Only 1 Active cpu?
Only 1 Active cpu?
When i go onto folding site and put in my name it says I only have 1 active CPU. Yet I fold on:
Old athlon pc - 1 client
My PC - 1 SMP client & 1 GPU client
My PS3
So surely that should bet 4 active cpu's? Should I be worried?
My PS3
Re: Only 1 Active cpu?
Check your client configurations ... you might have written your username/teamnumber wrong on some clients (be careful, it's case sensitive)
Nope checked that all seem fine
http://fah-web.stanford.edu/cgi-bin/mai ... ame=Bikerz
Its not sending the results grrr. Whats wrong any ideas? PG doesn't seem to be blocking it
Added [ code ] tags. -7im
20:25:28] Completed 100%
[20:26:28]
[20:26:28] Finished Work Unit:
[20:26:28] - Reading up to 1441080 from "work/wudata_03.trr": Read 1441080
[20:26:28] trr file hash check passed.
[20:26:28] - Reading up to 451708 from "work/wudata_03.xtc": Read 451708
[20:26:28] xtc file hash check passed.
[20:26:28] edr file hash check passed.
[20:26:28] logfile size: 61893
[20:26:28] Leaving Run
[20:26:28] - Writing 1955753 bytes of core data to disk...
[20:26:29] Done: 1955241 -> 1720090 (compressed to 87.9 percent)
[20:26:29] ... Done.
[20:26:29] - Shutting down core
[20:26:29]
[20:26:29] Folding@home Core Shutdown: FINISHED_UNIT
[20:26:32] CoreStatus = 64 (100)
[20:26:32] Sending work to server
[20:26:32] - Read packet limit of 540015616... Set to 524286976.
[20:26:32] + Attempting to send results
[20:26:35] - Couldn't send HTTP request to server
[20:26:35] + Could not connect to Work Server (results)
[20:26:35] (171.64.65.20:8080)
[20:26:35] - Error: Could not transmit unit 03 (completed June 21) to work server.
[20:26:35] Keeping unit 03 in queue.
[20:26:35] - Read packet limit of 540015616... Set to 524286976.
[20:26:35] + Attempting to send results
[20:26:41] - Couldn't send HTTP request to server
[20:26:41] + Could not connect to Work Server (results)
[20:26:41] (171.64.65.20:8080)
[20:26:41] - Error: Could not transmit unit 03 (completed June 21) to work server.
[20:26:41] - Read packet limit of 540015616... Set to 524286976.
[20:26:41] + Attempting to send results
[20:27:03] - Couldn't send HTTP request to server
[20:27:03] + Could not connect to Work Server (results)
[20:27:03] (171.64.122.76:8080)
[20:27:03] Could not transmit unit 03 to Collection server; keeping in queue.
[20:27:03] + Closed connections
[20:27:03] + Paused after finishing unit-
This server is down : viewtopic.php?f=43&t=3290 ...
ChelseaOilman
Only your PS3 and GPU clients are submitting WUs. Nothing from your AMD machine, or the SMP client.
Thank, how did u know that?
GPU and PS3 tho is surley 2 processors at least? So why saying 1?
Heres my SMP log:
Heres my SMP log:
--- Opening Log file [June 21 05:41:15]
# SMP Client ##################################################################
Folding@Home Client Version 5.91beta6
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\fah.exe
[05:41:15] - Ask before connecting: No
[05:41:15] - Use IE connection settings: Yes
[05:41:15] - User name: Bikerz (Team 35947)
[05:41:15] - User ID: 145DA8768A938CA
[05:41:15] - Machine ID: 1
[05:41:15]
[05:41:15] Loaded queue successfully.
[05:41:15]
[05:41:15] + Processing work unit
[05:41:15] Core required: FahCore_a1.exe
[05:41:15] Core found.
[05:41:15] Working on Unit 02 [June 21 05:41:15]
[05:41:15] + Working ...
[05:41:15]
[05:41:15] *------------------------------*
[05:41:15] Folding@Home Gromacs SMP Core
[05:41:15] Version 1.74 (March 10, 2007)
[05:41:15]
[05:41:15] Preparing to commence simulation
[05:41:15] - Ensuring status. Please wait.
[05:41:32] - Looking at optimizations...
[05:41:32] - Working with standard loops on this execution.
[05:41:32] Examination of work files indicates 8 consecutive improper terminations of core.
[05:41:45] - Expanded 4780328 -> 24426905 (decompressed 510.9 percent)
[05:41:48]
[05:41:48] Project: 2665 (Run 3, Clone 828, Gen 16)
[05:41:48]
[05:41:49] Entering M.D.
[05:41:55] Calling FAH init
[05:41:57] ater
[05:41:57] Writing local files[code]
[05:41:57] Completed 222500 out of 250000 steps (89 percent)
[05:41:57] er
[05:42:04] Extra SSE boost OK.
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [June 21 19:07:54]
[19:07:54] - Ask before connecting: No
[19:07:54] - Use IE connection settings: Yes
[19:07:54] - User name: Bikerz (Team 35947)
[19:07:54] - User ID: 145DA8768A938CA
[19:07:54] - Machine ID: 1
[19:07:54]
[19:07:54] Loaded queue successfully.
[19:07:54]
[19:07:54] + Processing work unit
[19:07:54] Core required: FahCore_a1.exe
[19:07:54] Core found.
[19:07:54] Working on Unit 02 [June 21 19:07:54]
[19:07:54] + Working ...
[19:08:02]
[19:08:02] *------------------------------*
[19:08:02] Folding@Home Gromacs SMP Core
[19:08:02] Version 1.74 (March 10, 2007)
[19:08:02]
[19:08:02] Preparing to commence simulation
[19:08:02] - Ensuring status. Please wait.
[19:08:19] - Looking at optimizations...
[19:08:19] - Working with standard loops on this execution.
[19:08:19] Examination of work files indicates 8 consecutive improper terminations of core.
[19:08:26] - Expanded 4780328 -> 24426905 (decompressed 510.9 percent)
[19:08:28]
[19:08:28] Project: 2665 (Run 3, Clone 828, Gen 16)
[19:08:28]
[19:08:28] Entering M.D.
[19:08:47] Calling FAH init
[19:08:48] Read topology
[19:08:48] (Starting from checkpoint)
[19:08:48] Read checkpoint
[19:08:49] teps (89 percent)
[19:08:49] er
[19:08:49] Writing local files
[19:08:49] Completed 222500 out of 250000 steps (89 percent)
[19:08:57] Extra SSE boost OK.
Folding@Home Client Shutdown.---
It's possible your smp client isn't uploading because of:
Try changing it to No by running the client with the -configonly option.
Someone said this already but never told me how to run the configonly option?
Copy your current shortcut used to start FAH and then edit the copied one by right-clicking on it and selecting properties.
Append -configonly to the command line. Click on apply and okay.
With your FAH client stopped, double click on the new shortcut. Most options you can just press enter and they will remain as they are but when you get to Use IE Settings type No.
gwildperson
Your GPU client is V6 and I'm assuming your SMP client is v5. I'm not sure about the others. Here is a WIKI article about flags and at the very bottom it has references for the Console and the GUI client. It works for all V5 clients but needs some information added for the V6 clients.
Wiki "switches" can be applied to -configonly.
gwildperson
He knew that because under his name "ChelseaOilman" you see the words ChelseaOilman "Site Moderator " They have some tools that us mere mortals don't get to see. It helps them help us with problems like this without bothering the Pande Group.Bikerz wrote:Thank, how did u know that?
If you post the Fahlog.txt from your AMD we may be able to help you with that one, too.
ChelseaOilman
Bikerz wrote:GPU and PS3 tho is surley 2 processors at least? So why saying 1?
Your last GPU WU:Bikerz Last updated: Sat Jun 21 12:00:01 PDT 2008
Sat Jun 21 19:00:01 UTC 2008
Date of last work unit 2008-06-21 06:19:53
Total score 35005
Overall rank (if points are combined) 80831 of 1012766
Active processors (within 50 days) 2 <--- looks like 2 to me
Active processors (within 7 days) 2 <--- looks like 2 to me
Hi Bikerz (team 35947),
Your WU (P5002 R1 C88 G37) was added to the stats database on 2008-06-20 14:37:56 for 98 points of credit.
Your last PS3 WU:
Your WU (P4016 R4 C92 G6) was added to the stats database on 2008-06-21 06:19:53 for 250 points of credit.
Cheers
Yeah it was 1 only just changed to 2. Was working for over 24 hours before updated to 2 processors which seemed weird to me but maybe because it was the 1st few WU they had done. Going to try and sort my SMP system now, but I feel ive lost the 2 WU I tryed to send.grrrrr
