New AMD Driver 20.3.1 seems good for FAH
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5043 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR/Sony Bravia 3(2024) EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.3 LTS Kernel 6.14.x HWE Generic UPS BX1500G
Post by DarkFoss »
If you are having temp/stability issues you may want to update to the 20.3.1 driver released today. It has lowered the temps on my Fury X by 2c. It also seems to have stopped a crashing issue on a fellow team members Vega.
DeeGee
Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10
Re: New AMD Driver 20.3.1 seems good for FAH
Post by DeeGee »
Hm, I guess I'll need to test if my Radeon VII works finally correctly with these drivers. I have had to keep on 19.12.1, as those were the newest drivers before the new Adrenaline 2020 update. Folding worked fine even on 2020 drivers, but if I used a browser with hardware acceleration at the same time, that would cause hard lock with black screen...
Post by foldy »
You can also disable browser hardware acceleration to not get issues.
Vester
Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
Post by Vester »
DeeGee, if your Radeon VII is a dedicated cruncher, you could try Radeon Software Crimson ReLive Edition Beta for Blockchain Compute. They have been around since 2017 and will remain "beta." They are not for gaming and don't worry that Radeon VII is not listed in the release notes.
Post by muziqaz »
Did they fix the issue when computer crashes while folding with GPU and browsing GPU accelerated browser?
Issue does not exist with 19.12.1, but reappeared in 20 series drivers
FAH Omega tester
Post by foldy »
Blockchain drivers beta are not a good choice for FAH as they optimize for memory timings used in e.g. ETH but FAH is not memory limited but by GPU clock and shaders.
DarkFoss
Post by DarkFoss »
I have hardware acceleration enabled in Chrome & Firefox. The only blackscreen issue I have with Chrome is if I pause a video walk away let the screensaver kick in it will randomly blackscreen and stay that way until restarted. It has never taken down the whole computer. I don't use Firefox enough to comment one way or the other.
Post by muziqaz »
DarkFoss wrote:I have hardware acceleration enabled in Chrome & Firefox. The only blackscreen issue I have with Chrome is if I pause a video walk away let the screensaver kick in it will randomly blackscreen and stay that way until restarted. It has never taken down the whole computer. I don't use Firefox enough to comment one way or the other.
Is this while folding and on newest driver?
FAH Omega tester
DarkFoss
Post by DarkFoss »
Yep, I went to bed last night with chrome minimized folding away. Came back this morning and just reopened the browser.
Post by muziqaz »
Thanks, will update mine tomorrow
FAH Omega tester
DarkFoss
Post by DarkFoss »
muziqaz wrote:Thanks, will update mine tomorrow
Your welcome. :D
I'm curious have you submitted a bug report with Amd? They have been hot and heavy with blackscreen fixes the past few releases. They can't fix what they don't know about. If this does help you'd be able to add feedback to make sure this optional driver fixes get mainlined too.
Post by muziqaz »
Your welcome. :D
Yes, I have been on the blast with their support. Now I'm dealing with distorted mouse cursor in dual monitor situation, the bug which has been with AMD for decade.
FAH Omega tester
DarkFoss
Post by DarkFoss »
muziqaz wrote:
Your welcome. :D
Yuck, I feel your pain dual booting with Linux is why I don't use a dual monitor set up anymore.
