ubuntu 20.04LTS and RX480
devpao
Post by devpao »
Are there hints of an easier linux support in next coming LTS release?
Re: ubuntu 20.04LTS and RX480
Until we get an update to the folding client, the newer Ubuntu version you try, the more problems you may encounter ...
EXT64
Post by EXT64 »
Good question - though that may be more of a question for AMD and Linux than for Folding at home. Half the fun of linux is the victory at the end after hours or days of pain and suffering. Why would you want to take that away?
Darth_Peter_dualxeon
Hardware configuration: EVGA SR-2 motherboard
2x Xeon x5670 CPU
64 GB ECC DDR3
Nvidia RTX 2070
Post by Darth_Peter_dualxeon »
Hi, just saying, here in this topic viewtopic.php?f=61&t=33364 I wrote some of my experience so far. Mint is not very different from Ubuntu.
Rainmaker
Hardware configuration: AMD Threadripper 3960X underclocked/undervolted to 3.7GHz 1.0125v
Asus RoG Strix TRX40-E Gaming motherboard
32GB DDR4 3600MHz 16,16,16,36 (Samsung B-Die)
Sapphire Vega 56 overclocked/undervolted to 1662MHz 1070mV
Samsung Evo Plus 1TB NVMe SSD
Linux FTW
Post by Rainmaker »
EXT64 wrote:Good question - though that may be more of a question for AMD and Linux than for Folding at home. Half the fun of linux is the victory at the end after hours or days of pain and suffering. Why would you want to take that away?
It's more a question for FaH really. Ubuntu 20.04 changes from 18.04 include removing python2.7, and some of the libraries FaH depends on have been renamed or removed. It'll need a client update to function in the new LTS release (or even install). AMD have already released a driver for 20.04 so their GPUs are covered at least.
ipkh
Post by ipkh »
It's likely the fahclient will be fine. I haven't tested it yet but generally only the fahcontrol program has broken dependency problems. Work is underway to fix it up to modern libraries.
Rainmaker
Linux FTW
Post by Rainmaker »
ipkh wrote:It's likely the fahclient will be fine. I haven't tested it yet but generally only the fahcontrol program has broken dependency problems. Work is underway to fix it up to modern libraries.
At the moment fahclient results in a fatal error, but of course 20.04 is still in beta.
Setting up fahclient (7.5.1) ...
update-rc.d: error: no runlevel symlinks to modify, aborting!
dpkg: error processing package fahclient (--configure):
 installed fahclient package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 fahclient
E: Sub-process /usr/bin/dpkg returned an error code (1)
ipkh
Post by ipkh »
Ok, that's the script for fahclient to run at startup. They changed init systems since the fahclient package was made. This just means you need to start fahclient manually by using a terminal window.
It does make a little more complicated to add in a username and passkey, but it's not that hard to figure out.
