Please dd Zotac/PC Partner NVIDIA GeForce RTX 2060 SUPER
mattwiese123
Post by mattwiese123 »
Name: NVIDIA GeForce RTX 2060 SUPER
GPU: TU106
Device ID: 10DE-1F06-19DA-5511
*********************** Log Started 2020-04-24T13:52:35Z ***********************
13:52:35:****************************** FAHClient ******************************
13:52:35:        Version: 7.6.9
13:52:35:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:52:35:      Copyright: 2020 foldingathome.org
13:52:35:       Homepage: https://foldingathome.org/
13:52:35:           Date: Apr 17 2020
13:52:35:           Time: 11:13:06
13:52:35:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
13:52:35:         Branch: master
13:52:35:       Compiler: Visual C++ 2008
13:52:35:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:52:35:       Platform: win32 10
13:52:35:           Bits: 32
13:52:35:           Mode: Release
13:52:35:           Args: --open-web-control
13:52:35:         Config: C:\Users\matt\AppData\Roaming\FAHClient\config.xml
13:52:35:******************************** CBang ********************************
13:52:35:           Time: 11:10:09
13:52:35:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
13:52:35:           Bits: 32
13:52:35:******************************* System ********************************
13:52:35:            CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
13:52:35:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
13:52:35:           CPUs: 8
13:52:35:         Memory: 31.92GiB
13:52:35:    Free Memory: 16.65GiB
13:52:35:        Threads: WINDOWS_THREADS
13:52:35:     OS Version: 6.2
13:52:35:    Has Battery: false
13:52:35:     On Battery: false
13:52:35:     UTC Offset: -4
13:52:35:            PID: 2924
13:52:35:            CWD: C:\Users\matt\AppData\Roaming\FAHClient
13:52:35:             OS: Windows 10 Enterprise
13:52:35:        OS Arch: AMD64
13:52:35:           GPUs: 0
13:52:35:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
13:52:35:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
13:52:35:  Win32 Service: false
13:52:35:******************************* libFAH ********************************
13:52:35:           Date: Apr 15 2020
13:52:35:           Time: 14:53:14
13:52:35:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:52:35:           Bits: 32
13:52:35:***********************************************************************
13:52:36:<config>
13:52:36:  <!-- Folding Slot Configuration -->
13:52:36:  <cause v='COVID_19'/>
13:52:36:
13:52:36:  <!-- Network -->
13:52:36:  <proxy v=':8080'/>
13:52:36:
13:52:36:  <!-- Slot Control -->
13:52:36:  <power v='FULL'/>
13:52:36:
13:52:36:  <!-- User Information -->
13:52:36:  <passkey v='*****'/>
13:52:36:  <user v='mattwiese'/>
13:52:36:
13:52:36:  <!-- Folding Slots -->
13:52:36:  <slot id='0' type='CPU'>
13:52:36:    <paused v='true'/>
13:52:36:  </slot>
13:52:36:</config>
13:52:36:Trying to access database...
13:52:36:Successfully acquired database lock
13:52:36:Enabled folding slot 00: PAUSED cpu:8 (by user)
13:52:37:3:127.0.0.1:New Web session
13:53:24:13:127.0.0.1:New Web session
13:53:59:Clean exit
Re: Please dd Zotac/PC Partner NVIDIA GeForce RTX 2060 SUPER
This is already in the list:
0x10de:0x1f06:2:7:TU106 [GeForce RTX 2060 Super]
The actual problem is that there is a bug in the 7.6.9 installer, it does not download the GPUs.txt file and install it. Then it does not set up a GPU slot.
Post by foldy »
Use the FAH beta version as workaround https://foldingathome.org/beta/
Welcome to the F@H Forum mattwiese123,
If you're not keen to use a Beta software, here's a workaround for you:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to C:\Users\matt\AppData\Roaming\FAHClient\
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
mattwiese123
I installed the beta and the GPU is up and running! Thank you all so much! :)
Harpo
Post by Harpo »
Same problem here, and though replacing gpus.txt worked on the last rig I built this time it did nothing.
It doesn't pick up the gpu at all (GTX 1660 ti), and when I remove the cpu it just adds another one. Very frustrating!
Harpo wrote:...when I remove the cpu it just adds another one. Very frustrating!
On Windows, FAHControl is always expected to have a folding Slot, either CPU or GPU. If you don't have any folding Slots, it will automatically add a CPU Slot. You can add a CPU Slot and ensure that pause-on-start is true which means it will be there but will not be folding.
After rebooting your system, please post the log file so we can see what's happening :)
Harpo
Post by Harpo »
Rebooted, same situation, no gpu. But now there is another CPU, and it is folding.
I have five other rigs, all are folding, and none of them has a slot for CPU.
I've seen this same issue now on a youtube video, a new guy was very proud of the points his cpu was doing. He had no idea that gpu's were used, and if someone just installs the current software that's exactly the results they will get too.
I'm sorry to complain, but this is very frustrating. This new software simply does not work "out of the box", and each new installation has required a different fix, for me at least.
*********************** Log Started 2020-04-25T23:45:53Z ***********************
23:45:53:****************************** FAHClient ******************************
23:45:53:        Version: 7.6.9
23:45:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:45:53:      Copyright: 2020 foldingathome.org
23:45:53:       Homepage: https://foldingathome.org/
23:45:53:           Date: Apr 17 2020
23:45:53:           Time: 11:13:06
23:45:53:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:45:53:         Branch: master
23:45:53:       Compiler: Visual C++ 2008
23:45:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:45:53:       Platform: win32 10
23:45:53:           Bits: 32
23:45:53:           Mode: Release
23:45:53:         Config: C:\Users\FOLD5\AppData\Roaming\FAHClient\config.xml
23:45:53:******************************** CBang ********************************
23:45:53:           Time: 11:10:09
23:45:53:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:45:53:           Bits: 32
23:45:53:******************************* System ********************************
23:45:53:            CPU: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
23:45:53:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:45:53:           CPUs: 6
23:45:53:         Memory: 7.94GiB
23:45:53:    Free Memory: 6.51GiB
23:45:53:        Threads: WINDOWS_THREADS
23:45:53:     OS Version: 6.2
23:45:53:    Has Battery: false
23:45:53:     On Battery: false
23:45:53:     UTC Offset: -7
23:45:53:            PID: 7232
23:45:53:            CWD: C:\Users\FOLD5\AppData\Roaming\FAHClient
23:45:53:             OS: Windows 10 Enterprise
23:45:53:        OS Arch: AMD64
23:45:53:           GPUs: 1
23:45:53:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 Ti]
23:45:53:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
23:45:53:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
23:45:53:  Win32 Service: false
23:45:53:******************************* libFAH ********************************
23:45:53:           Date: Apr 15 2020
23:45:53:           Time: 14:53:14
23:45:53:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:45:53:           Bits: 32
23:45:53:***********************************************************************
23:45:53:<config>
23:45:53:  <!-- Network -->
23:45:53:  <proxy v=':8080'/>
23:45:53:
23:45:53:  <!-- User Information -->
23:45:53:  <passkey v='*****'/>
23:45:53:  <team v='234771'/>
23:45:53:  <user v='Frodo3636'/>
23:45:53:
23:45:53:  <!-- Folding Slots -->
23:45:53:  <slot id='0' type='CPU'/>
23:45:53:</config>
23:45:53:Trying to access database...
23:45:53:Successfully acquired database lock
23:45:53:Enabled folding slot 00: READY cpu:5
23:45:53:WU00:FS00:Starting
23:45:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\FOLD5\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7232 -checkpoint 15 -np 5
23:45:53:WU00:FS00:Started FahCore on PID 7332
23:45:53:WU00:FS00:Core PID:7356
23:45:53:WU00:FS00:FahCore 0xa7 started
23:45:54:WU00:FS00:0xa7:*********************** Log Started 2020-04-25T23:45:53Z ***********************
23:45:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:45:54:WU00:FS00:0xa7:       Type: 0xa7
23:45:54:WU00:FS00:0xa7:       Core: Gromacs
23:45:54:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7332 -checkpoint 15 -np 5
23:45:54:WU00:FS00:0xa7:************************************ CBang *************************************
23:45:54:WU00:FS00:0xa7:       Date: Oct 26 2019
23:45:54:WU00:FS00:0xa7:       Time: 01:38:25
23:45:54:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:45:54:WU00:FS00:0xa7:     Branch: master
23:45:54:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:45:54:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:45:54:WU00:FS00:0xa7:   Platform: win32 10
23:45:54:WU00:FS00:0xa7:       Bits: 64
23:45:54:WU00:FS00:0xa7:       Mode: Release
23:45:54:WU00:FS00:0xa7:************************************ System ************************************
23:45:54:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
23:45:54:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:45:54:WU00:FS00:0xa7:       CPUs: 6
23:45:54:WU00:FS00:0xa7:     Memory: 7.94GiB
23:45:54:WU00:FS00:0xa7:Free Memory: 6.49GiB
23:45:54:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:45:54:WU00:FS00:0xa7: OS Version: 6.2
23:45:54:WU00:FS00:0xa7:Has Battery: false
23:45:54:WU00:FS00:0xa7: On Battery: false
23:45:54:WU00:FS00:0xa7: UTC Offset: -7
23:45:54:WU00:FS00:0xa7:        PID: 7356
23:45:54:WU00:FS00:0xa7:        CWD: C:\Users\FOLD5\AppData\Roaming\FAHClient\work
23:45:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:45:54:WU00:FS00:0xa7:    Version: 0.0.18
23:45:54:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:45:54:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:45:54:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:45:54:WU00:FS00:0xa7:       Time: 01:52:30
23:45:54:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:45:54:WU00:FS00:0xa7:************************************ Build *************************************
23:45:54:WU00:FS00:0xa7:       SIMD: avx_256
23:45:54:WU00:FS00:0xa7:********************************************************************************
23:45:54:WU00:FS00:0xa7:Project: 14375 (Run 1397, Clone 1, Gen 51)
23:45:54:WU00:FS00:0xa7:Unit: 0x000000382879986c5e887038a189c185
23:45:54:WU00:FS00:0xa7:Digital signatures verified
23:45:54:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
23:45:54:WU00:FS00:0xa7:Calling: mdrun -s frame51.tpr -o frame51.trr -cpt 15 -nt 4
23:45:54:WU00:FS00:0xa7:Steps: first=0 total=250000
23:45:55:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:46:35:FS00:Shutting core down
23:46:35:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7356
23:46:35:WU00:FS00:0xa7:Exiting, please wait. . .
23:46:35:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:46:36:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:46:36:WU00:FS00:Starting
23:46:36:WARNING:WU00:FS00:Changed SMP threads from 5 to 6 this can cause some work units to fail
23:46:36:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
23:46:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\FOLD5\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7232 -checkpoint 15 -np 5
23:46:36:WU00:FS00:Started FahCore on PID 7620
23:46:36:WU00:FS00:Core PID:7456
23:46:36:WU00:FS00:FahCore 0xa7 started
23:46:36:WU00:FS00:0xa7:*********************** Log Started 2020-04-25T23:46:36Z ***********************
23:46:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:46:36:WU00:FS00:0xa7:       Type: 0xa7
23:46:36:WU00:FS00:0xa7:       Core: Gromacs
23:46:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7620 -checkpoint 15 -np 5
23:46:36:WU00:FS00:0xa7:************************************ CBang *************************************
23:46:36:WU00:FS00:0xa7:       Date: Oct 26 2019
23:46:36:WU00:FS00:0xa7:       Time: 01:38:25
23:46:36:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:46:36:WU00:FS00:0xa7:     Branch: master
23:46:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:46:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:46:36:WU00:FS00:0xa7:   Platform: win32 10
23:46:36:WU00:FS00:0xa7:       Bits: 64
23:46:36:WU00:FS00:0xa7:       Mode: Release
23:46:36:WU00:FS00:0xa7:************************************ System ************************************
23:46:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
23:46:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:46:36:WU00:FS00:0xa7:       CPUs: 6
23:46:36:WU00:FS00:0xa7:     Memory: 7.94GiB
23:46:36:WU00:FS00:0xa7:Free Memory: 6.34GiB
23:46:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:46:36:WU00:FS00:0xa7: OS Version: 6.2
23:46:36:WU00:FS00:0xa7:Has Battery: false
23:46:36:WU00:FS00:0xa7: On Battery: false
23:46:36:WU00:FS00:0xa7: UTC Offset: -7
23:46:36:WU00:FS00:0xa7:        PID: 7456
23:46:36:WU00:FS00:0xa7:        CWD: C:\Users\FOLD5\AppData\Roaming\FAHClient\work
23:46:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:46:36:WU00:FS00:0xa7:    Version: 0.0.18
23:46:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:46:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:46:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:46:36:WU00:FS00:0xa7:       Time: 01:52:30
23:46:36:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:46:36:WU00:FS00:0xa7:************************************ Build *************************************
23:46:36:WU00:FS00:0xa7:       SIMD: avx_256
23:46:36:WU00:FS00:0xa7:********************************************************************************
23:46:36:WU00:FS00:0xa7:Project: 14375 (Run 1397, Clone 1, Gen 51)
23:46:36:WU00:FS00:0xa7:Unit: 0x000000382879986c5e887038a189c185
23:46:36:WU00:FS00:0xa7:Digital signatures verified
23:46:36:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
23:46:36:WU00:FS00:0xa7:Calling: mdrun -s frame51.tpr -o frame51.trr -cpi state.cpt -cpt 15 -nt 4
23:46:36:WU00:FS00:0xa7:Steps: first=0 total=250000
23:46:37:WU00:FS00:0xa7:Completed 1383 out of 250000 steps (0%)
23:46:54:Saving configuration to config.xml
23:46:54:<config>
23:46:54:  <!-- Network -->
23:46:54:  <proxy v=':8080'/>
23:46:54:
23:46:54:  <!-- Slot Control -->
23:46:54:  <power v='full'/>
23:46:54:
23:46:54:  <!-- User Information -->
23:46:54:  <passkey v='*****'/>
23:46:54:  <team v='234771'/>
23:46:54:  <user v='Frodo3636'/>
23:46:54:
23:46:54:  <!-- Folding Slots -->
23:46:54:  <slot id='0' type='CPU'/>
23:46:54:</config>
Harpo
Post by Harpo »
Additional: I've tried changing gpu index to 0, and all it does is add yet another CPU! The gpu index does not affect gpu at all, it just keeps adding CPU slots - and they do start folding.
I now have FOUR cpu slots; all are running different projects, and the rig only has one cpu. Yet still no gpu slots,,, This software is now hopelessly buggy. Will there be a new release soon?
(Btw, I'm reasonably computer literate, and I've run over 35 million points in the last 7 days. But this has me totally baffled.)
Harpo
Post by Harpo »
Here's a screen shot. FOUR cpus running (rig only has one), different projects all, and no gpu.
https://ibb.co/ZK1W3Zw
Please note that for your system, a single CPU Slot with 6 CPUs or less should be sufficent. Running multiple CPU Slots isn't ideal.
When you go to add a new GPU Slot, did you select the GPU radio button? If you don't it will default to the CPU Slot.
Harpo
Post by Harpo »
PantherX wrote:Please note that for your system, a single CPU Slot with 6 CPUs or less should be sufficent. Running multiple CPU Slots isn't ideal.
Finally found the radio button you mention, that is one rotten interface!!! A tiny little gray circle that I have completely overlooked through six installations now, apparently I need to RTFM.
Thanks!
Glad to have helped you... I do think that the GUI can do with some TCL. The challenge is to ensure that it works across Windows/Linux/macOS without too much overhead.
