Am I crazy or is this really low?
Imnohbdy
Hardware configuration: System is currently air cooled with no overclocking except for ram and AMD's standard boost clocking
MB: ASUS Crosshair Hero VIII
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Ram: 32Gb 3600Mhz (I know it's overkill but I like all 4 slots filled)
31.9Gb available when not using chrome
Post by Imnohbdy »
So, I want to make it clear that I'm not complaining. As I see it the points are just for fun and I only dug into this as a way to distract from the case law I'm supposed to be reading :lol:. I'm just curious about this because it seems weird imho. My CPU has been working on a WU for PRCG 13821 (169, 2, 83) for about 2.5 days now. The WU seems to be massive as the deadline timeout is 5 days, but the base credit and the k-factor (if my math is correct) seem really low for something so big. The base credit as seen below in the img (or url if I can't get the img to work) is 900 and I worked out the k-factor to be about 0.54 as opposed to the standard 0.75. It seems that CPU based WU give less credit anyway, but I've gotten more credit for WU that I blew through in an hour or less. Also, I'm running a Ryzen 7 3800X. So, not the fastest, but still well above average and I've only missed maybe 12 hours of work time on this due to letting the system rest for a bit when temps got over 90C. I'm no rocket doctor so if anyone can let me know what the reasoning is for a big WU worth about 200 PPD I'm super curious. Image https://imgur.com/a/1qJ5lPm
Currently installing upgrade to LAWYER 1.0/Known Bugs: hated by humanity/Patch Available: Stirring Speech *Patch requires Politician DLC
“Nearly all men can stand adversity, but if you want to test a man's character, give him power.”
― Abraham Lincoln
Imnohbdy
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Re: Am I crazy or is this really low?
Post by Imnohbdy »
Here's the full log for the most recent session on my CPU if it helps:
*********************** Log Started 2020-03-29T21:45:21Z ***********************
21:45:21:WU02:FS00:Starting
21:45:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\imnoh\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4788 -checkpoint 15 -np 15
21:45:22:WU02:FS00:Started FahCore on PID 16768
21:45:22:WU02:FS00:Core PID:9224
21:45:22:WU02:FS00:FahCore 0xa7 started
21:45:22:WU02:FS00:0xa7:*********************** Log Started 2020-03-29T21:45:22Z ***********************
21:45:22:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:45:22:WU02:FS00:0xa7:       Type: 0xa7
21:45:22:WU02:FS00:0xa7:       Core: Gromacs
21:45:22:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16768 -checkpoint 15 -np
21:45:22:WU02:FS00:0xa7:             15
21:45:22:WU02:FS00:0xa7:************************************ CBang *************************************
21:45:22:WU02:FS00:0xa7:       Date: Oct 26 2019
21:45:22:WU02:FS00:0xa7:       Time: 01:38:25
21:45:22:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:45:22:WU02:FS00:0xa7:     Branch: master
21:45:22:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:45:22:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:45:22:WU02:FS00:0xa7:   Platform: win32 10
21:45:22:WU02:FS00:0xa7:       Bits: 64
21:45:22:WU02:FS00:0xa7:       Mode: Release
21:45:22:WU02:FS00:0xa7:************************************ System ************************************
21:45:22:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:45:22:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:45:22:WU02:FS00:0xa7:       CPUs: 16
21:45:22:WU02:FS00:0xa7:     Memory: 31.92GiB
21:45:22:WU02:FS00:0xa7:Free Memory: 24.44GiB
21:45:22:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:45:22:WU02:FS00:0xa7: OS Version: 6.2
21:45:22:WU02:FS00:0xa7:Has Battery: false
21:45:22:WU02:FS00:0xa7: On Battery: false
21:45:22:WU02:FS00:0xa7: UTC Offset: -5
21:45:22:WU02:FS00:0xa7:        PID: 9224
21:45:22:WU02:FS00:0xa7:        CWD: C:\Users\imnoh\AppData\Roaming\FAHClient\work
21:45:22:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:45:22:WU02:FS00:0xa7:    Version: 0.0.18
21:45:22:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:45:22:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:45:22:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:45:22:WU02:FS00:0xa7:       Time: 01:52:30
21:45:22:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:45:22:WU02:FS00:0xa7:************************************ Build *************************************
21:45:22:WU02:FS00:0xa7:       SIMD: avx_256
21:45:22:WU02:FS00:0xa7:********************************************************************************
21:45:22:WU02:FS00:0xa7:Project: 13821 (Run 169, Clone 2, Gen 83)
21:45:22:WU02:FS00:0xa7:Unit: 0x0000005d80fccb095c8839bc09f82aed
21:45:22:WU02:FS00:0xa7:Digital signatures verified
21:45:22:WU02:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 15
21:45:22:WU02:FS00:0xa7:Steps: first=10375000 total=10375000
21:45:26:WU02:FS00:0xa7:Completed 4448372 out of 10375000 steps (42%)
21:53:42:WU02:FS00:0xa7:Completed 4461250 out of 10375000 steps (43%)
23:04:13:WU02:FS00:0xa7:Completed 4565000 out of 10375000 steps (44%)
00:07:04:WU02:FS00:0xa7:Completed 4668750 out of 10375000 steps (45%)
01:11:08:WU02:FS00:0xa7:Completed 4772500 out of 10375000 steps (46%)
02:15:14:WU02:FS00:0xa7:Completed 4876250 out of 10375000 steps (47%)
03:21:17:WU02:FS00:0xa7:Completed 4980000 out of 10375000 steps (48%)
******************************* Date: 2020-03-30 *******************************
04:29:21:WU02:FS00:0xa7:Completed 5083750 out of 10375000 steps (49%)
05:23:45:WU02:FS00:0xa7:Completed 5187500 out of 10375000 steps (50%)
06:30:16:WU02:FS00:0xa7:Completed 5291250 out of 10375000 steps (51%)
― Abraham Lincoln
Post by Neil-B »
This looks like another that Joe_H commented on ... it may be malformed ... wait until he or one of the team says so but it may be one for the bit bucket
Imnohbdy
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Post by Imnohbdy »
Neil-B wrote:This looks like another that Joe_H commented on ... it may be malformed ... wait until he or one of the team says so but it may be one for the bit bucket
Thanks, I wasn't sure but I thought it seemed off.
― Abraham Lincoln
Post by Neil-B »
the steps count looks high ... iirc that was the thing that was the give away previously ... but the team will need to confirm this
Yeah, that total step count is high, if I recall right it should be 125,000. If you want, the WU can be dumped. Or you can let it complete if that will happen before the Timeout. Points will be low but the results should still be usable.
The researcher running that project has fixed the settings for creating new WUs, but could not find and delete all of the rogue ones.
Imnohbdy
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Post by Imnohbdy »
Joe_H wrote:Yeah, that total step count is high, if I recall right it should be 125,000. If you want, the WU can be dumped. Or you can let it complete if that will happen before the Timeout. Points will be low but the results should still be usable.
No worries, I'll just let it run. I should be able to complete it before timeout, and if the results are usable that is more important. But thanks for taking the time to check it out for me.
― Abraham Lincoln
pasamio
Post by pasamio »
I got another one from 13821 (846, 1, 83) assigned to me a few hours back it seems and seems to have a similar issue. In my case it's telling me ETA is 7.84 days and timeout is around the same time. I'm a little new to this stuff but how does one dump the WU?
03:44:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13821 run:846 clone:1 gen:83 core:0xa7 unit:0x0000006780fccb095c8838194168959e
03:44:47:WU00:FS00:Starting
03:44:47:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 58 -checkpoint 15 -np 11
03:44:47:WU00:FS00:Started FahCore on PID 85044
03:44:47:WU00:FS00:Core PID:85045
03:44:47:WU00:FS00:FahCore 0xa7 started
03:44:47:WU00:FS00:0xa7:*********************** Log Started 2020-04-02T03:44:47Z ***********************
03:44:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:44:47:WU00:FS00:0xa7:       Type: 0xa7
03:44:47:WU00:FS00:0xa7:       Core: Gromacs
03:44:47:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 85044 -checkpoint 15 -np
03:44:47:WU00:FS00:0xa7:             11
03:44:47:WU00:FS00:0xa7:************************************ CBang *************************************
03:44:47:WU00:FS00:0xa7:       Date: Oct 26 2019
03:44:47:WU00:FS00:0xa7:       Time: 03:00:53
03:44:47:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
03:44:47:WU00:FS00:0xa7:     Branch: master
03:44:47:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
03:44:47:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
03:44:47:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
03:44:47:WU00:FS00:0xa7:   Platform: darwin 19.0.0
03:44:47:WU00:FS00:0xa7:       Bits: 64
03:44:47:WU00:FS00:0xa7:       Mode: Release
03:44:47:WU00:FS00:0xa7:************************************ System ************************************
03:44:47:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
03:44:47:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
03:44:47:WU00:FS00:0xa7:       CPUs: 12
03:44:47:WU00:FS00:0xa7:     Memory: 32.00GiB
03:44:47:WU00:FS00:0xa7:Free Memory: 375.09MiB
03:44:47:WU00:FS00:0xa7:    Threads: POSIX_THREADS
03:44:47:WU00:FS00:0xa7: OS Version: 10.14
03:44:47:WU00:FS00:0xa7:Has Battery: true
03:44:47:WU00:FS00:0xa7: On Battery: false
03:44:47:WU00:FS00:0xa7: UTC Offset: -7
03:44:47:WU00:FS00:0xa7:        PID: 85045
03:44:47:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
03:44:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:44:47:WU00:FS00:0xa7:    Version: 0.0.18
03:44:47:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:44:47:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:44:47:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
03:44:47:WU00:FS00:0xa7:       Time: 03:06:33
03:44:47:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
03:44:47:WU00:FS00:0xa7:************************************ Build *************************************
03:44:47:WU00:FS00:0xa7:       SIMD: avx_256
03:44:47:WU00:FS00:0xa7:********************************************************************************
03:44:47:WU00:FS00:0xa7:Project: 13821 (Run 846, Clone 1, Gen 83)
03:44:47:WU00:FS00:0xa7:Unit: 0x0000006780fccb095c8838194168959e
03:44:47:WU00:FS00:0xa7:Reading tar file core.xml
03:44:47:WU00:FS00:0xa7:Reading tar file frame83.tpr
03:44:47:WU00:FS00:0xa7:Digital signatures verified
03:44:47:WU00:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
03:44:47:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpt 15 -nt 10
03:44:47:WU00:FS00:0xa7:Steps: first=10375000 total=10375000
03:44:54:WU00:FS00:0xa7:Completed 1 out of 10375000 steps (0%)
******************************* Date: 2020-04-02 *******************************
05:38:59:WU00:FS00:0xa7:Completed 103750 out of 10375000 steps (1%)
06:25:26:FS00:Shutting core down
06:25:26:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 85045
06:25:26:WU00:FS00:0xa7:Exiting, please wait. . .
06:25:40:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:25:41:WU00:FS00:Starting
06:25:41:WARNING:WU00:FS00:Changed SMP threads from 11 to 5 this can cause some work units to fail
06:25:41:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 58 -checkpoint 15 -np 5
06:25:41:WU00:FS00:Started FahCore on PID 47714
06:25:41:WU00:FS00:Core PID:47716
06:25:41:WU00:FS00:FahCore 0xa7 started
06:25:41:WU00:FS00:0xa7:*********************** Log Started 2020-04-02T06:25:41Z ***********************
06:25:41:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:25:41:WU00:FS00:0xa7:       Type: 0xa7
06:25:41:WU00:FS00:0xa7:       Core: Gromacs
06:25:41:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 47714 -checkpoint 15 -np
06:25:41:WU00:FS00:0xa7:             5
06:25:41:WU00:FS00:0xa7:************************************ CBang *************************************
06:25:41:WU00:FS00:0xa7:       Date: Oct 26 2019
06:25:41:WU00:FS00:0xa7:       Time: 03:00:53
06:25:41:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
06:25:41:WU00:FS00:0xa7:     Branch: master
06:25:41:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
06:25:41:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
06:25:41:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
06:25:41:WU00:FS00:0xa7:   Platform: darwin 19.0.0
06:25:41:WU00:FS00:0xa7:       Bits: 64
06:25:41:WU00:FS00:0xa7:       Mode: Release
06:25:41:WU00:FS00:0xa7:************************************ System ************************************
06:25:41:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
06:25:41:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:25:41:WU00:FS00:0xa7:       CPUs: 12
06:25:41:WU00:FS00:0xa7:     Memory: 32.00GiB
06:25:41:WU00:FS00:0xa7:Free Memory: 367.06MiB
06:25:41:WU00:FS00:0xa7:    Threads: POSIX_THREADS
06:25:41:WU00:FS00:0xa7: OS Version: 10.14
06:25:41:WU00:FS00:0xa7:Has Battery: true
06:25:41:WU00:FS00:0xa7: On Battery: false
06:25:41:WU00:FS00:0xa7: UTC Offset: -7
06:25:41:WU00:FS00:0xa7:        PID: 47716
06:25:41:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
06:25:41:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:25:41:WU00:FS00:0xa7:    Version: 0.0.18
06:25:41:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:25:41:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:25:41:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:25:41:WU00:FS00:0xa7:       Time: 03:06:33
06:25:41:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
06:25:41:WU00:FS00:0xa7:************************************ Build *************************************
06:25:41:WU00:FS00:0xa7:       SIMD: avx_256
06:25:41:WU00:FS00:0xa7:********************************************************************************
06:25:41:WU00:FS00:0xa7:Project: 13821 (Run 846, Clone 1, Gen 83)
06:25:41:WU00:FS00:0xa7:Unit: 0x0000006780fccb095c8838194168959e
06:25:41:WU00:FS00:0xa7:Digital signatures verified
06:25:41:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
06:25:41:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 4
06:25:41:WU00:FS00:0xa7:Steps: first=10375000 total=10375000
06:25:42:WU00:FS00:0xa7:Completed 145972 out of 10375000 steps (1%)
06:25:59:Removing old file 'configs/config-20200315-205829.xml'
06:25:59:Saving configuration to config.xml
06:25:59:<config>
06:25:59:  <!-- Network -->
06:25:59:  <proxy v=':8080'/>
06:25:59:
06:25:59:  <!-- User Information -->
06:25:59:  <passkey v='********************************'/>
06:25:59:  <team v='223518'/>
06:25:59:  <user v='Pasamio'/>
06:25:59:
06:25:59:  <!-- Folding Slots -->
06:25:59:  <slot id='0' type='CPU'/>
06:25:59:</config>
06:49:03:FS00:Paused
06:49:03:FS00:Shutting core down
06:49:03:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 47716
06:49:03:WU00:FS00:0xa7:Exiting, please wait. . .
06:49:11:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:49:11:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:49:22:Removing old file 'configs/config-20200315-205851.xml'
06:49:22:Saving configuration to config.xml
06:49:22:<config>
06:49:22:  <!-- Network -->
06:49:22:  <proxy v=':8080'/>
06:49:22:
06:49:22:  <!-- User Information -->
06:49:22:  <passkey v='********************************'/>
06:49:22:  <team v='223518'/>
06:49:22:  <user v='Pasamio'/>
06:49:22:
06:49:22:  <!-- Folding Slots -->
06:49:22:  <slot id='0' type='CPU'>
06:49:22:    <paused v='true'/>
06:49:22:  </slot>
06:49:22:</config>
06:49:44:FS00:Unpaused
06:49:44:WU00:FS00:Starting
06:49:44:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 58 -checkpoint 15 -np 5
06:49:44:WU00:FS00:Started FahCore on PID 58649
06:49:44:WU00:FS00:Core PID:58650
06:49:44:WU00:FS00:FahCore 0xa7 started
06:49:44:WU00:FS00:0xa7:*********************** Log Started 2020-04-02T06:49:44Z ***********************
06:49:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:49:44:WU00:FS00:0xa7:       Type: 0xa7
06:49:44:WU00:FS00:0xa7:       Core: Gromacs
06:49:44:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 58649 -checkpoint 15 -np
06:49:44:WU00:FS00:0xa7:             5
06:49:44:WU00:FS00:0xa7:************************************ CBang *************************************
06:49:44:WU00:FS00:0xa7:       Date: Oct 26 2019
06:49:44:WU00:FS00:0xa7:       Time: 03:00:53
06:49:44:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
06:49:44:WU00:FS00:0xa7:     Branch: master
06:49:44:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
06:49:44:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
06:49:44:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
06:49:44:WU00:FS00:0xa7:   Platform: darwin 19.0.0
06:49:44:WU00:FS00:0xa7:       Bits: 64
06:49:44:WU00:FS00:0xa7:       Mode: Release
06:49:44:WU00:FS00:0xa7:************************************ System ************************************
06:49:44:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
06:49:44:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:49:44:WU00:FS00:0xa7:       CPUs: 12
06:49:44:WU00:FS00:0xa7:     Memory: 32.00GiB
06:49:44:WU00:FS00:0xa7:Free Memory: 260.34MiB
06:49:44:WU00:FS00:0xa7:    Threads: POSIX_THREADS
06:49:44:WU00:FS00:0xa7: OS Version: 10.14
06:49:44:WU00:FS00:0xa7:Has Battery: true
06:49:44:WU00:FS00:0xa7: On Battery: false
06:49:44:WU00:FS00:0xa7: UTC Offset: -7
06:49:44:WU00:FS00:0xa7:        PID: 58650
06:49:44:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
06:49:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:49:44:WU00:FS00:0xa7:    Version: 0.0.18
06:49:44:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:49:44:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:49:44:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:49:44:WU00:FS00:0xa7:       Time: 03:06:33
06:49:44:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
06:49:44:WU00:FS00:0xa7:************************************ Build *************************************
06:49:44:WU00:FS00:0xa7:       SIMD: avx_256
06:49:44:WU00:FS00:0xa7:********************************************************************************
06:49:44:WU00:FS00:0xa7:Project: 13821 (Run 846, Clone 1, Gen 83)
06:49:44:WU00:FS00:0xa7:Unit: 0x0000006780fccb095c8838194168959e
06:49:44:WU00:FS00:0xa7:Digital signatures verified
06:49:44:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
06:49:44:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 4
06:49:44:WU00:FS00:0xa7:Steps: first=10375000 total=10375000
06:49:45:WU00:FS00:0xa7:Completed 160412 out of 10375000 steps (1%)
06:50:23:Removing old file 'configs/config-20200317-234555.xml'
06:50:23:Saving configuration to config.xml
06:50:23:<config>
06:50:23:  <!-- Network -->
06:50:23:  <proxy v=':8080'/>
06:50:23:
06:50:23:  <!-- User Information -->
06:50:23:  <passkey v='********************************'/>
06:50:23:  <team v='223518'/>
06:50:23:  <user v='Pasamio'/>
06:50:23:
06:50:23:  <!-- Folding Slots -->
06:50:23:  <slot id='0' type='CPU'/>
06:50:23:</config>
06:55:38:FS00:Shutting core down
06:55:38:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 58650
06:55:38:WU00:FS00:0xa7:Exiting, please wait. . .
06:55:46:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:55:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:55:47:WU00:FS00:Starting
06:55:47:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 58 -checkpoint 15 -np 5
06:55:47:WU00:FS00:Started FahCore on PID 59398
06:55:47:WU00:FS00:Core PID:59399
06:55:47:WU00:FS00:FahCore 0xa7 started
06:55:47:WU00:FS00:0xa7:*********************** Log Started 2020-04-02T06:55:47Z ***********************
06:55:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:55:47:WU00:FS00:0xa7:       Type: 0xa7
06:55:47:WU00:FS00:0xa7:       Core: Gromacs
06:55:47:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 59398 -checkpoint 15 -np
06:55:47:WU00:FS00:0xa7:             5
06:55:47:WU00:FS00:0xa7:************************************ CBang *************************************
06:55:47:WU00:FS00:0xa7:       Date: Oct 26 2019
06:55:47:WU00:FS00:0xa7:       Time: 03:00:53
06:55:47:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
06:55:47:WU00:FS00:0xa7:     Branch: master
06:55:47:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
06:55:47:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
06:55:47:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
06:55:47:WU00:FS00:0xa7:   Platform: darwin 19.0.0
06:55:47:WU00:FS00:0xa7:       Bits: 64
06:55:47:WU00:FS00:0xa7:       Mode: Release
06:55:47:WU00:FS00:0xa7:************************************ System ************************************
06:55:47:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
06:55:47:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:55:47:WU00:FS00:0xa7:       CPUs: 12
06:55:47:WU00:FS00:0xa7:     Memory: 32.00GiB
06:55:47:WU00:FS00:0xa7:Free Memory: 378.23MiB
06:55:47:WU00:FS00:0xa7:    Threads: POSIX_THREADS
06:55:47:WU00:FS00:0xa7: OS Version: 10.14
06:55:47:WU00:FS00:0xa7:Has Battery: true
06:55:47:WU00:FS00:0xa7: On Battery: false
06:55:47:WU00:FS00:0xa7: UTC Offset: -7
06:55:47:WU00:FS00:0xa7:        PID: 59399
06:55:47:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
06:55:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:55:47:WU00:FS00:0xa7:    Version: 0.0.18
06:55:47:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:55:47:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:55:47:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:55:47:WU00:FS00:0xa7:       Time: 03:06:33
06:55:47:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
06:55:47:WU00:FS00:0xa7:************************************ Build *************************************
06:55:47:WU00:FS00:0xa7:       SIMD: avx_256
06:55:47:WU00:FS00:0xa7:********************************************************************************
06:55:47:WU00:FS00:0xa7:Project: 13821 (Run 846, Clone 1, Gen 83)
06:55:47:WU00:FS00:0xa7:Unit: 0x0000006780fccb095c8838194168959e
06:55:47:WU00:FS00:0xa7:Digital signatures verified
06:55:47:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
06:55:47:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 4
06:55:47:WU00:FS00:0xa7:Steps: first=10375000 total=10375000
06:55:49:WU00:FS00:0xa7:Completed 163922 out of 10375000 steps (1%)
Yes, this is really low since the number to total steps is many times normal for this project.
To dump WU, first pause folding. Since you are on OS X, go to the folder /Library/Application Support/FAHClient/. Inside that folder open the folder named 'work', and move the folder named '00' to the trash. You may be prompted for an admin password, I forget which files in this folder are protected by being owned by a different user. Then you can start up the client, it will do cleanup after detecting the work files are gone. Then it should request a new WU.
pasamio
Post by pasamio »
Awesome! Thanks!
