do RX 570 4 GB work?
mwroggenbuck
Post by mwroggenbuck »
I apologize if this is not the correct forum for this question. Please move if necessary.
Has anyone with a 4 GB RX 570 been successful recently? It does not seem to matter what I do (new drivers, multiple tries, etc), I can't get a WU to succeed. My normal result is a crash of the Radeon control software, followed by the GPU not using any power or capacity.
I may need to return my card, but other AMD projects seem to work fine for me, as do games and graphics benchmarks.
Bottom line - has anyone successfully used a 4 GB RX 570?
Thanks,
Mark
P.S. This is under Windows 10 professional.
Re: do RX 570 4 GB work?
Post by foldy »
Yes RX 570 4GB is supported. FAH is very demanding on hardware, so a game stable GPU may fail for compute stablility.
mwroggenbuck
I realize it is supported, I just want to know if anyone was successful recently. I am wondering if computing against the virus has worked in this configuration. Like I said, other GPU intensive projects (in particular Einstein@home, Milkway@home, and Amicable Numbers) have all worked for at least a day without issue.
Jan
Post by Jan »
I'm on a RX 570 with 8GB, which is the same chip. About lets say two weeks ago I met a few projects which produced error, most likely due to driver problems that need to be fixed by AMD. Apart from that - many WUs successfully completed since then, in fact all of them I believe. All of the WUs being COVID-19 as well, I think. So from my perspective: Everything fine with this setup.
What has been experienced though is reducing the clock speed a bit helping with stability. For my individual GPU it hasnt been neccessary, but there are positive reports about that approach. Are you on (factory-side) OC? If yes, maybe give it a try. If no - maybe also give it a try. :P
Are you monitoring other factors such as temps, etc?
mwroggenbuck wrote:I can't get a WU to succeed. My normal result is a crash of the Radeon control software, followed by the GPU not using any power or capacity.
Please post segments of FAH's log. We need the first couple pages of the log where FAH detects the hardware and sets it up plus segments showing the errors. What messages are you getting when it crashes and what WUs were active?
mwroggenbuck
Interesting thought about the clock speed. I was using the default factory settings. I will lower those a bit. If it works, then I know my card needs to be replaced.
Stay posted.
Jan
Post by Jan »
I highly recommend also following bruce's post. The man knows what he's talking about.
mwroggenbuck
I reduced the clock speed by 10%. So far, things are working great! I will let it run overnight to be sure, but I have already requested an RMA.
I should have thought of clock speed, but since I was NOT overclocking, I did not. Apparently, this hardware was right on the edge.
I will update this thread as I know more, but it looks like we found the problem.
Thanks for all who helped.
So many GPUs come from the factory overclocked, it becomes something people don't think of as a possible issue. nVidia and AMD spec their reference values for the GPU chips they sell to be stable for video and calculations. The cards overclocked by the manufacturer are just guaranteeing stability for video purposes such as gaming. It can make difference.
Both companies also sell "Pro" cards for the number crunching market. While often using the same chips, they cost much more. If you examine their specs, often they run at a slightly reduced clock rate compared to the consumer cards. Part of that is to produce less heat in systems, but some is also for additional computational stability.
mwroggenbuck
Well, the card ran all night without issue, so the problem was definitely stability versus the clock speed. I did check and the manufacturer had the clocks at the AMD specifications. As far as I can tell, there was no over clocking involved. I guess the hardware was right on the edge. I have an RMA and will send out for a replacement today. It will be interesting to see if a new card acts any differently.
Again, thanks for all the help. If the forum has a debugging thread some place, it might be nice to mention trying to under clock the GPU
mwroggenbuck
I received my replacement card today. I downloaded FAH. Then I downloaded GPUs.txt and manually created a GPU slot. Things look like they ran fine until the very end. Then it looked like it failed and did not upload a result.
Here is the log snippet
20:15:12:WU00:FS00:0x22:Completed 2000000 out of 2000000 steps (100%)
20:15:14:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
20:15:14:WU00:FS00:0x22:Saving result file checkpointState.xml
20:15:14:WU00:FS00:0x22:Saving result file checkpt.crc
20:15:14:WU00:FS00:0x22:Saving result file positions.xtc
20:15:14:WU00:FS00:0x22:Saving result file science.log
20:15:14:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:15:16:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:15:16:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
I think that my card is actually OK.
Did I do something wrong? I did stop the job (exit from FAH), and restarted later. It looked like it started properly from a checkpoint file
*********************** Log Started 2020-04-27T19:48:05Z ***********************
19:48:05:****************************** FAHClient ******************************
19:48:05:        Version: 7.6.9
19:48:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:48:05:      Copyright: 2020 foldingathome.org
19:48:05:       Homepage: https://foldingathome.org/
19:48:05:           Date: Apr 17 2020
19:48:05:           Time: 11:13:06
19:48:05:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
19:48:05:         Branch: master
19:48:05:       Compiler: Visual C++ 2008
19:48:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:48:05:       Platform: win32 10
19:48:05:           Bits: 32
19:48:05:           Mode: Release
19:48:05:           Args: --open-web-control
19:48:05:         Config: C:\Users\mrogg\AppData\Roaming\FAHClient\config.xml
19:48:05:******************************** CBang ********************************
19:48:05:           Time: 11:10:09
19:48:05:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
19:48:05:           Bits: 32
19:48:05:******************************* System ********************************
19:48:05:            CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
19:48:05:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:48:05:           CPUs: 8
19:48:05:         Memory: 31.96GiB
19:48:05:    Free Memory: 28.59GiB
19:48:05:        Threads: WINDOWS_THREADS
19:48:05:     OS Version: 6.2
19:48:05:    Has Battery: false
19:48:05:     On Battery: false
19:48:05:     UTC Offset: -4
19:48:05:            PID: 1868
19:48:05:            CWD: C:\Users\mrogg\AppData\Roaming\FAHClient
19:48:05:             OS: Windows 10 Enterprise
19:48:05:        OS Arch: AMD64
19:48:05:           GPUs: 1
19:48:05:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
19:48:05:                 470/480/570/580/590]
19:48:05:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:48:05:                 specified module could not be found.
19:48:05:
19:48:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
19:48:05:  Win32 Service: false
19:48:05:******************************* libFAH ********************************
19:48:05:           Date: Apr 15 2020
19:48:05:           Time: 14:53:14
19:48:05:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:48:05:           Bits: 32
19:48:05:***********************************************************************
19:48:05:<config>
19:48:05:  <!-- Folding Core -->
19:48:05:  <checkpoint v='5'/>
19:48:05:
19:48:05:  <!-- Folding Slot Configuration -->
19:48:05:  <cause v='COVID_19'/>
19:48:05:
19:48:05:  <!-- Network -->
19:48:05:  <proxy v=':8080'/>
19:48:05:
19:48:05:  <!-- Slot Control -->
19:48:05:  <pause-on-battery v='false'/>
19:48:05:
19:48:05:  <!-- User Information -->
19:48:05:  <passkey v='*****'/>
19:48:05:  <user v='Mark_Roggenbuck'/>
19:48:05:
19:48:05:  <!-- Folding Slots -->
19:48:05:  <slot id='0' type='GPU'/>
19:48:05:</config>
19:48:05:Trying to access database...
19:48:05:Successfully acquired database lock
19:48:05:Enabled folding slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
19:48:05:WU00:FS00:Starting
19:48:05:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mrogg\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1868 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:48:05:WU00:FS00:Started FahCore on PID 2840
19:48:05:WU00:FS00:Core PID:7044
19:48:05:WU00:FS00:FahCore 0x22 started
19:48:05:WU00:FS00:0x22:*********************** Log Started 2020-04-27T19:48:05Z ***********************
19:48:05:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:48:05:WU00:FS00:0x22:       Type: 0x22
19:48:05:WU00:FS00:0x22:       Core: Core22
19:48:05:WU00:FS00:0x22:    Website: https://foldingathome.org/
19:48:06:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:48:06:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:48:06:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
19:48:06:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2840 -checkpoint 5
19:48:06:WU00:FS00:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:48:06:WU00:FS00:0x22:     Config: <none>
19:48:06:WU00:FS00:0x22:************************************ Build *************************************
19:48:06:WU00:FS00:0x22:    Version: 0.0.5
19:48:06:WU00:FS00:0x22:       Date: Apr 22 2020
19:48:06:WU00:FS00:0x22:       Time: 04:42:59
19:48:06:WU00:FS00:0x22: Repository: Git
19:48:06:WU00:FS00:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:48:06:WU00:FS00:0x22:     Branch: HEAD
19:48:06:WU00:FS00:0x22:   Compiler: Visual C++ 2008
19:48:06:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:48:06:WU00:FS00:0x22:   Platform: win32 10
19:48:06:WU00:FS00:0x22:       Bits: 64
19:48:06:WU00:FS00:0x22:       Mode: Release
19:48:06:WU00:FS00:0x22:************************************ System ************************************
19:48:06:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
19:48:06:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:48:06:WU00:FS00:0x22:       CPUs: 8
19:48:06:WU00:FS00:0x22:     Memory: 31.96GiB
19:48:06:WU00:FS00:0x22:Free Memory: 28.55GiB
19:48:06:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
19:48:06:WU00:FS00:0x22: OS Version: 6.2
19:48:06:WU00:FS00:0x22:Has Battery: false
19:48:06:WU00:FS00:0x22: On Battery: false
19:48:06:WU00:FS00:0x22: UTC Offset: -4
19:48:06:WU00:FS00:0x22:        PID: 7044
19:48:06:WU00:FS00:0x22:        CWD: C:\Users\mrogg\AppData\Roaming\FAHClient\work
19:48:06:WU00:FS00:0x22:         OS: Windows 10 Pro
19:48:06:WU00:FS00:0x22:    OS Arch: AMD64
19:48:06:WU00:FS00:0x22:********************************************************************************
19:48:06:WU00:FS00:0x22:Project: 11761 (Run 0, Clone 2249, Gen 42)
19:48:06:WU00:FS00:0x22:Unit: 0x0000006080fccb0a5e6d7d3e7828a679
19:48:06:WU00:FS00:0x22:Digital signatures verified
19:48:06:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:48:06:WU00:FS00:0x22:Version 0.0.5
19:48:06:WU00:FS00:0x22:  Found a checkpoint file
19:48:09:17:127.0.0.1:New Web session
19:48:16:WU00:FS00:0x22:Completed 1750000 out of 2000000 steps (87%)
19:48:16:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:49:21:WU00:FS00:0x22:Completed 1760000 out of 2000000 steps (88%)
19:51:29:WU00:FS00:0x22:Completed 1780000 out of 2000000 steps (89%)
19:53:16:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
19:53:37:WU00:FS00:0x22:Completed 1800000 out of 2000000 steps (90%)
19:55:47:WU00:FS00:0x22:Completed 1820000 out of 2000000 steps (91%)
19:57:58:WU00:FS00:0x22:Completed 1840000 out of 2000000 steps (92%)
20:00:09:WU00:FS00:0x22:Completed 1860000 out of 2000000 steps (93%)
20:02:17:WU00:FS00:0x22:Completed 1880000 out of 2000000 steps (94%)
20:04:25:WU00:FS00:0x22:Completed 1900000 out of 2000000 steps (95%)
20:06:37:WU00:FS00:0x22:Completed 1920000 out of 2000000 steps (96%)
20:08:45:WU00:FS00:0x22:Completed 1940000 out of 2000000 steps (97%)
I would appreciate any thoughts.
It's good to see that you didn't loose the WU and instead, it fell back to the last good checkpoint. In this case, I would think that it is related to "storage" issues, i.e. a failing hard disk, faulty SSD, an anti-virus/anti-malware/anti-spyware/anti-ransomeware application potentially messing with the files:
I would add an exception to anti-* to exclude this folder (and it's files and sub-folders):
Also, since you're folding only on the GPU, this checkpoint value will be ignored. Instead, the GPU will create a checkpoint at a percentage which is between 2% and 5% IIRC and is done by the researcher.
<checkpoint v='5'/>
mwroggenbuck
Thanks for the information. I ran all night and processed 3 WUs without issue (all uploaded their information). You may be right about the "anti-" software. However, I suspect that falling back to a checkpoint was also part of the problem. Or maybe a GPU only slot.
If I have to stop, would it make more sense to pause rather than exit? I suspect that would not fall back to a checkpoint, but I am not sure about GPU.
Mark
mwroggenbuck
From what I can see, pause and exit do the same thing to a GPU slot.
I have move my installation to a non system drive. My user owns everything on it, so there should be no permission problems. I don't know about the "anti-" stuff. I will let this run for a bit, then stop and restart it. I will check if it recovers from a checkpoint and go from there.
mwroggenbuck
Well, even after I installed FAH on a different drive, I still had and error if I stopped and recovered from a checkpoint
15:10:18:WU00:FS00:0x22:Project: 11762 (Run 0, Clone 12100, Gen 7)
15:10:18:WU00:FS00:0x22:Unit: 0x0000001380fccb0a5e7113a145a0a516
15:10:18:WU00:FS00:0x22:Digital signatures verified
15:10:18:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:10:18:WU00:FS00:0x22:Version 0.0.5
15:10:18:WU00:FS00:0x22:  Found a checkpoint file
15:10:20:3:127.0.0.1:New Web session
15:10:32:WU00:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
15:10:32:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:12:17:WU00:FS00:0x22:Completed 60000 out of 1000000 steps (6%)
15:14:00:WU00:FS00:0x22:Completed 70000 out of 1000000 steps (7%)
15:14:35:14:127.0.0.1:New Web session
15:15:45:WU00:FS00:0x22:Completed 80000 out of 1000000 steps (8%)
15:17:30:WU00:FS00:0x22:Completed 90000 out of 1000000 steps (9%)
15:19:13:WU00:FS00:0x22:Completed 100000 out of 1000000 steps (10%)
15:20:58:WU00:FS00:0x22:Completed 110000 out of 1000000 steps (11%)
15:22:43:WU00:FS00:0x22:Completed 120000 out of 1000000 steps (12%)
15:24:28:WU00:FS00:0x22:Completed 130000 out of 1000000 steps (13%)
15:26:12:WU00:FS00:0x22:Completed 140000 out of 1000000 steps (14%)
15:27:56:WU00:FS00:0x22:Completed 150000 out of 1000000 steps (15%)
15:29:43:WU00:FS00:0x22:Completed 160000 out of 1000000 steps (16%)
15:31:27:WU00:FS00:0x22:Completed 170000 out of 1000000 steps (17%)
15:33:12:WU00:FS00:0x22:Completed 180000 out of 1000000 steps (18%)
15:34:56:WU00:FS00:0x22:Completed 190000 out of 1000000 steps (19%)
15:36:39:WU00:FS00:0x22:Completed 200000 out of 1000000 steps (20%)
15:38:25:WU00:FS00:0x22:Completed 210000 out of 1000000 steps (21%)
15:40:09:WU00:FS00:0x22:Completed 220000 out of 1000000 steps (22%)
15:41:52:WU00:FS00:0x22:Completed 230000 out of 1000000 steps (23%)
15:43:35:WU00:FS00:0x22:Completed 240000 out of 1000000 steps (24%)
15:45:18:WU00:FS00:0x22:Completed 250000 out of 1000000 steps (25%)
15:47:05:WU00:FS00:0x22:Completed 260000 out of 1000000 steps (26%)
15:48:48:WU00:FS00:0x22:Completed 270000 out of 1000000 steps (27%)
15:50:30:WU00:FS00:0x22:Completed 280000 out of 1000000 steps (28%)
15:52:15:WU00:FS00:0x22:Completed 290000 out of 1000000 steps (29%)
15:53:59:WU00:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
15:54:51:37:127.0.0.1:New Web session
15:55:20:51:127.0.0.1:New Web session
15:55:48:WU00:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
15:57:30:WU00:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
15:59:14:WU00:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
16:00:58:WU00:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
16:02:41:WU00:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
16:04:27:WU00:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
16:06:11:WU00:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
16:07:55:WU00:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
16:09:38:WU00:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
16:11:22:WU00:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
16:13:09:WU00:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
16:14:53:WU00:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
16:16:37:WU00:FS00:0x22:Completed 430000 out of 1000000 steps (43%)
16:18:21:WU00:FS00:0x22:Completed 440000 out of 1000000 steps (44%)
16:20:05:WU00:FS00:0x22:Completed 450000 out of 1000000 steps (45%)
16:21:51:WU00:FS00:0x22:Completed 460000 out of 1000000 steps (46%)
16:23:36:WU00:FS00:0x22:Completed 470000 out of 1000000 steps (47%)
16:25:21:WU00:FS00:0x22:Completed 480000 out of 1000000 steps (48%)
16:27:05:WU00:FS00:0x22:Completed 490000 out of 1000000 steps (49%)
16:28:49:WU00:FS00:0x22:Completed 500000 out of 1000000 steps (50%)
16:30:37:WU00:FS00:0x22:Completed 510000 out of 1000000 steps (51%)
16:32:22:WU00:FS00:0x22:Completed 520000 out of 1000000 steps (52%)
16:34:06:WU00:FS00:0x22:Completed 530000 out of 1000000 steps (53%)
16:35:50:WU00:FS00:0x22:Completed 540000 out of 1000000 steps (54%)
16:37:35:WU00:FS00:0x22:Completed 550000 out of 1000000 steps (55%)
16:39:23:WU00:FS00:0x22:Completed 560000 out of 1000000 steps (56%)
16:41:07:WU00:FS00:0x22:Completed 570000 out of 1000000 steps (57%)
16:42:51:WU00:FS00:0x22:Completed 580000 out of 1000000 steps (58%)
16:44:35:WU00:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
16:46:19:WU00:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
16:48:05:WU00:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
16:49:51:WU00:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
16:51:35:WU00:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
16:53:18:WU00:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
16:55:03:WU00:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
16:56:51:WU00:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
16:58:37:WU00:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
17:00:21:WU00:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
17:02:07:WU00:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
17:03:52:WU00:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
17:04:33:61:127.0.0.1:New Web session
17:05:41:WU00:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
17:07:26:WU00:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
17:09:12:WU00:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
17:10:57:WU00:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
17:12:40:WU00:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
17:14:28:WU00:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
17:16:12:WU00:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
17:17:57:WU00:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
17:19:41:WU00:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
17:21:26:WU00:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
17:23:12:WU00:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
17:24:57:WU00:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
17:26:41:WU00:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
17:28:25:WU00:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
17:30:10:WU00:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
17:31:57:WU00:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
17:33:41:WU00:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
17:35:25:WU00:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
17:37:10:WU00:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
17:38:54:WU00:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
17:40:41:WU00:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
17:42:25:WU00:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
17:44:09:WU00:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
17:45:53:WU00:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
17:47:37:WU00:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
17:49:27:WU00:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
17:51:12:WU00:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
17:52:58:WU00:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
17:54:42:WU00:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
17:54:43:WU01:FS00:Connecting to 65.254.110.245:80
17:54:43:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:54:43:WU01:FS00:Connecting to 18.218.241.186:80
17:54:44:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:54:44:WU01:FS00:Connecting to 65.254.110.245:80
17:54:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:54:44:WU01:FS00:Connecting to 18.218.241.186:80
17:54:44:WU01:FS00:Assigned to work server 128.252.203.10
17:54:44:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
17:54:44:WU01:FS00:Connecting to 128.252.203.10:8080
17:55:05:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
17:55:05:WU01:FS00:Connecting to 128.252.203.10:80
17:55:22:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
17:55:22:WU01:FS00:Connecting to 65.254.110.245:80
17:55:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:55:23:WU01:FS00:Connecting to 18.218.241.186:80
17:55:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:55:23:WU01:FS00:Connecting to 65.254.110.245:80
17:55:24:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:55:24:ERROR:WU01:FS00:Exception: Could not get an assignment
17:56:22:WU01:FS00:Connecting to 65.254.110.245:80
17:56:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:56:23:WU01:FS00:Connecting to 18.218.241.186:80
17:56:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:56:23:WU01:FS00:Connecting to 65.254.110.245:80
17:56:23:ERROR:WU01:FS00:Exception: Could not get an assignment
17:56:26:WU00:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
17:56:30:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
17:56:30:WU00:FS00:0x22:Saving result file checkpointState.xml
17:56:30:WU00:FS00:0x22:Saving result file checkpt.crc
17:56:30:WU00:FS00:0x22:Saving result file positions.xtc
17:56:30:WU00:FS00:0x22:Saving result file science.log
17:56:30:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:56:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:56:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:56:32:WU00:FS00:Starting
17:56:32:WU00:FS00:Running FahCore: D:\C_Alt\programs\FAHClient/FAHCoreWrapper.exe D:\C_Alt\data\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 14404 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:56:32:WU00:FS00:Started FahCore on PID 612
17:56:32:WU00:FS00:Core PID:11492
17:56:32:WU00:FS00:FahCore 0x22 started
17:56:33:WU00:FS00:0x22:*********************** Log Started 2020-04-28T17:56:32Z ***********************
17:56:33:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
17:56:33:WU00:FS00:0x22:       Type: 0x22
17:56:33:WU00:FS00:0x22:       Core: Core22
17:56:33:WU00:FS00:0x22:    Website: https://foldingathome.org/
17:56:33:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
17:56:33:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:56:33:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
17:56:33:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 612 -checkpoint 5
17:56:33:WU00:FS00:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:56:33:WU00:FS00:0x22:     Config: <none>
17:56:33:WU00:FS00:0x22:************************************ Build *************************************
17:56:33:WU00:FS00:0x22:    Version: 0.0.5
17:56:33:WU00:FS00:0x22:       Date: Apr 22 2020
17:56:33:WU00:FS00:0x22:       Time: 04:42:59
17:56:33:WU00:FS00:0x22: Repository: Git
17:56:33:WU00:FS00:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
17:56:33:WU00:FS00:0x22:     Branch: HEAD
17:56:33:WU00:FS00:0x22:   Compiler: Visual C++ 2008
17:56:33:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:56:33:WU00:FS00:0x22:   Platform: win32 10
17:56:33:WU00:FS00:0x22:       Bits: 64
17:56:33:WU00:FS00:0x22:       Mode: Release
17:56:33:WU00:FS00:0x22:************************************ System ************************************
17:56:33:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
17:56:33:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:56:33:WU00:FS00:0x22:       CPUs: 8
17:56:33:WU00:FS00:0x22:     Memory: 31.96GiB
17:56:33:WU00:FS00:0x22:Free Memory: 24.05GiB
17:56:33:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
17:56:33:WU00:FS00:0x22: OS Version: 6.2
17:56:33:WU00:FS00:0x22:Has Battery: false
17:56:33:WU00:FS00:0x22: On Battery: false
17:56:33:WU00:FS00:0x22: UTC Offset: -4
17:56:33:WU00:FS00:0x22:        PID: 11492
17:56:33:WU00:FS00:0x22:        CWD: D:\C_Alt\data\FAHClient\work
17:56:33:WU00:FS00:0x22:         OS: Windows 10 Pro
17:56:33:WU00:FS00:0x22:    OS Arch: AMD64
17:56:33:WU00:FS00:0x22:********************************************************************************
17:56:33:WU00:FS00:0x22:Project: 11762 (Run 0, Clone 12100, Gen 7)
17:56:33:WU00:FS00:0x22:Unit: 0x0000001380fccb0a5e7113a145a0a516
17:56:33:WU00:FS00:0x22:Reading tar file core.xml
17:56:33:WU00:FS00:0x22:Reading tar file integrator.xml
17:56:33:WU00:FS00:0x22:Reading tar file state.xml
17:56:33:WU00:FS00:0x22:Reading tar file system.xml
17:56:33:WU00:FS00:0x22:Digital signatures verified
17:56:33:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
17:56:33:WU00:FS00:0x22:Version 0.0.5
17:56:47:WU00:FS00:0x22:Completed 0 out of 1000000 steps (0%)
17:56:47:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:58:00:WU01:FS00:Connecting to 65.254.110.245:80
17:58:00:WU01:FS00:Assigned to work server 140.163.4.231
17:58:00:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.231
17:58:00:WU01:FS00:Connecting to 140.163.4.231:8080
17:58:42:WU00:FS00:0x22:Completed 10000 out of 1000000 steps (1%)
I will look though my "anti-" stuff, but I do not hold much hope.
Note that this is not the exact same error as the previous run.
Question:
Does anyone have a log file that shows an AMD GPU recover from a checkpoint that successfully uploads?
