13.82.98.119 not taking my Wu
gorganzolia
Post by gorganzolia »
I finished a Wu hours ago but the server has been down so it couldn't receive. It just came back online and it now refusing my Wu. What do i do now? Here is my log if you need it.
*********************** Log Started 2020-04-16T08:03:15Z ***********************
08:03:15:************************* Folding@home Client *************************
08:03:15:        Website: https://foldingathome.org/
08:03:15:      Copyright: (c) 2009-2018 foldingathome.org
08:03:15:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:03:15:           Args: --open-web-control
08:03:15:         Config: C:\Users\gorga\AppData\Roaming\FAHClient\config.xml
08:03:15:******************************** Build ********************************
08:03:15:        Version: 7.5.1
08:03:15:           Date: May 11 2018
08:03:15:           Time: 13:06:32
08:03:15:     Repository: Git
08:03:15:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:03:15:         Branch: master
08:03:15:       Compiler: Visual C++ 2008
08:03:15:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:03:15:       Platform: win32 10
08:03:15:           Bits: 32
08:03:15:           Mode: Release
08:03:15:******************************* System ********************************
08:03:15:            CPU: AMD FX(tm)-8350 Eight-Core Processor
08:03:15:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:03:15:           CPUs: 8
08:03:15:         Memory: 15.95GiB
08:03:15:    Free Memory: 11.64GiB
08:03:15:        Threads: WINDOWS_THREADS
08:03:15:     OS Version: 6.2
08:03:15:    Has Battery: false
08:03:15:     On Battery: false
08:03:15:     UTC Offset: -4
08:03:15:            PID: 6456
08:03:15:            CWD: C:\Users\gorga\AppData\Roaming\FAHClient
08:03:15:             OS: Windows 10 Enterprise
08:03:15:        OS Arch: AMD64
08:03:15:           GPUs: 1
08:03:15:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
08:03:15:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.0
08:03:15:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
08:03:15:  Win32 Service: false
08:03:15:***********************************************************************
08:03:15:<config>
08:03:15:  <!-- Network -->
08:03:15:  <proxy v=':8080'/>
08:03:15:
08:03:15:  <!-- User Information -->
08:03:15:  <passkey v='********************************'/>
08:03:15:  <team v='223518'/>
08:03:15:  <user v='gorganzolia'/>
08:03:15:
08:03:15:  <!-- Folding Slots -->
08:03:15:  <slot id='0' type='CPU'>
08:03:15:    <cpus v='4'/>
08:03:15:  </slot>
08:03:15:  <slot id='1' type='GPU'/>
08:03:15:</config>
08:03:15:Trying to access database...
08:03:15:Successfully acquired database lock
08:03:15:Enabled folding slot 00: READY cpu:4
08:03:15:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308
08:03:15:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13873 run:0 clone:105 gen:52 core:0x22 unit:0x000000420d5262775e791a48fac7d300
08:03:15:WU02:FS01:Uploading 48.11MiB to 13.82.98.119
08:03:15:WU03:FS00:Starting
08:03:15:WU02:FS01:Connecting to 13.82.98.119:8080
08:03:15:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gorga\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 6456 -checkpoint 15 -np 4
08:03:15:WU03:FS00:Started FahCore on PID 9872
08:03:15:WU03:FS00:Core PID:11552
08:03:15:WU03:FS00:FahCore 0xa7 started
08:03:15:WU01:FS01:Starting
08:03:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gorga\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6456 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:03:15:WU01:FS01:Started FahCore on PID 8188
08:03:15:WU01:FS01:Core PID:1764
08:03:15:WU01:FS01:FahCore 0x22 started
08:03:15:WU03:FS00:0xa7:*********************** Log Started 2020-04-16T08:03:15Z ***********************
08:03:15:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:03:15:WU03:FS00:0xa7:       Type: 0xa7
08:03:15:WU03:FS00:0xa7:       Core: Gromacs
08:03:15:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 9872 -checkpoint 15 -np 4
08:03:15:WU03:FS00:0xa7:************************************ CBang *************************************
08:03:15:WU03:FS00:0xa7:       Date: Oct 26 2019
08:03:15:WU03:FS00:0xa7:       Time: 01:38:25
08:03:15:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:03:15:WU03:FS00:0xa7:     Branch: master
08:03:15:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
08:03:15:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:03:15:WU03:FS00:0xa7:   Platform: win32 10
08:03:15:WU03:FS00:0xa7:       Bits: 64
08:03:15:WU03:FS00:0xa7:       Mode: Release
08:03:15:WU03:FS00:0xa7:************************************ System ************************************
08:03:15:WU03:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
08:03:15:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:03:15:WU03:FS00:0xa7:       CPUs: 8
08:03:15:WU03:FS00:0xa7:     Memory: 15.95GiB
08:03:15:WU03:FS00:0xa7:Free Memory: 11.62GiB
08:03:15:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
08:03:15:WU03:FS00:0xa7: OS Version: 6.2
08:03:15:WU03:FS00:0xa7:Has Battery: false
08:03:15:WU03:FS00:0xa7: On Battery: false
08:03:15:WU03:FS00:0xa7: UTC Offset: -4
08:03:15:WU03:FS00:0xa7:        PID: 11552
08:03:15:WU03:FS00:0xa7:        CWD: C:\Users\gorga\AppData\Roaming\FAHClient\work
08:03:15:WU01:FS01:0x22:*********************** Log Started 2020-04-16T08:03:15Z ***********************
08:03:15:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
08:03:15:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:03:15:WU03:FS00:0xa7:    Version: 0.0.18
08:03:15:WU01:FS01:0x22:       Type: 0x22
08:03:15:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:03:15:WU01:FS01:0x22:       Core: Core22
08:03:15:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:03:15:WU01:FS01:0x22:    Website: https://foldingathome.org/
08:03:15:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
08:03:15:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:03:15:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:03:15:WU03:FS00:0xa7:       Time: 01:52:30
08:03:15:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:03:15:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:03:15:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8188 -checkpoint 15
08:03:15:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:03:15:WU01:FS01:0x22:             0 -gpu 0
08:03:15:WU01:FS01:0x22:     Config: <none>
08:03:15:WU01:FS01:0x22:************************************ Build *************************************
08:03:15:WU01:FS01:0x22:    Version: 0.0.2
08:03:15:WU01:FS01:0x22:       Date: Dec 6 2019
08:03:15:WU03:FS00:0xa7:************************************ Build *************************************
08:03:15:WU01:FS01:0x22:       Time: 21:30:31
08:03:15:WU03:FS00:0xa7:       SIMD: avx_256
08:03:15:WU01:FS01:0x22: Repository: Git
08:03:15:WU03:FS00:0xa7:********************************************************************************
08:03:15:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:03:15:WU03:FS00:0xa7:Project: 14377 (Run 23, Clone 3, Gen 29)
08:03:15:WU01:FS01:0x22:     Branch: HEAD
08:03:16:WU03:FS00:0xa7:Unit: 0x0000001d455e42075e8ba78e70f2503e
08:03:16:WU01:FS01:0x22:   Compiler: Visual C++ 2008
08:03:16:WU03:FS00:0xa7:Digital signatures verified
08:03:16:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:03:16:WU03:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpi state.cpt -cpt 15 -nt 4
08:03:16:WU01:FS01:0x22:   Platform: win32 10
08:03:16:WU03:FS00:0xa7:Steps: first=0 total=250000
08:03:16:WU01:FS01:0x22:       Bits: 64
08:03:16:WU01:FS01:0x22:       Mode: Release
08:03:16:WU01:FS01:0x22:************************************ System ************************************
08:03:16:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
08:03:16:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:03:16:WU01:FS01:0x22:       CPUs: 8
08:03:16:WU01:FS01:0x22:     Memory: 15.95GiB
08:03:16:WU01:FS01:0x22:Free Memory: 11.61GiB
08:03:16:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
08:03:16:WU01:FS01:0x22: OS Version: 6.2
08:03:16:WU01:FS01:0x22:Has Battery: false
08:03:16:WU01:FS01:0x22: On Battery: false
08:03:16:WU01:FS01:0x22: UTC Offset: -4
08:03:16:WU01:FS01:0x22:        PID: 1764
08:03:16:WU01:FS01:0x22:        CWD: C:\Users\gorga\AppData\Roaming\FAHClient\work
08:03:16:WU01:FS01:0x22:         OS: Windows 10 Pro
08:03:16:WU01:FS01:0x22:    OS Arch: AMD64
08:03:16:WU01:FS01:0x22:********************************************************************************
08:03:16:WU01:FS01:0x22:Project: 11741 (Run 0, Clone 1023, Gen 45)
08:03:16:WU01:FS01:0x22:Unit: 0x0000005b8ca304f15e67d7a942fa0e50
08:03:16:WU01:FS01:0x22:Digital signatures verified
08:03:16:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:03:16:WU01:FS01:0x22:Version 0.0.2
08:03:16:WU01:FS01:0x22:  Found a checkpoint file
08:03:17:WU03:FS00:0xa7:Completed 189776 out of 250000 steps (75%)
08:03:17:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:03:17:WU02:FS01:Connecting to 13.82.98.119:80
08:03:29:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: No connection could be made because the target machine actively refused it.
08:03:29:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13873 run:0 clone:105 gen:52 core:0x22 unit:0x000000420d5262775e791a48fac7d300
08:03:29:WU02:FS01:Uploading 48.11MiB to 13.82.98.119
08:03:29:WU02:FS01:Connecting to 13.82.98.119:8080
08:03:29:17:127.0.0.1:New Web connection
08:03:30:29:127.0.0.1:New Web connection
08:03:31:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:03:31:WU02:FS01:Connecting to 13.82.98.119:80
08:03:34:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: No connection could be made because the target machine actively refused it.
08:03:46:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
08:03:46:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:03:47:WU03:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
08:04:29:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13873 run:0 clone:105 gen:52 core:0x22 unit:0x000000420d5262775e791a48fac7d300
08:04:29:WU02:FS01:Uploading 48.11MiB to 13.82.98.119
08:04:29:WU02:FS01:Connecting to 13.82.98.119:8080
08:04:31:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:04:31:WU02:FS01:Connecting to 13.82.98.119:80
08:04:33:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: No connection could be made because the target machine actively refused it.
08:06:06:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13873 run:0 clone:105 gen:52 core:0x22 unit:0x000000420d5262775e791a48fac7d300
08:06:06:WU02:FS01:Uploading 48.11MiB to 13.82.98.119
08:06:06:WU02:FS01:Connecting to 13.82.98.119:8080
08:06:09:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:06:09:WU02:FS01:Connecting to 13.82.98.119:80
08:06:11:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: No connection could be made because the target machine actively refused it.
08:08:42:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
08:08:43:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13873 run:0 clone:105 gen:52 core:0x22 unit:0x000000420d5262775e791a48fac7d300
08:08:43:WU02:FS01:Uploading 48.11MiB to 13.82.98.119
08:08:43:WU02:FS01:Connecting to 13.82.98.119:8080
08:08:46:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:08:46:WU02:FS01:Connecting to 13.82.98.119:80
08:08:48:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: No connection could be made because the target machine actively refused it.
08:09:08:WU03:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
Re: 13.82.98.119 not taking my Wu
Welcome to the F@H Forum gorganzolia,
Please note that the issue is known. In the meantime, just leave the client running and once the Server is back up, it will automatically accept the completed WU :)
gorganzolia
it took it lol only took like 7 hours but least it finally took it ty
Good news is that I have just received confirmation that the issue should be resolved for 13.82.98.119 so hopefully, your completed WU will be accepted soon. We appreciate your patience during this :)
andrewkv81
Failed to upload 13.82.98.119
Post by andrewkv81 »
Been trying to upload for over 36hrs now:
Log shows:
05:13:00:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14416 run:0 clone:543 gen:7 core:0x22 unit:0x0000000b0d5262775e84c8a7555a6003
05:13:00:WU00:FS01:Uploading 292.93MiB to 13.82.98.119
05:13:00:WU00:FS01:Connecting to 13.82.98.119:8080
05:13:29:WU00:FS01:Upload 0.06%
05:13:29:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
05:13:29:WU00:FS01:Trying to send results to collection server
05:13:29:WU00:FS01:Uploading 292.93MiB to 52.224.109.74
05:13:29:WU00:FS01:Connecting to 52.224.109.74:8080
05:13:29:ERROR:WU00:FS01:Exception: Transfer failed
I believe 52.224.109.74 does not have a CS so how do I get the data so sent. WS is 128.252.203.10.
Re: Failed to upload 13.82.98.119
Post by Neil-B »
Under these circumstances regrettably only patience will solve the issue … It should not be stopping or hindering your machine continuing to fold other WUs and it is likely that the team know there is an issue with load on this server (if not your post will help alert them to it) so if there is a bigger issue than just load they will be working on getting it resolved.
Edited when a nice person PM'd me to point out I'd missed out the most important word !! :shock: :D
LB23
Post by LB23 »
Same issue here. Posted about it over the weekend on another thread and someone said they were looking into it but that WU expired and now I have another failing. These take my GPU 7 to 10 hours to complete. That's a lot of time and energy wasted.
I get less than 0.1% uploaded before failing but if I VPN closer to the server it will hit 9% every time then fail.
21:53:19:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14417 run:0 clone:499 gen:4 core:0x22 unit:0x0000000a0d5262775e84c8a61fce69a5
21:53:19:WU04:FS01:Uploading 258.62MiB to 13.82.98.119
21:53:19:WU04:FS01:Connecting to 13.82.98.119:8080
21:53:29:WU04:FS01:Upload 0.07%
21:53:29:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
21:53:29:WU04:FS01:Trying to send results to collection server
21:53:29:WU04:FS01:Uploading 258.62MiB to 52.224.109.74
21:53:29:WU04:FS01:Connecting to 52.224.109.74:8080
21:53:31:ERROR:WU04:FS01:Exception: Transfer failed
21:53:31:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14417 run:0 clone:499 gen:4 core:0x22 unit:0x0000000a0d5262775e84c8a61fce69a5
21:53:31:WU04:FS01:Uploading 258.62MiB to 13.82.98.119
21:53:31:WU04:FS01:Connecting to 13.82.98.119:8080
21:53:40:WU04:FS01:Upload 0.07%
21:53:40:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
21:53:40:WU04:FS01:Trying to send results to collection server
21:53:40:WU04:FS01:Uploading 258.62MiB to 52.224.109.74
21:53:40:WU04:FS01:Connecting to 52.224.109.74:8080
21:53:40:ERROR:WU04:FS01:Exception: Transfer failed
21:55:08:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14417 run:0 clone:499 gen:4 core:0x22 unit:0x0000000a0d5262775e84c8a61fce69a5
21:55:08:WU04:FS01:Uploading 258.62MiB to 13.82.98.119
21:55:08:WU04:FS01:Connecting to 13.82.98.119:8080
21:55:22:WU04:FS01:Upload 0.07%
21:55:22:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
21:55:22:WU04:FS01:Trying to send results to collection server
21:55:22:WU04:FS01:Uploading 258.62MiB to 52.224.109.74
21:55:22:WU04:FS01:Connecting to 52.224.109.74:8080
21:55:22:ERROR:WU04:FS01:Exception: Transfer failed
*********************** Log Started 2020-04-21T21:53:18Z ***********************
21:57:45:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14417 run:0 clone:499 gen:4 core:0x22 unit:0x0000000a0d5262775e84c8a61fce69a5
21:57:45:WU04:FS01:Uploading 258.62MiB to 13.82.98.119
21:57:45:WU04:FS01:Connecting to 13.82.98.119:8080
21:57:52:WU04:FS01:Upload 0.07%
21:57:52:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
21:57:52:WU04:FS01:Trying to send results to collection server
21:57:52:WU04:FS01:Uploading 258.62MiB to 52.224.109.74
21:57:52:WU04:FS01:Connecting to 52.224.109.74:8080
21:57:52:ERROR:WU04:FS01:Exception: Transfer failed
LB23
Post by LB23 »
Got another.
I hope to get some help on this this time. last thread was locked with a attitude like its not worth looking into.
I'm sitting on 2 now and had 2 expire.
04:16:25:WU00:FS01:Connecting to 65.254.110.245:80
04:16:25:WU00:FS01:Assigned to work server 13.82.98.119
04:16:25:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
04:16:25:WU00:FS01:Connecting to 13.82.98.119:8080
04:16:35:WU00:FS01:Downloading 131.47MiB
04:16:41:WU00:FS01:Download 20.73%
04:16:47:WU00:FS01:Download 44.64%
04:16:53:WU00:FS01:Download 70.59%
04:16:59:WU00:FS01:Download 95.03%
04:17:00:WU00:FS01:Download complete
04:17:00:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
04:17:00:WU00:FS01:Starting
04:17:00:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matty\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15272 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
04:17:00:WU00:FS01:Started FahCore on PID 15452
04:17:00:WU00:FS01:Core PID:12876
04:17:00:WU00:FS01:FahCore 0x22 started
04:17:00:WU00:FS01:0x22:*********************** Log Started 2020-04-22T04:17:00Z ***********************
04:17:00:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:17:00:WU00:FS01:0x22:       Type: 0x22
04:17:00:WU00:FS01:0x22:       Core: Core22
04:17:00:WU00:FS01:0x22:    Website: https://foldingathome.org/
04:17:00:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:17:00:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:17:00:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:17:00:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15452 -checkpoint 10
04:17:00:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
04:17:00:WU00:FS01:0x22:     Config: <none>
04:17:00:WU00:FS01:0x22:************************************ Build *************************************
04:17:00:WU00:FS01:0x22:    Version: 0.0.2
04:17:00:WU00:FS01:0x22:       Date: Dec 6 2019
04:17:00:WU00:FS01:0x22:       Time: 21:30:31
04:17:00:WU00:FS01:0x22: Repository: Git
04:17:00:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:17:00:WU00:FS01:0x22:     Branch: HEAD
04:17:00:WU00:FS01:0x22:   Compiler: Visual C++ 2008
04:17:00:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:17:00:WU00:FS01:0x22:   Platform: win32 10
04:17:00:WU00:FS01:0x22:       Bits: 64
04:17:00:WU00:FS01:0x22:       Mode: Release
04:17:00:WU00:FS01:0x22:************************************ System ************************************
04:17:00:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3700X 8-Core Processor
04:17:00:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
04:17:00:WU00:FS01:0x22:       CPUs: 16
04:17:00:WU00:FS01:0x22:     Memory: 31.93GiB
04:17:00:WU00:FS01:0x22:Free Memory: 26.62GiB
04:17:00:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
04:17:00:WU00:FS01:0x22: OS Version: 6.2
04:17:00:WU00:FS01:0x22:Has Battery: false
04:17:00:WU00:FS01:0x22: On Battery: false
04:17:00:WU00:FS01:0x22: UTC Offset: -5
04:17:00:WU00:FS01:0x22:        PID: 12876
04:17:00:WU00:FS01:0x22:        CWD: C:\Users\matty\AppData\Roaming\FAHClient\work
04:17:00:WU00:FS01:0x22:         OS: Windows 10 Home
04:17:00:WU00:FS01:0x22:    OS Arch: AMD64
04:17:00:WU00:FS01:0x22:********************************************************************************
04:17:00:WU00:FS01:0x22:Project: 14415 (Run 0, Clone 1319, Gen 10)
04:17:00:WU00:FS01:0x22:Unit: 0x000000130d5262775e839e5951c36633
04:17:00:WU00:FS01:0x22:Reading tar file core.xml
04:17:00:WU00:FS01:0x22:Reading tar file integrator.xml
04:17:00:WU00:FS01:0x22:Reading tar file state.xml
04:17:01:WU00:FS01:0x22:Reading tar file system.xml
04:17:01:WU00:FS01:0x22:Digital signatures verified
04:17:01:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:17:01:WU00:FS01:0x22:Version 0.0.2
04:17:35:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
04:17:36:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:19:37:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
04:21:34:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
04:23:32:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
04:25:30:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
04:27:27:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
04:29:35:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
04:31:32:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
04:33:30:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
04:35:28:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
04:37:26:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
04:39:34:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
04:41:31:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
04:43:29:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
04:45:27:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
04:47:25:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
04:49:32:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
05:00:20:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
05:00:20:WARNING:WU00:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
05:00:20:WU00:FS01:Starting
05:00:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matty\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15272 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
05:00:20:WU00:FS01:Started FahCore on PID 6980
05:00:20:WU00:FS01:Core PID:17572
05:00:20:WU00:FS01:FahCore 0x22 started
05:00:21:WU00:FS01:0x22:*********************** Log Started 2020-04-22T05:00:21Z ***********************
05:00:21:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:00:21:WU00:FS01:0x22:       Type: 0x22
05:00:21:WU00:FS01:0x22:       Core: Core22
05:00:21:WU00:FS01:0x22:    Website: https://foldingathome.org/
05:00:21:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:00:21:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:00:21:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:00:21:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6980 -checkpoint 10
05:00:21:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
05:00:21:WU00:FS01:0x22:     Config: <none>
05:00:21:WU00:FS01:0x22:************************************ Build *************************************
05:00:21:WU00:FS01:0x22:    Version: 0.0.2
05:00:21:WU00:FS01:0x22:       Date: Dec 6 2019
05:00:21:WU00:FS01:0x22:       Time: 21:30:31
05:00:21:WU00:FS01:0x22: Repository: Git
05:00:21:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:00:21:WU00:FS01:0x22:     Branch: HEAD
05:00:21:WU00:FS01:0x22:   Compiler: Visual C++ 2008
05:00:21:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:00:21:WU00:FS01:0x22:   Platform: win32 10
05:00:21:WU00:FS01:0x22:       Bits: 64
05:00:21:WU00:FS01:0x22:       Mode: Release
05:00:21:WU00:FS01:0x22:************************************ System ************************************
05:00:21:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3700X 8-Core Processor
05:00:21:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
05:00:21:WU00:FS01:0x22:       CPUs: 16
05:00:21:WU00:FS01:0x22:     Memory: 31.93GiB
05:00:21:WU00:FS01:0x22:Free Memory: 26.64GiB
05:00:21:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
05:00:21:WU00:FS01:0x22: OS Version: 6.2
05:00:21:WU00:FS01:0x22:Has Battery: false
05:00:21:WU00:FS01:0x22: On Battery: false
05:00:21:WU00:FS01:0x22: UTC Offset: -5
05:00:21:WU00:FS01:0x22:        PID: 17572
05:00:21:WU00:FS01:0x22:        CWD: C:\Users\matty\AppData\Roaming\FAHClient\work
05:00:21:WU00:FS01:0x22:         OS: Windows 10 Home
05:00:21:WU00:FS01:0x22:    OS Arch: AMD64
05:00:21:WU00:FS01:0x22:********************************************************************************
05:00:21:WU00:FS01:0x22:Project: 14415 (Run 0, Clone 1319, Gen 10)
05:00:21:WU00:FS01:0x22:Unit: 0x000000130d5262775e839e5951c36633
05:00:21:WU00:FS01:0x22:Digital signatures verified
05:00:21:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:00:21:WU00:FS01:0x22:Version 0.0.2
05:00:21:WU00:FS01:0x22:  Found a checkpoint file
05:00:55:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
05:00:55:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:04:12:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
05:04:12:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
05:14:21:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
05:14:21:WARNING:WU00:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
05:14:21:WU00:FS01:Starting
05:14:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matty\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15272 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
05:14:21:WU00:FS01:Started FahCore on PID 7776
05:14:21:WU00:FS01:Core PID:5048
05:14:21:WU00:FS01:FahCore 0x22 started
05:14:22:WU00:FS01:0x22:*********************** Log Started 2020-04-22T05:14:22Z ***********************
05:14:22:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:14:22:WU00:FS01:0x22:       Type: 0x22
05:14:22:WU00:FS01:0x22:       Core: Core22
05:14:22:WU00:FS01:0x22:    Website: https://foldingathome.org/
05:14:22:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:14:22:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:14:22:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:14:22:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7776 -checkpoint 10
05:14:22:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
05:14:22:WU00:FS01:0x22:     Config: <none>
05:14:22:WU00:FS01:0x22:************************************ Build *************************************
05:14:22:WU00:FS01:0x22:    Version: 0.0.2
05:14:22:WU00:FS01:0x22:       Date: Dec 6 2019
05:14:22:WU00:FS01:0x22:       Time: 21:30:31
05:14:22:WU00:FS01:0x22: Repository: Git
05:14:22:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:14:22:WU00:FS01:0x22:     Branch: HEAD
05:14:22:WU00:FS01:0x22:   Compiler: Visual C++ 2008
05:14:22:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:14:22:WU00:FS01:0x22:   Platform: win32 10
05:14:22:WU00:FS01:0x22:       Bits: 64
05:14:22:WU00:FS01:0x22:       Mode: Release
05:14:22:WU00:FS01:0x22:************************************ System ************************************
05:14:22:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3700X 8-Core Processor
05:14:22:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
05:14:22:WU00:FS01:0x22:       CPUs: 16
05:14:22:WU00:FS01:0x22:     Memory: 31.93GiB
05:14:22:WU00:FS01:0x22:Free Memory: 26.76GiB
05:14:22:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
05:14:22:WU00:FS01:0x22: OS Version: 6.2
05:14:22:WU00:FS01:0x22:Has Battery: false
05:14:22:WU00:FS01:0x22: On Battery: false
05:14:22:WU00:FS01:0x22: UTC Offset: -5
05:14:22:WU00:FS01:0x22:        PID: 5048
05:14:22:WU00:FS01:0x22:        CWD: C:\Users\matty\AppData\Roaming\FAHClient\work
05:14:22:WU00:FS01:0x22:         OS: Windows 10 Home
05:14:22:WU00:FS01:0x22:    OS Arch: AMD64
05:14:22:WU00:FS01:0x22:********************************************************************************
05:14:22:WU00:FS01:0x22:Project: 14415 (Run 0, Clone 1319, Gen 10)
05:14:22:WU00:FS01:0x22:Unit: 0x000000130d5262775e839e5951c36633
05:14:22:WU00:FS01:0x22:Digital signatures verified
05:14:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:14:22:WU00:FS01:0x22:Version 0.0.2
05:14:22:WU00:FS01:0x22:  Found a checkpoint file
05:14:54:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
05:14:54:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:16:52:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
05:18:48:WU00:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
05:20:45:WU00:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
05:22:41:WU00:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
05:24:37:WU00:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
05:26:43:WU00:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
05:28:39:WU00:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
05:30:35:WU00:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
05:32:32:WU00:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
05:34:28:WU00:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
05:36:34:WU00:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
05:38:31:WU00:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
05:40:27:WU00:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
05:42:24:WU00:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
05:44:20:WU00:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
05:46:26:WU00:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
05:48:22:WU00:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
05:50:19:WU00:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
05:52:16:WU00:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
05:54:12:WU00:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
05:56:17:WU00:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
05:58:14:WU00:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
06:00:10:WU00:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
06:02:07:WU00:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
06:04:04:WU00:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
06:06:09:WU00:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
06:08:06:WU00:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
06:10:02:WU00:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
06:11:59:WU00:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
06:13:55:WU00:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
06:16:01:WU00:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
06:17:57:WU00:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
06:19:54:WU00:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
06:21:50:WU00:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
06:23:47:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
06:25:52:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
06:27:50:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
06:29:47:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
06:31:44:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
06:33:42:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
06:35:48:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
06:37:46:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
06:39:43:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
06:41:41:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
06:43:38:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
06:45:45:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
06:47:42:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
06:49:39:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
06:51:37:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
06:53:34:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
06:55:41:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
06:56:33:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
06:56:33:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
07:00:27:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
07:02:24:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
07:04:22:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
07:06:19:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
07:08:26:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
07:10:24:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
07:12:21:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
07:14:19:WU00:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
07:16:16:WU00:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
07:18:23:WU00:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
07:20:20:WU00:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
07:22:17:WU00:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
07:24:15:WU00:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
07:26:12:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
07:28:19:WU00:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
07:30:16:WU00:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
07:32:13:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
07:34:10:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
07:36:08:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
07:38:14:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
07:40:11:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
07:42:07:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
07:44:02:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
07:44:02:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
07:45:59:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
07:47:55:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
07:49:52:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
07:51:48:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
07:53:45:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
07:55:51:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
07:57:47:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
07:59:44:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
08:01:40:WU00:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
08:03:37:WU00:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
08:05:42:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
08:07:38:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
08:09:35:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
08:11:31:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
08:13:28:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
08:13:37:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
08:13:37:WU00:FS01:0x22:Saving result file badstate-0.xml
08:13:38:WU00:FS01:0x22:Saving result file badstate-1.xml
08:13:39:WU00:FS01:0x22:Saving result file checkpointState.xml
08:13:39:WU00:FS01:0x22:Saving result file checkpt.crc
08:13:39:WU00:FS01:0x22:Saving result file positions.xtc
08:13:40:WU00:FS01:0x22:Saving result file science.log
08:13:40:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:13:40:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:13:40:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:13:40:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:13:40:WU00:FS01:Connecting to 13.82.98.119:8080
08:14:02:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:14:02:WU00:FS01:Connecting to 13.82.98.119:80
08:14:23:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:14:23:WU00:FS01:Trying to send results to collection server
08:14:23:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:14:23:WU00:FS01:Connecting to 52.224.109.74:8080
08:14:23:ERROR:WU00:FS01:Exception: Transfer failed
08:14:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:14:24:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:14:24:WU00:FS01:Connecting to 13.82.98.119:8080
08:14:31:WU00:FS01:Upload 0.03%
08:15:09:WU00:FS01:Upload 0.08%
08:15:09:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:15:09:WU00:FS01:Trying to send results to collection server
08:15:09:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:15:09:WU00:FS01:Connecting to 52.224.109.74:8080
08:15:09:ERROR:WU00:FS01:Exception: Transfer failed
08:15:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:15:24:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:15:24:WU00:FS01:Connecting to 13.82.98.119:8080
08:15:45:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:15:45:WU00:FS01:Connecting to 13.82.98.119:80
08:16:00:WU00:FS01:Upload 0.03%
08:16:44:WU00:FS01:Upload 0.08%
08:16:44:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:16:44:WU00:FS01:Trying to send results to collection server
08:16:44:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:16:44:WU00:FS01:Connecting to 52.224.109.74:8080
08:16:45:ERROR:WU00:FS01:Exception: Transfer failed
08:17:01:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:17:01:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:17:01:WU00:FS01:Connecting to 13.82.98.119:8080
08:17:22:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:17:22:WU00:FS01:Connecting to 13.82.98.119:80
08:17:22:WU00:FS01:Upload 0.03%
08:18:01:WU00:FS01:Upload 0.08%
08:18:01:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:18:01:WU00:FS01:Trying to send results to collection server
08:18:01:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:18:01:WU00:FS01:Connecting to 52.224.109.74:8080
08:18:02:ERROR:WU00:FS01:Exception: Transfer failed
08:19:38:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:19:38:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:19:38:WU00:FS01:Connecting to 13.82.98.119:8080
08:20:00:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:20:00:WU00:FS01:Connecting to 13.82.98.119:80
08:20:00:WU00:FS01:Upload 0.03%
08:20:34:WU00:FS01:Upload 0.08%
08:20:34:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:20:34:WU00:FS01:Trying to send results to collection server
08:20:34:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:20:34:WU00:FS01:Connecting to 52.224.109.74:8080
08:20:35:ERROR:WU00:FS01:Exception: Transfer failed
08:23:53:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:23:53:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:23:53:WU00:FS01:Connecting to 13.82.98.119:8080
08:24:00:WU00:FS01:Upload 0.03%
08:24:28:WU00:FS01:Upload 0.08%
08:24:28:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:24:28:WU00:FS01:Trying to send results to collection server
08:24:28:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:24:28:WU00:FS01:Connecting to 52.224.109.74:8080
08:24:28:ERROR:WU00:FS01:Exception: Transfer failed
08:30:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:30:44:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:30:44:WU00:FS01:Connecting to 13.82.98.119:8080
08:31:29:WU00:FS01:Upload 0.08%
08:31:29:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:31:29:WU00:FS01:Trying to send results to collection server
08:31:29:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:31:29:WU00:FS01:Connecting to 52.224.109.74:8080
08:31:30:ERROR:WU00:FS01:Exception: Transfer failed
08:41:49:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:41:49:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:41:49:WU00:FS01:Connecting to 13.82.98.119:8080
08:42:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:42:11:WU00:FS01:Connecting to 13.82.98.119:80
08:42:32:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:42:32:WU00:FS01:Trying to send results to collection server
08:42:32:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
08:42:32:WU00:FS01:Connecting to 52.224.109.74:8080
08:42:32:ERROR:WU00:FS01:Exception: Transfer failed
08:59:46:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
08:59:46:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
08:59:46:WU00:FS01:Connecting to 13.82.98.119:8080
09:00:19:WU00:FS01:Upload 0.08%
09:00:19:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
09:00:19:WU00:FS01:Trying to send results to collection server
09:00:19:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
09:00:19:WU00:FS01:Connecting to 52.224.109.74:8080
09:00:19:ERROR:WU00:FS01:Exception: Transfer failed
09:28:48:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
09:28:48:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
09:28:48:WU00:FS01:Connecting to 13.82.98.119:8080
09:29:09:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:29:09:WU00:FS01:Connecting to 13.82.98.119:80
09:29:31:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:29:31:WU00:FS01:Trying to send results to collection server
09:29:31:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
09:29:31:WU00:FS01:Connecting to 52.224.109.74:8080
09:29:31:ERROR:WU00:FS01:Exception: Transfer failed
******************************* Date: 2020-04-22 *******************************
10:15:47:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
10:15:47:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
10:15:47:WU00:FS01:Connecting to 13.82.98.119:8080
10:16:09:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:16:09:WU00:FS01:Connecting to 13.82.98.119:80
10:16:24:WU00:FS01:Upload 0.03%
10:16:59:WU00:FS01:Upload 0.08%
10:16:59:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
10:16:59:WU00:FS01:Trying to send results to collection server
10:16:59:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
10:16:59:WU00:FS01:Connecting to 52.224.109.74:8080
10:17:00:ERROR:WU00:FS01:Exception: Transfer failed
11:31:48:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
11:31:48:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
11:31:48:WU00:FS01:Connecting to 13.82.98.119:8080
11:32:10:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:32:10:WU00:FS01:Connecting to 13.82.98.119:80
11:32:25:WU00:FS01:Upload 0.03%
11:32:56:WU00:FS01:Upload 0.08%
11:32:56:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
11:32:56:WU00:FS01:Trying to send results to collection server
11:32:56:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
11:32:56:WU00:FS01:Connecting to 52.224.109.74:8080
11:32:56:ERROR:WU00:FS01:Exception: Transfer failed
13:34:48:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
13:34:48:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
13:34:48:WU00:FS01:Connecting to 13.82.98.119:8080
Post by Neil-B »
LB23 wrote:Got another.
The thread you mentioned was locked for the reasons explained - not because wasn't worth looking into and I'm sorry if you felt it was that way - it was conflating a number of issues and until it the issue with the server in question was resolved there wasn't really much point in debating and guessing as to what might be the reason or when it might be fixed.
This is a report for a different server … As with the other thread, all issues with individual servers are looked into by the team as quickly as possible - as delays impact folders, but even more so the researchers and delays the science so the team do try to get things sorted asap - but it takes time - especially if over a weekend (as was the last issue) … Reporting here on the Forums is a really good thing to do - but with the massive amount of effort in play just standing up new infrastructure and getting it all running nicely some of the issues are not able to be instantly fixed.
Where information is available that might inform people as to what is happening it will be shared - and members of the forums will try to assist in making sure that it is simply server overload or whether there are other issues such as configuration that might be causing the issues for any individual.
Post by Neil-B »
andrewkv81 wrote:Been trying to upload for over 36hrs now: … ... ... ... I believe 52.224.109.74 does not have a CS so how do I get the data so sent. WS is 128.252.203.10.
Thanks for the report ... Want to look into this as you are reporting IP's that don't match you log ... I'll repost in a few minutes.
From your log the WS is ... 05:13:00:WU00:FS01:Connecting to 13.82.98.119:8080 ... and then the client tries the CS ... 05:13:29:WU00:FS01:Connecting to 52.224.109.74:8080 ... so the IP you quote is the CS for WS 13.82.98.119 ... Looks like both are busy ... but this report will give someone the heads up to check them.
Not sure where you get the final IP you quote from - but I am not sure if it is relevant ... Another folder is having the same issue as you are, given this and that it looks like simple sever overload there is little you can do other than wait and hope the load reduces enough for you WUs to upload or that the team can tweak something and get a bit more out of the servers.
LB23
Post by LB23 »
Got 3 now that wont upload. One is going to expire today and that will put me up to 3 that expired. They all have been large WU that take 7 to 10 hours to work. I'm not worried about points its just all these hours for nothing since they just expire when I could have done 4 or 5 normal size WU in the time it takes to do 1 of these and would have been accepted.
13:33:50:WU05:FS01:Sending unit results: id:05 state:SEND error:FAULTY project:14415 run:0 clone:342 gen:12 core:0x22 unit:0x000000160d5262775e839e5cfcdc6efd
13:33:50:WU05:FS01:Uploading 273.92MiB to 13.82.98.119
13:33:50:WU05:FS01:Connecting to 13.82.98.119:8080
13:34:06:WU05:FS01:Upload 0.05%
13:34:14:WARNING:WU05:FS01:Exception: Failed to send results to work server: Transfer failed
13:34:14:WU05:FS01:Trying to send results to collection server
13:34:14:WU05:FS01:Uploading 273.92MiB to 52.224.109.74
13:34:14:WU05:FS01:Connecting to 52.224.109.74:8080
13:34:14:ERROR:WU05:FS01:Exception: Transfer failed
13:34:14:WU05:FS01:Sending unit results: id:05 state:SEND error:FAULTY project:14415 run:0 clone:342 gen:12 core:0x22 unit:0x000000160d5262775e839e5cfcdc6efd
13:34:14:WU05:FS01:Uploading 273.92MiB to 13.82.98.119
13:34:14:WU05:FS01:Connecting to 13.82.98.119:8080
13:34:45:WU05:FS01:Upload 0.07%
13:34:46:WARNING:WU05:FS01:Exception: Failed to send results to work server: Transfer failed
13:34:46:WU05:FS01:Trying to send results to collection server
13:34:46:WU05:FS01:Uploading 273.92MiB to 52.224.109.74
13:34:46:WU05:FS01:Connecting to 52.224.109.74:8080
13:34:46:ERROR:WU05:FS01:Exception: Transfer failed
13:35:52:WU05:FS01:Sending unit results: id:05 state:SEND error:FAULTY project:14415 run:0 clone:342 gen:12 core:0x22 unit:0x000000160d5262775e839e5cfcdc6efd
13:35:52:WU05:FS01:Uploading 273.92MiB to 13.82.98.119
13:35:52:WU05:FS01:Connecting to 13.82.98.119:8080
13:36:10:WU05:FS01:Upload 0.07%
13:36:10:WARNING:WU05:FS01:Exception: Failed to send results to work server: Transfer failed
13:36:10:WU05:FS01:Trying to send results to collection server
13:36:10:WU05:FS01:Uploading 273.92MiB to 52.224.109.74
13:36:10:WU05:FS01:Connecting to 52.224.109.74:8080
13:36:11:ERROR:WU05:FS01:Exception: Transfer failed
13:38:29:WU05:FS01:Sending unit results: id:05 state:SEND error:FAULTY project:14415 run:0 clone:342 gen:12 core:0x22 unit:0x000000160d5262775e839e5cfcdc6efd
13:38:29:WU05:FS01:Uploading 273.92MiB to 13.82.98.119
13:38:29:WU05:FS01:Connecting to 13.82.98.119:8080
13:38:50:WARNING:WU05:FS01:WorkServer connection failed on port 8080 trying 80
13:38:50:WU05:FS01:Connecting to 13.82.98.119:80
13:38:53:WU05:FS01:Upload 0.02%
13:39:26:WU05:FS01:Upload 0.05%
13:39:59:WU05:FS01:Upload 0.07%
13:39:59:WARNING:WU05:FS01:Exception: Failed to send results to work server: Transfer failed
13:39:59:WU05:FS01:Trying to send results to collection server
13:39:59:WU05:FS01:Uploading 273.92MiB to 52.224.109.74
13:39:59:WU05:FS01:Connecting to 52.224.109.74:8080
13:40:00:ERROR:WU05:FS01:Exception: Transfer failed
The FAULTY project WU will probably never upload, it is on the too large to be accepted at 273 MB. You may as well delete it, the WU has already been completed by someone else.
If you examine the log for when that WU was running, if you see a number of error reports, and crash reports in the log, there is a good chance that there is an issue with your GPU. That could be an excessive overclock, overheating, or something else along that line.
LB23
Post by LB23 »
OK now I have another. What is the cutoff on size? Is that only on the faulty WU or all of them? They are coming to me at 124.80MiB and as far as I understand they are bigger after running.
I have only had a few failed WU since starting folding again a month or so ago. When there is a failed WU its always a massive one. It's so rare I chock it up to bad WU.
This one didnt fail and its 222 MB
23:36:52:WU00:FS01:Trying to send results to collection server
23:36:52:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
23:36:52:WU00:FS01:Connecting to 52.224.109.74:8080
23:36:53:ERROR:WU00:FS01:Exception: Transfer failed
23:40:55:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
23:40:55:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
23:40:55:WU00:FS01:Connecting to 13.82.98.119:8080
23:41:01:WU00:FS01:Upload 1.18%
23:41:07:WU00:FS01:Upload 2.95%
23:41:13:WU00:FS01:Upload 4.61%
23:41:18:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
23:41:18:WU00:FS01:Trying to send results to collection server
23:41:18:WU00:FS01:Uploading 222.18MiB to 52.224.109.74
23:41:18:WU00:FS01:Connecting to 52.224.109.74:8080
23:41:20:ERROR:WU00:FS01:Exception: Transfer failed
23:47:46:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14415 run:0 clone:1319 gen:10 core:0x22 unit:0x000000130d5262775e839e5951c36633
23:47:46:WU00:FS01:Uploading 222.18MiB to 13.82.98.119
23:47:46:WU00:FS01:Connecting to 13.82.98.119:8080
23:47:50:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
The "massive" ones will push your GPU harder. So one that is stable enough to complete WUs from other projects, maybe with a recoverable error or two in the middle of processing, may fail to finish processing one of these.
As for size, I just happen to recognize this project and knew from prior reports that 270+ MB is carrying too many error reports in the upload package. The extra size just makes it a bit harder to get uploaded.
greenbaarron
Failed to connect: 3.133.76.19 and 3.21.157.11
Post by greenbaarron »
01:23:35:WU02:FS02:Uploading 137.39MiB to 3.133.76.19
01:23:35:WU02:FS02:Connecting to 3.133.76.19:8080
01:23:35:WARNING:WU02:FS02:Exception: Failed to send results to work server: Transfer failed
01:23:35:WU02:FS02:Trying to send results to collection server
01:23:35:WU02:FS02:Uploading 137.39MiB to 3.21.157.11
01:23:35:WU02:FS02:Connecting to 3.21.157.11:8080
01:23:35:ERROR:WU02:FS02:Exception: Transfer failed
01:25:53:WU00:FS02:0x22:Completed 2320000 out of 8000000 steps (29%)
01:26:12:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:16434 run:277 clone:0 gen:6 core:0x22 unit:0x0000000803854c135e9cbacc25a0b0e9
01:26:12:WU02:FS02:Uploading 137.39MiB to 3.133.76.19
01:26:12:WU02:FS02:Connecting to 3.133.76.19:8080
01:26:12:WARNING:WU02:FS02:Exception: Failed to send results to work server: Transfer
