FAH Control 7.6.9 Won't Start On Fedora 31 After Upgrade
bamapolitics
Post by bamapolitics »
Not sure how I can troubleshoot this. FAHClient runs fine and is folding, however when I click to launch FAHControl, nothing happens.
Edit: Errors below
Apr 18 08:47:40 threadripper systemd[2898]: Started Application launched by gnome-shell.
Apr 18 08:47:40 threadripper gnome-shell[2997]: value "nan" of type 'gdouble' is invalid or out of range for property 'vignette-sharpness' of type 'gdouble'
Apr 18 08:47:40 threadripper python[5338]: detected unhandled Python exception in '/usr/bin/FAHControl'
Apr 18 08:47:40 threadripper FAHControl.desktop[2997]: Traceback (most recent call last):
Apr 18 08:47:40 threadripper FAHControl.desktop[2997]:   File "/usr/bin/FAHControl", line 25, in <module>
Apr 18 08:47:40 threadripper FAHControl.desktop[2997]:     from fah import FAHControl, load_fahcontrol_db
Apr 18 08:47:40 threadripper FAHControl.desktop[2997]: ModuleNotFoundError: No module named 'fah'
Apr 18 08:47:40 threadripper systemd[2898]: gnome-launched-FAHControl.desktop-5338.scope: Succeeded.
Apr 18 08:47:41 threadripper abrt-server[5341]: Package 'fahcontrol' isn't signed with proper key
Apr 18 08:47:41 threadripper abrt-server[5341]: 'post-create' on '/var/spool/abrt/Python3-2020-04-18-08:47:40-5338' exited with 1
Apr 18 08:47:41 threadripper abrt-server[5341]: Deleting problem directory '/var/spool/abrt/Python3-2020-04-18-08:47:40-5338'
bamapolitics
Re: FAH Control 7.6.9 Won't Start On Fedora 31 After Upgrade
I upgraded via sudo dnf install fahcontrol-7.6.9-1.noarch.rpm
I then removed via sudo dnf remove fahcontrol
Then installed again via first command.
Still will not start. Are there logs for FAHControl somewhere?
HaloJones
Post by HaloJones »
/var/lib/fahclient
if you can post the first part of the logfile?
4070 super
bamapolitics
*********************** Log Started 2020-04-18T12:31:13Z ***********************
12:31:13:****************************** FAHClient ******************************
12:31:13:    Version: 7.6.9
12:31:13:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:31:13:  Copyright: 2020 foldingathome.org
12:31:13:   Homepage: https://foldingathome.org/
12:31:13:	Date: Apr 17 2020
12:31:13:	Time: 18:11:30
12:31:13:   Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:31:13:     Branch: master
12:31:13:   Compiler: GNU 4.9.4
12:31:13:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
12:31:13:   Platform: linux2 4.19.0-5-amd64
12:31:13:	Bits: 64
12:31:13:	Mode: Release
12:31:13:	Args: --child /etc/fahclient/config.xml --run-as fahclient
12:31:13:             --pid-file=/var/run/fahclient.pid --daemon
12:31:13:     Config: /etc/fahclient/config.xml
12:31:13:******************************** CBang ********************************
12:31:13:	Time: 18:10:08
12:31:13:   Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:31:13:             -fPIC
12:31:13:	Bits: 64
12:31:13:******************************* System ********************************
12:31:13:        CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
12:31:13:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
12:31:13:	CPUs: 32
12:31:13:     Memory: 15.55GiB
12:31:13:Free Memory: 7.40GiB
12:31:13:    Threads: POSIX_THREADS
12:31:13: OS Version: 5.5
12:31:13:Has Battery: false
12:31:13: On Battery: false
12:31:13: UTC Offset: -5
12:31:13:        PID: 14522
12:31:13:        CWD: /var/lib/fahclient
12:31:13:         OS: Linux 5.5.17-200.fc31.x86_64 x86_64
12:31:13:    OS Arch: AMD64
12:31:13:	GPUs: 1
12:31:13:      GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
12:31:13:	CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
12:31:13:             libcuda.so: cannot open shared object file: No such file or
12:31:13:             directory
12:31:13:     OpenCL: Not detected: clGetDeviceIDs() returned -1
12:31:13:******************************* libFAH ********************************
12:31:13:	Date: Apr 15 2020
12:31:13:	Time: 21:43:27
12:31:13:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:31:13:	Bits: 64
12:31:13:***********************************************************************
12:31:13:<config>
12:31:13:  <!-- Folding Core -->
12:31:13:  <checkpoint v='5'/>
12:31:13:
12:31:13:  <!-- Network -->
12:31:13:  <proxy v=':8080'/>
12:31:13:
12:31:13:  <!-- Slot Control -->
12:31:13:  <pause-on-battery v='false'/>
12:31:13:
12:31:13:  <!-- User Information -->
12:31:13:  <passkey v='*****'/>
12:31:13:  <team v='249510'/>
12:31:13:  <user v='bamapoliticsdotcom'/>
12:31:13:
12:31:13:  <!-- Folding Slots -->
12:31:13:  <slot id='0' type='CPU'>
12:31:13:    <cpus v='8'/>
12:31:13:  </slot>
12:31:13:  <slot id='1' type='CPU'>
12:31:13:    <cpus v='16'/>
12:31:13:  </slot>
12:31:13:</config>
12:31:13:Trying to access database...
12:31:13:Successfully acquired database lock
12:31:13:Enabled folding slot 00: READY cpu:8
12:31:13:Enabled folding slot 01: READY cpu:16
12:31:13:WU01:FS00:Starting
12:31:13:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 14522 -checkpoint 5 -np 8
12:31:13:WU01:FS00:Started FahCore on PID 14548
12:31:13:WU01:FS00:Core PID:14552
12:31:13:WU02:FS01:FahCore 0xa7 started
Please note that looking at your configuration, I noticed few items:
1) You have a supported GPU, GTX 1060, which you can fold on. However, do to do, you must install the vendor (Nvidia) drivers and potentially some OpenCL dependencies too.
2) You have 2 CPU Slots; 16 CPUs and 8 CPUs. You can combine them into 1 CPU Slot with 24 CPUs. That may result in a higher PPD and also, faster science being done.
bamapolitics
1) I don't fold on GPU because it isn't stable. Not sure if it is the drivers or the card but WU keep failing. I plan to upgrade the card soon to AMD and will fold when I do that.
2) I created this thread here regarding that: viewtopic.php?f=106&t=34334 do you still think a 1 24 CPU would be better?
Any ideas on what is wrong with FAHControl or how else I can troubleshoot?
I would suggest that you experiment with 24 CPUs and see how the performance is compared to 16+8. Personally, I would keep 24 CPUs as it ensures that I get the quickest amount of science done and hopefully same if not more PPD when compared to 16+8.
Do note that when you're transcoding, 16+8 would mean that you would slow down 2 WUs as opposed to 24 which means a single WU.
Unfortunately, I am not proficient to help you out with *unix systems :( However, there are members here who are and hopefully, can sort your issue out :)
bamapolitics
Here is the issue:
How can I resolve this?
pr0ti3n
Post by pr0ti3n »
On Fedora 31 I have been using the python3 port of FAHControl. Been working good.
https://github.com/FoldingAtHome/fah-control/pull/56
bamapolitics
pr0ti3n wrote:On Fedora 31 I have been using the python3 port of FAHControl. Been working good.
Is this port 7.6.9?
pr0ti3n
Post by pr0ti3n »
bamapolitics wrote:This is same issue: https://github.com/FoldingAtHome/fah-control/issues/61
The link I posted is for python3. Your link is a python2 problem.
bamapolitics
Adjusting it as described in my link solved the issue.
