GPU Unit WU shows 0 (0,0,0) in Web Control
RubixNoob13
Hardware configuration: Win 10 core i7 8700k, 64 GB Ram, GTX 1070
HP Laptop running Lubuntu 19.04 with AMD A8-3500M Quad Core with Radeon HD Graphics, 6 GB Ram
ODROID H2 (lovingly dubbed "SmolBoi") Intel Quad Core J4105 with Intel UHD Graphics 600, 32 GB Ram
Post by RubixNoob13 »
Hello, new poster here and new to folding in general. I am pretty sure this is just a web viewer issue, but for WU running on my GPU when my CPU is idle, I've noticed they all say 0 (0,0,0) in the web viewer. However, the most recent one, when I checked the advanced control, it *does* show 14533 (0, 6987, 2) as the WU currently being worked on.
I honestly am not worried about points calculation, or any of those other things, I'm mostly concerned that my GPU is actually doing something that is helping out the researchers, and not just making a lot of noise inside my PC :D
Hopefully this helps out! Thanks for all the work you are doing, both the researchers *AND* everyone contributing CPU/GPU power to this project!
My specs as per the "New Members, Start here" post:
Computer Specs: Intel Core i7-8700k 3.70 GHz (although it shows 4.29 in Win10 Task Manager) 64 GB RAM, 6 physical cores, 12 logical processors. GPU: NVIDIA GeForce GTX 1070, 8GB VRAM
Network Connection: Fiber, gigabit
Operating System: Windows 10, Version 10.0.18363 Build 18363 (I have 2 Linux systems but they are CPU only, and this is a GPU issue, so they're maybe not relevant to this post :egeek: )
Overclocked?: Nothing, however CPU clocks up higher than the stock 3.70 (motherboard set to "performance" + water cooling)
Stable?: Yes
Software: Windows Client 7.5.1 Public Release. Not sure about core version? Whatever the default Windows installer uses :)
WU details: GPU, however the question pertains to WU showing as 0 (0, 0, 0) in the viewer instead of meaningful data.
Re: GPU Unit WU shows 0 (0,0,0) in Web Control
Without more information (such as a posted log) I'm not sure what you're reporting.
Apparently you're working on two WUs, one for the CPU and one for the GPU. Either or both may be active or trying to download a new assignment. When a WU has been completed, FAHClient will attempt to get a new WU assigned, and until one is downloaded, the Control app shows the PRCG numbers as 0 (0,0,0). Once there's a new WU, the values are updated.
With the current flood of new Donors, all anxious to help solve the COVAID issues, our servers are overloaded, trying to service everyone so the 0 (0,0,0) may persist for a long time.
RubixNoob13
I suppose that would be helpful :) Here's what I could post of the log file (full log file says it's 2x the allowed number of characters for the board)
16:26:20:WU02:FS01:Connecting to 65.254.110.245:8080
16:26:20:WU02:FS01:Assigned to work server 128.252.203.10
16:26:20:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 128.252.203.10
16:26:20:WU02:FS01:Connecting to 128.252.203.10:8080
16:26:26:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
16:26:41:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
16:26:41:WU02:FS01:Connecting to 128.252.203.10:80
16:27:28:WU02:FS01:Downloading 50.74MiB
16:27:31:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
16:27:34:WU02:FS01:Download 13.30%
16:27:40:WU02:FS01:Download 76.62%
16:27:42:WU02:FS01:Download complete
16:27:42:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:8065 gen:6 core:0x22 unit:0x0000000980fccb0a5e7113ceb6918367
16:27:42:WU02:FS01:Starting
16:27:42:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 12892 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:27:42:WU02:FS01:Started FahCore on PID 6276
16:27:42:WU02:FS01:Core PID:12988
16:27:42:WU02:FS01:FahCore 0x22 started
16:27:42:WU02:FS01:0x22:*********************** Log Started 2020-03-21T16:27:42Z ***********************
16:27:42:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:27:42:WU02:FS01:0x22:       Type: 0x22
16:27:42:WU02:FS01:0x22:       Core: Core22
16:27:42:WU02:FS01:0x22:    Website: https://foldingathome.org/
16:27:42:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:27:42:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:27:42:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:27:42:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 6276 -checkpoint 15
16:27:42:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:27:42:WU02:FS01:0x22:             0 -gpu 0
16:27:42:WU02:FS01:0x22:     Config: <none>
16:27:42:WU02:FS01:0x22:************************************ Build *************************************
16:27:42:WU02:FS01:0x22:    Version: 0.0.2
16:27:42:WU02:FS01:0x22:       Date: Dec 6 2019
16:27:42:WU02:FS01:0x22:       Time: 21:30:31
16:27:42:WU02:FS01:0x22: Repository: Git
16:27:42:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:27:42:WU02:FS01:0x22:     Branch: HEAD
16:27:42:WU02:FS01:0x22:   Compiler: Visual C++ 2008
16:27:42:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:27:42:WU02:FS01:0x22:   Platform: win32 10
16:27:42:WU02:FS01:0x22:       Bits: 64
16:27:42:WU02:FS01:0x22:       Mode: Release
16:27:42:WU02:FS01:0x22:************************************ System ************************************
16:27:42:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
16:27:42:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:27:42:WU02:FS01:0x22:       CPUs: 12
16:27:42:WU02:FS01:0x22:     Memory: 63.95GiB
16:27:42:WU02:FS01:0x22:Free Memory: 53.84GiB
16:27:42:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
16:27:42:WU02:FS01:0x22: OS Version: 6.2
16:27:42:WU02:FS01:0x22:Has Battery: false
16:27:42:WU02:FS01:0x22: On Battery: false
16:27:42:WU02:FS01:0x22: UTC Offset: -5
16:27:42:WU02:FS01:0x22:        PID: 12988
16:27:42:WU02:FS01:0x22:        CWD: C:\Users\steve\AppData\Roaming\FAHClient\work
16:27:42:WU02:FS01:0x22:         OS: Windows 10 Pro
16:27:42:WU02:FS01:0x22:    OS Arch: AMD64
16:27:42:WU02:FS01:0x22:********************************************************************************
16:27:42:WU02:FS01:0x22:Project: 11762 (Run 0, Clone 8065, Gen 6)
16:27:42:WU02:FS01:0x22:Unit: 0x0000000980fccb0a5e7113ceb6918367
16:27:42:WU02:FS01:0x22:Reading tar file core.xml
16:27:42:WU02:FS01:0x22:Reading tar file integrator.xml
16:27:42:WU02:FS01:0x22:Reading tar file state.xml
16:27:43:WU02:FS01:0x22:Reading tar file system.xml
16:27:43:WU02:FS01:0x22:Digital signatures verified
16:27:43:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:27:43:WU02:FS01:0x22:Version 0.0.2
16:27:58:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:27:58:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:28:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:28:43:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
16:29:15:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
16:29:54:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
16:30:29:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
16:31:06:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
16:31:43:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
16:32:17:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
16:32:58:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
16:33:27:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
16:34:12:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
16:34:37:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
16:35:32:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
16:35:46:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
16:36:46:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
16:36:55:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
16:38:00:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
16:38:05:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
16:39:14:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
16:39:14:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
16:40:23:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
16:40:28:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
16:41:33:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
16:41:48:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
16:42:43:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
16:43:02:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
16:43:51:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
16:44:16:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
16:45:01:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
16:45:30:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
16:46:14:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
16:46:44:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
16:47:23:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
16:48:04:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
16:48:32:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
16:49:18:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
16:49:41:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
16:50:32:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
16:50:50:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
16:51:46:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
16:52:00:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
16:53:00:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
16:53:08:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
16:54:18:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
16:54:20:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
16:55:27:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
16:55:34:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
16:56:36:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
16:56:48:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
16:57:45:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
16:58:02:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
16:58:54:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
16:59:16:WU02:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
17:00:06:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
17:00:35:WU02:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
17:01:16:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
17:01:49:WU02:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
17:02:23:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
17:03:04:WU02:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
17:03:32:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
17:04:18:WU02:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
17:04:41:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
17:05:32:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
17:05:51:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
17:06:51:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
17:06:58:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
17:08:05:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
17:08:08:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
17:09:17:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
17:09:19:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
17:10:25:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
17:10:33:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
17:11:33:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
17:11:47:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
17:12:42:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
17:13:06:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
17:13:51:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
17:14:21:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
17:14:59:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
17:15:35:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
17:16:10:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
17:16:49:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
17:17:19:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
17:18:03:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
17:18:29:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
17:19:22:WU02:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
17:19:36:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
17:20:36:WU02:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
17:20:45:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
17:21:50:WU02:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
17:21:54:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
17:23:02:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
17:23:04:WU02:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
17:24:09:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
17:24:18:WU02:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
17:25:18:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
17:25:37:WU02:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
17:26:26:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
17:26:51:WU02:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
17:27:35:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
17:28:05:WU02:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
17:28:43:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
17:29:19:WU02:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
17:29:52:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
17:30:33:WU02:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
17:31:03:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
17:31:53:WU02:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
17:32:12:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
17:33:07:WU02:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
17:33:19:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
17:34:21:WU02:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
17:34:28:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
17:35:35:WU02:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
17:35:36:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
17:36:44:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
17:36:49:WU02:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
******************************* Date: 2020-03-21 *******************************
17:37:53:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
17:38:09:WU02:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
17:39:02:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
17:39:22:WU02:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
17:40:11:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
17:40:37:WU02:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
17:41:18:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
17:41:50:WU02:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
17:42:26:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
17:43:05:WU02:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
17:43:35:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
17:44:24:WU02:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
17:44:45:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
17:45:38:WU02:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
17:45:54:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
17:46:52:WU02:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
17:47:03:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
17:48:06:WU02:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
17:48:12:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
17:49:20:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
17:49:21:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
17:50:28:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
17:50:39:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
17:51:36:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
17:51:53:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
17:52:45:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
17:53:07:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
17:53:52:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
17:53:53:WU01:FS00:Connecting to 65.254.110.245:8080
17:53:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:53:53:WU01:FS00:Connecting to 18.218.241.186:80
17:53:53:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:53:53:ERROR:WU01:FS00:Exception: Could not get an assignment
17:53:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:53:54:WU01:FS00:Connecting to 18.218.241.186:80
17:53:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:53:54:ERROR:WU01:FS00:Exception: Could not get an assignment
17:54:21:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
17:54:54:WU01:FS00:Connecting to 65.254.110.245:8080
17:54:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:54:54:WU01:FS00:Connecting to 18.218.241.186:80
17:54:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:54:54:ERROR:WU01:FS00:Exception: Could not get an assignment
17:55:01:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
17:55:09:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:55:09:WU00:FS00:0xa7:Saving result file frame111.trr
17:55:09:WU00:FS00:0xa7:Saving result file frame111.xtc
17:55:09:WU00:FS00:0xa7:Saving result file md.log
17:55:09:WU00:FS00:0xa7:Saving result file science.log
17:55:09:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:55:10:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:55:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14400 run:0 clone:4563 gen:111 core:0xa7 unit:0x0000008480fccb095dcad70adfd1893e
17:55:10:WU00:FS00:Uploading 9.81MiB to 128.252.203.9
17:55:10:WU00:FS00:Connecting to 128.252.203.9:8080
17:55:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:55:12:WU00:FS00:Connecting to 128.252.203.9:80
17:55:14:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 128.252.203.9:80: No connection could be made because the target machine actively refused it.
17:55:14:WU00:FS00:Trying to send results to collection server
17:55:14:WU00:FS00:Uploading 9.81MiB to 155.247.166.219
17:55:14:WU00:FS00:Connecting to 155.247.166.219:8080
17:55:16:WU00:FS00:Upload complete
17:55:16:WU00:FS00:Server responded WORK_ACK (400)
17:55:16:WU00:FS00:Final credit estimate, 5664.00 points
17:55:16:WU00:FS00:Cleaning up
17:55:35:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
17:56:31:WU01:FS00:Connecting to 65.254.110.245:8080
17:56:31:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:56:31:WU01:FS00:Connecting to 18.218.241.186:80
17:56:31:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:56:31:ERROR:WU01:FS00:Exception: Could not get an assignment
17:56:50:WU02:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
17:58:02:WU02:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
17:59:08:WU01:FS00:Connecting to 65.254.110.245:8080
17:59:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:59:08:WU01:FS00:Connecting to 18.218.241.186:80
17:59:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:59:08:ERROR:WU01:FS00:Exception: Could not get an assignment
17:59:14:WU02:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
18:00:27:WU02:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
18:01:39:WU02:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
18:02:54:WU02:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
18:03:22:WU01:FS00:Connecting to 65.254.110.245:8080
18:03:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:03:22:WU01:FS00:Connecting to 18.218.241.186:80
18:03:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:03:22:ERROR:WU01:FS00:Exception: Could not get an assignment
18:04:07:WU02:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
18:05:19:WU02:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
18:06:32:WU02:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
18:07:44:WU02:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
18:08:59:WU02:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
18:10:11:WU02:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
18:10:14:WU01:FS00:Connecting to 65.254.110.245:8080
18:10:14:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:14:WU01:FS00:Connecting to 18.218.241.186:80
18:10:14:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:14:ERROR:WU01:FS00:Exception: Could not get an assignment
18:11:23:WU02:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
18:12:36:WU02:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
18:13:48:WU02:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
18:15:04:WU02:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
18:16:16:WU02:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
18:17:12:217:127.0.0.1:New Web connection
18:17:30:WU02:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
18:18:43:WU02:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
18:19:56:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
18:21:14:WU02:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
18:21:19:WU01:FS00:Connecting to 65.254.110.245:8080
18:21:19:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:21:19:WU01:FS00:Connecting to 18.218.241.186:80
18:21:19:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:21:19:ERROR:WU01:FS00:Exception: Could not get an assignment
18:22:28:WU02:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
18:23:42:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
18:24:56:WU02:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
18:26:10:WU02:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
18:27:27:WU02:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
18:28:41:WU02:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
And here's a screenshot of the web viewer showing PRCG: 0 (0, 0, 0)
Lastly, here's a screenshot of the Advanced Control, which appears to show PRCG 11762 (0, 8065, 6)
Again, I think it's just the web viewer not updating, so as long as the log looks good, I'll stop worrying about things and let it do it's thing :)
I am going to make one suggestion.
Set your # of CPUs to 9
You have 12 threads, F@H calls them CPUs.
One is reserved to feed your GTX 1070 data via the PCIE bus, leaving 11.
F@H hates prime large prime numbers, and multiples of large primes. 7 is always large, sometimes 5 is large, 3 never is.
So currently it is set to 11 which is a large Prime, and may fail.
If you choose 10 that is 2 x 5 and 5 can be a large prime so sometimes fails
If you choose 9, that is 3 x 3 and it should never fail due to this quirk.
In the lower right in the task bar you should see the F@H molecule icon (you may need to press an up arrow to see it ^)
the second item on this menu should be Advanced Control, click it
a screen should pop up and near the left should be a configure button, click it
Now we get a screen and one tab should be Slots, click it
in a white area should be cpu and gpu, click cpu and then the Edit button
By default it is set to -1 which lets the software decide, but I would set it to 9.
then save and exit
jonault
Post by jonault »
The web control only shows the details for one folding slot at a time. Right now it's showing you the CPU slot which is inactive. Click on the GPU progress bar, and it should switch over to showing you the GPU folding slot info.
RubixNoob13
@JimboPalmer - Thanks for the suggestion, I made that change
@jonault - OMG Now I feel like a total noob, that did the trick. I didn't even realize that the 2 different progress bars were like, tabs in the interface. In my defense, I think I need to up the contrast on this monitor, because they're almost the same color no matter which is selected (or maybe I've been staring at the monitor too long doing other things)
Thanks again for all the help!
jonault
Post by jonault »
Don't feel bad, you're not the only person to have trouble with that recently. I think the problem is, the tabs are so large that they don't really look like tabs.
