AMD GPU RX470 does not show any progress
christianlupus
Post by christianlupus »
Hello,
I just joined FAH and installed it on my personal workstation. This is yet working on the CPU but not on the GPU. I put the logs here in a gist. Unfortunately, I am not yet allowed to post URLs.
*********************** Log Started 2020-03-18T12:10:38Z ***********************
12:10:38:************************* Folding@home Client *************************
12:10:38:        Website: https://foldingathome.org/
12:10:38:      Copyright: (c) 2009-2018 foldingathome.org
12:10:38:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:38:           Args:
12:10:38:         Config: /var/lib/private/fah/config.xml
12:10:38:******************************** Build ********************************
12:10:38:        Version: 7.5.1
12:10:38:           Date: May 11 2018
12:10:38:           Time: 19:59:04
12:10:38:     Repository: Git
12:10:38:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:10:38:         Branch: master
12:10:38:       Compiler: GNU 6.3.0 20170516
12:10:38:        Options: -std=gnu++98 -O3 -funroll-loops
12:10:38:       Platform: linux2 4.14.0-3-amd64
12:10:38:           Bits: 64
12:10:38:           Mode: Release
12:10:38:******************************* System ********************************
12:10:38:            CPU: AMD FX(tm)-8320 Eight-Core Processor
12:10:38:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
12:10:38:           CPUs: 8
12:10:38:         Memory: 23.52GiB
12:10:38:    Free Memory: 22.98GiB
12:10:38:        Threads: POSIX_THREADS
12:10:38:     OS Version: 5.5
12:10:38:    Has Battery: false
12:10:38:     On Battery: false
12:10:38:     UTC Offset: 1
12:10:38:            PID: 842
12:10:38:            CWD: /var/lib/private/fah
12:10:38:             OS: Linux 5.5.9-arch1-2 x86_64
12:10:38:        OS Arch: AMD64
12:10:38:           GPUs: 1
12:10:38:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
12:10:38:                 470/480/570/580]
12:10:38:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
12:10:38:                 libcuda.so: cannot open shared object file: No such file or
12:10:38:                 directory
12:10:38:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.6
12:10:38:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:19.3
12:10:38:***********************************************************************
12:10:38:<config>
12:10:38:  <!-- Client Control -->
12:10:38:  <client-threads v='6'/>
12:10:38:  <cycle-rate v='4'/>
12:10:38:  <cycles v='-1'/>
12:10:38:  <data-directory v='.'/>
12:10:38:  <disable-sleep-when-active v='true'/>
12:10:38:  <exec-directory v='/opt/fah'/>
12:10:38:  <exit-when-done v='false'/>
12:10:38:  <fold-anon v='false'/>
12:10:38:  <idle-seconds v='300'/>
12:10:38:  <open-web-control v='false'/>
12:10:38:
12:10:38:  <!-- Configuration -->
12:10:38:  <config-rotate v='true'/>
12:10:38:  <config-rotate-dir v='configs'/>
12:10:38:  <config-rotate-max v='16'/>
12:10:38:
12:10:38:  <!-- Debugging -->
12:10:38:  <assignment-servers>
12:10:38:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
12:10:38:  </assignment-servers>
12:10:38:  <auth-as v='true'/>
12:10:38:  <capture-directory v='capture'/>
12:10:38:  <capture-on-error v='false'/>
12:10:38:  <capture-packets v='false'/>
12:10:38:  <capture-requests v='false'/>
12:10:38:  <capture-responses v='false'/>
12:10:38:  <capture-sockets v='false'/>
12:10:38:  <core-exec v='FahCore_$type'/>
12:10:38:  <core-wrapper-exec v='FAHCoreWrapper'/>
12:10:38:  <debug-sockets v='false'/>
12:10:38:  <exception-locations v='true'/>
12:10:38:  <stack-traces v='false'/>
12:10:38:
12:10:38:  <!-- Error Handling -->
12:10:38:  <max-slot-errors v='10'/>
12:10:38:  <max-unit-errors v='5'/>
12:10:38:
12:10:38:  <!-- Folding Core -->
12:10:38:  <checkpoint v='15'/>
12:10:38:  <core-dir v='cores'/>
12:10:38:  <core-priority v='idle'/>
12:10:38:  <cpu-affinity v='false'/>
12:10:38:  <cpu-usage v='100'/>
12:10:38:  <gpu-usage v='100'/>
12:10:38:  <no-assembly v='false'/>
12:10:38:
12:10:38:  <!-- Folding Slot Configuration -->
12:10:38:  <cause v='ANY'/>
12:10:38:  <client-subtype v='LINUX'/>
12:10:38:  <client-type v='normal'/>
12:10:38:  <cpu-species v='X86_AMD'/>
12:10:38:  <cpu-type v='AMD64'/>
12:10:38:  <cpus v='-1'/>
12:10:38:  <disable-viz v='false'/>
12:10:38:  <gpu v='true'/>
12:10:38:  <max-packet-size v='normal'/>
12:10:38:  <os-species v='UNKNOWN'/>
12:10:38:  <os-type v='LINUX'/>
12:10:38:  <project-key v='0'/>
12:10:38:  <smp v='true'/>
12:10:38:
12:10:38:  <!-- GUI -->
12:10:38:  <gui-enabled v='true'/>
12:10:38:
12:10:38:  <!-- HTTP Server -->
12:10:38:  <allow v='127.0.0.1 192.168.6.0/24'/>
12:10:38:  <connection-timeout v='60'/>
12:10:38:  <deny v='0/0'/>
12:10:38:  <http-addresses v='0:7396'/>
12:10:38:  <https-addresses v=''/>
12:10:38:  <max-connect-time v='900'/>
12:10:38:  <max-connections v='800'/>
12:10:38:  <max-request-length v='52428800'/>
12:10:38:  <min-connect-time v='300'/>
12:10:38:
12:10:38:  <!-- Logging -->
12:10:38:  <log v='log.txt'/>
12:10:38:  <log-color v='true'/>
12:10:38:  <log-crlf v='false'/>
12:10:38:  <log-date v='false'/>
12:10:38:  <log-date-periodically v='21600'/>
12:10:38:  <log-domain v='false'/>
12:10:38:  <log-header v='true'/>
12:10:38:  <log-level v='true'/>
12:10:38:  <log-no-info-header v='true'/>
12:10:38:  <log-redirect v='false'/>
12:10:38:  <log-rotate v='true'/>
12:10:38:  <log-rotate-dir v='logs'/>
12:10:38:  <log-rotate-max v='16'/>
12:10:38:  <log-short-level v='false'/>
12:10:38:  <log-simple-domains v='true'/>
12:10:38:  <log-thread-id v='false'/>
12:10:38:  <log-thread-prefix v='true'/>
12:10:38:  <log-time v='true'/>
12:10:38:  <log-to-screen v='true'/>
12:10:38:  <log-truncate v='false'/>
12:10:38:  <verbosity v='4'/>
12:10:38:
12:10:38:  <!-- Network -->
12:10:38:  <proxy v=':8080'/>
12:10:38:  <proxy-enable v='false'/>
12:10:38:  <proxy-pass v=''/>
12:10:38:  <proxy-user v=''/>
12:10:38:
12:10:38:  <!-- Process Control -->
12:10:38:  <child v='false'/>
12:10:38:  <daemon v='false'/>
12:10:38:  <fork v='false'/>
12:10:38:  <pid v='false'/>
12:10:38:  <pid-file v='Folding@home Client.pid'/>
12:10:38:  <respawn v='false'/>
12:10:38:  <service v='false'/>
12:10:38:
12:10:38:  <!-- Remote Command Server -->
12:10:38:  <command-address v='0.0.0.0'/>
12:10:38:  <command-allow-no-pass v='127.0.0.1'/>
12:10:38:  <command-deny-no-pass v='0/0'/>
12:10:38:  <command-enable v='true'/>
12:10:38:  <command-port v='36330'/>
12:10:38:
12:10:38:  <!-- Slot Control -->
12:10:38:  <idle v='false'/>
12:10:38:  <max-shutdown-wait v='60'/>
12:10:38:  <pause-on-battery v='true'/>
12:10:38:  <pause-on-start v='false'/>
12:10:38:  <paused v='false'/>
12:10:38:  <power v='FULL'/>
12:10:38:
12:10:38:  <!-- User Information -->
12:10:38:  <machine-id v='0'/>
12:10:38:  <passkey v=''/>
12:10:38:  <team v='45032'/>
12:10:38:  <user v='christianlupus1987'/>
12:10:38:
12:10:38:  <!-- Web Server -->
12:10:38:  <web-allow v='127.0.0.1 192.168.6.0/24'/>
12:10:38:  <web-deny v='0/0'/>
12:10:38:  <web-enable v='true'/>
12:10:38:
12:10:38:  <!-- Web Server Sessions -->
12:10:38:  <session-cookie v='sid'/>
12:10:38:  <session-lifetime v='86400'/>
12:10:38:  <session-timeout v='3600'/>
12:10:38:
12:10:38:  <!-- Work Unit Control -->
12:10:38:  <dump-after-deadline v='true'/>
12:10:38:  <max-queue v='16'/>
12:10:38:  <max-units v='0'/>
12:10:38:  <next-unit-percentage v='99'/>
12:10:38:  <stall-detection-enabled v='false'/>
12:10:38:  <stall-percent v='5'/>
12:10:38:  <stall-timeout v='1800'/>
12:10:38:
12:10:38:  <!-- Folding Slots -->
12:10:38:  <slot id='0' type='CPU'>
12:10:38:    <paused v='true'/>
12:10:38:  </slot>
12:10:38:  <slot id='1' type='GPU'>
12:10:38:  </slot>
12:10:38:</config>
12:10:38:Trying to access database...
12:10:38:Successfully acquired database lock
12:10:38:Enabled folding slot 00: PAUSED cpu:7 (by user)
12:10:38:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (by user)
12:14:12:1:192.168.6.2 GET /api/updates?_=1584533180550&sid=34f46d9bc63a455a7a972ba87c213227
12:14:13:3:192.168.6.2 GET /
12:14:13:4:192.168.6.2 GET /api/updates?_=1584533180551&sid=34f46d9bc63a455a7a972ba87c213227
12:14:14:5:192.168.6.2 GET /css/normalize.css
12:14:14:6:192.168.6.2 GET /css/main.css
12:14:14:7:192.168.6.2 GET /js/jquery-1.10.2.min.js
12:14:14:8:192.168.6.2 GET /js/libs/jquery.selectbox-0.2.js
12:14:14:9:192.168.6.2 GET /js/intercom.min.js
12:14:14:10:192.168.6.2 GET /js/main.js
12:14:14:10:192.168.6.2:New Web connection
12:14:15:11:192.168.6.2 GET /images/mail.png
12:14:15:12:192.168.6.2 GET /images/facebook.png
12:14:15:13:192.168.6.2 GET /images/twitter.png
12:14:15:14:192.168.6.2 GET /images/report-bug.png
12:14:15:15:192.168.6.2 GET /images/template/bg.jpg
12:14:15:16:192.168.6.2 GET /images/template/logo_folding_home.png
12:14:15:17:192.168.6.2 GET /api/updates/set?_=1584533655061&sid=dc690ebafc2e993f4d56ea450f13b21f&update_id=0&update_path=/api/basic&update_rate=1
12:14:15:18:192.168.6.2 GET /api/updates/set?_=1584533655062&sid=dc690ebafc2e993f4d56ea450f13b21f&update_id=1&update_path=/api/slots&update_rate=1
12:14:15:19:192.168.6.2 GET /api/configured?_=1584533655063&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:15:20:192.168.6.2 GET /images/template/input_radio.png
12:14:16:21:192.168.6.2 GET /images/template/button_bg.png
12:14:16:22:192.168.6.2 GET /api/updates?_=1584533655064&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:16:23:192.168.6.2 GET /images/template/select-icons.png
12:14:16:24:192.168.6.2 GET /images/template/ui-bg-slider.png
12:14:17:22:192.168.6.2 GET /api/updates?_=1584533655065&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:17:25:192.168.6.2 GET /images/template/ui-icon-slider.png
12:14:17:26:192.168.6.2 GET /images/template/ui-progress-bg.png
12:14:18:27:192.168.6.2 GET /favicon.ico
12:14:18:28:192.168.6.2 GET /api/updates?_=1584533655068&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:22:28:192.168.6.2 GET /api/set?_=1584533655069&pause=false&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:22:FS00:Unpaused
12:14:22:FS01:Unpaused
12:14:22:WU01:FS01:Starting
12:14:22:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 842 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:14:22:WU01:FS01:Started FahCore on PID 2094
12:14:22:WU01:FS01:Core PID:2098
12:14:22:WU01:FS01:FahCore 0x22 started
12:14:22:29:192.168.6.2 GET /api/updates?_=1584533655070&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:22:WU00:FS00:Connecting to 65.254.110.245:8080
12:14:22:WU01:FS01:0x22:*********************** Log Started 2020-03-18T12:14:22Z ***********************
12:14:22:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:14:22:WU01:FS01:0x22:       Type: 0x22
12:14:22:WU01:FS01:0x22:       Core: Core22
12:14:22:WU01:FS01:0x22:    Website: https://foldingathome.org/
12:14:22:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:14:22:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:14:22:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:14:22:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2094 -checkpoint 15
12:14:22:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:14:22:WU01:FS01:0x22:     Config: <none>
12:14:22:WU01:FS01:0x22:************************************ Build *************************************
12:14:22:WU01:FS01:0x22:    Version: 0.0.2
12:14:22:WU01:FS01:0x22:       Date: Dec 6 2019
12:14:22:WU01:FS01:0x22:       Time: 21:20:17
12:14:22:WU01:FS01:0x22: Repository: Git
12:14:22:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
12:14:22:WU01:FS01:0x22:     Branch: core22
12:14:22:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
12:14:22:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
12:14:22:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
12:14:22:WU01:FS01:0x22:       Bits: 64
12:14:22:WU01:FS01:0x22:       Mode: Release
12:14:22:WU01:FS01:0x22:************************************ System ************************************
12:14:22:WU01:FS01:0x22:        CPU: AMD FX(tm)-8320 Eight-Core Processor
12:14:22:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
12:14:22:WU01:FS01:0x22:       CPUs: 8
12:14:22:WU01:FS01:0x22:     Memory: 23.52GiB
12:14:22:WU01:FS01:0x22:Free Memory: 21.54GiB
12:14:22:WU01:FS01:0x22:    Threads: POSIX_THREADS
12:14:22:WU01:FS01:0x22: OS Version: 5.5
12:14:22:WU01:FS01:0x22:Has Battery: false
12:14:22:WU01:FS01:0x22: On Battery: false
12:14:22:WU01:FS01:0x22: UTC Offset: 1
12:14:22:WU01:FS01:0x22:        PID: 2098
12:14:22:WU01:FS01:0x22:        CWD: /var/lib/private/fah/work
12:14:22:WU01:FS01:0x22:         OS: Linux 5.5.9-arch1-2 x86_64
12:14:22:WU01:FS01:0x22:    OS Arch: AMD64
12:14:22:WU01:FS01:0x22:********************************************************************************
12:14:22:WU01:FS01:0x22:Project: 11755 (Run 0, Clone 1033, Gen 8)
12:14:22:WU01:FS01:0x22:Unit: 0x0000000b9bf7a4d55e6d76e29be256f9
12:14:22:WU01:FS01:0x22:Reading tar file core.xml
12:14:22:WU01:FS01:0x22:Reading tar file integrator.xml
12:14:22:WU01:FS01:0x22:Reading tar file state.xml
[93m12:14:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:14:23:WU00:FS00:Connecting to 18.218.241.186:80
[93m12:14:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:14:23:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:14:23:WU01:FS01:0x22:Reading tar file system.xml
12:14:23:WU00:FS00:Connecting to 65.254.110.245:8080
12:14:24:WU01:FS01:0x22:Digital signatures verified
12:14:24:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:14:24:WU01:FS01:0x22:Version 0.0.2
[93m12:14:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:14:24:WU00:FS00:Connecting to 18.218.241.186:80
12:14:24:22:192.168.6.2 GET /images/template/anim_arrow.gif
[93m12:14:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:14:24:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:14:25:30:192.168.6.2 GET /api/updates?_=1584533655072&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:41:30:192.168.6.2 GET /api/updates?_=1584533655083&sid=dc690ebafc2e993f4d56ea450f13b21f
12:14:42:Saving configuration to config.xml
12:14:42:<config>
12:14:42:  <!-- HTTP Server -->
12:14:42:  <allow v='127.0.0.1 192.168.6.0/24'/>
12:14:42:
12:14:42:  <!-- Logging -->
12:14:42:  <verbosity v='4'/>
12:14:42:
12:14:42:  <!-- Network -->
12:14:42:  <proxy v=':8080'/>
12:14:42:
12:14:42:  <!-- Slot Control -->
12:14:42:  <power v='FULL'/>
12:14:42:
12:14:42:  <!-- User Information -->
12:14:42:  <team v='45032'/>
12:14:42:  <user v='christianlupus1987'/>
12:14:42:
12:14:42:  <!-- Web Server -->
12:14:42:  <web-allow v='127.0.0.1 192.168.6.0/24'/>
12:14:42:
12:14:42:  <!-- Folding Slots -->
12:14:42:  <slot id='0' type='CPU'/>
12:14:42:  <slot id='1' type='GPU'/>
12:14:42:</config>
12:14:43:29:192.168.6.2 GET /api/updates?_=1584533655084&sid=dc690ebafc2e993f4d56ea450f13b21f
12:15:23:30:192.168.6.2 GET /api/updates?_=1584533655111&sid=dc690ebafc2e993f4d56ea450f13b21f
12:15:23:WU00:FS00:Connecting to 65.254.110.245:8080
[93m12:15:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:15:24:WU00:FS00:Connecting to 18.218.241.186:80
[93m12:15:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:15:24:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:15:25:29:192.168.6.2 GET /api/updates?_=1584533655112&sid=dc690ebafc2e993f4d56ea450f13b21f
12:16:54:30:192.168.6.2 GET /api/updates?_=1584533655176&sid=dc690ebafc2e993f4d56ea450f13b21f
12:17:01:WU00:FS00:Connecting to 65.254.110.245:8080
[93m12:17:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:17:01:WU00:FS00:Connecting to 18.218.241.186:80
[93m12:17:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:17:02:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:18:34:30:192.168.6.2 GET /api/updates?_=1584533655177&sid=dc690ebafc2e993f4d56ea450f13b21f
12:19:36:33:192.168.6.2 GET /api/updates?_=1584533655214&sid=dc690ebafc2e993f4d56ea450f13b21f
12:19:38:WU00:FS00:Connecting to 65.254.110.245:8080
12:19:38:30:192.168.6.2 GET /api/updates?_=1584533655215&sid=dc690ebafc2e993f4d56ea450f13b21f
[93m12:19:38:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:19:38:WU00:FS00:Connecting to 18.218.241.186:80
[93m12:19:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:19:39:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:19:39:33:192.168.6.2 GET /api/updates?_=1584533655216&sid=dc690ebafc2e993f4d56ea450f13b21f
12:20:40:33:192.168.6.2 GET /api/updates?_=1584533655261&sid=dc690ebafc2e993f4d56ea450f13b21f
12:23:52:WU00:FS00:Connecting to 65.254.110.245:8080
[93m12:23:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:23:53:WU00:FS00:Connecting to 18.218.241.186:80
[93m12:23:53:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m12:23:53:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
12:26:55:34:192.168.6.2 GET /api/updates?_=1584533655262&sid=dc690ebafc2e993f4d56ea450f13b21f
12:28:59:35:192.168.6.2 GET /api/updates?_=1584533655349&sid=dc690ebafc2e993f4d56ea450f13b21f
12:30:44:WU00:FS00:Connecting to 65.254.110.245:8080
[93m12:30:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration[0m
12:30:44:WU00:FS00:Connecting to 18.218.241.186:80
12:30:45:WU00:FS00:Assigned to work server 155.247.164.213
12:30:45:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.213
12:30:45:WU00:FS00:Connecting to 155.247.164.213:8080
12:30:45:WU00:FS00:Downloading 1.23MiB
12:30:46:WU00:FS00:Download complete
12:30:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14308 run:9 clone:913 gen:6 core:0xa7 unit:0x000000079bf7a4d55e66c2b6d4b14ea7
12:30:47:WU00:FS00:Starting
12:30:47:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 842 -checkpoint 15 -np 7
12:30:47:WU00:FS00:Started FahCore on PID 2333
12:30:47:WU00:FS00:Core PID:2337
12:30:47:WU00:FS00:FahCore 0xa7 started
12:30:47:WU00:FS00:0xa7:*********************** Log Started 2020-03-18T12:30:47Z ***********************
12:30:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:30:47:WU00:FS00:0xa7:       Type: 0xa7
12:30:47:WU00:FS00:0xa7:       Core: Gromacs
12:30:47:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2333 -checkpoint 15 -np 7
12:30:47:WU00:FS00:0xa7:************************************ CBang *************************************
12:30:47:WU00:FS00:0xa7:       Date: Nov 5 2019
12:30:47:WU00:FS00:0xa7:       Time: 06:06:57
12:30:47:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
12:30:47:WU00:FS00:0xa7:     Branch: master
12:30:47:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
12:30:47:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
12:30:47:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
12:30:47:WU00:FS00:0xa7:       Bits: 64
12:30:47:WU00:FS00:0xa7:       Mode: Release
12:30:47:WU00:FS00:0xa7:************************************ System ************************************
12:30:47:WU00:FS00:0xa7:        CPU: AMD FX(tm)-8320 Eight-Core Processor
12:30:47:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
12:30:47:WU00:FS00:0xa7:       CPUs: 8
12:30:47:WU00:FS00:0xa7:     Memory: 23.52GiB
12:30:47:WU00:FS00:0xa7:Free Memory: 21.04GiB
12:30:47:WU00:FS00:0xa7:    Threads: POSIX_THREADS
12:30:47:WU00:FS00:0xa7: OS Version: 5.5
12:30:47:WU00:FS00:0xa7:Has Battery: false
12:30:47:WU00:FS00:0xa7: On Battery: false
12:30:47:WU00:FS00:0xa7: UTC Offset: 1
12:30:47:WU00:FS00:0xa7:        PID: 2337
12:30:47:WU00:FS00:0xa7:        CWD: /var/lib/private/fah/work
12:30:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:30:47:WU00:FS00:0xa7:    Version: 0.0.18
12:30:47:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:30:47:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:30:47:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:30:47:WU00:FS00:0xa7:       Time: 06:13:26
12:30:47:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
12:30:47:WU00:FS00:0xa7:************************************ Build *************************************
12:30:47:WU00:FS00:0xa7:       SIMD: avx_256
12:30:47:WU00:FS00:0xa7:********************************************************************************
12:30:47:WU00:FS00:0xa7:Project: 14308 (Run 9, Clone 913, Gen 6)
12:30:47:WU00:FS00:0xa7:Unit: 0x000000079bf7a4d55e66c2b6d4b14ea7
12:30:47:WU00:FS00:0xa7:Reading tar file core.xml
12:30:47:WU00:FS00:0xa7:Reading tar file frame6.tpr
12:30:47:WU00:FS00:0xa7:Digital signatures verified
12:30:47:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
12:30:47:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 6
12:30:47:WU00:FS00:0xa7:Steps: first=3000000 total=500000
12:30:48:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:32:02:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
12:33:17:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
12:34:31:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
12:35:24:36:192.168.6.2 GET /api/updates?_=1584533655351&sid=dc690ebafc2e993f4d56ea450f13b21f
12:35:44:37:192.168.6.2 GET /api/updates?_=1584533655367&sid=dc690ebafc2e993f4d56ea450f13b21f
12:35:45:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
12:35:46:36:192.168.6.2 GET /api/updates?_=1584533655368&sid=dc690ebafc2e993f4d56ea450f13b21f
As far as understand things, there is already a job assigned to the GPU but the GOU seems unaffected by this. Checking load on radeontop does show that the graphics card is mostly idle.
Am I missing anything relevant here or why can I not start the GPU computing?
Thank you
Christian
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: AMD GPU RX470 does not show any progress
Post by Jesse_V »
The "No WUs available for this configuration" error is common at the moment. The servers are slammed due to the overwhelming number of new users, which have exhausted most of the workunits in the queue. The research teams are working swiftly to set up new servers and get more projects into the queue. I'd recommend keeping everything running as the GPU should pick up work when it's available.
viewtopic.php?f=17&p=314942#p314942
viewtopic.php?f=61&t=32424
christianlupus
You are referring to FS00, which in turn is my CPU slot. There was some successful work done, no problem here.
The problem is FS01. I try to add the gist link once more. Her is a screenshot of the current process:
You see that the GPU has in fact a WU associated. It is running. But it did not make any progress and the GPU also has no load. So I assume it is simply not firing up correctly the job.
Christian
You can also post your log here. But first, change the logging verbosity back to the default value of 3, the extra messages in the log are not providing any useful information for troubleshooting your system.
Briefly, I did spot one possible problem with your installation of OpenCL support, but could not tell because of the extra verbosity.
_r2w_ben
Post by _r2w_ben »
I recently had a GPU work unit startup but never made any progress. This was on Windows and FahCore_22.exe could not be killed via Task Manager. The work unit successfully began processing after a reboot and ran to completion.
Since you're running Linux, try restarting the FAHclient service and see if it progresses to 1% within ~10 minutes.
This is my log from when this happened.
02:11:27:WU01:FS01:Connecting to 128.252.203.10:80
02:12:04:WU01:FS01:Downloading 50.83MiB
02:12:10:WU01:FS01:Download 12.54%
02:12:16:WU01:FS01:Download 22.87%
02:12:22:WU01:FS01:Download 32.46%
02:12:28:WU01:FS01:Download 43.52%
02:12:34:WU01:FS01:Download 53.97%
02:12:40:WU01:FS01:Download 67.87%
02:12:46:WU01:FS01:Download 82.01%
02:12:52:WU01:FS01:Download 92.95%
02:12:54:WU01:FS01:Download complete
02:12:55:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:7392 gen:0 core:0x22 unit:0x0000000080fccb0a5e7113d6ea191baf
02:12:55:WU01:FS01:Starting
02:12:55:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\[snip]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 1384 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:12:55:WU01:FS01:Started FahCore on PID 4104
02:12:55:WU01:FS01:Core PID:3276
02:12:55:WU01:FS01:FahCore 0x22 started
02:12:55:WU01:FS01:0x22:*********************** Log Started 2020-03-18T02:12:55Z ***********************
02:12:55:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:12:55:WU01:FS01:0x22:       Type: 0x22
02:12:55:WU01:FS01:0x22:       Core: Core22
02:12:55:WU01:FS01:0x22:    Website: https://foldingathome.org/
02:12:55:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
02:12:55:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
02:12:55:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
02:12:55:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4104 -checkpoint 15
02:12:55:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:12:55:WU01:FS01:0x22:     Config: <none>
02:12:55:WU01:FS01:0x22:************************************ Build *************************************
02:12:55:WU01:FS01:0x22:    Version: 0.0.2
02:12:55:WU01:FS01:0x22:       Date: Dec 6 2019
02:12:55:WU01:FS01:0x22:       Time: 21:30:31
02:12:55:WU01:FS01:0x22: Repository: Git
02:12:55:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
02:12:55:WU01:FS01:0x22:     Branch: HEAD
02:12:55:WU01:FS01:0x22:   Compiler: Visual C++ 2008
02:12:55:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:12:55:WU01:FS01:0x22:   Platform: win32 10
02:12:55:WU01:FS01:0x22:       Bits: 64
02:12:55:WU01:FS01:0x22:       Mode: Release
02:12:55:WU01:FS01:0x22:************************************ System ************************************
02:12:55:WU01:FS01:0x22:        CPU: AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G
02:12:55:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
02:12:55:WU01:FS01:0x22:       CPUs: 4
02:12:55:WU01:FS01:0x22:     Memory: 6.94GiB
02:12:55:WU01:FS01:0x22:Free Memory: 5.24GiB
02:12:55:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
02:12:55:WU01:FS01:0x22: OS Version: 6.2
02:12:55:WU01:FS01:0x22:Has Battery: false
02:12:55:WU01:FS01:0x22: On Battery: false
02:12:55:WU01:FS01:0x22: UTC Offset: -4
02:12:55:WU01:FS01:0x22:        PID: 3276
02:12:55:WU01:FS01:0x22:        CWD: C:\Users\[snip]\AppData\Roaming\FAHClient\work
02:12:55:WU01:FS01:0x22:         OS: Windows 8.1
02:12:55:WU01:FS01:0x22:    OS Arch: AMD64
02:12:55:WU01:FS01:0x22:********************************************************************************
02:12:55:WU01:FS01:0x22:Project: 11762 (Run 0, Clone 7392, Gen 0)
02:12:55:WU01:FS01:0x22:Unit: 0x0000000080fccb0a5e7113d6ea191baf
02:12:55:WU01:FS01:0x22:Reading tar file core.xml
02:12:55:WU01:FS01:0x22:Reading tar file integrator.xml
02:12:55:WU01:FS01:0x22:Reading tar file state.xml
02:12:55:WU01:FS01:0x22:Reading tar file system.xml
02:12:55:WU01:FS01:0x22:Digital signatures verified
02:12:55:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:12:55:WU01:FS01:0x22:Version 0.0.2
02:13:16:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
02:13:17:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
christianlupus
Hello once more,
I recently rebooted but restarted nevertheless. There was no change in the effect. I put here the log lines regarding the GPU (by applying grep FS01 to log.txt):
07:04:39:WU01:FS01:Starting
07:04:39:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /var/lib/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 2444 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:04:39:WU01:FS01:Started FahCore on PID 2484
07:04:39:WU01:FS01:Core PID:2488
07:04:39:WU01:FS01:FahCore 0x22 started
07:04:39:WU01:FS01:0x22:*********************** Log Started 2020-03-19T07:04:39Z ***********************
07:04:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:04:39:WU01:FS01:0x22:       Type: 0x22
07:04:39:WU01:FS01:0x22:       Core: Core22
07:04:39:WU01:FS01:0x22:    Website: https://foldingathome.org/
07:04:39:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
07:04:39:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:04:39:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
07:04:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15
07:04:39:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:04:39:WU01:FS01:0x22:     Config: <none>
07:04:39:WU01:FS01:0x22:************************************ Build *************************************
07:04:39:WU01:FS01:0x22:    Version: 0.0.2
07:04:39:WU01:FS01:0x22:       Date: Dec 6 2019
07:04:39:WU01:FS01:0x22:       Time: 21:20:17
07:04:39:WU01:FS01:0x22: Repository: Git
07:04:39:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
07:04:39:WU01:FS01:0x22:     Branch: core22
07:04:39:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
07:04:39:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
07:04:39:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
07:04:39:WU01:FS01:0x22:       Bits: 64
07:04:39:WU01:FS01:0x22:       Mode: Release
07:04:39:WU01:FS01:0x22:************************************ System ************************************
07:04:39:WU01:FS01:0x22:        CPU: AMD FX(tm)-8320 Eight-Core Processor
07:04:39:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
07:04:39:WU01:FS01:0x22:       CPUs: 8
07:04:39:WU01:FS01:0x22:     Memory: 23.52GiB
07:04:39:WU01:FS01:0x22:Free Memory: 21.01GiB
07:04:39:WU01:FS01:0x22:    Threads: POSIX_THREADS
07:04:39:WU01:FS01:0x22: OS Version: 5.5
07:04:39:WU01:FS01:0x22:Has Battery: false
07:04:39:WU01:FS01:0x22: On Battery: false
07:04:39:WU01:FS01:0x22: UTC Offset: 1
07:04:39:WU01:FS01:0x22:        PID: 2488
07:04:39:WU01:FS01:0x22:        CWD: /var/lib/fah/work
07:04:39:WU01:FS01:0x22:         OS: Linux 5.5.9-arch1-2 x86_64
07:04:39:WU01:FS01:0x22:    OS Arch: AMD64
07:04:39:WU01:FS01:0x22:********************************************************************************
07:04:39:WU01:FS01:0x22:Project: 11755 (Run 0, Clone 1033, Gen 8)
07:04:39:WU01:FS01:0x22:Unit: 0x0000000b9bf7a4d55e6d76e29be256f9
07:04:39:WU01:FS01:0x22:Reading tar file core.xml
07:04:39:WU01:FS01:0x22:Reading tar file integrator.xml
07:04:39:WU01:FS01:0x22:Reading tar file state.xml
07:04:39:WU01:FS01:0x22:Reading tar file system.xml
07:04:40:WU01:FS01:0x22:Digital signatures verified
07:04:40:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:04:40:WU01:FS01:0x22:Version 0.0.2
To complete this, the currently runnin gprocesses are:
fah         2484  0.0  0.0  80888  4308 ?        SNl  08:04   0:00 /opt/fah/FAHCoreWrapper /var/lib/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 2444 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
fah         2488  2.2  1.6 3009160 407676 ?      SNl  08:04   0:05 /var/lib/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
fah         2491  0.0  0.0  80888  4440 ?        SNl  08:04   0:00 /opt/fah/FAHCoreWrapper /var/lib/fah/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 705 -lifeline 2444 -checkpoint 15 -np 7
fah         2495  594  1.5 654492 383820 ?       RNl  08:04  22:40 /var/lib/fah/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 705 -lifeline 2491 -checkpoint 15 -np 7
A side remark: I have to kill the process manually in order to stop it. Normal termination is not working.
I updated the abovementioned gist with the lasted log.txt content (old content in the revisions). The verbosity was set back to 3.
