Issue uploading complete projects
eldridgep
Post by eldridgep »
Guys understand the team is very busy and appreciate all the great work you are doing so if this is a complete noob question and I'm being impatient just say.
Have one project that fails to upload I keep getting:
23:05:09:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
The work and collection servers both appear to be responding on port 80 so look up.
Any suggestions or just wait? Would have posted screenshots but the forum won't let me link them... :roll:
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Issue uploading complete projects
Post by Jesse_V »
Hi and welcome to the forum.
I'd recommend just waiting a bit more. The servers are very busy under the massive numbers of new users, so that workunit will likely upload in time. If it still hasn't uploaded tomorrow, check back with us. In the meantime, can you post more of your log? I'd like to see more clues that might explain why it was marked as faulty.
eldridgep
Post by eldridgep »
No problem left it overnight and still the same:
04:09:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
04:09:13:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
04:09:13:WU02:FS01:Connecting to 13.82.98.119:8080
04:09:14:WU01:FS01:Connecting to 65.254.110.245:8080
04:09:14:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
04:09:14:WU02:FS01:Trying to send results to collection server
04:09:14:WU02:FS01:Uploading 271.26MiB to 52.224.109.74
04:09:14:WU02:FS01:Connecting to 52.224.109.74:8080
04:09:14:ERROR:WU02:FS01:Exception: Transfer failed
My concern is that I've not gotten any GPU based projects through since this started happening I've gotten over half a million points in the last couple of weeks but CPU projects which still arrive fine are nowhere near as efficient points wise.
If you need any more log files let me know how to submit or upload them and more than happy to, appreciate the reply.
Post by Neil-B »
For future reference when needed … viewtopic.php?f=24&t=26036
eldridgep
Post by eldridgep »
https://www.photobox.co.uk/my/photo/ful ... 2854518878
07:26:58:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:11 from 150.136.14.110
07:26:58:WU00:FS00:Connecting to 150.136.14.110:8080
07:27:01:WU00:FS00:Downloading 1.25MiB
07:27:01:WU00:FS00:Download complete
07:27:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16403 run:406 clone:3 gen:11 core:0xa7 unit:0x0000000c96880e6e5e8be0480fe473d0
07:28:02:WU03:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
07:28:03:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
07:28:03:WU03:FS00:0xa7:Saving result file frame70.trr
07:28:03:WU03:FS00:0xa7:Saving result file frame70.xtc
07:28:03:WU03:FS00:0xa7:Saving result file md.log
07:28:03:WU03:FS00:0xa7:Saving result file science.log
07:28:03:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
07:28:03:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:28:03:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16401 run:683 clone:3 gen:70 core:0xa7 unit:0x0000004d96880e6e5e814c638b88a1b4
07:28:03:WU03:FS00:Uploading 1.43MiB to 150.136.14.110
07:28:03:WU03:FS00:Connecting to 150.136.14.110:8080
07:28:03:WU00:FS00:Starting
07:28:03:WARNING:WU00:FS00:AS lowered CPUs from 11 to 9
07:28:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 11160 -checkpoint 15 -np 9
07:28:03:WU00:FS00:Started FahCore on PID 3328
07:28:03:WU00:FS00:Core PID:4408
07:28:03:WU00:FS00:FahCore 0xa7 started
07:28:04:WU00:FS00:0xa7:*********************** Log Started 2020-04-11T07:28:04Z ***********************
07:28:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:28:04:WU00:FS00:0xa7:       Type: 0xa7
07:28:04:WU00:FS00:0xa7:       Core: Gromacs
07:28:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3328 -checkpoint 15 -np 9
07:28:04:WU00:FS00:0xa7:************************************ CBang *************************************
07:28:04:WU00:FS00:0xa7:       Date: Oct 26 2019
07:28:04:WU00:FS00:0xa7:       Time: 01:38:25
07:28:04:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:28:04:WU00:FS00:0xa7:     Branch: master
07:28:04:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:28:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:28:04:WU00:FS00:0xa7:   Platform: win32 10
07:28:04:WU00:FS00:0xa7:       Bits: 64
07:28:04:WU00:FS00:0xa7:       Mode: Release
07:28:04:WU00:FS00:0xa7:************************************ System ************************************
07:28:04:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
07:28:04:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:28:04:WU00:FS00:0xa7:       CPUs: 12
07:28:04:WU00:FS00:0xa7:     Memory: 15.95GiB
07:28:04:WU00:FS00:0xa7:Free Memory: 12.28GiB
07:28:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:28:04:WU00:FS00:0xa7: OS Version: 6.2
07:28:04:WU00:FS00:0xa7:Has Battery: false
07:28:04:WU00:FS00:0xa7: On Battery: false
07:28:04:WU00:FS00:0xa7: UTC Offset: 1
07:28:04:WU00:FS00:0xa7:        PID: 4408
07:28:04:WU00:FS00:0xa7:        CWD: C:\Users\Phil\AppData\Roaming\FAHClient\work
07:28:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:28:04:WU00:FS00:0xa7:    Version: 0.0.18
07:28:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:28:04:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:28:04:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:28:04:WU00:FS00:0xa7:       Time: 01:52:30
07:28:04:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:28:04:WU00:FS00:0xa7:************************************ Build *************************************
07:28:04:WU00:FS00:0xa7:       SIMD: avx_256
07:28:04:WU00:FS00:0xa7:********************************************************************************
07:28:04:WU00:FS00:0xa7:Project: 16403 (Run 406, Clone 3, Gen 11)
07:28:04:WU00:FS00:0xa7:Unit: 0x0000000c96880e6e5e8be0480fe473d0
07:28:04:WU00:FS00:0xa7:Reading tar file core.xml
07:28:04:WU00:FS00:0xa7:Reading tar file frame11.tpr
07:28:04:WU00:FS00:0xa7:Digital signatures verified
07:28:04:WU00:FS00:0xa7:Calling: mdrun -s frame11.tpr -o frame11.trr -x frame11.xtc -cpt 15 -nt 9
07:28:04:WU00:FS00:0xa7:Steps: first=5500000 total=500000
07:28:05:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
07:28:07:WU03:FS00:Upload complete
07:28:07:WU03:FS00:Server responded WORK_ACK (400)
07:28:07:WU03:FS00:Final credit estimate, 3629.00 points
07:28:07:WU03:FS00:Cleaning up
07:28:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
07:28:14:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
07:28:14:WU02:FS01:Connecting to 13.82.98.119:8080
07:28:14:WU01:FS01:Connecting to 65.254.110.245:8080
07:28:14:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
07:28:14:WU02:FS01:Trying to send results to collection server
07:28:14:WU02:FS01:Uploading 271.26MiB to 52.224.109.74
07:28:14:WU02:FS01:Connecting to 52.224.109.74:8080
07:28:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:28:14:WU01:FS01:Connecting to 18.218.241.186:80
07:28:15:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:28:15:ERROR:WU01:FS01:Exception: Could not get an assignment
07:28:15:ERROR:WU02:FS01:Exception: Transfer failed
07:29:11:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
07:30:18:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
07:31:24:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
07:32:30:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
07:33:37:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
07:34:43:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
07:35:49:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
07:36:56:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
07:38:03:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
07:39:09:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
07:40:16:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
07:41:22:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
07:42:29:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
07:43:35:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
07:44:42:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
07:45:49:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
07:46:55:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
07:48:02:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
07:49:09:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
07:50:15:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
07:51:22:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
07:52:28:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
07:53:35:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
07:54:42:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
07:55:48:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
07:56:55:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
07:58:01:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
07:59:08:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
08:00:14:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
08:01:21:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
08:02:27:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
08:03:34:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
08:04:41:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
08:05:47:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
08:06:54:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
08:08:00:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
08:09:06:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
08:10:13:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
08:11:19:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
08:12:26:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
08:13:32:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
08:14:39:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
08:15:45:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
08:16:52:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
08:17:58:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
08:19:05:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
08:20:11:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
08:21:18:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
08:22:24:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
08:23:31:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
08:24:37:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
08:25:44:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
08:26:50:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
08:27:56:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
08:29:03:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
08:30:10:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
08:31:16:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
08:32:23:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
08:33:29:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
08:34:35:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
08:35:42:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
08:36:48:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
08:37:54:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
08:39:01:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
08:40:07:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
08:41:14:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
08:42:20:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
08:43:26:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
08:44:33:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
08:45:39:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
08:46:46:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
08:47:52:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
08:48:59:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
08:50:05:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
08:51:12:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
08:52:18:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
08:53:25:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
08:54:31:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
08:55:37:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
08:56:44:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
08:57:50:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
08:58:57:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
09:00:03:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
09:01:10:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
09:02:17:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
09:03:23:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
09:04:30:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
09:05:37:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
09:06:43:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
09:07:50:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
09:08:57:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
09:10:03:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
09:11:10:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
09:12:16:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
09:13:23:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
09:14:30:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
09:15:36:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
09:16:43:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
09:17:49:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
09:17:50:WU03:FS00:Connecting to 65.254.110.245:8080
09:17:50:WARNING:WU03:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:17:50:WU03:FS00:Connecting to 18.218.241.186:80
09:17:51:WARNING:WU03:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:17:51:ERROR:WU03:FS00:Exception: Could not get an assignment
09:17:51:WU03:FS00:Connecting to 65.254.110.245:8080
09:17:52:WU03:FS00:Assigned to work server 40.114.52.201
09:17:52:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:11 from 40.114.52.201
09:17:52:WU03:FS00:Connecting to 40.114.52.201:8080
09:17:52:ERROR:WU03:FS00:Exception: Server did not assign work unit
09:18:51:WU03:FS00:Connecting to 65.254.110.245:8080
09:18:52:WARNING:WU03:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:18:52:WU03:FS00:Connecting to 18.218.241.186:80
09:18:52:WU03:FS00:Assigned to work server 13.82.98.119
09:18:52:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:11 from 13.82.98.119
09:18:52:WU03:FS00:Connecting to 13.82.98.119:8080
09:18:56:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
09:18:57:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
09:18:57:WU00:FS00:0xa7:Saving result file frame11.trr
09:18:57:WU00:FS00:0xa7:Saving result file frame11.xtc
09:18:57:WU00:FS00:0xa7:Saving result file md.log
09:18:57:WU00:FS00:0xa7:Saving result file science.log
09:18:57:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:18:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:18:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16403 run:406 clone:3 gen:11 core:0xa7 unit:0x0000000c96880e6e5e8be0480fe473d0
09:18:57:WU00:FS00:Uploading 1.43MiB to 150.136.14.110
09:18:57:WU00:FS00:Connecting to 150.136.14.110:8080
09:18:58:WU03:FS00:Downloading 6.98MiB
09:18:58:WU03:FS00:Download complete
09:18:58:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13872 run:0 clone:3644 gen:103 core:0xa7 unit:0x000000700d5262775e7bbb043e757165
09:18:58:WU03:FS00:Starting
09:18:58:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 11160 -checkpoint 15 -np 11
09:18:58:WU03:FS00:Started FahCore on PID 6736
09:18:58:WU03:FS00:Core PID:9016
09:18:58:WU03:FS00:FahCore 0xa7 started
09:18:59:WU03:FS00:0xa7:*********************** Log Started 2020-04-11T09:18:58Z ***********************
09:18:59:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:18:59:WU03:FS00:0xa7:       Type: 0xa7
09:18:59:WU03:FS00:0xa7:       Core: Gromacs
09:18:59:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 6736 -checkpoint 15 -np
09:18:59:WU03:FS00:0xa7:             11
09:18:59:WU03:FS00:0xa7:************************************ CBang *************************************
09:18:59:WU03:FS00:0xa7:       Date: Oct 26 2019
09:18:59:WU03:FS00:0xa7:       Time: 01:38:25
09:18:59:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:18:59:WU03:FS00:0xa7:     Branch: master
09:18:59:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:18:59:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:18:59:WU03:FS00:0xa7:   Platform: win32 10
09:18:59:WU03:FS00:0xa7:       Bits: 64
09:18:59:WU03:FS00:0xa7:       Mode: Release
09:18:59:WU03:FS00:0xa7:************************************ System ************************************
09:18:59:WU03:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
09:18:59:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:18:59:WU03:FS00:0xa7:       CPUs: 12
09:18:59:WU03:FS00:0xa7:     Memory: 15.95GiB
09:18:59:WU03:FS00:0xa7:Free Memory: 12.23GiB
09:18:59:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:18:59:WU03:FS00:0xa7: OS Version: 6.2
09:18:59:WU03:FS00:0xa7:Has Battery: false
09:18:59:WU03:FS00:0xa7: On Battery: false
09:18:59:WU03:FS00:0xa7: UTC Offset: 1
09:18:59:WU03:FS00:0xa7:        PID: 9016
09:18:59:WU03:FS00:0xa7:        CWD: C:\Users\Phil\AppData\Roaming\FAHClient\work
09:18:59:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:18:59:WU03:FS00:0xa7:    Version: 0.0.18
09:18:59:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:18:59:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:18:59:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:18:59:WU03:FS00:0xa7:       Time: 01:52:30
09:18:59:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:18:59:WU03:FS00:0xa7:************************************ Build *************************************
09:18:59:WU03:FS00:0xa7:       SIMD: avx_256
09:18:59:WU03:FS00:0xa7:********************************************************************************
09:18:59:WU03:FS00:0xa7:Project: 13872 (Run 0, Clone 3644, Gen 103)
09:18:59:WU03:FS00:0xa7:Unit: 0x000000700d5262775e7bbb043e757165
09:18:59:WU03:FS00:0xa7:Reading tar file core.xml
09:18:59:WU03:FS00:0xa7:Reading tar file frame103.tpr
09:18:59:WU03:FS00:0xa7:Digital signatures verified
09:18:59:WU03:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
09:18:59:WU03:FS00:0xa7:Calling: mdrun -s frame103.tpr -o frame103.trr -x frame103.xtc -e frame103.edr -cpt 15 -nt 10
09:18:59:WU03:FS00:0xa7:Steps: first=6500000 total=62500
09:19:02:WU00:FS00:Upload complete
09:19:02:WU00:FS00:Server responded WORK_ACK (400)
09:19:02:WU00:FS00:Final credit estimate, 3696.00 points
09:19:02:WU00:FS00:Cleaning up
09:19:02:WU03:FS00:0xa7:Completed 1 out of 62500 steps (0%)
09:19:41:WU03:FS00:0xa7:Completed 625 out of 62500 steps (1%)
09:20:21:WU03:FS00:0xa7:Completed 1250 out of 62500 steps (2%)
09:21:01:WU03:FS00:0xa7:Completed 1875 out of 62500 steps (3%)
09:21:40:WU03:FS00:0xa7:Completed 2500 out of 62500 steps (4%)
09:22:20:WU03:FS00:0xa7:Completed 3125 out of 62500 steps (5%)
09:22:59:WU03:FS00:0xa7:Completed 3750 out of 62500 steps (6%)
09:23:39:WU03:FS00:0xa7:Completed 4375 out of 62500 steps (7%)
09:24:19:WU03:FS00:0xa7:Completed 5000 out of 62500 steps (8%)
09:24:58:WU03:FS00:0xa7:Completed 5625 out of 62500 steps (9%)
09:25:38:WU03:FS00:0xa7:Completed 6250 out of 62500 steps (10%)
09:26:18:WU03:FS00:0xa7:Completed 6875 out of 62500 steps (11%)
09:26:57:WU03:FS00:0xa7:Completed 7500 out of 62500 steps (12%)
09:27:37:WU03:FS00:0xa7:Completed 8125 out of 62500 steps (13%)
09:28:17:WU03:FS00:0xa7:Completed 8750 out of 62500 steps (14%)
09:28:56:WU03:FS00:0xa7:Completed 9375 out of 62500 steps (15%)
09:29:36:WU03:FS00:0xa7:Completed 10000 out of 62500 steps (16%)
09:30:15:WU03:FS00:0xa7:Completed 10625 out of 62500 steps (17%)
09:30:55:WU03:FS00:0xa7:Completed 11250 out of 62500 steps (18%)
09:31:35:WU03:FS00:0xa7:Completed 11875 out of 62500 steps (19%)
09:32:14:WU03:FS00:0xa7:Completed 12500 out of 62500 steps (20%)
09:32:54:WU03:FS00:0xa7:Completed 13125 out of 62500 steps (21%)
09:33:33:WU03:FS00:0xa7:Completed 13750 out of 62500 steps (22%)
09:34:14:WU03:FS00:0xa7:Completed 14375 out of 62500 steps (23%)
09:34:54:WU03:FS00:0xa7:Completed 15000 out of 62500 steps (24%)
09:35:34:WU03:FS00:0xa7:Completed 15625 out of 62500 steps (25%)
09:35:57:60:127.0.0.1:New Web connection
09:36:14:WU03:FS00:0xa7:Completed 16250 out of 62500 steps (26%)
09:36:55:WU03:FS00:0xa7:Completed 16875 out of 62500 steps (27%)
09:37:34:WU03:FS00:0xa7:Completed 17500 out of 62500 steps (28%)
09:38:14:WU03:FS00:0xa7:Completed 18125 out of 62500 steps (29%)
09:38:54:WU03:FS00:0xa7:Completed 18750 out of 62500 steps (30%)
09:39:34:WU03:FS00:0xa7:Completed 19375 out of 62500 steps (31%)
09:40:13:WU03:FS00:0xa7:Completed 20000 out of 62500 steps (32%)
09:40:22:FS00:Paused
09:40:22:FS01:Paused
09:40:22:FS00:Shutting core down
09:40:23:WU03:FS00:0xa7:WARNING:Console control signal 1 on PID 9016
09:40:23:WU03:FS00:0xa7:Exiting, please wait. . .
09:40:25:WU03:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:40:25:WU03:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:41:23:Removing old file 'configs/config-20200322-144122.xml'
09:41:23:Saving configuration to config.xml
09:41:23:<config>
09:41:23:  <!-- Slot Control -->
09:41:23:  <power v='FULL'/>
09:41:23:
09:41:23:  <!-- User Information -->
09:41:23:  <team v='40051'/>
09:41:23:  <user v='eldridgep'/>
09:41:23:
09:41:23:  <!-- Folding Slots -->
09:41:23:  <slot id='0' type='CPU'>
09:41:23:    <paused v='true'/>
09:41:23:  </slot>
09:41:23:  <slot id='1' type='GPU'>
09:41:23:  </slot>
09:41:23:</config>
09:44:22:FS00:Unpaused
09:44:22:FS01:Unpaused
09:44:22:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
09:44:22:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
09:44:22:WU02:FS01:Connecting to 13.82.98.119:8080
09:44:22:WU01:FS01:Connecting to 65.254.110.245:8080
09:44:22:WU03:FS00:Starting
09:44:22:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 11160 -checkpoint 15 -np 11
09:44:22:WU03:FS00:Started FahCore on PID 13244
09:44:22:WU03:FS00:Core PID:8276
09:44:22:WU03:FS00:FahCore 0xa7 started
09:44:23:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
09:44:23:WU02:FS01:Trying to send results to collection server
09:44:23:WU02:FS01:Uploading 271.26MiB to 52.224.109.74
09:44:23:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:44:23:WU02:FS01:Connecting to 52.224.109.74:8080
09:44:23:WU01:FS01:Connecting to 18.218.241.186:80
09:44:23:WU03:FS00:0xa7:*********************** Log Started 2020-04-11T09:44:22Z ***********************
09:44:23:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:44:23:WU03:FS00:0xa7:       Type: 0xa7
09:44:23:WU03:FS00:0xa7:       Core: Gromacs
09:44:23:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 13244 -checkpoint 15 -np
09:44:23:WU03:FS00:0xa7:             11
09:44:23:WU03:FS00:0xa7:************************************ CBang *************************************
09:44:23:WU03:FS00:0xa7:       Date: Oct 26 2019
09:44:23:WU03:FS00:0xa7:       Time: 01:38:25
09:44:23:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:44:23:WU03:FS00:0xa7:     Branch: master
09:44:23:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:44:23:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:44:23:WU03:FS00:0xa7:   Platform: win32 10
09:44:23:WU03:FS00:0xa7:       Bits: 64
09:44:23:WU03:FS00:0xa7:       Mode: Release
09:44:23:WU03:FS00:0xa7:************************************ System ************************************
09:44:23:WU03:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
09:44:23:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:44:23:WU03:FS00:0xa7:       CPUs: 12
09:44:23:WU03:FS00:0xa7:     Memory: 15.95GiB
09:44:23:WU03:FS00:0xa7:Free Memory: 12.15GiB
09:44:23:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:44:23:WU03:FS00:0xa7: OS Version: 6.2
09:44:23:WU03:FS00:0xa7:Has Battery: false
09:44:23:WU03:FS00:0xa7: On Battery: false
09:44:23:WU03:FS00:0xa7: UTC Offset: 1
09:44:23:WU03:FS00:0xa7:        PID: 8276
09:44:23:WU03:FS00:0xa7:        CWD: C:\Users\Phil\AppData\Roaming\FAHClient\work
09:44:23:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:44:23:WU03:FS00:0xa7:    Version: 0.0.18
09:44:23:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:44:23:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:44:23:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:44:23:WU03:FS00:0xa7:       Time: 01:52:30
09:44:23:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:44:23:WU03:FS00:0xa7:************************************ Build *************************************
09:44:23:WU03:FS00:0xa7:       SIMD: avx_256
09:44:23:WU03:FS00:0xa7:********************************************************************************
09:44:23:WU03:FS00:0xa7:Project: 13872 (Run 0, Clone 3644, Gen 103)
09:44:23:WU03:FS00:0xa7:Unit: 0x000000700d5262775e7bbb043e757165
09:44:23:WU03:FS00:0xa7:Digital signatures verified
09:44:23:WU03:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
09:44:23:WU03:FS00:0xa7:Calling: mdrun -s frame103.tpr -o frame103.trr -x frame103.xtc -e frame103.edr -cpi state.cpt -cpt 15 -nt 10
09:44:23:WU03:FS00:0xa7:Steps: first=6500000 total=62500
09:44:25:WU03:FS00:0xa7:Completed 20152 out of 62500 steps (32%)
09:44:28:Removing old file 'configs/config-20200322-144223.xml'
09:44:28:Saving configuration to config.xml
09:44:28:<config>
09:44:28:  <!-- Slot Control -->
09:44:28:  <power v='FULL'/>
09:44:28:
09:44:28:  <!-- User Information -->
09:44:28:  <team v='40051'/>
09:44:28:  <user v='eldridgep'/>
09:44:28:
09:44:28:  <!-- Folding Slots -->
09:44:28:  <slot id='0' type='CPU'/>
09:44:28:  <slot id='1' type='GPU'/>
09:44:28:</config>
09:44:28:ERROR:WU02:FS01:Exception: Transfer failed
09:44:28:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:44:28:ERROR:WU01:FS01:Exception: Could not get an assignment
09:44:55:WU03:FS00:0xa7:Completed 20625 out of 62500 steps (33%)
09:45:34:WU03:FS00:0xa7:Completed 21250 out of 62500 steps (34%)
09:45:59:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
09:45:59:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
09:45:59:WU02:FS01:Connecting to 13.82.98.119:8080
09:45:59:WU01:FS01:Connecting to 65.254.110.245:8080
09:45:59:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
09:45:59:WU02:FS01:Trying to send results to collection server
09:45:59:WU02:FS01:Uploading 271.26MiB to 52.224.109.74
09:45:59:WU02:FS01:Connecting to 52.224.109.74:8080
09:46:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:46:00:WU01:FS01:Connecting to 18.218.241.186:80
09:46:00:ERROR:WU02:FS01:Exception: Transfer failed
09:46:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:46:00:ERROR:WU01:FS01:Exception: Could not get an assignment
09:46:14:WU03:FS00:0xa7:Completed 21875 out of 62500 steps (35%)
09:46:54:WU03:FS00:0xa7:Completed 22500 out of 62500 steps (36%)
09:47:34:WU03:FS00:0xa7:Completed 23125 out of 62500 steps (37%)
09:48:14:WU03:FS00:0xa7:Completed 23750 out of 62500 steps (38%)
09:48:36:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
09:48:36:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
09:48:36:WU02:FS01:Connecting to 13.82.98.119:8080
09:48:36:WU01:FS01:Connecting to 65.254.110.245:8080
09:48:37:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
09:48:37:WU02:FS01:Trying to send results to collection server
09:48:37:WU02:FS01:Uploading 271.26MiB to 52.224.109.74
09:48:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:48:37:WU02:FS01:Connecting to 52.224.109.74:8080
09:48:37:WU01:FS01:Connecting to 18.218.241.186:80
09:48:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:48:37:ERROR:WU01:FS01:Exception: Could not get an assignment
09:48:38:ERROR:WU02:FS01:Exception: Transfer failed
09:48:53:WU03:FS00:0xa7:Completed 24375 out of 62500 steps (39%)
09:49:33:WU03:FS00:0xa7:Completed 25000 out of 62500 steps (40%)
09:50:13:WU03:FS00:0xa7:Completed 25625 out of 62500 steps (41%)
Please note that the URL posted takes me to the main site, not a picture :( I would need to see what the system configuration is so please reload the log and paste the initial section which would be something like this:
*********************** Log Started 2020-04-11T03:29:02Z ***********************
03:29:02:************************* Folding@home Client *************************
03:29:02:        Website: https://foldingathome.org/
03:29:02:      Copyright: (c) 2009-2018 foldingathome.org
03:29:02:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:29:02:           Args:
03:29:02:         Config: C:\Users\PantherX-H\AppData\Roaming\FAHClient\config.xml
03:29:02:******************************** Build ********************************
03:29:02:        Version: 7.5.1
03:29:02:           Date: May 11 2018
03:29:02:           Time: 13:06:32
03:29:02:     Repository: Git
03:29:02:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:29:02:         Branch: master
03:29:02:       Compiler: Visual C++ 2008
03:29:02:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:29:02:       Platform: win32 10
03:29:02:           Bits: 32
03:29:02:           Mode: Release
03:29:02:******************************* System ********************************
03:29:02:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:29:02:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:29:02:           CPUs: 8
03:29:02:         Memory: 31.94GiB
03:29:02:    Free Memory: 27.89GiB
03:29:02:        Threads: WINDOWS_THREADS
03:29:02:     OS Version: 6.2
03:29:02:    Has Battery: false
03:29:02:     On Battery: false
03:29:02:     UTC Offset: 12
03:29:02:            PID: 1532
03:29:02:            CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient
03:29:02:             OS: Windows 10 Enterprise
03:29:02:        OS Arch: AMD64
03:29:02:           GPUs: 1
03:29:02:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
03:29:02:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
03:29:02:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
03:29:02:  Win32 Service: false
03:29:02:***********************************************************************
03:29:02:<config>
03:29:02:  <!-- Network -->
03:29:02:  <proxy v=':8080'/>
03:29:02:
03:29:02:  <!-- Slot Control -->
03:29:02:  <power v='full'/>
03:29:02:
03:29:02:  <!-- User Information -->
03:29:02:  <passkey v='********************************'/>
03:29:02:  <team v='69411'/>
03:29:02:  <user v='PantherX'/>
03:29:02:
03:29:02:  <!-- Folding Slots -->
03:29:02:  <slot id='1' type='GPU'>
03:29:02:    <next-unit-percentage v='100'/>
03:29:02:    <pause-on-start v='true'/>
03:29:02:  </slot>
03:29:02:</config>
03:29:02:Trying to access database...
03:29:02:Successfully acquired database lock
03:29:02:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
03:30:05:FS01:Unpaused
03:30:05:WU01:FS01:Starting
03:30:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PantherX-H\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 1532 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:30:05:WU01:FS01:Started FahCore on PID 8052
03:30:06:WU01:FS01:Core PID:1800
03:30:06:WU01:FS01:FahCore 0x22 started
03:30:06:WU01:FS01:0x22:*********************** Log Started 2020-04-11T03:30:06Z ***********************
03:30:06:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:30:06:WU01:FS01:0x22:       Type: 0x22
03:30:06:WU01:FS01:0x22:       Core: Core22
03:30:06:WU01:FS01:0x22:    Website: https://foldingathome.org/
03:30:06:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:30:06:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:30:06:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:30:06:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8052 -checkpoint 15
03:30:06:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:30:06:WU01:FS01:0x22:             0 -gpu 0
03:30:06:WU01:FS01:0x22:     Config: <none>
03:30:06:WU01:FS01:0x22:************************************ Build *************************************
03:30:06:WU01:FS01:0x22:    Version: 0.0.2
03:30:06:WU01:FS01:0x22:       Date: Dec 6 2019
03:30:06:WU01:FS01:0x22:       Time: 21:30:31
03:30:06:WU01:FS01:0x22: Repository: Git
03:30:06:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:30:06:WU01:FS01:0x22:     Branch: HEAD
03:30:06:WU01:FS01:0x22:   Compiler: Visual C++ 2008
03:30:06:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:30:06:WU01:FS01:0x22:   Platform: win32 10
03:30:06:WU01:FS01:0x22:       Bits: 64
03:30:06:WU01:FS01:0x22:       Mode: Release
03:30:06:WU01:FS01:0x22:************************************ System ************************************
03:30:06:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:30:06:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:30:06:WU01:FS01:0x22:       CPUs: 8
03:30:06:WU01:FS01:0x22:     Memory: 31.94GiB
03:30:06:WU01:FS01:0x22:Free Memory: 27.29GiB
03:30:06:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
03:30:06:WU01:FS01:0x22: OS Version: 6.2
03:30:06:WU01:FS01:0x22:Has Battery: false
03:30:06:WU01:FS01:0x22: On Battery: false
03:30:06:WU01:FS01:0x22: UTC Offset: 12
03:30:06:WU01:FS01:0x22:        PID: 1800
03:30:06:WU01:FS01:0x22:        CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient\work
03:30:06:WU01:FS01:0x22:         OS: Windows 10 Pro
03:30:06:WU01:FS01:0x22:    OS Arch: AMD64
03:30:06:WU01:FS01:0x22:********************************************************************************
03:30:06:WU01:FS01:0x22:Project: 11761 (Run 0, Clone 7538, Gen 10)
03:30:06:WU01:FS01:0x22:Unit: 0x0000001a80fccb0a5e7001958353bbf1
03:30:06:WU01:FS01:0x22:Digital signatures verified
03:30:06:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:30:06:WU01:FS01:0x22:Version 0.0.2
03:30:06:WU01:FS01:0x22:  Found a checkpoint file
03:30:11:WU01:FS01:0x22:Completed 1050000 out of 2000000 steps (52%)
AFAIK, I am able to get WUs within few hours of uploading a completed WU.
eldridgep
Post by eldridgep »
No problem mate see below. Essential Ryzen 5 2600 and AMD RX 480 single GPU on this one.
I'm getting new CPU WU's no problem, havent had a GPU one since this issue AFAIK, the completed one is just not uploading currently.
*********************** Log Started 2020-04-10T22:48:41Z ***********************
22:48:41:************************* Folding@home Client *************************
22:48:41:        Website: https://foldingathome.org/
22:48:41:      Copyright: (c) 2009-2018 foldingathome.org
22:48:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:48:41:           Args:
22:48:41:         Config: C:\Users\Phil\AppData\Roaming\FAHClient\config.xml
22:48:41:******************************** Build ********************************
22:48:41:        Version: 7.5.1
22:48:41:           Date: May 11 2018
22:48:41:           Time: 13:06:32
22:48:41:     Repository: Git
22:48:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:48:41:         Branch: master
22:48:41:       Compiler: Visual C++ 2008
22:48:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:48:41:       Platform: win32 10
22:48:41:           Bits: 32
22:48:41:           Mode: Release
22:48:41:******************************* System ********************************
22:48:41:            CPU: AMD Ryzen 5 2600 Six-Core Processor
22:48:41:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:48:41:           CPUs: 12
22:48:41:         Memory: 15.95GiB
22:48:41:    Free Memory: 13.10GiB
22:48:41:        Threads: WINDOWS_THREADS
22:48:41:     OS Version: 6.2
22:48:41:    Has Battery: false
22:48:41:     On Battery: false
22:48:41:     UTC Offset: 1
22:48:41:            PID: 11160
22:48:41:            CWD: C:\Users\Phil\AppData\Roaming\FAHClient
22:48:41:             OS: Windows 10 Enterprise
22:48:41:        OS Arch: AMD64
22:48:41:           GPUs: 1
22:48:41:          GPU 0: Bus:6 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
22:48:41:                 470/480/570/580]
22:48:41:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:48:41:                 specified module could not be found.
22:48:41:
22:48:41:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
22:48:41:  Win32 Service: false
22:48:41:***********************************************************************
22:48:41:<config>
22:48:41:  <!-- Slot Control -->
22:48:41:  <power v='FULL'/>
22:48:41:
22:48:41:  <!-- User Information -->
22:48:41:  <team v='40051'/>
22:48:41:  <user v='eldridgep'/>
22:48:41:
22:48:41:  <!-- Folding Slots -->
22:48:41:  <slot id='0' type='CPU'/>
22:48:41:  <slot id='1' type='GPU'/>
22:48:41:</config>
22:48:41:Trying to access database...
22:48:41:Successfully acquired database lock
22:48:41:Enabled folding slot 00: READY cpu:11
22:48:41:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
22:48:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1750 gen:2 core:0x22 unit:0x000000020d5262775e84c8a53e796e45
22:48:41:WU02:FS01:Uploading 271.26MiB to 13.82.98.119
22:48:41:WU00:FS00:Starting
22:48:41:WU02:FS01:Connecting to 13.82.98.119:8080
22:48:41:WARNING:WU00:FS00:AS lowered CPUs from 11 to 9
22:48:41:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 11160 -checkpoint 15 -np 9
22:48:41:WU00:FS00:Started FahCore on PID 12424
22:48:41:WU00:FS00:Core PID:12524
22:48:41:WU00:FS00:FahCore 0xa7 started
22:48:41:WU00:FS00:0xa7:*********************** Log Started 2020-04-10T22:48:41Z ***********************
22:48:41:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:48:41:WU00:FS00:0xa7:       Type: 0xa7
22:48:41:WU00:FS00:0xa7:       Core: Gromacs
22:48:41:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12424 -checkpoint 15 -np
22:48:41:WU00:FS00:0xa7:             9
22:48:41:WU00:FS00:0xa7:************************************ CBang *************************************
22:48:41:WU00:FS00:0xa7:       Date: Oct 26 2019
22:48:41:WU00:FS00:0xa7:       Time: 01:38:25
22:48:41:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:48:41:WU00:FS00:0xa7:     Branch: master
22:48:41:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:48:41:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:48:41:WU00:FS00:0xa7:   Platform: win32 10
22:48:41:WU00:FS00:0xa7:       Bits: 64
22:48:41:WU00:FS00:0xa7:       Mode: Release
22:48:41:WU00:FS00:0xa7:************************************ System ************************************
22:48:41:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
22:48:41:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:48:41:WU00:FS00:0xa7:       CPUs: 12
22:48:41:WU00:FS00:0xa7:     Memory: 15.95GiB
22:48:41:WU00:FS00:0xa7:Free Memory: 12.41GiB
22:48:41:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:48:41:WU00:FS00:0xa7: OS Version: 6.2
22:48:41:WU00:FS00:0xa7:Has Battery: false
22:48:41:WU01:FS01:Connecting to 65.254.110.245:8080
22:48:41:WU00:FS00:0xa7: On Battery: false
22:48:41:WU00:FS00:0xa7: UTC Offset: 1
22:48:41:WU00:FS00:0xa7:        PID: 12524
22:48:41:WU00:FS00:0xa7:        CWD: C:\Users\Phil\AppData\Roaming\FAHClient\work
22:48:41:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:48:41:WU00:FS00:0xa7:    Version: 0.0.18
22:48:41:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:48:41:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:48:41:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:48:41:WU00:FS00:0xa7:       Time: 01:52:30
22:48:41:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:48:41:WU00:FS00:0xa7:************************************ Build *************************************
22:48:41:WU00:FS00:0xa7:       SIMD: avx_256
22:48:41:WU00:FS00:0xa7:********************************************************************************
22:48:41:WU00:FS00:0xa7:Project: 16411 (Run 2982, Clone 3, Gen 21)
22:48:41:WU00:FS00:0xa7:Unit: 0x00000016a8f5c67d5e8771fa2b1cd1c1
22:48:41:WU00:FS00:0xa7:Digital signatures verified
22:48:41:WU00:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -x frame21.xtc -cpi state.cpt -cpt 15 -nt 9
22:48:41:WU00:FS00:0xa7:Steps: first=5250000 total=250000
22:48:42:WU00:FS00:0xa7:Completed 188032 out of 250000 steps (75%)
22:48:47:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
Your GPU which is AMD RX 480 supports OpenCL 2. and Double Precision which means that it is supported by F@H. I have read some donors are unable to get GPU WUs while others are. I can't find any common grounds yet.
I also noticed that you're not using a passkey. If you don't care about points, that's okay. However, if you do keep track, then it is recommended that you get yourself a passkey to get the bonus points once you qualify for it: https://foldingathome.org/support/faq/points/passkey/
eldridgep
Post by eldridgep »
Cheers mate will look into passkey, not had any issues getting GPU projects before well they were scarce for a while but no real issues completed dozens of them so far so it's not the rig thats preventing it.
First real issue I've had still getting CPU projects by the dozen but no GPU ones and I've a thrid work queue:
00 Running CPU projects
01 Download (looking for GPU projects?)
02 Send which is the stuck one with a permanent ETA of 8 hours 48m been like that since 9th April at 12:31 Zulu time
Happy to hang on a while but is there way to purge units that won't send? Have tried pausing/unpausing and rebooting the machine already.
WU02 seems to have failed on your system and for some reason, the upload size is massive, ~300 MBs. I will check to see if that's the expected case or not. Once I know the answer, will update you. If the Expiration date has been reached, the WU will automatically be deleted from your system. Here's the information in your log:
WU01 is the AMD GPU trying to get a WU to fold.
WU00 is happily folding along.
eldridgep
Post by eldridgep »
Cheers mate that's what I thought, will wait for a response.
appepi
Hardware configuration: HP Z600 (5) HP Z800 (3) HP Z440 (3) HP Z4G4 (3) ASUS Turbo GTX 1060, 1070, 1080, RTX 2060 (3) Dell GTX 1080 NVIDIA P1000 (3)
Post by appepi »
A somewhat different different issue - HP Z440 with Folding (because of high temps and 24/7 running) given CPU affinity to half (3 cores x 2 threads =6) of Xeon E5-1650V3) and Quadro K620. Has been Folding fine for weeks but drop in output today led me to check and I found a CPU project completed without error, sent OK, then log says server didn't like the results it and it was dumped. No WU assignment since though GPU WU still running. Is the problem at your end or mine?
01:15:21:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
01:15:23:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
01:15:23:WU00:FS00:0xa7:Saving result file frame14.edr
01:15:23:WU00:FS00:0xa7:Saving result file frame14.trr
01:15:23:WU00:FS00:0xa7:Saving result file frame14.xtc
01:15:23:WU00:FS00:0xa7:Saving result file md.log
01:15:23:WU00:FS00:0xa7:Saving result file science.log
01:15:23:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:15:24:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:15:24:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13851 run:0 clone:31145 gen:14 core:0xa7 unit:0x0000001a287234c95e78838c1a5555b5
01:15:24:WU00:FS00:Uploading 2.48MiB to 40.114.52.201
01:15:24:WU00:FS00:Connecting to 40.114.52.201:8080
01:15:25:WU02:FS00:Connecting to 65.254.110.245:8080
01:15:25:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:15:25:WU02:FS00:Connecting to 18.218.241.186:80
01:15:26:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:15:26:ERROR:WU02:FS00:Exception: Could not get an assignment
01:15:44:WU00:FS00:Upload complete
01:15:45:WU00:FS00:Server responded WORK_QUIT (404)
01:15:45:WARNING:WU00:FS00:Server did not like results, dumping
01:15:45:WU00:FS00:Cleaning up
>>'??Whatsup :shock: ?
Welcome to the F@H Forum appepi,
That's an indication that the completed WU didn't successfully pass the verification test done on the F@H Servers. It can be due to transfer corruption or some other reasons.
appepi
Post by appepi »
Thanx Pantherx, The Z440 in my post has since completed another CPU project without problems, so for the moment I exclude CPU problems.
09:04:00:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:04:01:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:04:01:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16423 run:525 clone:0 gen:15 core:0xa7 unit:0x0000000f96880e6e5e8a8e7b3bf4f9f1
09:04:01:WU02:FS00:Uploading 1.85MiB to 150.136.14.110
09:04:01:WU02:FS00:Connecting to 150.136.14.110:8080
09:04:03:WU00:FS00:Connecting to 65.254.110.245:8080
09:04:18:WU02:FS00:Upload complete
09:04:18:WU02:FS00:Server responded WORK_ACK (400)
09:04:18:WU02:FS00:Final credit estimate, 1307.00 points
09:04:18:WU02:FS00:Cleaning up
That being said, if we assume transfer corruption is the most likely problem, and given that the file is small, why doesn't the server try a re-transfer rather than dumping hours and hours of work? Or why not a hash to check transfer?
appepi wrote:...if we assume transfer corruption is the most likely problem, and given that the file is small, why doesn't the server try a re-transfer rather than dumping hours and hours of work? Or why not a hash to check transfer?
In this case, the file size was small but in other cases, it can be as large as 50 MBs. However, the decision to not re-try would be a developmental one. I don't know the reason behind that decision.
