Please add AMD WX 2100
noisycat05
Post by noisycat05 »
This GPU is for more common workstations.
I have a workstation that I would like to be running the client on, and I think that this GPU would be pretty
fast and power efficient to run on a project like this. Thanks a lot!
22:23:01:******************************** Build ********************************
22:23:01:        Version: 7.5.1
22:23:01:           Date: May 11 2018
22:23:01:           Time: 13:06:32
22:23:01:     Repository: Git
22:23:01:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:23:01:         Branch: master
22:23:01:       Compiler: Visual C++ 2008
22:23:01:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:23:01:       Platform: win32 10
22:23:01:           Bits: 32
22:23:01:           Mode: Release
22:23:01:******************************* System ********************************
22:23:01:            CPU: AMD Ryzen 5 3600X 6-Core Processor
22:23:01:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:23:01:           CPUs: 12
22:23:01:         Memory: 31.94GiB
22:23:01:    Free Memory: 25.25GiB
22:23:01:        Threads: WINDOWS_THREADS
22:23:01:     OS Version: 6.2
22:23:01:    Has Battery: false
22:23:01:     On Battery: false
22:23:01:     UTC Offset: -7
22:23:01:            PID: 5564
22:23:01:            CWD: C:\Users\<UserName>\AppData\Roaming\FAHClient
22:23:01:             OS: Windows 10 Enterprise
22:23:01:        OS Arch: AMD64
22:23:01:           GPUs: 1
22:23:01:          GPU 0: Bus:8 Slot:0 Func:0 AMD:5 Polaris Pro [Radeon Pro WX 2100]
22:23:01:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:23:01:                 specified module could not be found.
22:23:01:
22:23:01:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:3004.8
22:23:01:  Win32 Service: false
Straight from GPU-Z
Name: AMD Radeon Pro WX 2100
GPU: Lexa
Device ID: 1002 6995 - 1002 0B0C
Re: Please add AMD WX 2100
Your GPU is recognized, and we don't get to see what happens next, the log ends.
I am not sure how we can help without more log. (don't be shy, give us enough to see the issue)
Or do you have two GPUs installed and just one shows up? The device ID given is not in the file yet - 1002 6995
noisycat05
*********************** Log Started 2020-03-22T22:55:51Z ***********************
22:55:51:************************* Folding@home Client *************************
22:55:51:        Website: https://foldingathome.org/
22:55:51:      Copyright: (c) 2009-2018 foldingathome.org
22:55:51:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:51:           Args:
22:55:51:         Config: C:\Users\<UserName>\AppData\Roaming\FAHClient\config.xml
22:55:51:******************************** Build ********************************
22:55:51:        Version: 7.5.1
22:55:51:           Date: May 11 2018
22:55:51:           Time: 13:06:32
22:55:51:     Repository: Git
22:55:51:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:55:51:         Branch: master
22:55:51:       Compiler: Visual C++ 2008
22:55:51:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:55:51:       Platform: win32 10
22:55:51:           Bits: 32
22:55:51:           Mode: Release
22:55:51:******************************* System ********************************
22:55:51:            CPU: AMD Ryzen 5 3600X 6-Core Processor
22:55:51:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:55:51:           CPUs: 12
22:55:51:         Memory: 31.94GiB
22:55:51:    Free Memory: 29.99GiB
22:55:51:        Threads: WINDOWS_THREADS
22:55:51:     OS Version: 6.2
22:55:51:    Has Battery: false
22:55:51:     On Battery: false
22:55:51:     UTC Offset: -7
22:55:51:            PID: 5296
22:55:51:            CWD: C:\Users\<UserName>\AppData\Roaming\FAHClient
22:55:51:             OS: Windows 10 Enterprise
22:55:51:        OS Arch: AMD64
22:55:51:           GPUs: 1
22:55:51:          GPU 0: Bus:8 Slot:0 Func:0 AMD:5 Polaris Pro [Radeon Pro WX 2100]
22:55:51:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:55:51:                 specified module could not be found.
22:55:51:
22:55:51:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:3004.8
22:55:51:  Win32 Service: false
22:55:51:***********************************************************************
22:55:51:<config>
22:55:51:  <!-- Network -->
22:55:51:  <proxy v=':8080'/>
22:55:51:
22:55:51:  <!-- Remote Command Server -->
22:55:51:  <command-deny-no-pass v=''/>
22:55:51:
22:55:51:  <!-- Slot Control -->
22:55:51:  <power v='FULL'/>
22:55:51:
22:55:51:  <!-- User Information -->
22:55:51:  <passkey v='********************************'/>
22:55:51:  <team v='223518'/>
22:55:51:  <user v='noisycat05'/>
22:55:51:
22:55:51:  <!-- Folding Slots -->
22:55:51:  <slot id='0' type='CPU'/>
22:55:51:</config>
22:55:51:Trying to access database...
22:55:51:Successfully acquired database lock
22:55:51:Enabled folding slot 00: READY cpu:12
22:55:51:WU00:FS00:Starting
22:55:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fred\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5296 -checkpoint 15 -np 12
22:55:52:WU00:FS00:Started FahCore on PID 4752
22:55:52:WU00:FS00:Core PID:7184
22:55:52:WU00:FS00:FahCore 0xa7 started
22:55:52:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T22:55:52Z ***********************
22:55:52:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:55:52:WU00:FS00:0xa7:       Type: 0xa7
22:55:52:WU00:FS00:0xa7:       Core: Gromacs
22:55:52:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4752 -checkpoint 15 -np
22:55:52:WU00:FS00:0xa7:             12
22:55:52:WU00:FS00:0xa7:************************************ CBang *************************************
22:55:52:WU00:FS00:0xa7:       Date: Oct 26 2019
22:55:52:WU00:FS00:0xa7:       Time: 01:38:25
22:55:52:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:55:52:WU00:FS00:0xa7:     Branch: master
22:55:52:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:55:52:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:55:52:WU00:FS00:0xa7:   Platform: win32 10
22:55:52:WU00:FS00:0xa7:       Bits: 64
22:55:52:WU00:FS00:0xa7:       Mode: Release
22:55:52:WU00:FS00:0xa7:************************************ System ************************************
22:55:52:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3600X 6-Core Processor
22:55:52:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:55:52:WU00:FS00:0xa7:       CPUs: 12
22:55:52:WU00:FS00:0xa7:     Memory: 31.94GiB
22:55:52:WU00:FS00:0xa7:Free Memory: 29.97GiB
22:55:52:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:55:52:WU00:FS00:0xa7: OS Version: 6.2
22:55:52:WU00:FS00:0xa7:Has Battery: false
22:55:52:WU00:FS00:0xa7: On Battery: false
22:55:52:WU00:FS00:0xa7: UTC Offset: -7
22:55:52:WU00:FS00:0xa7:        PID: 7184
22:55:52:WU00:FS00:0xa7:        CWD: C:\Users\<UserName>\AppData\Roaming\FAHClient\work
22:55:52:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:55:52:WU00:FS00:0xa7:    Version: 0.0.18
22:55:52:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:52:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:55:52:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:55:52:WU00:FS00:0xa7:       Time: 01:52:30
22:55:52:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:55:52:WU00:FS00:0xa7:************************************ Build *************************************
22:55:52:WU00:FS00:0xa7:       SIMD: avx_256
22:55:52:WU00:FS00:0xa7:********************************************************************************
22:55:52:WU00:FS00:0xa7:Project: 14051 (Run 16, Clone 466, Gen 3)
22:55:52:WU00:FS00:0xa7:Unit: 0x000000030002894b5e73d41d11fa0853
22:55:52:WU00:FS00:0xa7:Digital signatures verified
22:55:52:WU00:FS00:0xa7:Calling: mdrun -s frame3.tpr -o frame3.trr -cpi state.cpt -cpt 15 -nt 12
22:55:52:WU00:FS00:0xa7:ERROR:Guru Meditation #2fa772000957222b.a3d52a388c91f6b (22312.31248) '00/01/traj_comp.xtc'
22:55:52:WU00:FS00:0xa7:WARNING:Unexpected exit() call
22:55:52:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
22:55:52:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
22:55:52:WU00:FS00:0xa7:Saving result file ener.edr
22:55:52:WU00:FS00:0xa7:ERROR:Guru Meditation #30dfda93655367a2.967589faba22538f (172072.206272) '00/01/ener.edr'
22:55:53:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:55:53:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:55:54:WU00:FS00:Starting
22:55:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\<UserName>\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5296 -checkpoint 15 -np 12
22:55:54:WU00:FS00:Started FahCore on PID 8348
22:55:54:WU00:FS00:Core PID:8372
22:55:54:WU00:FS00:FahCore 0xa7 started
22:55:54:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T22:55:54Z ***********************
22:55:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:55:54:WU00:FS00:0xa7:       Type: 0xa7
22:55:54:WU00:FS00:0xa7:       Core: Gromacs
22:55:54:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8348 -checkpoint 15 -np
22:55:54:WU00:FS00:0xa7:             12
22:55:54:WU00:FS00:0xa7:************************************ CBang *************************************
22:55:54:WU00:FS00:0xa7:       Date: Oct 26 2019
22:55:54:WU00:FS00:0xa7:       Time: 01:38:25
22:55:54:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:55:54:WU00:FS00:0xa7:     Branch: master
22:55:54:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:55:54:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:55:54:WU00:FS00:0xa7:   Platform: win32 10
22:55:54:WU00:FS00:0xa7:       Bits: 64
22:55:54:WU00:FS00:0xa7:       Mode: Release
22:55:54:WU00:FS00:0xa7:************************************ System ************************************
22:55:54:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3600X 6-Core Processor
22:55:54:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:55:54:WU00:FS00:0xa7:       CPUs: 12
22:55:54:WU00:FS00:0xa7:     Memory: 31.94GiB
22:55:54:WU00:FS00:0xa7:Free Memory: 29.96GiB
22:55:54:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:55:54:WU00:FS00:0xa7: OS Version: 6.2
22:55:54:WU00:FS00:0xa7:Has Battery: false
22:55:54:WU00:FS00:0xa7: On Battery: false
22:55:54:WU00:FS00:0xa7: UTC Offset: -7
22:55:54:WU00:FS00:0xa7:        PID: 8372
22:55:54:WU00:FS00:0xa7:        CWD: C:\Users\<UserName>\AppData\Roaming\FAHClient\work
22:55:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:55:54:WU00:FS00:0xa7:    Version: 0.0.18
22:55:54:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:54:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:55:54:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:55:54:WU00:FS00:0xa7:       Time: 01:52:30
22:55:54:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:55:54:WU00:FS00:0xa7:************************************ Build *************************************
22:55:54:WU00:FS00:0xa7:       SIMD: avx_256
22:55:54:WU00:FS00:0xa7:********************************************************************************
22:55:54:WU00:FS00:0xa7:Project: 14051 (Run 16, Clone 466, Gen 3)
22:55:54:WU00:FS00:0xa7:Unit: 0x000000030002894b5e73d41d11fa0853
22:55:54:WU00:FS00:0xa7:Digital signatures verified
22:55:54:WU00:FS00:0xa7:Calling: mdrun -s frame3.tpr -o frame3.trr -cpi state.cpt -cpt 15 -nt 12
22:55:54:WU00:FS00:0xa7:ERROR:Guru Meditation #2fa772000957222b.a3d52a388c91f6b (22312.31248) '00/01/traj_comp.xtc'
22:55:54:WU00:FS00:0xa7:WARNING:Unexpected exit() call
22:55:54:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
22:55:54:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
22:55:54:WU00:FS00:0xa7:Saving result file ener.edr
22:55:54:WU00:FS00:0xa7:ERROR:Guru Meditation #30dfda93655367a2.967589faba22538f (172072.206272) '00/01/ener.edr'
22:55:55:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:55:55:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:55:55:WARNING:WU00:FS00:Too many errors, failing
22:55:55:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14051 run:16 clone:466 gen:3 core:0xa7 unit:0x000000030002894b5e73d41d11fa0853
22:55:55:WU00:FS00:Connecting to 155.247.166.219:8080
22:55:55:WU01:FS00:Connecting to 65.254.110.245:8080
22:55:55:WU00:FS00:Server responded WORK_ACK (400)
22:55:55:WU00:FS00:Cleaning up
22:55:56:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:55:56:WU01:FS00:Connecting to 18.218.241.186:80
Here is a more complete log. However, if you look, you can see that it does see that there is OpenCL Device 0, however there is no slot for that GPU. I already looked in the GPUs.txt and there was no entry.
(Sorry for not enough log, I followed the GPU submission instructions to the Letter.) :lol:
Did you add the entry to your local copy? Just wondering how the client picked up the description, normally if it does not find an entry that field will not be filled and it will not show "GPUs: 1". Not the only possibility.
noisycat05
I just attempted to add the GPU to the white list. However, It doesn't appear that it has worked. I tried to restart the client multiple times.
Right. Adding it the locally cached copy of GPUs.txt doesn't get it added to the server's copy ... which is where it has to be.
Added Device ID: 1002 6995 Polaris Pro [Radeon Pro WX 2100]
noisycat05
Thank you so much!
Happy folding! :D
Raikins
Post by Raikins »
Hi, I have the same problem. I'm not a pro, so please be gentle. Other than my home PC, there are two servers gathering dust at work that I've been running full time on FAH for a year now.
One of the servers has an AMD Radeon Pro WX 2100 GPU in it.
Can you please tell me how to add the device ID, which is identical to previously mentioned GPU in this thread, to the 'server copy' ?
And where to find this ''server copy'?
Thank you!
As mentioned in prior responses, this card has already been added to the list. The client will add the card if its PCI device ID matches. The client also downloads an updated copy of the list about once a month, and any changes within it are applied the next time the client software is restarted or the system rebooted.
Your local copy of GPUs.txt is located in the F@h data directory, the same location as the log files which of course depends on whether you are running Linux or Windows.
You can download a current copy from here - https://apps.foldingathome.org/GPUs.txt. It will be at most a few hours different from what is used by the F@h servers. Someone like Bruce could add or change an entry, it takes a short time before the servers update.
As for the server copy, you do not have access to the F@h Assignment or Work Servers to get their "server copy".
Joe_H wrote:As mentioned in prior responses, this card has already been added to the list. The client will add the card if its PCI device ID matches. The client also downloads an updated copy of the list about once a month, and any changes within it are applied the next time the client software is restarted or the system rebooted.
If you delete the local cached copy and restart, a fresh copy will download.
Hi Raikins, Welcome to Folding@Home!
As Joe_H and bruce have hinted, your computer should download a server copy of GPUs.txt if it does not have a copy, or every month.
There are many computers called servers, but if you had a Folding@Home server, you would live in a major University.
If you think your computers are not folding as well as you would like, you can send us the first 200 lines of your computer's log, this should tell you how:
viewtopic.php?f=24&t=26036
I hope this helps!
greekchief
Post by greekchief »
Whats the PPD for this card. I have a hd7670 card yet its a fake card that claims to have 4gb instead of 1gb. Wish i could use it to fold but im not sure fake gpu's will do
greekchief wrote:Whats the PPD for this card. I have a hd7670 card yet its a fake card that claims to have 4gb instead of 1gb. Wish i could use it to fold but im not sure fake gpu's will do
It will not fold. The HD 7670 is based on a Terascale GPU chip, and does not support Double Precision (FP64) calculations. The minimum card in the HD 7000 series that can be used is the HD 7700 series and above.
As Joe_H says, you card does not meet one of two prerequisites for folding, while it supports OpenCL 1.2, it does not support Double Precision Floating Point math (FP64)
https://www.techpowerup.com/gpu-specs/a ... 1-gb.b1202
The card is nine years old, if it could fold, it might never finish before the deadline. It is about 1/2 as fast as a GT 1030, the minimum I know will finish before the deadlines.
Many Work Units would fit within 1 gig, memory is not the real problem. It lacks math skills.
