I've recenty installed Folding@Home on my Windows 10 pc.
When going into the web control, I selected "While im working" and Medium power".
My CPU and GPU both have a yellow circle and say "ready".
Here is an image: https://prnt.sc/rhop4a
I have also tried the option "only when idle", with no success. I activated the screensaver in windows and in the advanced controls, but the screensaver just shows the 4 demo frames, with all the values on it being --.
When I then come back after having it on the screensaver for about 2 hours, and I check back on the web control, the amount of points didn't change at all.
It does appear, however, that my computer is doing something when I select "while I'm working", as the fans are blowing out hot air (normally cold air during idle), but task manager shows no sign of F@H doing anything.
I have a username, team number and passkey, which are all correct.
My specs are:
i7-9700K
EVGA RTX 2070 XC Ultra
F@H "ready" but not folding
Re: F@H "ready" but not folding
Check the log in "Advanced Control". It may be that work units are not available as fast as everyone is demanding them at present.
Yes, I have the same issue with
Xeon E3 v5 1230
zotac gtx 1060
I have already updated the drivers and reinstall the folding-client, but nothing changed
Xeon E3 v5 1230
zotac gtx 1060
Yep. That was the problem! Thanks anyways though!
Topic can be closed
Topic can be closed
