19:WU00:FS00:0xa7:   Platform: win32 10
10:26:19:WU00:FS00:0xa7:       Bits: 64
10:26:19:WU00:FS00:0xa7:       Mode: Release
10:26:19:WU00:FS00:0xa7:************************************ System ************************************
10:26:19:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700 Eight-Core Processor
10:26:19:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:26:19:WU00:FS00:0xa7:       CPUs: 16
10:26:19:WU00:FS00:0xa7:     Memory: 15.94GiB
10:26:19:WU00:FS00:0xa7:Free Memory: 8.29GiB
10:26:19:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:26:19:WU00:FS00:0xa7: OS Version: 6.2
10:26:19:WU00:FS00:0xa7:Has Battery: false
10:26:19:WU00:FS00:0xa7: On Battery: false
10:26:19:WU00:FS00:0xa7: UTC Offset: 1
10:26:19:WU00:FS00:0xa7:        PID: 8548
10:26:19:WU00:FS00:0xa7:        CWD: E:\FoldData\work
10:26:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:26:19:WU00:FS00:0xa7:    Version: 0.0.18
10:26:19:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:26:19:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:26:19:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:26:19:WU00:FS00:0xa7:       Time: 01:52:30
10:26:19:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:26:19:WU00:FS00:0xa7:************************************ Build *************************************
10:26:19:WU00:FS00:0xa7:       SIMD: avx_256
10:26:19:WU00:FS00:0xa7:********************************************************************************
10:26:19:WU00:FS00:0xa7:Project: 14625 (Run 526, Clone 2, Gen 73)
10:26:19:WU00:FS00:0xa7:Unit: 0x000000519bf7a4d65e88df55bf9578d4
10:26:19:WU00:FS00:0xa7:Digital signatures verified
10:26:19:WU00:FS00:0xa7:Calling: mdrun -s frame73.tpr -o frame73.trr -cpi state.cpt -cpt 15 -nt 15
10:26:19:WU00:FS00:0xa7:Steps: first=0 total=250000
10:26:20:WU00:FS00:0xa7:Completed 5076 out of 250000 steps (2%)
10:27:10:Connecting to assign1.foldingathome.org:80
10:27:10:Updated GPUs.txt
10:27:16:Saving configuration to config.xml
10:27:16:<config>
10:27:16:  <!-- Network -->
10:27:16:  <proxy v=':8080'/>
10:27:16:
10:27:16:  <!-- Slot Control -->
10:27:16:  <power v='full'/>
10:27:16:
10:27:16:  <!-- User Information -->
10:27:16:  <passkey v='*****'/>
10:27:16:  <team v='224497'/>
10:27:16:  <user v='NickJames_FLDC_1HzWXEewvDfhazr65wD461r7r29rgJC8xt'/>
10:27:16:
10:27:16:  <!-- Folding Slots -->
10:27:16:  <slot id='0' type='CPU'/>
10:27:16:</config>
10:27:34:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
10:27:40:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
10:29:09:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
10:30:34:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
10:31:58:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
10:33:16:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
10:34:34:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
10:35:55:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
10:37:18:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
10:38:39:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
10:39:56:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
10:41:15:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
10:42:35:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
Hope you can help :)
Re: Cant Add GPU
Welcome to the F@H Forum nickjames2006,
This is a known issue for a fresh installation of V7.6.9 on a GPU system, here's a workaround for you (For Windows system):
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to E:\FoldData
Reboot your system OR Restart your client (which ever is easier)
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
nickjames2006
Re: Cant Add GPU
Happy Days. its worked. Thanks :)
Hyperbob
Re: Cant Add GPU
Post by Hyperbob »
I just started folding today, and I had a similar problem with my RX 590. Applying the downloaded GPUs.txt solved the problem, but I found the directory in a different location.
Under the [System Info] tab of the client -> first section -> "Config" has a filepath to the configuration XML. This is also where the GPUs.txt file should go. Navigate to that location (bearing in mind that you might have to enable hidden folders) and replace GPUs.txt. Doing this + restarting my machine solved the problem! Thanks a bunch!
(If you're a brand new user like myself, you'll probably also have to add the GPU as a slot)
Re: Cant Add GPU
Welcome to the F@H Forum Hyperbob,
Please note that the reason your CWD changed is because you modified the installation directory. Generally speaking, Donors who modify paths during installation would have sufficient computer proficiency to adapt the instructions written for default installation to their own. In this case, you sorted it out :)
