RX 580 Issues
skydivingcatfan
- Hardware configuration: AMD 5700x, Asus Prime X570-Pro, EVGA 3080 12gb, G.SKILL Aegis 16GB DDR4 3200, Windows 10
RX 580 Issues
Put together a system with spare parts but can not get the GPU to work Sapphire Radeon RX580 it worked in my main system prior to installing a RX5700XT.
This is what my System Info Tab has
GPUs 1
GPU 0 Bus: 8 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX 470/480/570/580/590]
Not detected: Failed to open dynamic library 'nvcuda.dll': The specified module could not be found.
GPUs 1
Re: RX 580 Issues
Welcome to the F@H Forum skydivingcatfan,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=81&t=26036
I am aware that the demand for GPU WUs is a lot higher than the supply but work is being done to address this.
skydivingcatfan
Re: RX 580 Issues
*********************** Log Started 2020-04-18T01:09:39Z ***********************
01:09:39:****************************** FAHClient ******************************
01:09:39: Version: 7.6.9
01:09:39: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:09:39: Copyright: 2020 foldingathome.org
01:09:39: Homepage: https://foldingathome.org/
01:09:39: Date: Apr 17 2020
01:09:39: Time: 11:13:06
01:09:39: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
01:09:39: Branch: master
01:09:39: Compiler: Visual C++ 2008
01:09:39: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:09:39: Platform: win32 10
01:09:39: Bits: 32
01:09:39: Mode: Release
01:09:39: Config: C:\Users\Folding\AppData\Roaming\FAHClient\config.xml
01:09:39:******************************** CBang ********************************
01:09:39: Time: 11:10:09
01:09:39: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
01:09:39: Bits: 32
01:09:39:******************************* System ********************************
01:09:39: CPU: AMD Ryzen 5 3600 6-Core Processor
01:09:39: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
01:09:39: CPUs: 12
01:09:39: Memory: 15.93GiB
01:09:39: Free Memory: 14.36GiB
01:09:39: Threads: WINDOWS_THREADS
01:09:39: OS Version: 6.2
01:09:39: Has Battery: false
01:09:39: On Battery: false
01:09:39: UTC Offset: -7
01:09:39: PID: 7772
01:09:39: CWD: C:\Users\Folding\AppData\Roaming\FAHClient
01:09:39: OS: Windows 10 Enterprise
01:09:39: OS Arch: AMD64
01:09:39: GPUs: 1
01:09:39: GPU 0: Bus:8 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
01:09:39: 470/480/570/580/590]
01:09:39: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
01:09:39: specified module could not be found.
01:09:39:
01:09:39:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:3004.8
01:09:39: Win32 Service: false
01:09:39:******************************* libFAH ********************************
01:09:39: Date: Apr 15 2020
01:09:39: Time: 14:53:14
01:09:39: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
01:09:39: Bits: 32
01:09:39:***********************************************************************
01:09:39:<config>
01:09:39: <!-- Network -->
01:09:39: <proxy v=':8080'/>
01:09:39:
01:09:39: <!-- Slot Control -->
01:09:39: <power v='FULL'/>
01:09:39:
01:09:39: <!-- User Information -->
01:09:39: <passkey v='*****'/>
01:09:39: <team v='234771'/>
01:09:39: <user v='skydivingcatfan'/>
01:09:39:
01:09:39: <!-- Folding Slots -->
01:09:39: <slot id='0' type='CPU'/>
01:09:39:</config>
01:09:39:Trying to access database...
01:09:39:Successfully acquired database lock
01:09:39:Enabled folding slot 00: READY cpu:12
01:09:39:WU00:FS00:Starting
01:09:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Folding\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7772 -checkpoint 15 -np 12
01:09:41:WU00:FS00:Started FahCore on PID 8012
01:09:42:WU00:FS00:Core PID:8092
01:09:42:WU00:FS00:FahCore 0xa7 started
01:09:43:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T01:09:43Z ***********************
01:09:43:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:09:43:WU00:FS00:0xa7: Type: 0xa7
01:09:43:WU00:FS00:0xa7: Core: Gromacs
01:09:43:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8012 -checkpoint 15 -np
01:09:43:WU00:FS00:0xa7: 12
01:09:43:WU00:FS00:0xa7:************************************ CBang *************************************
01:09:43:WU00:FS00:0xa7: Date: Oct 26 2019
01:09:43:WU00:FS00:0xa7: Time: 01:38:25
01:09:43:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:09:43:WU00:FS00:0xa7: Branch: master
01:09:43:WU00:FS00:0xa7: Compiler: Visual C++ 2008
01:09:43:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:09:43:WU00:FS00:0xa7: Platform: win32 10
01:09:43:WU00:FS00:0xa7: Bits: 64
01:09:43:WU00:FS00:0xa7: Mode: Release
01:09:43:WU00:FS00:0xa7:************************************ System ************************************
01:09:43:WU00:FS00:0xa7: CPU: AMD Ryzen 5 3600 6-Core Processor
01:09:43:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
01:09:43:WU00:FS00:0xa7: CPUs: 12
01:09:43:WU00:FS00:0xa7: Memory: 15.93GiB
01:09:43:WU00:FS00:0xa7:Free Memory: 14.31GiB
01:09:43:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
01:09:43:WU00:FS00:0xa7: OS Version: 6.2
01:09:43:WU00:FS00:0xa7:Has Battery: false
01:09:43:WU00:FS00:0xa7: On Battery: false
01:09:43:WU00:FS00:0xa7: UTC Offset: -7
01:09:43:WU00:FS00:0xa7: PID: 8092
01:09:43:WU00:FS00:0xa7: CWD: C:\Users\Folding\AppData\Roaming\FAHClient\work
01:09:43:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:09:43:WU00:FS00:0xa7: Version: 0.0.18
01:09:43:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:09:43:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
01:09:43:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
01:09:43:WU00:FS00:0xa7: Time: 01:52:30
01:09:43:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:09:43:WU00:FS00:0xa7:************************************ Build *************************************
01:09:43:WU00:FS00:0xa7: SIMD: avx_256
01:09:43:WU00:FS00:0xa7:********************************************************************************
01:09:43:WU00:FS00:0xa7:Project: 13861 (Run 0, Clone 14947, Gen 61)
01:09:43:WU00:FS00:0xa7:Unit: 0x000000480d5a98395e730c236b87bcd2
01:09:43:WU00:FS00:0xa7:Digital signatures verified
01:09:43:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -x frame61.xtc -e frame61.edr -cpi state.cpt -cpt 15 -nt 12
01:09:44:WU00:FS00:0xa7:Steps: first=7625000 total=125000
01:09:46:WU00:FS00:0xa7:Completed 44681 out of 125000 steps (35%)
01:09:53:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
01:10:18:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
01:10:41:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
01:11:04:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
01:11:26:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
01:11:48:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
01:12:11:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
01:12:33:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
01:12:55:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
01:13:17:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
01:13:40:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
01:14:02:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
01:14:26:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
01:14:48:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
01:15:11:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
01:15:35:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
01:16:00:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
01:16:27:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
01:16:57:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
01:17:25:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
01:17:53:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
01:18:15:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
01:18:38:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
01:19:01:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
01:19:23:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
01:19:45:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
01:20:07:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
01:20:30:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
01:20:53:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
01:21:25:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
01:21:55:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
Re: RX 580 Issues
What happens if you open up FAHControl -> Configure -> Slots Tab -> Add -> Select GPU -> OK -> Save
In theory, you need to add a GPU slot and that's it
skydivingcatfan
Re: RX 580 Issues
Well, I believe you and it seems that everything is working fine so glad that your GPU can now join the folding cause
skydivingcatfan
Re: RX 580 Issues
Has been folding fine since this. I have seen a couple other users have to add a second time to get it to show up
skydivingcatfan
Re: RX 580 Issues
I had to reinstall because I screwed something up and now can not get a gpu slot added again
skydivingcatfan
Re: RX 580 Issues
In case you were wondering, the reason why a fresh installation of V7.6.9 wasn't picking up the GPU was because the GPUs.txt file wasn't downloaded. It would automatically download after the client/system restarts. The workaround is to manually download the GPUs.txt file in the correct location. This issue has been resolved in the latest beta of the client.
skydivingcatfan
Re: RX 580 Issues
I looked for that file and it was therePantherX wrote:In case you were wondering, the reason why a fresh installation of V7.6.9 wasn't picking up the GPU was because the GPUs.txt file wasn't downloaded. It would automatically download after the client/system restarts. The workaround is to manually download the GPUs.txt file in the correct location. This issue has been resolved in the latest beta of the client.
Re: RX 580 Issues
Where is "there"? FAH only looks in the place it downloads it ... in it's working files area.skydivingcatfan wrote:I looked for that file and it was there
