GPU WU Crashes every time at around 3%
peterjammo
Post by peterjammo »
I've picked up 3 wu only since setting up. Each has crashed at around 3% with same error messages
19:51:58:WU00:FS01:Connecting to 65.254.110.245:8080
19:51:59:WU00:FS01:Assigned to work server 140.163.4.231
19:51:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress Pro [Radeon HD 5800/6850] from 140.163.4.231
19:51:59:WU00:FS01:Connecting to 140.163.4.231:8080
19:52:42:WU00:FS01:Downloading 4.53MiB
19:52:48:WU00:FS01:Download 28.98%
19:52:52:WU00:FS01:Download complete
19:52:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:8133 gen:20 core:0x22 unit:0x000000278ca304e75e6bb237ef0e0007
19:52:53:WU00:FS01:Starting
19:52:53:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 10032 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:52:53:WU00:FS01:Started FahCore on PID 8600
19:52:54:WU00:FS01:Core PID:4636
19:52:54:WU00:FS01:FahCore 0x22 started
19:52:55:WU00:FS01:0x22:*********************** Log Started 2020-04-10T19:52:55Z ***********************
19:52:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:52:55:WU00:FS01:0x22:       Type: 0x22
19:52:55:WU00:FS01:0x22:       Core: Core22
19:52:55:WU00:FS01:0x22:    Website: https://foldingathome.org/
19:52:55:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:52:55:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:52:55:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:52:55:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8600 -checkpoint 15
19:52:55:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:52:55:WU00:FS01:0x22:     Config: <none>
19:52:55:WU00:FS01:0x22:************************************ Build *************************************
19:52:55:WU00:FS01:0x22:    Version: 0.0.2
19:52:55:WU00:FS01:0x22:       Date: Dec 6 2019
19:52:55:WU00:FS01:0x22:       Time: 21:30:31
19:52:55:WU00:FS01:0x22: Repository: Git
19:52:55:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
19:52:55:WU00:FS01:0x22:     Branch: HEAD
19:52:55:WU00:FS01:0x22:   Compiler: Visual C++ 2008
19:52:55:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:52:55:WU00:FS01:0x22:   Platform: win32 10
19:52:55:WU00:FS01:0x22:       Bits: 64
19:52:55:WU00:FS01:0x22:       Mode: Release
19:52:55:WU00:FS01:0x22:************************************ System ************************************
19:52:55:WU00:FS01:0x22:        CPU: AMD Phenom(tm) II X4 955 Processor
19:52:55:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
19:52:55:WU00:FS01:0x22:       CPUs: 4
19:52:55:WU00:FS01:0x22:     Memory: 8.00GiB
19:52:55:WU00:FS01:0x22:Free Memory: 5.20GiB
19:52:55:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
19:52:55:WU00:FS01:0x22: OS Version: 6.2
19:52:55:WU00:FS01:0x22:Has Battery: false
19:52:55:WU00:FS01:0x22: On Battery: false
19:52:55:WU00:FS01:0x22: UTC Offset: 1
19:52:55:WU00:FS01:0x22:        PID: 4636
19:52:55:WU00:FS01:0x22:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
19:52:55:WU00:FS01:0x22:         OS: Windows 10 Home
19:52:55:WU00:FS01:0x22:    OS Arch: AMD64
19:52:55:WU00:FS01:0x22:********************************************************************************
19:52:55:WU00:FS01:0x22:Project: 11748 (Run 0, Clone 8133, Gen 20)
19:52:55:WU00:FS01:0x22:Unit: 0x000000278ca304e75e6bb237ef0e0007
19:52:55:WU00:FS01:0x22:Reading tar file core.xml
19:52:55:WU00:FS01:0x22:Reading tar file integrator.xml
19:52:55:WU00:FS01:0x22:Reading tar file state.xml
19:52:57:WU00:FS01:0x22:Reading tar file system.xml
19:52:57:WU00:FS01:0x22:Digital signatures verified
19:52:57:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:52:57:WU00:FS01:0x22:Version 0.0.2
19:53:48:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
19:53:48:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:55:23:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:55:23:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:57:13:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:57:13:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:59:04:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:59:04:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:59:04:WU00:FS01:0x22:ERROR:114: Max Retries Reached
19:59:04:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
19:59:04:WU00:FS01:0x22:Saving result file badstate-0.xml
19:59:11:WU00:FS01:0x22:Saving result file badstate-1.xml
19:59:20:WU00:FS01:0x22:Saving result file badstate-2.xml
19:59:26:WU00:FS01:0x22:Saving result file checkpt.crc
19:59:27:WU00:FS01:0x22:Saving result file science.log
19:59:27:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:59:28:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:59:28:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11748 run:0 clone:8133 gen:20 core:0x22 unit:0x000000278ca304e75e6bb237ef0e0007
19:59:28:WU00:FS01:Uploading 18.79KiB to 140.163.4.231
19:59:28:WU00:FS01:Connecting to 140.163.4.231:8080
HW Monitor Showing temp of 52c, 1.088V, Fans 2353rpm, Graphics 725MHz, Memory 1000MHz, GPU 100%, Memory 56% at time of crash. All figures more or less identical to max figures.
Any suggestions how to proceed?
Re: GPU WU Crashes every time at around 3%
The first 200 lines of your log show how your PC is configured, what CPUs and GPUs the software thinks it is running on, what OS, which Drivers etc.
It also shows configurations you may have chosen.
If we could see that part of the log, we would know what the PC thinks is in the PC.
NuovaApe
Post by NuovaApe »
I'm chipping in due to "Fans 2353rpm". 2k-ish rpm is typical max for most PC fans. Like Star Trek, they just canny go any faster Captain!
I've seen Bad State detected/Particle coordinate is nan when I first started FAH'ing.
It was a heat problem. My aluminium tower case was roasting hot.
I took a side panel off, pointed a household fan (14") at my mobo/GPU on full blast and the problem went away. Problem proved.
Long story short I upgraded case/fans/GPU/mobo. The old tower case was from an era when 200W was a lot.
Obviously a tower case is vertical. My old case had fans at the bottom. Heat rises. My new tower has more front "push" fans than pull. That way I know cooler air gets forced front to back across my mobo surface, as well as pushing hot GPU exhaust out the back door.
Having stronger pull (exit) fans means ambient air can be sucked in through any nearest hole in the case, typically the PSU grating. That doesn't give great front to back mobo cooling.
Thermodynamics ain't no different to queue theory; if more goes into a system that goes out then you're stuffed. Well, it did me.
NuovaApe wrote:...Having stronger pull (exit) fans means ambient air can be sucked in through any nearest hole in the case, typically the PSU grating...
I personally like to have a positive air pressure in my case than negative. Reason is that with positive pressure, dust will not be sucked into my system from various gaps. All my air will enter through the air filters which means less maintenance and more folding.
peterjammo
JimboPalmer wrote:The first 200 lines of your log show how your PC is configured, what CPUs and GPUs the software thinks it is running on, what OS, which Drivers etc.
I had it set to only show the GPU entries on the log, which I think removed that from the log. This is the start of an earlier log.
*********************** Log Started 2020-04-09T13:13:37Z ***********************
13:13:37:************************* Folding@home Client *************************
13:13:37:        Website: https://foldingathome.org/
13:13:37:      Copyright: (c) 2009-2018 foldingathome.org
13:13:37:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:13:37:           Args:
13:13:37:         Config: C:\Users\Ryan\AppData\Roaming\FAHClient\config.xml
13:13:37:******************************** Build ********************************
13:13:37:        Version: 7.5.1
13:13:37:           Date: May 11 2018
13:13:37:           Time: 13:06:32
13:13:37:     Repository: Git
13:13:37:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:13:37:         Branch: master
13:13:37:       Compiler: Visual C++ 2008
13:13:37:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:13:37:       Platform: win32 10
13:13:37:           Bits: 32
13:13:37:           Mode: Release
13:13:37:******************************* System ********************************
13:13:37:            CPU: AMD Phenom(tm) II X4 955 Processor
13:13:37:         CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
13:13:37:           CPUs: 4
13:13:37:         Memory: 8.00GiB
13:13:37:    Free Memory: 5.75GiB
13:13:37:        Threads: WINDOWS_THREADS
13:13:37:     OS Version: 6.2
13:13:37:    Has Battery: false
13:13:37:     On Battery: false
13:13:37:     UTC Offset: 1
13:13:37:            PID: 11320
13:13:37:            CWD: C:\Users\Ryan\AppData\Roaming\FAHClient
13:13:37:             OS: Windows 10 Home
13:13:37:        OS Arch: AMD64
13:13:37:           GPUs: 1
13:13:37:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Cypress Pro [Radeon HD 5800/6850]
13:13:37:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:13:37:                 specified module could not be found.
13:13:37:
13:13:37:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.12
13:13:37:  Win32 Service: false
13:13:37:***********************************************************************
13:13:37:<config>
13:13:37:  <!-- Folding Core -->
13:13:37:  <core-priority v='low'/>
13:13:37:
13:13:37:  <!-- Network -->
13:13:37:  <proxy v=':8080'/>
13:13:37:
13:13:37:  <!-- Slot Control -->
13:13:37:  <power v='LIGHT'/>
13:13:37:
13:13:37:  <!-- User Information -->
13:13:37:  <user v='PeterJammo'/>
13:13:37:
13:13:37:  <!-- Folding Slots -->
13:13:37:  <slot id='0' type='CPU'/>
13:13:37:  <slot id='1' type='GPU'/>
13:13:37:</config>
13:13:37:Trying to access database...
13:13:37:Successfully acquired database lock
13:13:37:Enabled folding slot 00: READY cpu:1
13:13:37:Enabled folding slot 01: PAUSED gpu:0:Cypress Pro [Radeon HD 5800/6850] (waiting for idle)
13:13:38:WU02:FS00:Starting
13:13:38:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11320 -checkpoint 15 -np 1
13:13:38:WU02:FS00:Started FahCore on PID 11780
13:13:41:WU02:FS00:Core PID:11164
13:13:41:WU02:FS00:FahCore 0xa7 started
13:13:42:WU02:FS00:0xa7:*********************** Log Started 2020-04-09T13:13:42Z ***********************
13:13:42:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:13:42:WU02:FS00:0xa7:       Type: 0xa7
13:13:42:WU02:FS00:0xa7:       Core: Gromacs
13:13:42:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 11780 -checkpoint 15 -np
13:13:42:WU02:FS00:0xa7:             1
13:13:42:WU02:FS00:0xa7:************************************ CBang *************************************
13:13:42:WU02:FS00:0xa7:       Date: Oct 26 2019
13:13:42:WU02:FS00:0xa7:       Time: 01:38:35
13:13:42:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:13:42:WU02:FS00:0xa7:     Branch: master
13:13:42:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
13:13:42:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:13:42:WU02:FS00:0xa7:   Platform: win32 10
13:13:42:WU02:FS00:0xa7:       Bits: 64
13:13:42:WU02:FS00:0xa7:       Mode: Release
13:13:42:WU02:FS00:0xa7:************************************ System ************************************
13:13:42:WU02:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 955 Processor
13:13:42:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
13:13:42:WU02:FS00:0xa7:       CPUs: 4
13:13:42:WU02:FS00:0xa7:     Memory: 8.00GiB
13:13:42:WU02:FS00:0xa7:Free Memory: 5.40GiB
13:13:42:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
13:13:42:WU02:FS00:0xa7: OS Version: 6.2
13:13:42:WU02:FS00:0xa7:Has Battery: false
13:13:42:WU02:FS00:0xa7: On Battery: false
13:13:42:WU02:FS00:0xa7: UTC Offset: 1
13:13:42:WU02:FS00:0xa7:        PID: 11164
13:13:42:WU02:FS00:0xa7:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
13:13:42:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
13:13:42:WU02:FS00:0xa7:    Version: 0.0.18
13:13:42:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:13:42:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:13:42:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
13:13:42:WU02:FS00:0xa7:       Time: 01:52:44
13:13:42:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:13:42:WU02:FS00:0xa7:************************************ Build *************************************
13:13:42:WU02:FS00:0xa7:       SIMD: sse2
13:13:42:WU02:FS00:0xa7:********************************************************************************
The priority slider had been set to medium to get the gpu to come off waiting for idle to, otherwise no changes that I can think of. If you need to see the start of the actual log which failed, can you tell me where to find the old logs in Win 10?
peterjammo wrote:...If you need to see the start of the actual log which failed, can you tell me where to find the old logs in Win 10?
On your system, it would be here:
C:\Users\Ryan\AppData\Roaming\FAHClient\logs
I noticed that you're not using a Passkey. That is find if you're not concerned about points. However, if you do keep track of your points, then please get a passkey and you will get bonus points once you qualify for it: https://apps.foldingathome.org/getpasskey
peterjammo
On the heat stuff, the gpu has a freshly cleaned and pasted twin fan MSI Frozr ii cooler. The fan speed mentioned is for the two gpu fans. CPU fins are running between 1950 and 2070rpm, cpu temp maxes out at around 62c. As above GPU temp maxed out at 53c, wouldn't preclude any temp issues? Case is decent sized with a clean filtered rear bottom entry and a decent sized fan at the top of the rear. Intake air comes past the GPU first and past the cpu on the way out. Case and exit air isn't particularly warm.
HaloJones
Post by HaloJones »
Has this gpu ever folded successfully? I ask only because it is quite an old card and FAH is seriously hard work. It may simply be exposing that your card can't work accurately enough at the current work.
FAH uses double precision so the work is constantly being checked as it goes along. If it detects errors, it tries to recover but if it can't it's better to dump the unit and allocate it to someone else than to risk getting an inaccurate result.
It is ten years old, after all. To be frank, I'm surprised it's even still supported.
4070 super
peterjammo
Full log from start to crash.
*********************** Log Started 2020-04-10T19:23:42Z ***********************
19:23:42:************************* Folding@home Client *************************
19:23:42:        Website: https://foldingathome.org/
19:23:42:      Copyright: (c) 2009-2018 foldingathome.org
19:23:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:23:42:           Args:
19:23:42:         Config: C:\Users\Ryan\AppData\Roaming\FAHClient\config.xml
19:23:42:******************************** Build ********************************
19:23:42:        Version: 7.5.1
19:23:42:           Date: May 11 2018
19:23:42:           Time: 13:06:32
19:23:42:     Repository: Git
19:23:42:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:23:42:         Branch: master
19:23:42:       Compiler: Visual C++ 2008
19:23:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:23:42:       Platform: win32 10
19:23:42:           Bits: 32
19:23:42:           Mode: Release
19:23:42:******************************* System ********************************
19:23:42:            CPU: AMD Phenom(tm) II X4 955 Processor
19:23:42:         CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
19:23:42:           CPUs: 4
19:23:42:         Memory: 8.00GiB
19:23:42:    Free Memory: 6.14GiB
19:23:42:        Threads: WINDOWS_THREADS
19:23:42:     OS Version: 6.2
19:23:42:    Has Battery: false
19:23:42:     On Battery: false
19:23:42:     UTC Offset: 1
19:23:42:            PID: 10032
19:23:42:            CWD: C:\Users\Ryan\AppData\Roaming\FAHClient
19:23:42:             OS: Windows 10 Home
19:23:42:        OS Arch: AMD64
19:23:42:           GPUs: 1
19:23:42:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Cypress Pro [Radeon HD 5800/6850]
19:23:42:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:23:42:                 specified module could not be found.
19:23:42:
19:23:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.12
19:23:42:  Win32 Service: false
19:23:42:***********************************************************************
19:23:42:<config>
19:23:42:  <!-- Folding Core -->
19:23:42:  <core-priority v='low'/>
19:23:42:
19:23:42:  <!-- Network -->
19:23:42:  <proxy v=':8080'/>
19:23:42:
19:23:42:  <!-- User Information -->
19:23:42:  <user v='PeterJammo'/>
19:23:42:
19:23:42:  <!-- Folding Slots -->
19:23:42:  <slot id='0' type='CPU'>
19:23:42:    <cpus v='4'/>
19:23:42:    <paused v='true'/>
19:23:42:  </slot>
19:23:42:</config>
19:23:42:Trying to access database...
19:23:42:Successfully acquired database lock
19:23:42:Enabled folding slot 00: PAUSED cpu:4 (by user)
19:35:37:Adding folding slot 01: READY gpu:0:Cypress Pro [Radeon HD 5800/6850]
19:35:37:Saving configuration to config.xml
19:35:37:<config>
19:35:37:  <!-- Folding Core -->
19:35:37:  <core-priority v='low'/>
19:35:37:
19:35:37:  <!-- Network -->
19:35:37:  <proxy v=':8080'/>
19:35:37:
19:35:37:  <!-- User Information -->
19:35:37:  <user v='PeterJammo'/>
19:35:37:
19:35:37:  <!-- Folding Slots -->
19:35:37:  <slot id='0' type='CPU'>
19:35:37:    <cpus v='4'/>
19:35:37:    <paused v='true'/>
19:35:37:  </slot>
19:35:37:  <slot id='1' type='GPU'/>
19:35:37:</config>
19:35:37:WU00:FS01:Connecting to 65.254.110.245:8080
19:35:38:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:35:38:WU00:FS01:Connecting to 18.218.241.186:80
19:35:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:35:38:ERROR:WU00:FS01:Exception: Could not get an assignment
19:35:38:WU00:FS01:Connecting to 65.254.110.245:8080
19:35:39:WU00:FS01:Assigned to work server 128.252.203.10
19:35:39:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress Pro [Radeon HD 5800/6850] from 128.252.203.10
19:35:39:WU00:FS01:Connecting to 128.252.203.10:8080
19:35:49:FS00:Unpaused
19:35:49:WU01:FS00:Connecting to 65.254.110.245:8080
19:35:49:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:35:49:WU01:FS00:Connecting to 18.218.241.186:80
19:35:50:WU01:FS00:Assigned to work server 150.136.14.110
19:35:50:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 150.136.14.110
19:35:50:WU01:FS00:Connecting to 150.136.14.110:8080
19:35:50:WU01:FS00:Downloading 2.34MiB
19:35:52:WU01:FS00:Download complete
19:35:52:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16417 run:1536 clone:3 gen:38 core:0xa7 unit:0x0000002b96880e6e5e8a61d5a223f96c
19:35:52:WU01:FS00:Starting
19:35:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 10032 -checkpoint 15 -np 4
19:35:52:WU01:FS00:Started FahCore on PID 11620
19:35:54:WU01:FS00:Core PID:12240
19:35:54:WU01:FS00:FahCore 0xa7 started
19:35:54:Removing old file 'configs/config-20200404-101622.xml'
19:35:54:Saving configuration to config.xml
19:35:54:<config>
19:35:54:  <!-- Folding Core -->
19:35:54:  <core-priority v='low'/>
19:35:54:
19:35:54:  <!-- Network -->
19:35:54:  <proxy v=':8080'/>
19:35:54:
19:35:54:  <!-- User Information -->
19:35:54:  <user v='PeterJammo'/>
19:35:54:
19:35:54:  <!-- Folding Slots -->
19:35:54:  <slot id='0' type='CPU'>
19:35:54:    <cpus v='4'/>
19:35:54:  </slot>
19:35:54:  <slot id='1' type='GPU'/>
19:35:54:</config>
19:35:55:WU01:FS00:0xa7:*********************** Log Started 2020-04-10T19:35:54Z ***********************
19:35:55:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:35:55:WU01:FS00:0xa7:       Type: 0xa7
19:35:55:WU01:FS00:0xa7:       Core: Gromacs
19:35:55:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 11620 -checkpoint 15 -np
19:35:55:WU01:FS00:0xa7:             4
19:35:55:WU01:FS00:0xa7:************************************ CBang *************************************
19:35:55:WU01:FS00:0xa7:       Date: Oct 26 2019
19:35:55:WU01:FS00:0xa7:       Time: 01:38:35
19:35:55:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:35:55:WU01:FS00:0xa7:     Branch: master
19:35:55:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
19:35:55:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:35:55:WU01:FS00:0xa7:   Platform: win32 10
19:35:55:WU01:FS00:0xa7:       Bits: 64
19:35:55:WU01:FS00:0xa7:       Mode: Release
19:35:55:WU01:FS00:0xa7:************************************ System ************************************
19:35:55:WU01:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 955 Processor
19:35:55:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
19:35:55:WU01:FS00:0xa7:       CPUs: 4
19:35:55:WU01:FS00:0xa7:     Memory: 8.00GiB
19:35:55:WU01:FS00:0xa7:Free Memory: 5.11GiB
19:35:55:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
19:35:55:WU01:FS00:0xa7: OS Version: 6.2
19:35:55:WU01:FS00:0xa7:Has Battery: false
19:35:55:WU01:FS00:0xa7: On Battery: false
19:35:55:WU01:FS00:0xa7: UTC Offset: 1
19:35:55:WU01:FS00:0xa7:        PID: 12240
19:35:55:WU01:FS00:0xa7:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
19:35:55:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
19:35:55:WU01:FS00:0xa7:    Version: 0.0.18
19:35:55:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:35:55:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:35:55:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
19:35:55:WU01:FS00:0xa7:       Time: 01:52:44
19:35:55:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:35:55:WU01:FS00:0xa7:************************************ Build *************************************
19:35:55:WU01:FS00:0xa7:       SIMD: sse2
19:35:55:WU01:FS00:0xa7:********************************************************************************
19:35:55:WU01:FS00:0xa7:Project: 16417 (Run 1536, Clone 3, Gen 38)
19:35:55:WU01:FS00:0xa7:Unit: 0x0000002b96880e6e5e8a61d5a223f96c
19:35:55:WU01:FS00:0xa7:Reading tar file core.xml
19:35:55:WU01:FS00:0xa7:Reading tar file frame38.tpr
19:35:55:WU01:FS00:0xa7:Digital signatures verified
19:35:55:WU01:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -x frame38.xtc -cpt 15 -nt 4
19:35:55:WU01:FS00:0xa7:Steps: first=9500000 total=250000
19:35:57:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
19:36:00:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:36:00:WU00:FS01:Connecting to 128.252.203.10:80
19:36:09:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
19:36:38:WU00:FS01:Connecting to 65.254.110.245:8080
19:36:39:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:36:39:WU00:FS01:Connecting to 18.218.241.186:80
19:36:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:36:39:ERROR:WU00:FS01:Exception: Could not get an assignment
19:37:09:Removing old file 'configs/config-20200404-101723.xml'
19:37:09:Saving configuration to config.xml
19:37:09:<config>
19:37:09:  <!-- Folding Core -->
19:37:09:  <core-priority v='low'/>
19:37:09:
19:37:09:  <!-- Network -->
19:37:09:  <proxy v=':8080'/>
19:37:09:
19:37:09:  <!-- User Information -->
19:37:09:  <user v='PeterJammo'/>
19:37:09:
19:37:09:  <!-- Folding Slots -->
19:37:09:  <slot id='0' type='CPU'/>
19:37:09:  <slot id='1' type='GPU'/>
19:37:09:</config>
19:37:09:FS00:Shutting core down
19:37:09:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 12240
19:37:09:WU01:FS00:0xa7:Exiting, please wait. . .
19:37:11:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
19:37:11:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:37:12:WU01:FS00:Starting
19:37:12:WARNING:WU01:FS00:Changed SMP threads from 4 to 2 this can cause some work units to fail
19:37:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 10032 -checkpoint 15 -np 2
19:37:12:WU01:FS00:Started FahCore on PID 8800
19:37:13:WU01:FS00:Core PID:11580
19:37:13:WU01:FS00:FahCore 0xa7 started
19:37:13:WU01:FS00:0xa7:*********************** Log Started 2020-04-10T19:37:13Z ***********************
19:37:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:37:13:WU01:FS00:0xa7:       Type: 0xa7
19:37:13:WU01:FS00:0xa7:       Core: Gromacs
19:37:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8800 -checkpoint 15 -np 2
19:37:13:WU01:FS00:0xa7:************************************ CBang *************************************
19:37:13:WU01:FS00:0xa7:       Date: Oct 26 2019
19:37:13:WU01:FS00:0xa7:       Time: 01:38:35
19:37:13:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:37:13:WU01:FS00:0xa7:     Branch: master
19:37:13:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
19:37:13:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:37:13:WU01:FS00:0xa7:   Platform: win32 10
19:37:13:WU01:FS00:0xa7:       Bits: 64
19:37:13:WU01:FS00:0xa7:       Mode: Release
19:37:13:WU01:FS00:0xa7:************************************ System ************************************
19:37:13:WU01:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 955 Processor
19:37:13:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
19:37:13:WU01:FS00:0xa7:       CPUs: 4
19:37:13:WU01:FS00:0xa7:     Memory: 8.00GiB
19:37:13:WU01:FS00:0xa7:Free Memory: 5.07GiB
19:37:13:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
19:37:13:WU01:FS00:0xa7: OS Version: 6.2
19:37:13:WU01:FS00:0xa7:Has Battery: false
19:37:13:WU01:FS00:0xa7: On Battery: false
19:37:13:WU01:FS00:0xa7: UTC Offset: 1
19:37:13:WU01:FS00:0xa7:        PID: 11580
19:37:13:WU01:FS00:0xa7:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
19:37:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
19:37:13:WU01:FS00:0xa7:    Version: 0.0.18
19:37:13:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:37:13:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:37:14:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
19:37:14:WU01:FS00:0xa7:       Date: Oct 26 2019
19:37:14:WU01:FS00:0xa7:       Time: 01:52:44
19:37:14:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:37:14:WU01:FS00:0xa7:     Branch: master
19:37:14:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
19:37:14:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:37:14:WU01:FS00:0xa7:   Platform: win32 10
19:37:14:WU01:FS00:0xa7:       Bits: 64
19:37:14:WU01:FS00:0xa7:       Mode: Release
19:37:14:WU01:FS00:0xa7:************************************ Build *************************************
19:37:14:WU01:FS00:0xa7:       SIMD: sse2
19:37:14:WU01:FS00:0xa7:********************************************************************************
19:37:14:WU01:FS00:0xa7:Project: 16417 (Run 1536, Clone 3, Gen 38)
19:37:14:WU01:FS00:0xa7:Unit: 0x0000002b96880e6e5e8a61d5a223f96c
19:37:14:WU01:FS00:0xa7:Digital signatures verified
19:37:14:WU01:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -x frame38.xtc -cpi state.cpt -cpt 15 -nt 2
19:37:14:WU01:FS00:0xa7:Steps: first=9500000 total=250000
19:37:16:WU01:FS00:0xa7:Completed 462 out of 250000 steps (0%)
19:37:56:Removing old file 'configs/config-20200404-102320.xml'
19:37:56:Saving configuration to config.xml
19:37:56:<config>
19:37:56:  <!-- Folding Core -->
19:37:56:  <core-priority v='low'/>
19:37:56:
19:37:56:  <!-- Network -->
19:37:56:  <proxy v=':8080'/>
19:37:56:
19:37:56:  <!-- User Information -->
19:37:56:  <user v='PeterJammo'/>
19:37:56:
19:37:56:  <!-- Folding Slots -->
19:37:56:  <slot id='0' type='CPU'/>
19:37:56:  <slot id='1' type='GPU'/>
19:37:56:</config>
19:38:16:WU00:FS01:Connecting to 65.254.110.245:8080
19:38:16:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:38:16:WU00:FS01:Connecting to 18.218.241.186:80
19:38:16:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:38:16:ERROR:WU00:FS01:Exception: Could not get an assignment
19:40:53:WU00:FS01:Connecting to 65.254.110.245:8080
19:40:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:40:53:WU00:FS01:Connecting to 18.218.241.186:80
19:40:54:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:40:54:ERROR:WU00:FS01:Exception: Could not get an assignment
19:42:56:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
19:45:07:WU00:FS01:Connecting to 65.254.110.245:8080
19:45:07:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:45:07:WU00:FS01:Connecting to 18.218.241.186:80
19:45:08:WU00:FS01:Assigned to work server 128.252.203.10
19:45:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress Pro [Radeon HD 5800/6850] from 128.252.203.10
19:45:08:WU00:FS01:Connecting to 128.252.203.10:8080
19:45:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:45:29:WU00:FS01:Connecting to 128.252.203.10:80
19:45:50:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:48:33:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
19:53:49:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
19:58:51:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
19:59:28:WU02:FS01:Connecting to 65.254.110.245:8080
19:59:28:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:59:28:WU02:FS01:Connecting to 18.218.241.186:80
19:59:29:WU02:FS01:Assigned to work server 13.82.98.119
19:59:29:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress Pro [Radeon HD 5800/6850] from 13.82.98.119
19:59:29:WU02:FS01:Connecting to 13.82.98.119:8080
19:59:30:WU02:FS01:Downloading 124.80MiB
19:59:36:WU02:FS01:Download 6.71%
19:59:42:WU02:FS01:Download 15.62%
19:59:48:WU02:FS01:Download 24.44%
19:59:54:WU02:FS01:Download 29.50%
20:00:00:WU02:FS01:Download 38.21%
20:00:06:WU02:FS01:Download 46.72%
20:00:12:WU02:FS01:Download 52.83%
20:00:18:WU02:FS01:Download 61.30%
20:00:24:WU02:FS01:Download 69.71%
20:00:30:WU02:FS01:Download 77.87%
20:00:36:WU02:FS01:Download 85.89%
20:00:42:WU02:FS01:Download 94.45%
20:00:45:WU02:FS01:Download complete
20:00:45:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14417 run:0 clone:1537 gen:2 core:0x22 unit:0x000000040d5262775e84c8a5a1df0f67
20:00:45:WU02:FS01:Starting
20:00:45:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 10032 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:45:WU02:FS01:Started FahCore on PID 124
20:00:46:WU02:FS01:Core PID:11572
20:00:46:WU02:FS01:FahCore 0x22 started
20:00:47:WU02:FS01:0x22:*********************** Log Started 2020-04-10T20:00:47Z ***********************
20:00:47:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:00:47:WU02:FS01:0x22:       Type: 0x22
20:00:47:WU02:FS01:0x22:       Core: Core22
20:00:47:WU02:FS01:0x22:    Website: https://foldingathome.org/
20:00:47:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
20:00:47:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:00:47:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
20:00:47:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 124 -checkpoint 15
20:00:47:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:47:WU02:FS01:0x22:     Config: <none>
20:00:47:WU02:FS01:0x22:************************************ Build *************************************
20:00:47:WU02:FS01:0x22:    Version: 0.0.2
20:00:47:WU02:FS01:0x22:       Date: Dec 6 2019
20:00:47:WU02:FS01:0x22:       Time: 21:30:31
20:00:47:WU02:FS01:0x22: Repository: Git
20:00:47:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:00:47:WU02:FS01:0x22:     Branch: HEAD
20:00:47:WU02:FS01:0x22:   Compiler: Visual C++ 2008
20:00:47:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:00:47:WU02:FS01:0x22:   Platform: win32 10
20:00:47:WU02:FS01:0x22:       Bits: 64
20:00:47:WU02:FS01:0x22:       Mode: Release
20:00:47:WU02:FS01:0x22:************************************ System ************************************
20:00:47:WU02:FS01:0x22:        CPU: AMD Phenom(tm) II X4 955 Processor
20:00:47:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
20:00:47:WU02:FS01:0x22:       CPUs: 4
20:00:47:WU02:FS01:0x22:     Memory: 8.00GiB
20:00:47:WU02:FS01:0x22:Free Memory: 5.10GiB
20:00:47:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
20:00:47:WU02:FS01:0x22: OS Version: 6.2
20:00:47:WU02:FS01:0x22:Has Battery: false
20:00:47:WU02:FS01:0x22: On Battery: false
20:00:47:WU02:FS01:0x22: UTC Offset: 1
20:00:47:WU02:FS01:0x22:        PID: 11572
20:00:47:WU02:FS01:0x22:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
20:00:47:WU02:FS01:0x22:         OS: Windows 10 Home
20:00:47:WU02:FS01:0x22:    OS Arch: AMD64
20:00:47:WU02:FS01:0x22:********************************************************************************
20:00:47:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 1537, Gen 2)
20:00:47:WU02:FS01:0x22:Unit: 0x000000040d5262775e84c8a5a1df0f67
20:00:47:WU02:FS01:0x22:Reading tar file core.xml
20:00:47:WU02:FS01:0x22:Reading tar file integrator.xml
20:00:47:WU02:FS01:0x22:Reading tar file state.xml
20:00:48:WU02:FS01:0x22:Reading tar file system.xml
20:00:50:WU02:FS01:0x22:Digital signatures verified
20:00:50:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:00:50:WU02:FS01:0x22:Version 0.0.2
20:00:55:WU00:FS01:Upload complete
20:00:55:WU00:FS01:Server responded WORK_ACK (400)
20:00:55:WU00:FS01:Cleaning up
20:01:35:WU02:FS01:0x22:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
20:01:35:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:01:35:WU02:FS01:0x22:Saving result file science.log
20:01:35:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:01:35:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:01:35:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14417 run:0 clone:1537 gen:2 core:0x22 unit:0x000000040d5262775e84c8a5a1df0f67
20:01:35:WU02:FS01:Uploading 8.00KiB to 13.82.98.119
20:01:35:WU02:FS01:Connecting to 13.82.98.119:8080
20:01:36:WU02:FS01:Upload complete
20:01:36:WU02:FS01:Server responded WORK_ACK (400)
20:01:36:WU02:FS01:Cleaning up
20:01:36:WU00:FS01:Connecting to 65.254.110.245:8080
20:01:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:01:36:WU00:FS01:Connecting to 18.218.241.186:80
20:01:37:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:01:37:ERROR:WU00:FS01:Exception: Could not get an assignment
20:01:37:WU00:FS01:Connecting to 65.254.110.245:8080
20:01:37:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:01:37:WU00:FS01:Connecting to 18.218.241.186:80
20:01:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:01:38:ERROR:WU00:FS01:Exception: Could not get an assignment
20:01:59:FS00:Paused
20:01:59:FS01:Paused
20:01:59:FS00:Shutting core down
20:01:59:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 11580
20:01:59:WU01:FS00:0xa7:Exiting, please wait. . .
20:02:00:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:02:01:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:02:16:Removing old file 'configs/config-20200404-102329.xml'
20:02:16:Saving configuration to config.xml
20:02:16:<config>
20:02:16:  <!-- Folding Core -->
20:02:16:  <core-priority v='low'/>
20:02:16:
20:02:16:  <!-- Network -->
20:02:16:  <proxy v=':8080'/>
20:02:16:
20:02:16:  <!-- User Information -->
20:02:16:  <user v='PeterJammo'/>
20:02:16:
20:02:16:  <!-- Folding Slots -->
20:02:16:  <slot id='0' type='CPU'>
20:02:16:    <paused v='true'/>
20:02:16:  </slot>
20:02:16:</config>
20:02:16:WU00:Slot ID 1 no longer exists and not yet downloaded, dumping
20:02:17:WU00:Cleaning up
Note, initial setup had cpu cores set to 4 (set whilst GPU was disabled), reset further down log to -1 to allow gpu to work. At the end of the log I deleted the gpu slot again to allow the cpu to carry on folding but stop the gpu seeking further work.
peterjammo
HaloJones wrote:Has this gpu ever folded successfully? I ask only because it is quite an old card and FAH is seriously hard work. It may simply be exposing that your card can't work accurately enough at the current work.
I've already asked that question (specifically whether something this slow was worth trying to get working) and been told that the GPU type is supported and should be able to fold within deadlines. Has this actual GPU successfully folded? No. As at start of post, 3 tries three fails.
If the consensus is that this is a waste of time, I'm happy to leave it disabled, but so far I've been largely encouraged to fold with my collection of obsolete hardware.
Considering that there seems to be a GPU WU shortage, it's a good idea to remove the GPU slot now and maybe revisit in the future.
I noticed in your log that you haven't configured a passkey. While most donors are encouraged to use it, have a read of this and think about if you would like to use it or not: https://foldingathome.org/support/faq/points/passkey/
That is a really old Driver, but when I look for newer ones, the latest is from 2015
https://www.amd.com/en/support/graphics ... on-hd-6850
AMD seems to have made HD 6850 cards that have different specs, some support the Double Precision Floating Point math that F@H requires, and some don't.
https://www.techpowerup.com/gpu-specs/r ... -6850.c255
https://www.techpowerup.com/gpu-specs/r ... tion.c2219
It might be interesting to see if GPU-Z thought you had a Barts Pro or a Cypress Pro. (F@H thinks it is a Cypress Pro)
https://www.techpowerup.com/download/techpowerup-gpu-z/
peterjammo
That sounds like a sensible suggestion. I removed the slot after the first 2 crashes, and again after the third one to prevent it trying to pick up any more wu. I'll leave it removed.
I hadn't bothered with a passkey as I'd understood that the main function of it was collection of bonus points, and that's something that I didn't see much point in collecting with my obsolete hardware. I see in the FAQ that there may be more reasons to set one up, and I'm happy to do so.
I have 2 usernames on the go - when I set up the second one I wasn't sure if I could do multiple machines so played it safe. Can I use the same passkey with both, or should I change the second user name to match the other 4?
peterjammo
GPU-Z says Cypress. This is the card http://www.gpuzoo.com/GPU-MSI/Radeon_HD ... zr_II.html
Post by foldy »
I also got bad state detected at 3% once with this project Project 11748 while other projects work without issues.
viewtopic.php?f=19&t=34244
