FAH Stuck on Ready
TheNanuak
FAH Stuck on Ready
Post by TheNanuak »
My CPU is an intel i5-9600K I think it has 6 cores
I have 8 GB of ram
my GPU is a Radeon RX 580
I am using a wireless connection on a sky hub
windows 10 pro latest version
not overclocked
FAH is not crashing
not sure what these two mean
Software: What version of the client are you using? Remember that Beta and prerelease versions can be unstable. What version of the core(s) are you using?
WU details: Gromacs, DGromacs, SMP, GPU? What WU? Run/Clone/Gen.
my problem is that FAH says my GPU and CPU are both ready but nothing happens, it just says waiting on WS Assignment, Attempts 9, Next attempt 1 mins 06 seconds etc
I'm not sure what I am doing wrong
Re: FAH Stuck on Ready
Subject: Temporary server outages - explains why you might not get work immediately.
Will leave the other questions for others to answer.
TheNanuak
Post by TheNanuak »
I did see that but i also saw on the server stats page that half the servers are giving out work, however I don't appear to be able to manually choose a server
TheNanuak
Post by TheNanuak »
also, does it matter that I do not have OpenCL
GingeraMan
Post by GingeraMan »
Yeah mine is stuck too, is that just the nature of it sometimes. I was wondering if I have connection issues.
TheNanuak
Post by TheNanuak »
I'm getting an error with the title "AMDRSServ.exe - system error" with the text
The code execution cannot proceed because OpenCl.dll was not found. Reinstalling the program may fix this problem.
TheNanuak
Post by TheNanuak »
reinstalled and now no error, CPU is running now but the GPU is getting the same problem as before. the log is saying that it cannot find any WUs for this configuration so is my GPU not supported?
Your GPU is supported, the problems with the servers remain. They are assigning work as fast as possible, just way more people joined after the project was widely advertised by supporters starting Friday. Some of the large sites did not contact F@h beforehand, so were not ready to scale up to over 15 times the number of assignment requests. Work is being done to get more servers online.
TheNanuak wrote:also, does it matter that I do not have OpenCL
FAH will not distribute assignments to the GPUs of systems that don't support OpenCL. You can still fold with your CPU. If you need help, open a new topic and attach FAH's log (see below).
TheNanuak
Post by TheNanuak »
Update: I am getting the error on system startup abount openCL.dll
I looked online and I cannot find any downloads or anything for this
alxbelu
Post by alxbelu »
TheNanuak wrote:Update: I am getting the error on system startup abount openCL.dll
They should be provided with drivers from the manufacturer (i.e. Nvidia/Amd).
Try updating your GPU with drivers from AMD (i.e. not through windows update/etc): https://www.amd.com/en/support
Official F@H Twitter (frequently updated): https://twitter.com/foldingathome
Official F@H Facebook: https://www.facebook.com/Foldinghome-136059519794607/
(I'm not affiliated with the F@H Team, just promoting these channels for official updates)
The latest driver straight from AMD should install OpenCL Other sources, not so much.
https://www.amd.com/en/support/graphics ... eon-rx-580
The first 200 lines of your log would tell us much about how your PC was configured and what it thought the problem was.
viewtopic.php?f=24&t=26036
TheNanuak
Post by TheNanuak »
Here is my latest log
*********************** Log Started 2020-03-17T15:21:07Z ***********************
15:21:07:************************* Folding@home Client *************************
15:21:07:      Website: https://foldingathome.org/
15:21:07:    Copyright: (c) 2009-2018 foldingathome.org
15:21:07:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:07:         Args:
15:21:07:       Config: D:\Users\David\AppData\Roaming\FAHClient\config.xml
15:21:07:******************************** Build ********************************
15:21:07:      Version: 7.5.1
15:21:07:         Date: May 11 2018
15:21:07:         Time: 13:06:32
15:21:07:   Repository: Git
15:21:07:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:21:07:       Branch: master
15:21:07:     Compiler: Visual C++ 2008
15:21:07:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:21:07:     Platform: win32 10
15:21:07:         Bits: 32
15:21:07:         Mode: Release
15:21:07:******************************* System ********************************
15:21:07:          CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
15:21:07:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:21:07:         CPUs: 6
15:21:07:       Memory: 7.94GiB
15:21:07:  Free Memory: 3.57GiB
15:21:07:      Threads: WINDOWS_THREADS
15:21:07:   OS Version: 6.2
15:21:07:  Has Battery: false
15:21:07:   On Battery: false
15:21:07:   UTC Offset: 0
15:21:07:          PID: 18052
15:21:07:          CWD: D:\Users\David\AppData\Roaming\FAHClient
15:21:07:           OS: Windows 10 Enterprise
15:21:07:      OS Arch: AMD64
15:21:07:         GPUs: 1
15:21:07:        GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
15:21:07:               470/480/570/580]
15:21:07:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
15:21:07:               specified module could not be found.
15:21:07:
15:21:07:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
15:21:07:
15:21:07:Win32 Service: false
15:21:07:***********************************************************************
15:21:07:<config>
15:21:07:  <service-description v='Folding@home Client'/>
15:21:07:  <service-restart v='true'/>
15:21:07:  <service-restart-delay v='5000'/>
15:21:07:
15:21:07:  <!-- Client Control -->
15:21:07:  <client-threads v='6'/>
15:21:07:  <cycle-rate v='4'/>
15:21:07:  <cycles v='-1'/>
15:21:07:  <data-directory v='.'/>
15:21:07:  <disable-sleep-when-active v='true'/>
15:21:07:  <exec-directory v='D:\Program Files (x86)\FAHClient'/>
15:21:07:  <exit-when-done v='false'/>
15:21:07:  <fold-anon v='false'/>
15:21:07:  <open-web-control v='false'/>
15:21:07:
15:21:07:  <!-- Configuration -->
15:21:07:  <config-rotate v='true'/>
15:21:07:  <config-rotate-dir v='configs'/>
15:21:07:  <config-rotate-max v='16'/>
15:21:07:
15:21:07:  <!-- Debugging -->
15:21:07:  <assignment-servers>
15:21:07:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
15:21:07:  </assignment-servers>
15:21:07:  <auth-as v='true'/>
15:21:07:  <capture-directory v='capture'/>
15:21:07:  <capture-on-error v='false'/>
15:21:07:  <capture-packets v='false'/>
15:21:07:  <capture-requests v='false'/>
15:21:07:  <capture-responses v='false'/>
15:21:07:  <capture-sockets v='false'/>
15:21:07:  <core-exec v='FahCore_$type'/>
15:21:07:  <core-wrapper-exec v='FAHCoreWrapper'/>
15:21:07:  <debug-sockets v='false'/>
15:21:07:  <exception-locations v='true'/>
15:21:07:  <stack-traces v='false'/>
15:21:07:
15:21:07:  <!-- Error Handling -->
15:21:07:  <max-slot-errors v='10'/>
15:21:07:  <max-unit-errors v='5'/>
15:21:07:
15:21:07:  <!-- Folding Core -->
15:21:07:  <checkpoint v='15'/>
15:21:07:  <core-dir v='cores'/>
15:21:07:  <core-priority v='idle'/>
15:21:07:  <cpu-affinity v='false'/>
15:21:07:  <cpu-usage v='100'/>
15:21:07:  <gpu-usage v='100'/>
15:21:07:  <no-assembly v='false'/>
15:21:07:
15:21:07:  <!-- Folding Slot Configuration -->
15:21:07:  <cause v='ANY'/>
15:21:07:  <client-subtype v='STDCLI'/>
15:21:07:  <client-type v='normal'/>
15:21:07:  <cpu-species v='X86_PENTIUM_II'/>
15:21:07:  <cpu-type v='AMD64'/>
15:21:07:  <cpus v='-1'/>
15:21:07:  <disable-viz v='false'/>
15:21:07:  <gpu v='true'/>
15:21:07:  <max-packet-size v='normal'/>
15:21:07:  <os-species v='WIN_8'/>
15:21:07:  <os-type v='WIN32'/>
15:21:07:  <project-key v='0'/>
15:21:07:  <smp v='true'/>
15:21:07:
15:21:07:  <!-- GUI -->
15:21:07:  <gui-enabled v='true'/>
15:21:07:
15:21:07:  <!-- HTTP Server -->
15:21:07:  <allow v='127.0.0.1'/>
15:21:07:  <connection-timeout v='60'/>
15:21:07:  <deny v='0/0'/>
15:21:07:  <http-addresses v='0:7396'/>
15:21:07:  <https-addresses v=''/>
15:21:07:  <max-connect-time v='900'/>
15:21:07:  <max-connections v='800'/>
15:21:07:  <max-request-length v='52428800'/>
15:21:07:  <min-connect-time v='300'/>
15:21:07:
15:21:07:  <!-- Logging -->
15:21:07:  <log v='log.txt'/>
15:21:07:  <log-color v='false'/>
15:21:07:  <log-crlf v='true'/>
15:21:07:  <log-date v='false'/>
15:21:07:  <log-date-periodically v='21600'/>
15:21:07:  <log-domain v='false'/>
15:21:07:  <log-header v='true'/>
15:21:07:  <log-level v='true'/>
15:21:07:  <log-no-info-header v='true'/>
15:21:07:  <log-redirect v='false'/>
15:21:07:  <log-rotate v='true'/>
15:21:07:  <log-rotate-dir v='logs'/>
15:21:07:  <log-rotate-max v='16'/>
15:21:07:  <log-short-level v='false'/>
15:21:07:  <log-simple-domains v='true'/>
15:21:07:  <log-thread-id v='false'/>
15:21:07:  <log-thread-prefix v='true'/>
15:21:07:  <log-time v='true'/>
15:21:07:  <log-to-screen v='true'/>
15:21:07:  <log-truncate v='false'/>
15:21:07:  <verbosity v='4'/>
15:21:07:
15:21:07:  <!-- Network -->
15:21:07:  <proxy v=':8080'/>
15:21:07:  <proxy-enable v='false'/>
15:21:07:  <proxy-pass v=''/>
15:21:07:  <proxy-user v=''/>
15:21:07:
15:21:07:  <!-- Process Control -->
15:21:07:  <child v='false'/>
15:21:07:  <daemon v='false'/>
15:21:07:  <pid v='false'/>
15:21:07:  <pid-file v='Folding@home Client.pid'/>
15:21:07:  <respawn v='false'/>
15:21:07:  <service v='false'/>
15:21:07:
15:21:07:  <!-- Remote Command Server -->
15:21:07:  <command-address v='0.0.0.0'/>
15:21:07:  <command-allow-no-pass v='127.0.0.1'/>
15:21:07:  <command-deny-no-pass v='0/0'/>
15:21:07:  <command-enable v='true'/>
15:21:07:  <command-port v='36330'/>
15:21:07:
15:21:07:  <!-- Slot Control -->
15:21:07:  <idle v='false'/>
15:21:07:  <max-shutdown-wait v='60'/>
15:21:07:  <pause-on-battery v='true'/>
15:21:07:  <pause-on-start v='false'/>
15:21:07:  <paused v='false'/>
15:21:07:  <power v='full'/>
15:21:07:
15:21:07:  <!-- User Information -->
15:21:07:  <machine-id v='0'/>
15:21:07:  <passkey v=''/>
15:21:07:  <team v='0'/>
15:21:07:  <user v='TheNanuak'/>
15:21:07:
15:21:07:  <!-- Web Server -->
15:21:07:  <web-allow v='127.0.0.1'/>
15:21:07:  <web-deny v='0/0'/>
15:21:07:  <web-enable v='true'/>
15:21:07:
15:21:07:  <!-- Web Server Sessions -->
15:21:07:  <session-cookie v='sid'/>
15:21:07:  <session-lifetime v='86400'/>
15:21:07:  <session-timeout v='3600'/>
15:21:07:
15:21:07:  <!-- Work Unit Control -->
15:21:07:  <dump-after-deadline v='true'/>
15:21:07:  <max-queue v='16'/>
15:21:07:  <max-units v='0'/>
15:21:07:  <next-unit-percentage v='99'/>
15:21:07:  <stall-detection-enabled v='false'/>
15:21:07:  <stall-percent v='5'/>
15:21:07:  <stall-timeout v='1800'/>
15:21:07:
15:21:07:  <!-- Folding Slots -->
15:21:07:  <slot id='0' type='CPU'/>
15:21:07:  <slot id='1' type='GPU'/>
15:21:07:</config>
15:21:08:Trying to access database...
15:21:09:Successfully acquired database lock
15:21:09:Enabled folding slot 00: READY cpu:5
15:21:10:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
15:21:10:ERROR:No compute devices matched GPU #0 AMD:5 Ellesmere XT [Radeon RX 470/480/570/580].  You may need to update your graphics drivers.
15:21:11:WU00:FS00:Connecting to 65.254.110.245:8080
15:21:11:WU01:FS01:Connecting to 65.254.110.245:8080
15:21:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:21:12:WU01:FS01:Connecting to 18.218.241.186:80
15:21:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:21:12:WU00:FS00:Connecting to 18.218.241.186:80
15:21:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:21:13:ERROR:WU01:FS01:Exception: Could not get an assignment
15:21:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:21:13:ERROR:WU00:FS00:Exception: Could not get an assignment
15:21:13:WU01:FS01:Connecting to 65.254.110.245:8080
15:21:13:WU00:FS00:Connecting to 65.254.110.245:8080
15:21:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:21:14:WU01:FS01:Connecting to 18.218.241.186:80
15:21:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:21:14:WU00:FS00:Connecting to 18.218.241.186:80
15:21:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:21:14:ERROR:WU00:FS00:Exception: Could not get an assignment
15:21:14:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:21:14:ERROR:WU01:FS01:Exception: Could not get an assignment
15:22:13:WU00:FS00:Connecting to 65.254.110.245:8080
15:22:13:WU01:FS01:Connecting to 65.254.110.245:8080
15:22:13:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:22:13:WU00:FS00:Connecting to 18.218.241.186:80
15:22:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:22:14:WU01:FS01:Connecting to 18.218.241.186:80
15:22:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:22:14:ERROR:WU00:FS00:Exception: Could not get an assignment
15:22:14:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:22:14:ERROR:WU01:FS01:Exception: Could not get an assignment
15:23:50:WU00:FS00:Connecting to 65.254.110.245:8080
15:23:51:WU01:FS01:Connecting to 65.254.110.245:8080
15:23:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:23:51:WU00:FS00:Connecting to 18.218.241.186:80
15:23:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:23:51:WU01:FS01:Connecting to 18.218.241.186:80
15:23:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:23:51:ERROR:WU01:FS01:Exception: Could not get an assignment
15:23:51:WU00:FS00:Assigned to work server 128.252.203.9
15:23:51:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 128.252.203.9
15:23:51:WU00:FS00:Connecting to 128.252.203.9:8080
15:24:01:ERROR:WU00:FS00:Exception: Server did not assign work unit
15:26:28:WU00:FS00:Connecting to 65.254.110.245:8080
15:26:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:26:28:WU00:FS00:Connecting to 18.218.241.186:80
15:26:28:WU01:FS01:Connecting to 65.254.110.245:8080
15:26:28:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:26:28:ERROR:WU00:FS00:Exception: Could not get an assignment
15:26:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:26:28:WU01:FS01:Connecting to 18.218.241.186:80
15:26:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:26:29:ERROR:WU01:FS01:Exception: Could not get an assignment
15:30:42:WU00:FS00:Connecting to 65.254.110.245:8080
15:30:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:30:42:WU00:FS00:Connecting to 18.218.241.186:80
15:30:42:WU01:FS01:Connecting to 65.254.110.245:8080
15:30:43:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:30:43:WU01:FS01:Connecting to 18.218.241.186:80
15:30:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:30:43:ERROR:WU00:FS00:Exception: Could not get an assignment
15:30:43:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:30:43:ERROR:WU01:FS01:Exception: Could not get an assignment
15:37:33:WU00:FS00:Connecting to 65.254.110.245:8080
15:37:34:WU01:FS01:Connecting to 65.254.110.245:8080
15:37:34:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:37:34:WU00:FS00:Connecting to 18.218.241.186:80
15:37:34:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:37:34:WU01:FS01:Connecting to 18.218.241.186:80
15:37:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:37:34:ERROR:WU00:FS00:Exception: Could not get an assignment
15:37:34:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:37:34:ERROR:WU01:FS01:Exception: Could not get an assignment
15:48:39:WU00:FS00:Connecting to 65.254.110.245:8080
15:48:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:48:39:WU00:FS00:Connecting to 18.218.241.186:80
15:48:39:WU01:FS01:Connecting to 65.254.110.245:8080
15:48:39:WU00:FS00:Assigned to work server 155.247.166.219
15:48:39:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 155.247.166.219
15:48:39:WU00:FS00:Connecting to 155.247.166.219:8080
15:48:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:48:39:WU01:FS01:Connecting to 18.218.241.186:80
15:48:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:48:40:ERROR:WU01:FS01:Exception: Could not get an assignment
15:48:40:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:59:59:Saving configuration to config.xml
15:59:59:<config>
15:59:59:  <!-- Network -->
15:59:59:  <proxy v=':8080'/>
15:59:59:
15:59:59:  <!-- Slot Control -->
15:59:59:  <power v='full'/>
15:59:59:
15:59:59:  <!-- User Information -->
15:59:59:  <user v='TheNanuak'/>
15:59:59:
15:59:59:  <!-- Folding Slots -->
15:59:59:  <slot id='0' type='CPU'/>
15:59:59:  <slot id='1' type='GPU'/>
15:59:59:</config>
16:00:48:Saving configuration to config.xml
16:00:48:<config>
16:00:48:  <!-- Network -->
16:00:48:  <proxy v=':8080'/>
16:00:48:
16:00:48:  <!-- Slot Control -->
16:00:48:  <power v='full'/>
16:00:48:
16:00:48:  <!-- User Information -->
16:00:48:  <user v='TheNanuak'/>
16:00:48:
16:00:48:  <!-- Folding Slots -->
16:00:48:  <slot id='0' type='CPU'/>
16:00:48:  <slot id='1' type='GPU'/>
16:00:48:</config>
Nathan_P
Not currently folding
Post by Nathan_P »
Hmm, the latest drivers have not installed OpenCL, or if they have its been borked during installation.
I would recommend a full driver uninstall using the utility DDU, and reinstalling the drivers from stratch.
Oh, and please return the logging verbosity to the default of 3. The higher level does not provide any useful extra information at this point, and does get in the way of figuring out what is going on with your client setup.
