Minimum cores for a7
Kebast
Post by Kebast »
I have a 16 thread Ryzen 3800x that's been running fine on the a7 WUs. I need to remove a few threads from FAH though for other work. What's the minimum number of threads/cores that a7 WUs need? I think it used to be 8, is that still the case?
Ryzen 5900x 12T - RTX 4070 TI
Re: Minimum cores for a7
You need at least 1. I have a Core Duo with a GPU, so 2 CPUs but one reserved for the GPU.
Most of my desktops use 3
The 8-core minimum was for the now defunct Bigadv projects using the A5 folding core. At this point all CPU folding cores older than A7 have been retired.
JimF
Post by JimF »
Kebast wrote:I have a 16 thread Ryzen 3800x that's been running fine on the a7 WUs.
The last time I checked, there was a disproportionate drop in output as you remove cores.
I like to keep all of the cores of my Ryzen 3700x on FAH, and use other machines for other work.
Correct, the aptly named Quick Return Bonus gives you more points the quicker you return the Work Unit. This is separate from how many threads you need to fold. More is always better, (at least to 128 threads) but the minimum is 1. Over 128 threads you may need Linux or Windows Enterprise.
Kebast
Post by Kebast »
Sure, but I need a few free for other things. I've still got the GPU churning out 500k per day anyway.
Athlonite
Hardware configuration: Asus Crosshair V Formula
AMD FX8320 @3.8GHz
Mushkin DDR3-2400MHz 8GB (2x4GB)
Sapphire Nitro+ RX580 *GB OC 1375/2000MHz
Samsung 860 EVO 500GB + 11TB's of HDD storage
Silverstone ST75F-P (750W) PSU & Silverstone raVen RV02B-W + USB3 Upgrade case
Post by Athlonite »
The min cores is 1 but I find 12 on my R7 3700X is a good base for throughput vs being able to do other things without interfering with folding
Asus Strix X470F Gaming
AMD R7 3700
16GB GSkill trident Z DDR4-3200
Samsung 860 Evo 500GB SATA SSD
Gigabyte RX580 8GB
I don't know what you are reserving the cores for so my comment may not apply to you but FAHCore_a7 should be using N cores at a very low OS priority so that foreground activities will automatically receive preferential execution. Task Manager says the base priority for FAHCore* is "low"
