I'm setting up a system with GPU's, and only have a 2 core celeron for the cpu.
Folding at home automatically sets up to use a cpu slot and a slot for each gpu.
Can I eliminate the CPU slot and still have the GPU slots work?
Do I have to have a cpu slot ina gpu system?
Re: Do I have to have a cpu slot ina gpu system?
no, not at all. the software will automatically create one, but it's easy to remove it. I don't run any CPU clients but run 7 GPU clients.
single 1070
I choose to run CPU slots but they are easy to get rid of.
On this white field should be a cpu item, click it and then click remove.
