Quadro 5000 GPU's
r0k0
- Hardware configuration: Intel i7 6850K - MSI Tomahawk - 32GB DDR4-3000 - Asus ROG 5700XT
Intel 2x Xeon X5675 - HP Board - 48GB DDR3-1333 ECC - nVIDIA Quadro K4000 - Location: Gatineau, QC
Quadro 5000 GPU's
I saw 2 quadros 5000 cards for sale dirt cheap, ive searched to check how they performe but can't find any.
How do they performe in folding and do we put them in sli or not ?
Main - Intel 10700K / Asus Z490-E / 32GBGB DDR4-3200 / 2080Ti
Folding - HP Z220 Xeon E3 1245 V2 / 16GB DDR3-1600 / GTX 1060 6GB
Folding - HP Z420 Xeon E5 2650 / 16GB DDR3-1600 ECC / GTX 1070Ti
Folding - HP Z800 2X Xeon X5675 / 48GB DDR3-1333 ECC / RX480
Nathan_P
Not currently folding
Re: Quadro 5000 GPU's
That would depend on which quadro 5000 they were, Fermi.Kepler, Maxwell, Pascal or RTX? The model usually goes P5000 for example which would indicate a pascal based quadro 5000 which is a powerful card, a Kepler based 5000 - not so much.
If these are named exactly as Quadro 5000, those are based on Fermi, about the equivalent of a GTX 465 running at a slower clock. Still usable, but Kepler or newer would be recommended.
r0k0
Ok thanks guys for the reply, they are 2.5gb cards so fermi. I will skip then
Hello,
I have a Quadro P5000 here, and I get 82918 PPD (could get more, but I have manually set gpu-power=90 to avoid it totally sucking up my GUI performance)
Cheers,
-- Durval.
Cheers,
-- Durval.
Welcome to the F@H Forum durval,
Please note that the feature of gpu-power isn't functional. Thus, you can remove it from your configuration. If you if you have questions about your configuration, please post them with your log file for us to comment on (viewtopic.php?f=24&t=26036).
Nathan_P
hi Durval
for a P5000 that seems low, do you have a passkey?
https://foldingathome.org/support/faq/points/passkey/
If you go up one page from the passkey link Nathan_P linked you will get a description of the points system and the QRB qualification requirements - QRB has a very significant impact on points for faster machines.
Hello @PantherX,
Cheers,
-- Durval
Thanks!PantherX wrote:Welcome to the F@H Forum durval,
Weird! I was pretty sure I saw more responsiveness from mostly-graphical apps (like web browsers) in my system when I changed it down from its default of 100. Placebo effect, perhaps... :-/PantherX wrote:Please note that the feature of gpu-power isn't functional.
Does it cause any damage or problems being left there? Placebo effect is an effect nonethelessPantherX wrote:Thus, you can remove it from your configuration.
Not really... I think I got it pretty much figured out now that you set me straight re: gpu-power. But thanks for the pointer!PantherX wrote:If you if you have questions about your configuration, please post them with your log file for us to comment on (viewtopic.php?f=24&t=26036).
Cheers,
-- Durval
I would think coincidence. Reason is that on some GPUs, large WUs can cause screen lag. It is possible that when you entered that flag, you got a smaller WU which didn't cause screen lag.durval wrote:...Weird! I was pretty sure I saw more responsiveness from mostly-graphical apps (like web browsers) in my system when I changed it down from its default of 100. Placebo effect, perhaps... :-/...
If you would like to minimize screens lag from your system while folding, I would suggest that you can disable hardware acceleration on your system and other applications. Here are some pointers to common applications:
Windows: https://www.thewindowsclub.com/hardware ... -windows-7
Firefox: https://support.mozilla.org/en-US/kb/ha ... inds-crash
Chrome: https://www.technize.net/google-chrome- ... eleration/
VLC: https://wiki.videolan.org/VLC_HowTo/Har ... eleration/
Nope, anything that the FahCore (the code that does the folding) doesn't accept as a parameter (values passed to it) will be ignored.durval wrote:...Does it cause any damage or problems being left there?...
