FaHClient 7.5.1 Installation problem on Windows 10
riiice
Post by riiice »
Hi guys,
I need some help or some advice.
I cant start folding, if the client is installed and running (FAHClient in Task-Manager) the Web-GUI will not connect, either the FAHControl panel - it stays orange - connecting inactive.
What I've done:
Reinstalled it for a couple times, with and without restarts and also as administrator, always with the recommended express installation.
Allowed the App manually in the firewall and on private/public network.
Restarted the client.
Updated Windows.
Updated my NVIDIA Driver.
I think I have problem at the installation or the initial startup.
If I run the setup I cant choose multiuser installation (maybe because I am the only user) after the installation is finished I dont get a prompt for the network question and even no website shows up for the small setup.
Here is my Log from the last installation:
*********************** Log Started 2020-03-24T08:44:10Z ***********************
08:44:10:************************* Folding@home Client *************************
08:44:10:      Website: https://foldingathome.org/
08:44:10:    Copyright: (c) 2009-2018 foldingathome.org
08:44:10:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:44:10:         Args: --open-web-control
08:44:10:       Config: <none>
08:44:10:******************************** Build ********************************
08:44:10:      Version: 7.5.1
08:44:10:         Date: May 11 2018
08:44:10:         Time: 13:06:32
08:44:10:   Repository: Git
08:44:10:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:44:10:       Branch: master
08:44:10:     Compiler: Visual C++ 2008
08:44:10:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:44:10:     Platform: win32 10
08:44:10:         Bits: 32
08:44:10:         Mode: Release
08:44:10:******************************* System ********************************
08:44:10:          CPU: AMD Ryzen 5 2600 Six-Core Processor
08:44:10:       CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
08:44:10:         CPUs: 12
08:44:10:       Memory: 15.95GiB
08:44:10:  Free Memory: 13.86GiB
08:44:10:      Threads: WINDOWS_THREADS
08:44:10:   OS Version: 6.2
08:44:10:  Has Battery: false
08:44:10:   On Battery: false
08:44:10:   UTC Offset: 1
08:44:10:          PID: 10388
08:44:10:          CWD: C:\Users\timoc\AppData\Roaming\FAHClient
08:44:10:           OS: Windows 10 Enterprise N
08:44:10:      OS Arch: AMD64
08:44:10:         GPUs: 0
08:44:10:         CUDA: Not detected
08:44:10:       OpenCL: Not detected
08:44:10:Win32 Service: false
08:44:10:***********************************************************************
08:44:10:<config>
08:44:10:  <!-- Folding Slots -->
08:44:10:</config>
08:44:10:Connecting to assign1.foldingathome.org:8080
08:44:11:Updated GPUs.txt
08:44:11:Read GPUs.txt
08:44:11:Trying to access database...
08:44:11:Successfully acquired database lock
08:44:11:Enabled folding slot 00: PAUSED cpu:10 (not configured)
Thanks & BG
Re: FaHClient 7.5.1 Installation problem on Windows 10
Just to check, is that as far as the log file gets? Since you mentioned FAHcontrol was not connecting, I am assuming ou opened up the log file directly.
I don't see anything particularly off in the setup as far as it got as shown in the log except not detecting OpenCL or CUDA if you happen to have a nVidia card. For a newer GPU the client will not recognize it until it downloads the current GPUs.txt file, that recognition would come shortly after the last message shown in the log when configuration occurs.
For your video drivers, are you getting direct from AMD or nVIdia, or using the driver supplied by Windows Update? The one from Windows Update leaves out OpenCL support.
riiice
Post by riiice »
Hi, thanks for your replie.
I downloaded the latest driver from nVidia directly.
The log output is from the appdata folder of my user, I just copied it from there.
Also there is no config.xml only the sample one, seems to be right, because the config never shows up after the installation.
I will care about the CUDA or OpenCL problem later. First I want to get the Client run, even if its just use the CPU.
Do you have any ideas ?
Or need other informations ?
Should I try to telnet to 127.0.0.1 and the 7xxx port ?
Or do you have any guess on the firwall thing bit prompted ?
