GPU stuck on Ready or Failed
Magnat07
Post by Magnat07 »
HI there,
I'm new to this community, some friends of mine talked about it and I started right away.
I created my account last Monday, and since then I NEVER had my GPU folding. I work from home, so must of the day my PC is running and looks like my GPU doesn't exist for the FAHControl.
I already read about identical problems, unnistall the GPU drivers and installed the last ones, and yes I know that the number off people folding was grown like never before. But I have friends that only turn on their PCs in 2-3 hours and they always using the GPU, in the same time I only make 1/2 WU with my CPU.
Sometimes my GPU starts a WU, but in less than 1/2 minutes the WU stops and the GPU becomes "ready" again.
Also I have an UPS powering my PC, and when the GPU starts something the UPS starts the fan, but I can read the power that the UPS is providing to the PC and never went above 60%. I really want to help the community with my PC, and can't use the most powerfull part, my GPU. Hope that someone can help me.
I'm running the Intel i7-5820K and GeForce GTX 1080 Ti.
*********************** Log Started 2020-03-21T12:10:22Z ***********************
12:10:22:************************* Folding@home Client *************************
12:10:22:        Website: https://foldingathome.org/
12:10:22:      Copyright: (c) 2009-2018 foldingathome.org
12:10:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:22:           Args:
12:10:22:         Config: C:\Users\gonca\AppData\Roaming\FAHClient\config.xml
12:10:22:******************************** Build ********************************
12:10:22:        Version: 7.5.1
12:10:22:           Date: May 11 2018
12:10:22:           Time: 13:06:32
12:10:22:     Repository: Git
12:10:22:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:10:22:         Branch: master
12:10:22:       Compiler: Visual C++ 2008
12:10:22:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:10:22:       Platform: win32 10
12:10:22:           Bits: 32
12:10:22:           Mode: Release
12:10:22:******************************* System ********************************
12:10:22:            CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
12:10:22:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
12:10:22:           CPUs: 12
12:10:22:         Memory: 31.91GiB
12:10:22:    Free Memory: 28.72GiB
12:10:22:        Threads: WINDOWS_THREADS
12:10:22:     OS Version: 6.2
12:10:22:    Has Battery: false
12:10:22:     On Battery: false
12:10:22:     UTC Offset: 0
12:10:22:            PID: 15332
12:10:22:            CWD: C:\Users\gonca\AppData\Roaming\FAHClient
12:10:22:             OS: Windows 10 Enterprise
12:10:22:        OS Arch: AMD64
12:10:22:           GPUs: 1
12:10:22:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
12:10:22:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
12:10:22:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.74
12:10:22:  Win32 Service: false
12:10:22:***********************************************************************
12:10:22:<config>
12:10:22:  <!-- Network -->
12:10:22:  <proxy v=':8080'/>
12:10:22:
12:10:22:  <!-- Slot Control -->
12:10:22:  <power v='full'/>
12:10:22:
12:10:22:  <!-- User Information -->
12:10:22:  <passkey v='********************************'/>
12:10:22:  <team v='35271'/>
12:10:22:  <user v='Magnat07'/>
12:10:22:
12:10:22:  <!-- Folding Slots -->
12:10:22:  <slot id='0' type='CPU'>
12:10:22:    <cpus v='10'/>
12:10:22:  </slot>
12:10:22:  <slot id='1' type='GPU'/>
12:10:22:</config>
12:10:22:Trying to access database...
12:10:22:Successfully acquired database lock
12:10:22:Enabled folding slot 00: READY cpu:10
12:10:22:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
12:10:22:WU00:FS00:Starting
12:10:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gonca\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15332 -checkpoint 15 -np 10
12:10:22:WU00:FS00:Started FahCore on PID 6172
12:10:22:WU00:FS00:Core PID:9228
12:10:22:WU00:FS00:FahCore 0xa7 started
12:10:22:WU01:FS01:Connecting to 65.254.110.245:8080
12:10:22:WU00:FS00:0xa7:*********************** Log Started 2020-03-21T12:10:22Z ***********************
12:10:22:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:10:22:WU00:FS00:0xa7:       Type: 0xa7
12:10:22:WU00:FS00:0xa7:       Core: Gromacs
12:10:22:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6172 -checkpoint 15 -np
12:10:22:WU00:FS00:0xa7:             10
12:10:22:WU00:FS00:0xa7:************************************ CBang *************************************
12:10:22:WU00:FS00:0xa7:       Date: Oct 26 2019
12:10:22:WU00:FS00:0xa7:       Time: 01:38:25
12:10:22:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:10:22:WU00:FS00:0xa7:     Branch: master
12:10:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:10:23:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:10:23:WU00:FS00:0xa7:   Platform: win32 10
12:10:23:WU00:FS00:0xa7:       Bits: 64
12:10:23:WU00:FS00:0xa7:       Mode: Release
12:10:23:WU00:FS00:0xa7:************************************ System ************************************
12:10:23:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
12:10:23:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
12:10:23:WU00:FS00:0xa7:       CPUs: 12
12:10:23:WU00:FS00:0xa7:     Memory: 31.91GiB
12:10:23:WU00:FS00:0xa7:Free Memory: 28.53GiB
12:10:23:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:10:23:WU00:FS00:0xa7: OS Version: 6.2
12:10:23:WU00:FS00:0xa7:Has Battery: false
12:10:23:WU00:FS00:0xa7: On Battery: false
12:10:23:WU00:FS00:0xa7: UTC Offset: 0
12:10:23:WU00:FS00:0xa7:        PID: 9228
12:10:23:WU00:FS00:0xa7:        CWD: C:\Users\gonca\AppData\Roaming\FAHClient\work
12:10:23:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:10:23:WU00:FS00:0xa7:    Version: 0.0.18
12:10:23:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:23:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:10:23:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:10:23:WU00:FS00:0xa7:       Date: Oct 26 2019
12:10:23:WU00:FS00:0xa7:       Time: 01:52:30
12:10:23:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:10:23:WU00:FS00:0xa7:     Branch: master
12:10:23:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:10:23:WU00:FS00:0xa7:************************************ Build *************************************
12:10:23:WU00:FS00:0xa7:       SIMD: avx_256
12:10:23:WU00:FS00:0xa7:********************************************************************************
12:10:23:WU00:FS00:0xa7:Project: 14307 (Run 1, Clone 737, Gen 16)
12:10:23:WU00:FS00:0xa7:Unit: 0x000000139bf7a4d55e66c5c9206c1fab
12:10:23:WU00:FS00:0xa7:Digital signatures verified
12:10:23:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpi state.cpt -cpt 15 -nt 10
12:10:23:WU00:FS00:0xa7:Steps: first=8000000 total=500000
12:10:23:WU00:FS00:0xa7:Completed 31442 out of 500000 steps (6%)
12:10:23:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:10:23:WU01:FS01:Connecting to 18.218.241.186:80
12:10:24:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:10:24:ERROR:WU01:FS01:Exception: Could not get an assignment
12:10:24:WU01:FS01:Connecting to 65.254.110.245:8080
12:10:25:WU01:FS01:Assigned to work server 128.252.203.2
12:10:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 128.252.203.2
12:10:25:WU01:FS01:Connecting to 128.252.203.2:8080
12:11:03:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
12:11:26:WU01:FS01:Downloading 79.12MiB
12:11:32:WU01:FS01:Download 28.75%
12:11:37:Removing old file 'configs/config-20200319-191607.xml'
12:11:37:Saving configuration to config.xml
12:11:37:<config>
12:11:37:  <!-- Network -->
12:11:37:  <proxy v=':8080'/>
12:11:37:
12:11:37:  <!-- Slot Control -->
12:11:37:  <power v='full'/>
12:11:37:
12:11:37:  <!-- User Information -->
12:11:37:  <passkey v='********************************'/>
12:11:37:  <team v='35271'/>
12:11:37:  <user v='Magnat07'/>
12:11:37:
12:11:37:  <!-- Folding Slots -->
12:11:37:  <slot id='0' type='CPU'>
12:11:37:    <cpus v='10'/>
12:11:37:  </slot>
12:11:37:  <slot id='1' type='GPU'/>
12:11:37:</config>
12:11:37:WU01:FS01:Download complete
12:11:37:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14533 run:0 clone:2782 gen:6 core:0x22 unit:0x0000000b80fccb025e72f20cfcb32ac4
12:11:37:WU01:FS01:Starting
12:11:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gonca\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 15332 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:11:37:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
12:11:37:WU01:FS01:Started FahCore on PID 17576
12:11:38:WU01:FS01:Core PID:17556
12:11:38:WU01:FS01:FahCore 0x22 started
12:11:39:WU01:FS01:0x22:*********************** Log Started 2020-03-21T12:11:38Z ***********************
12:11:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:11:39:WU01:FS01:0x22:       Type: 0x22
12:11:39:WU01:FS01:0x22:       Core: Core22
12:11:39:WU01:FS01:0x22:    Website: https://foldingathome.org/
12:11:39:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:11:39:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:11:39:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:11:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 17576 -checkpoint 15
12:11:39:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:11:39:WU01:FS01:0x22:             0 -gpu 0
12:11:39:WU01:FS01:0x22:     Config: <none>
12:11:39:WU01:FS01:0x22:************************************ Build *************************************
12:11:39:WU01:FS01:0x22:    Version: 0.0.2
12:11:39:WU01:FS01:0x22:       Date: Dec 6 2019
12:11:39:WU01:FS01:0x22:       Time: 21:30:31
12:11:39:WU01:FS01:0x22: Repository: Git
12:11:39:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
12:11:39:WU01:FS01:0x22:     Branch: HEAD
12:11:39:WU01:FS01:0x22:   Compiler: Visual C++ 2008
12:11:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:11:39:WU01:FS01:0x22:   Platform: win32 10
12:11:39:WU01:FS01:0x22:       Bits: 64
12:11:39:WU01:FS01:0x22:       Mode: Release
12:11:39:WU01:FS01:0x22:************************************ System ************************************
12:11:39:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
12:11:39:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
12:11:39:WU01:FS01:0x22:       CPUs: 12
12:11:39:WU01:FS01:0x22:     Memory: 31.91GiB
12:11:39:WU01:FS01:0x22:Free Memory: 26.60GiB
12:11:39:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
12:11:39:WU01:FS01:0x22: OS Version: 6.2
12:11:39:WU01:FS01:0x22:Has Battery: false
12:11:39:WU01:FS01:0x22: On Battery: false
12:11:39:WU01:FS01:0x22: UTC Offset: 0
12:11:39:WU01:FS01:0x22:        PID: 17556
12:11:39:WU01:FS01:0x22:        CWD: C:\Users\gonca\AppData\Roaming\FAHClient\work
12:11:39:WU01:FS01:0x22:         OS: Windows 10 Pro
12:11:39:WU01:FS01:0x22:    OS Arch: AMD64
12:11:39:WU01:FS01:0x22:********************************************************************************
12:11:39:WU01:FS01:0x22:Project: 14533 (Run 0, Clone 2782, Gen 6)
12:11:39:WU01:FS01:0x22:Unit: 0x0000000b80fccb025e72f20cfcb32ac4
12:11:39:WU01:FS01:0x22:Reading tar file core.xml
12:11:39:WU01:FS01:0x22:Reading tar file integrator.xml
12:11:39:WU01:FS01:0x22:Reading tar file state.xml
12:11:39:WU01:FS01:0x22:Reading tar file system.xml
12:11:40:WU01:FS01:0x22:Digital signatures verified
12:11:40:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:11:40:WU01:FS01:0x22:Version 0.0.2
12:12:13:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
12:12:14:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
12:12:14:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:12:26:WU01:FS01:0x22:ERROR:exception: Error downloading array energySum: clEnqueueReadBuffer (-5)
12:12:26:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
12:12:26:WU01:FS01:0x22:Saving result file checkpt.crc
12:12:26:WU01:FS01:0x22:Saving result file science.log
12:12:26:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
12:12:27:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:12:27:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14533 run:0 clone:2782 gen:6 core:0x22 unit:0x0000000b80fccb025e72f20cfcb32ac4
12:12:27:WU01:FS01:Uploading 10.00KiB to 128.252.203.2
12:12:27:WU01:FS01:Connecting to 128.252.203.2:8080
12:12:27:WU02:FS01:Connecting to 65.254.110.245:8080
12:12:28:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:12:28:WU02:FS01:Connecting to 18.218.241.186:80
12:12:28:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:12:28:ERROR:WU02:FS01:Exception: Could not get an assignment
12:12:29:WU02:FS01:Connecting to 65.254.110.245:8080
12:12:29:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:12:29:WU02:FS01:Connecting to 18.218.241.186:80
12:12:30:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:12:30:ERROR:WU02:FS01:Exception: Could not get an assignment
12:12:48:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
12:12:52:WU01:FS01:Upload complete
12:12:52:WU01:FS01:Server responded WORK_ACK (400)
12:12:53:WU01:FS01:Cleaning up
12:13:21:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
12:13:25:Removing old file 'configs/config-20200319-191708.xml'
12:13:25:Saving configuration to config.xml
12:13:25:<config>
12:13:25:  <!-- Network -->
12:13:25:  <proxy v=':8080'/>
12:13:25:
12:13:25:  <!-- Slot Control -->
12:13:25:  <power v='full'/>
12:13:25:
12:13:25:  <!-- User Information -->
12:13:25:  <passkey v='********************************'/>
12:13:25:  <team v='35271'/>
12:13:25:  <user v='Magnat07'/>
12:13:25:
12:13:25:  <!-- Folding Slots -->
12:13:25:  <slot id='0' type='CPU'>
12:13:25:    <cpus v='10'/>
12:13:25:  </slot>
12:13:25:  <slot id='1' type='GPU'>
12:13:25:    <idle v='true'/>
12:13:25:  </slot>
12:13:25:</config>
12:13:53:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
12:14:10:FS01:Finishing
12:14:12:WU02:FS01:Connecting to 65.254.110.245:8080
12:14:12:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:14:12:WU02:FS01:Connecting to 18.218.241.186:80
12:14:13:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:14:13:ERROR:WU02:FS01:Exception: Could not get an assignment
12:14:26:Removing old file 'configs/config-20200320-100622.xml'
12:14:26:Saving configuration to config.xml
12:14:26:<config>
12:14:26:  <!-- Network -->
12:14:26:  <proxy v=':8080'/>
12:14:26:
12:14:26:  <!-- Slot Control -->
12:14:26:  <power v='full'/>
12:14:26:
12:14:26:  <!-- User Information -->
12:14:26:  <passkey v='********************************'/>
12:14:26:  <team v='35271'/>
12:14:26:  <user v='Magnat07'/>
12:14:26:
12:14:26:  <!-- Folding Slots -->
12:14:26:  <slot id='0' type='CPU'>
12:14:26:    <cpus v='10'/>
12:14:26:  </slot>
12:14:26:  <slot id='1' type='GPU'/>
12:14:26:</config>
12:14:26:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
12:14:58:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
12:15:07:Removing old file 'configs/config-20200320-100713.xml'
12:15:07:Saving configuration to config.xml
12:15:07:<config>
12:15:07:  <!-- Network -->
12:15:07:  <proxy v=':8080'/>
12:15:07:
12:15:07:  <!-- Slot Control -->
12:15:07:  <power v='full'/>
12:15:07:
12:15:07:  <!-- User Information -->
12:15:07:  <passkey v='********************************'/>
12:15:07:  <team v='35271'/>
12:15:07:  <user v='Magnat07'/>
12:15:07:
12:15:07:  <!-- Folding Slots -->
12:15:07:  <slot id='0' type='CPU'>
12:15:07:    <cpus v='10'/>
12:15:07:  </slot>
12:15:07:  <slot id='1' type='GPU'/>
12:15:07:</config>
12:15:32:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
12:15:49:WU02:FS01:Connecting to 65.254.110.245:8080
12:15:50:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:15:50:WU02:FS01:Connecting to 18.218.241.186:80
12:15:50:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:15:50:ERROR:WU02:FS01:Exception: Could not get an assignment
12:16:04:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
12:16:36:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
12:17:08:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:17:40:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
12:18:12:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
12:18:26:WU02:FS01:Connecting to 65.254.110.245:8080
12:18:27:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:18:27:WU02:FS01:Connecting to 18.218.241.186:80
12:18:27:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:18:27:ERROR:WU02:FS01:Exception: Could not get an assignment
12:18:44:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:19:16:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:19:48:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:20:20:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
12:20:52:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
12:21:24:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
12:21:56:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
12:22:28:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
12:22:41:WU02:FS01:Connecting to 65.254.110.245:8080
12:22:41:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:22:41:WU02:FS01:Connecting to 18.218.241.186:80
12:22:41:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:22:41:ERROR:WU02:FS01:Exception: Could not get an assignment
12:23:00:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
12:23:32:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
12:24:04:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
12:24:36:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
12:25:18:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
12:25:50:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
12:26:22:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
12:26:54:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
12:27:26:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
12:27:58:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
12:28:30:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
12:29:03:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
12:29:32:WU02:FS01:Connecting to 65.254.110.245:8080
12:29:32:WU02:FS01:Assigned to work server 13.90.152.57
12:29:32:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 13.90.152.57
12:29:32:WU02:FS01:Connecting to 13.90.152.57:8080
12:29:36:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
12:30:07:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
12:30:34:WU02:FS01:Downloading 86.23MiB
12:30:40:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
12:30:41:WU02:FS01:Download 6.52%
12:30:47:WU02:FS01:Download 22.40%
12:30:53:WU02:FS01:Download 50.95%
12:30:59:WU02:FS01:Download 89.66%
12:31:00:WU02:FS01:Download complete
12:31:00:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11781 run:0 clone:3445 gen:5 core:0x22 unit:0x0000000e0d5a98395e73c5082dfd0b20
12:31:00:WU02:FS01:Starting
12:31:00:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gonca\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 15332 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:31:00:WU02:FS01:Started FahCore on PID 18080
12:31:00:WU02:FS01:Core PID:5812
12:31:00:WU02:FS01:FahCore 0x22 started
12:31:01:WU02:FS01:0x22:*********************** Log Started 2020-03-21T12:31:01Z ***********************
12:31:01:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:31:01:WU02:FS01:0x22:       Type: 0x22
12:31:01:WU02:FS01:0x22:       Core: Core22
12:31:01:WU02:FS01:0x22:    Website: https://foldingathome.org/
12:31:01:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:31:01:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:31:01:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:31:01:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 18080 -checkpoint 15
12:31:01:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:31:01:WU02:FS01:0x22:             0 -gpu 0
12:31:01:WU02:FS01:0x22:     Config: <none>
12:31:01:WU02:FS01:0x22:************************************ Build *************************************
12:31:01:WU02:FS01:0x22:    Version: 0.0.2
12:31:01:WU02:FS01:0x22:       Date: Dec 6 2019
12:31:01:WU02:FS01:0x22:       Time: 21:30:31
12:31:01:WU02:FS01:0x22: Repository: Git
12:31:01:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
12:31:01:WU02:FS01:0x22:     Branch: HEAD
12:31:01:WU02:FS01:0x22:   Compiler: Visual C++ 2008
12:31:01:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:31:01:WU02:FS01:0x22:   Platform: win32 10
12:31:01:WU02:FS01:0x22:       Bits: 64
12:31:01:WU02:FS01:0x22:       Mode: Release
12:31:01:WU02:FS01:0x22:************************************ System ************************************
12:31:01:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
12:31:01:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
12:31:01:WU02:FS01:0x22:       CPUs: 12
12:31:01:WU02:FS01:0x22:     Memory: 31.91GiB
12:31:01:WU02:FS01:0x22:Free Memory: 26.66GiB
12:31:01:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
12:31:01:WU02:FS01:0x22: OS Version: 6.2
12:31:01:WU02:FS01:0x22:Has Battery: false
12:31:01:WU02:FS01:0x22: On Battery: false
12:31:01:WU02:FS01:0x22: UTC Offset: 0
12:31:01:WU02:FS01:0x22:        PID: 5812
12:31:01:WU02:FS01:0x22:        CWD: C:\Users\gonca\AppData\Roaming\FAHClient\work
12:31:01:WU02:FS01:0x22:         OS: Windows 10 Pro
12:31:01:WU02:FS01:0x22:    OS Arch: AMD64
12:31:01:WU02:FS01:0x22:********************************************************************************
12:31:01:WU02:FS01:0x22:Project: 11781 (Run 0, Clone 3445, Gen 5)
12:31:01:WU02:FS01:0x22:Unit: 0x0000000e0d5a98395e73c5082dfd0b20
12:31:01:WU02:FS01:0x22:Reading tar file core.xml
12:31:01:WU02:FS01:0x22:Reading tar file integrator.xml
12:31:01:WU02:FS01:0x22:Reading tar file state.xml
12:31:02:WU02:FS01:0x22:Reading tar file system.xml
12:31:02:WU02:FS01:0x22:Digital signatures verified
12:31:02:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:31:02:WU02:FS01:0x22:Version 0.0.2
12:31:18:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
12:31:36:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
12:31:37:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:31:54:WU02:FS01:0x22:ERROR:exception: clWaitForEvents
12:31:54:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
12:31:54:WU02:FS01:0x22:Saving result file checkpt.crc
12:31:54:WU02:FS01:0x22:Saving result file science.log
12:31:54:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
12:31:54:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:31:54:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11781 run:0 clone:3445 gen:5 core:0x22 unit:0x0000000e0d5a98395e73c5082dfd0b20
12:31:54:WU02:FS01:Uploading 10.00KiB to 13.90.152.57
12:31:54:WU02:FS01:Connecting to 13.90.152.57:8080
12:32:02:WU02:FS01:Upload 100.00%
12:32:04:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
12:32:42:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:32:59:WU02:FS01:Upload complete
12:32:59:WU02:FS01:Server responded WORK_ACK (400)
12:32:59:WU02:FS01:Cleaning up
12:33:05:WU01:FS01:Connecting to 65.254.110.245:8080
12:33:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:33:06:WU01:FS01:Connecting to 18.218.241.186:80
12:33:06:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:33:06:ERROR:WU01:FS01:Exception: Could not get an assignment
12:33:06:WU01:FS01:Connecting to 65.254.110.245:8080
12:33:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:33:07:WU01:FS01:Connecting to 18.218.241.186:80
12:33:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:33:07:ERROR:WU01:FS01:Exception: Could not get an assignment
12:33:18:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
12:33:55:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
12:34:06:WU01:FS01:Connecting to 65.254.110.245:8080
12:34:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:34:07:WU01:FS01:Connecting to 18.218.241.186:80
12:34:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:34:07:ERROR:WU01:FS01:Exception: Could not get an assignment
12:34:31:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
12:35:05:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
12:35:38:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
12:35:44:WU01:FS01:Connecting to 65.254.110.245:8080
12:35:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:35:44:WU01:FS01:Connecting to 18.218.241.186:80
12:35:45:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:35:45:ERROR:WU01:FS01:Exception: Could not get an assignment
12:36:13:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
12:36:50:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
12:37:26:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
12:38:02:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
12:38:21:WU01:FS01:Connecting to 65.254.110.245:8080
12:38:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:38:21:WU01:FS01:Connecting to 18.218.241.186:80
12:38:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:38:22:ERROR:WU01:FS01:Exception: Could not get an assignment
12:38:37:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
12:39:12:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
12:39:47:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
12:40:20:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
12:40:53:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
12:41:26:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
12:41:58:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
12:42:30:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
12:42:35:WU01:FS01:Connecting to 65.254.110.245:8080
12:42:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:42:36:WU01:FS01:Connecting to 18.218.241.186:80
12:42:36:WU01:FS01:Assigned to work server 13.90.152.57
12:42:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 13.90.152.57
12:42:36:WU01:FS01:Connecting to 13.90.152.57:8080
12:42:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:42:57:WU01:FS01:Connecting to 13.90.152.57:80
12:43:02:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
12:43:19:ERROR:WU01:FS01:Exception: Failed to connect to 13.90.152.57:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:43:38:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
12:44:15:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
12:44:51:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
12:45:28:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
12:46:04:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
12:46:40:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
12:47:16:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
12:47:51:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
12:48:27:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
12:49:03:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
12:49:27:WU01:FS01:Connecting to 65.254.110.245:8080
12:49:27:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:49:27:WU01:FS01:Connecting to 18.218.241.186:80
12:49:27:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:49:27:ERROR:WU01:FS01:Exception: Could not get an assignment
12:49:41:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
12:50:17:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
12:50:54:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
12:51:30:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
12:52:04:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
12:52:39:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
12:53:13:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
12:53:48:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
12:54:24:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
12:54:58:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
12:55:33:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
12:56:07:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
12:56:43:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
12:57:20:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
12:57:57:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
12:58:34:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
12:59:09:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
12:59:44:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
13:00:18:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
13:00:32:WU01:FS01:Connecting to 65.254.110.245:8080
13:00:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:00:32:WU01:FS01:Connecting to 18.218.241.186:80
13:00:33:WU01:FS01:Assigned to work server 140.163.4.231
13:00:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
13:00:33:WU01:FS01:Connecting to 140.163.4.231:8080
13:00:53:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
13:01:27:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
13:02:01:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
13:02:24:WU01:FS01:Downloading 13.15MiB
13:02:33:WU01:FS01:Download 0.95%
13:02:35:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
13:02:39:WU01:FS01:Download 5.23%
13:02:45:WU01:FS01:Download 13.79%
13:02:51:WU01:FS01:Download 25.20%
13:02:57:WU01:FS01:Download 45.64%
13:03:03:WU01:FS01:Download 56.57%
13:03:10:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
13:03:19:WU01:FS01:Download 60.85%
13:03:25:WU01:FS01:Download 75.11%
13:03:37:WU01:FS01:Download 79.39%
13:03:44:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
13:03:44:WU01:FS01:Download 96.03%
13:03:45:WU02:FS00:Connecting to 65.254.110.245:8080
13:03:45:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:03:45:WU02:FS00:Connecting to 18.218.241.186:80
13:03:45:WU01:FS01:Download complete
13:03:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11752 run:0 clone:3125 gen:7 core:0x22 unit:0x000000128ca304e75e6a806c7a2a4687
13:03:46:WU01:FS01:Starting
13:03:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gonca\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 15332 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:03:46:WU01:FS01:Started FahCore on PID 15108
13:03:46:WU01:FS01:Core PID:4140
13:03:46:WU01:FS01:FahCore 0x22 started
13:03:46:WU02:FS00:Assigned to work server 155.247.164.214
13:03:46:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 155.247.164.214
13:03:46:WU02:FS00:Connecting to 155.247.164.214:8080
13:03:47:WU01:FS01:0x22:*********************** Log Started 2020-03-21T13:03:46Z ***********************
13:03:47:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:03:47:WU01:FS01:0x22:       Type: 0x22
13:03:47:WU01:FS01:0x22:       Core: Core22
13:03:47:WU01:FS01:0x22:    Website: https://foldingathome.org/
13:03:47:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
13:03:47:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:03:47:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
13:03:47:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 15108 -checkpoint 15
13:03:47:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:03:47:WU01:FS01:0x22:             0 -gpu 0
13:03:47:WU01:FS01:0x22:     Config: <none>
13:03:47:WU01:FS01:0x22:************************************ Build *************************************
13:03:47:WU01:FS01:0x22:    Version: 0.0.2
13:03:47:WU01:FS01:0x22:       Date: Dec 6 2019
13:03:47:WU01:FS01:0x22:       Time: 21:30:31
13:03:47:WU01:FS01:0x22: Repository: Git
13:03:47:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
13:03:47:WU01:FS01:0x22:     Branch: HEAD
13:03:47:WU01:FS01:0x22:   Compiler: Visual C++ 2008
13:03:47:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:03:47:WU01:FS01:0x22:   Platform: win32 10
13:03:47:WU01:FS01:0x22:       Bits: 64
13:03:47:WU01:FS01:0x22:       Mode: Release
13:03:47:WU01:FS01:0x22:************************************ System ************************************
13:03:47:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
13:03:47:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
13:03:47:WU01:FS01:0x22:       CPUs: 12
13:03:47:WU01:FS01:0x22:     Memory: 31.91GiB
13:03:47:WU01:FS01:0x22:Free Memory: 25.68GiB
13:03:47:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:03:47:WU01:FS01:0x22: OS Version: 6.2
13:03:47:WU01:FS01:0x22:Has Battery: false
13:03:47:WU01:FS01:0x22: On Battery: false
13:03:47:WU01:FS01:0x22: UTC Offset: 0
13:03:47:WU01:FS01:0x22:        PID: 4140
13:03:47:WU01:FS01:0x22:        CWD: C:\Users\gonca\AppData\Roaming\FAHClient\work
13:03:47:WU01:FS01:0x22:         OS: Windows 10 Pro
13:03:47:WU01:FS01:0x22:    OS Arch: AMD64
13:03:47:WU01:FS01:0x22:********************************************************************************
13:03:47:WU01:FS01:0x22:Project: 11752 (Run 0, Clone 3125, Gen 7)
13:03:47:WU01:FS01:0x22:Unit: 0x000000128ca304e75e6a806c7a2a4687
13:03:47:WU01:FS01:0x22:Reading tar file core.xml
13:03:47:WU01:FS01:0x22:Reading tar file integrator.xml
13:03:47:WU01:FS01:0x22:Reading tar file state.xml
13:03:47:WU02:FS00:Downloading 1.53MiB
13:03:49:WU01:FS01:0x22:Reading tar file system.xml
13:03:51:WU01:FS01:0x22:Digital signatures verified
13:03:51:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:03:51:WU01:FS01:0x22:Version 0.0.2
13:03:53:WU02:FS00:Download 81.89%
13:03:56:WU02:FS00:Download complete
13:03:56:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14328 run:9 clone:2507 gen:19 core:0xa7 unit:0x000000159bf7a4d65e6d0b567bf4b617
13:04:18:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
13:04:18:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:04:24:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
13:04:25:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
13:04:25:WU00:FS00:0xa7:Saving result file frame16.trr
13:04:25:WU00:FS00:0xa7:Saving result file md.log
13:04:25:WU00:FS00:0xa7:Saving result file pullf.xvg
13:04:25:WU00:FS00:0xa7:Saving result file pullx.xvg
13:04:25:WU00:FS00:0xa7:Saving result file science.log
13:04:25:WU00:FS00:0xa7:Saving result file traj_comp.xtc
13:04:25:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
13:04:25:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:04:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14307 run:1 clone:737 gen:16 core:0xa7 unit:0x000000139bf7a4d55e66c5c9206c1fab
13:04:25:WU00:FS00:Uploading 2.71MiB to 155.247.164.213
13:04:25:WU02:FS00:Starting
13:04:25:WU00:FS00:Connecting to 155.247.164.213:8080
13:04:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gonca\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 15332 -checkpoint 15 -np 10
13:04:25:WU02:FS00:Started FahCore on PID 8980
13:04:25:WU02:FS00:Core PID:1168
13:04:25:WU02:FS00:FahCore 0xa7 started
13:04:26:WU02:FS00:0xa7:*********************** Log Started 2020-03-21T13:04:25Z ***********************
13:04:26:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:04:26:WU02:FS00:0xa7:       Type: 0xa7
13:04:26:WU02:FS00:0xa7:       Core: Gromacs
13:04:26:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 8980 -checkpoint 15 -np
13:04:26:WU02:FS00:0xa7:             10
13:04:26:WU02:FS00:0xa7:************************************ CBang *************************************
13:04:26:WU02:FS00:0xa7:       Date: Oct 26 2019
13:04:26:WU02:FS00:0xa7:       Time: 01:38:25
13:04:26:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:04:26:WU02:FS00:0xa7:     Branch: master
13:04:26:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
13:04:26:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:04:26:WU02:FS00:0xa7:   Platform: win32 10
13:04:26:WU02:FS00:0xa7:       Bits: 64
13:04:26:WU02:FS00:0xa7:       Mode: Release
13:04:26:WU02:FS00:0xa7:************************************ System ************************************
13:04:26:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
13:04:26:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
13:04:26:WU02:FS00:0xa7:       CPUs: 12
13:04:26:WU02:FS00:0xa7:     Memory: 31.91GiB
13:04:26:WU02:FS00:0xa7:Free Memory: 24.98GiB
13:04:26:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
13:04:26:WU02:FS00:0xa7: OS Version: 6.2
13:04:26:WU02:FS00:0xa7:Has Battery: false
13:04:26:WU02:FS00:0xa7: On Battery: false
13:04:26:WU02:FS00:0xa7: UTC Offset: 0
13:04:26:WU02:FS00:0xa7:        PID: 1168
13:04:26:WU02:FS00:0xa7:        CWD: C:\Users\gonca\AppData\Roaming\FAHClient\work
13:04:26:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
13:04:26:WU02:FS00:0xa7:    Version: 0.0.18
13:04:26:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:04:26:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:04:26:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
13:04:26:WU02:FS00:0xa7:       Time: 01:52:30
13:04:26:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:04:26:WU02:FS00:0xa7:************************************ Build *************************************
13:04:26:WU02:FS00:0xa7:       SIMD: avx_256
13:04:26:WU02:FS00:0xa7:********************************************************************************
13:04:26:WU02:FS00:0xa7:Project: 14328 (Run 9, Clone 2507, Gen 19)
13:04:26:WU02:FS00:0xa7:Unit: 0x000000159bf7a4d65e6d0b567bf4b617
13:04:26:WU02:FS00:0xa7:Reading tar file core.xml
13:04:26:WU02:FS00:0xa7:Reading tar file frame19.tpr
13:04:26:WU02:FS00:0xa7:Digital signatures verified
13:04:26:WU02:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpt 15 -nt 10
13:04:26:WU02:FS00:0xa7:Steps: first=4750000 total=250000
13:04:28:WU00:FS00:Upload complete
13:04:28:WU00:FS00:Server responded WORK_ACK (400)
13:04:28:WU00:FS00:Final credit estimate, 1922.00 points
13:04:28:WU00:FS00:Cleaning up
13:04:28:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
13:05:16:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
13:05:48:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
13:06:05:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
13:06:23:WU01:FS01:0x22:ERROR:exception: clWaitForEvents
13:06:23:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:06:23:WU01:FS01:0x22:Saving result file checkpt.crc
13:06:23:WU01:FS01:0x22:Saving result file science.log
13:06:23:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:06:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:06:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11752 run:0 clone:3125 gen:7 core:0x22 unit:0x000000128ca304e75e6a806c7a2a4687
13:06:24:WU01:FS01:Uploading 3.33KiB to 140.163.4.231
13:06:24:WU01:FS01:Connecting to 140.163.4.231:8080
13:06:25:WU00:FS01:Connecting to 65.254.110.245:8080
13:06:25:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:06:25:WU00:FS01:Connecting to 18.218.241.186:80
13:06:25:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:06:25:ERROR:WU00:FS01:Exception: Could not get an assignment
13:06:26:WU00:FS01:Connecting to 65.254.110.245:8080
13:06:26:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:06:26:WU00:FS01:Connecting to 18.218.241.186:80
13:06:27:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:06:27:ERROR:WU00:FS01:Exception: Could not get an assignment
13:06:48:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
13:07:26:WU00:FS01:Connecting to 65.254.110.245:8080
13:07:26:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:07:26:WU00:FS01:Connecting to 18.218.241.186:80
13:07:27:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:07:27:ERROR:WU00:FS01:Exception: Could not get an assignment
13:07:28:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
Than you for your help.
Best regards.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: GPU stuck on Ready or Failed
Post by Jesse_V »
Folding@home's userbase has increased about 10x over the past several weeks, which has flooded the servers under the load and exhausted workunits faster than they can be generated. When the queue is empty, the server says "No WUs available for this configuration". The research teams are rapidly setting up new servers and getting more projects into the queue, including for the Wuhan Coronavirus, so hopefully that can keep up with demand soon. In the meantime, keep everything running and the software should pick up workunits when they are available.
Rel25917
Post by Rel25917 »
Did you even read the post Jesse? He is getting unit that are failing instantly. This is usually a driver problem. Were the drivers installed by windows? Windows does not include the opencl drivers and that looks like your problem, if you got them from the card manufacturer you need the full install if you didnt.
Paragon
Hardware configuration: Rig1 (Dedicated SMP): AMD Phenom II X6 1100T, Gigabyte GA-880GMA-USB3 board, 8 GB Kingston 1333 DDR3 Ram, Seasonic S12 II 380 Watt PSU, Noctua CPU Cooler
Rig2 (Part-Time GPU): Intel Q6600, Gigabyte 965P-S3 Board, EVGA 460 GTX Graphics, 8 GB Kingston 800 DDR2 Ram, Seasonic Gold X-650 PSU, Artic Cooling Freezer 7 CPU Cooler
Post by Paragon »
That's definitely not normal behavior. Yes there the starving for work unit thing going on too, but it's definitely failing .
I agree with Rel. Looks like messed up drivers. Do a full driver uninstall, reboot, and re-install from Nvidia's website. I am folding on a 1080 Ti right now with the latest Nvidia drivers, no problem.
Thread discussing that exact error: viewtopic.php?f=101&t=30779
Nvidia 1080 Ti Drivers: https://www.nvidia.com/Download/driverR ... 8759/en-us
Magnat07
Post by Magnat07 »
Rel25917 wrote:Did you even read the post Jesse? He is getting unit that are failing instantly. This is usually a driver problem. Were the drivers installed by windows? Windows does not include the opencl drivers and that looks like your problem, if you got them from the card manufacturer you need the full install if you didnt.
Yes. Today in the mornig I unnistall the drivers, and went to NVIDIA site and download the Gamers Ready Drivers from the scratch, and made a clean install.
EDIT: I went to Computer Management - Device Manager - Display Adapters - Driver Details, and I can see some ".....OPENCL.dll."
Magnat07
Post by Magnat07 »
Hi there,
so after your feedback, I installed the DDU to unnistall all the nvidia drivers. Made another clean full install from Nvidia site, again.
In this process also unnistall the FAH Control and installed it again.
After this morning, without touch the PC, I have the same probleme. Only the CPU works.
[Don't know what I can do.
HaloJones
Post by HaloJones »
is the card in any way overclocked?
Download GPU-z
once running, there is a little question mark halfway down on the right hand side. It will open a window with a box saying "Start Render Test". Open the Sensors tab on the main GPU-Z window which will show you temperatures etc. Then start the render test. It's not a stress test per se but it will give your card a little work to do. See what the sensors go to.
If that all looks OK, you might need to get another stress test for your GPU and check it works properly.
Sadly, games aren't nearly as challenging to the GPU as Folding@Home. It may be that your card is unable to fold reliably. It does happen.
4070 super
kostuek
Post by kostuek »
It appears you've got the newest 442.74 driver, which is from 03.19. Usually having the newest drivers is a good thing, but sometimes it also can break existing stuff. If nothing else helps, you may try and install a slightly older driver, for example https://www.nvidia.com/download/driverR ... 7537/en-us
Magnat07
Post by Magnat07 »
HaloJones wrote:is the card in any way overclocked?
Download GPU-z
I there, so I installed the GPU-z and run the render test, and I think that everthing wen very well.
https://i.imgur.com/K5sDLN4.png
kostuek wrote:It appears you've got the newest 442.74 driver, which is from 03.19. Usually having the newest drivers is a good thing, but sometimes it also can break existing stuff. If nothing else helps, you may try and install a slightly older driver, for example https://www.nvidia.com/download/driverR ... 7537/en-us
I already thin about that option, but I don't know what version to install. And at least yerterday someone say that have the same gpu with the latest drivers and the GPU foldes like a champ.
Which GPU drivers are you using and where did you download them from?
Magnat07
Post by Magnat07 »
bruce wrote:Which GPU drivers are you using and where did you download them from?
Current I have the version 442.74, and I got them from Nvidia offical site. And also made a clean install. Before the install I used the DDU program.
