FaH client doesn't start when booting or logging in.
Abyssopellagic One
Post by Abyssopellagic One »
I've done an "express install" of FaH client, and rebooted my PC.
To try and get it running I've run firefox and gone to client dot foldingathome dot org
It tries to connect to my client, but just times out and comes up with this:
Your browser was unable to connect to a Folding@home client running on your computer.
1 Install the Folding@home client.
2 Make sure your Folding@home client is running.
3 Reload this page.
Step 1 is already done but I'm struggling with step 2. I've tried finding FAHClient.exe in my program files and double-clicking it, but that just makes a black window come up and then disappear.
Any idea what to do?
Obligatory system details:
Computer Specs: Specifically CPU type and speed, RAM amount and number of CPU cores, especially. Don't forget your GPU type if you're folding with it.
CPU is a Ryzen 2600 (6 cores, 12 threads, 3.4 GHz), RAM is 16Gb. GPU is and AMD RX570 with 8Gb of VRAM and two fans (Sapphire Nitro+).
Network Connection: Network is motherboard to router via ethernet cable, then router to plug in the wall marked "adsl" by some other cable.
Operating System: Windows 10 Home, Version 1909, OS Build 18363.720 Updates last checked for about midnight last night.
Overclocked?: Just the GPU - Core voltage 900mV, power limit +20%, temp. limit 85 C, core clock 1410 MHz, memory clock 1750MHz. Fan curve starts at 30% at 30 C , goes to 100% at 80 C , and is steeper at the hotter end.
Stable?: No formal stability tests done.
Software: Don't know how to tell without making it run. Installer was "fah-installer_7.5.1_x86"
WU details: Haven't started them yet.
Re: FaH client doesn't start when booting or logging in.
Post by muziqaz »
Fahcontrol should be tucked in in the sys tray, by the system clock. Little protein molecule sign. Right click that and select Advanced Control. Window should pop up with options to control everything :)
Webcontrol has been known to have few issues ever since Google and Mozilla decided to switch things up in their browser code :)
FAH Omega tester
Abyssopellagic One
Thanks, I do use Firefox. I uninstalled because I couldn't get it to work. I'll reinstall on my admin account instead of my regular one, stick to Advanced Control, and see how it goes.
Abyssopellagic One
Okay after a few uninstalls and reinstalls, here's how it's going:
No matter which account I install FaH on, it only shows up in the system tray and task manager when I'm logged in and switch-user-ed as The Administrator.
Is there some way to get it to run when I just log in on my regular account?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
The installer prompts for admin rights and installs the software to the admin profile. If there are two different accounts on the Windows PC, it will put the desktop links and such into the admin's account, not the lower-level account.
This seems related to the discussions in this thread: viewtopic.php?f=61&t=32098 and there's some advice on how to fix the problem near the end of the thread.
