Hi all,
why don't you publish the folding@home client on the Windowst store?
It will give a lot more visibility and ease of download/installation.
It's easy to convert a win32/64 desktop application with the bridge tool (Project Centennial), so that you can publish it in the store.
https__:__//__developer__.__microsoft__.__com/en-us/windows/bridges/desktop/
thanks
massimo
F@H client on the Windows store will give more visibility
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Re: F@H client on the Windows store will give more visibilit
Probably because they dont have the work to feed everyone currently folding, let alone adding more users that will join the masses that have no work to fold. Until they fix the infrastructure, adding clients is pointless. Advertising for clients, even more pointless.
