Total newbie, installation on Linux 32 bit
yep
Post by yep »
Hello,
I have installed the fahcontrol_7.5.1-1_all.deb package from the website for a Lenovo ThinkPad X200s running 32-bit LinuxLite. Does this download contain everything I need to start as I noticed the 64-bit downloads have fahclient and fahviewer as well.
Thank You.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Total newbie, installation on Linux 32 bit
Post by Jesse_V »
You need the FAHClient component as well. The FAHControl package is simply a graphical front-end for controlling FAHClient. FAHViewer is a 3D protein viewer.
yep
Post by yep »
Thanks for the reply. Where do I download the 32-bit fahclient from?
32-bit Linux is not supported.
kostuek
Post by kostuek »
It seems there is an older 7.4.4 32-Bit version
https://download.foldingathome.org/rele ... 2bit/v7.4/
Well ... it's ... just old ... :roll:
Although the clients can be 32 bits (it's the case of Windows one), the compute cores require 64 bits CPU and OS.
