Project 13831 is S..L..O..W
dooley
Post by dooley »
Stats on my first Project 13831: TPF 4 hours 4 mins, PPD 53, ETA 16.30 days, Dumping.
log.txt
22:13:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13831 run:183 clone:1 gen:104 core:0xa7 unit:0x0000007780fccb095d693b801ec43c7e
22:13:40:WU01:FS00:Starting
22:13:40:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 976 -checkpoint 15 -np 6
22:13:40:WU01:FS00:Started FahCore on PID 18762
22:13:40:WU01:FS00:Core PID:18766
22:13:40:WU01:FS00:FahCore 0xa7 started
22:13:40:WU01:FS00:0xa7:*********************** Log Started 2020-03-13T22:13:40Z ***********************
22:13:40:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:13:40:WU01:FS00:0xa7:       Type: 0xa7
22:13:40:WU01:FS00:0xa7:       Core: Gromacs
22:13:40:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 18762 -checkpoint 15 -np
22:13:40:WU01:FS00:0xa7:             6
22:13:40:WU01:FS00:0xa7:************************************ CBang *************************************
22:13:40:WU01:FS00:0xa7:       Date: Nov 5 2019
22:13:40:WU01:FS00:0xa7:       Time: 06:06:57
22:13:40:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
22:13:40:WU01:FS00:0xa7:     Branch: master
22:13:40:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
22:13:40:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
22:13:40:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
22:13:40:WU01:FS00:0xa7:       Bits: 64
22:13:40:WU01:FS00:0xa7:       Mode: Release
22:13:40:WU01:FS00:0xa7:************************************ System ************************************
22:13:40:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
22:13:40:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:13:40:WU01:FS00:0xa7:       CPUs: 8
22:13:40:WU01:FS00:0xa7:     Memory: 15.63GiB
22:13:40:WU01:FS00:0xa7:Free Memory: 3.21GiB
22:13:40:WU01:FS00:0xa7:    Threads: POSIX_THREADS
22:13:40:WU01:FS00:0xa7: OS Version: 4.9
22:13:40:WU01:FS00:0xa7:Has Battery: false
22:13:40:WU01:FS00:0xa7: On Battery: false
22:13:40:WU01:FS00:0xa7: UTC Offset: -7
22:13:40:WU01:FS00:0xa7:        PID: 18766
22:13:40:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
22:13:40:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:13:40:WU01:FS00:0xa7:    Version: 0.0.18
22:13:40:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:13:40:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:13:40:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:13:40:WU01:FS00:0xa7:       Time: 06:13:26
22:13:40:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
22:13:40:WU01:FS00:0xa7:************************************ Build *************************************
22:13:40:WU01:FS00:0xa7:       SIMD: avx_256
22:13:40:WU01:FS00:0xa7:********************************************************************************
22:13:40:WU01:FS00:0xa7:Project: 13831 (Run 183, Clone 1, Gen 104)
22:13:40:WU01:FS00:0xa7:Unit: 0x0000007780fccb095d693b801ec43c7e
22:13:40:WU01:FS00:0xa7:Reading tar file core.xml
22:13:40:WU01:FS00:0xa7:Reading tar file frame104.tpr
22:13:40:WU01:FS00:0xa7:Digital signatures verified
22:13:40:WU01:FS00:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -cpt 15 -nt 6
22:13:40:WU01:FS00:0xa7:Steps: first=13000000 total=13000000
22:13:42:WU00:FS00:Upload complete
22:13:42:WU00:FS00:Server responded WORK_ACK (400)
22:13:42:WU00:FS00:Final credit estimate, 10598.00 points
22:13:42:WU00:FS00:Cleaning up
22:13:43:WU01:FS00:0xa7:Completed 1 out of 13000000 steps (0%)
02:23:09:WU01:FS00:0xa7:Completed 130000 out of 13000000 steps (1%)
******************************* Date: 2020-03-14 *******************************
06:32:13:WU01:FS00:0xa7:Completed 260000 out of 13000000 steps (2%)
10:36:49:WU01:FS00:0xa7:Completed 390000 out of 13000000 steps (3%)
setup
*********************** Log Started 2020-03-11T02:59:56Z ***********************
02:59:56:************************* Folding@home Client *************************
02:59:56:      Website: https://foldingathome.org/
02:59:56:    Copyright: (c) 2009-2018 foldingathome.org
02:59:56:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:59:56:         Args: --child --lifeline 974 /etc/fahclient/config.xml --run-as
02:59:56:               fahclient --pid-file=/var/run/fahclient.pid --daemon
02:59:56:       Config: /etc/fahclient/config.xml
02:59:56:******************************** Build ********************************
02:59:56:      Version: 7.5.1
02:59:56:         Date: May 11 2018
02:59:56:         Time: 19:59:04
02:59:56:   Repository: Git
02:59:56:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:59:56:       Branch: master
02:59:56:     Compiler: GNU 6.3.0 20170516
02:59:56:      Options: -std=gnu++98 -O3 -funroll-loops
02:59:56:     Platform: linux2 4.14.0-3-amd64
02:59:56:         Bits: 64
02:59:56:         Mode: Release
02:59:56:******************************* System ********************************
02:59:56:          CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
02:59:56:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:59:56:         CPUs: 8
02:59:56:       Memory: 15.63GiB
02:59:56:  Free Memory: 15.15GiB
02:59:56:      Threads: POSIX_THREADS
02:59:56:   OS Version: 4.9
02:59:56:  Has Battery: false
02:59:56:   On Battery: false
02:59:56:   UTC Offset: -7
02:59:56:          PID: 976
02:59:56:          CWD: /var/lib/fahclient
02:59:56:           OS: Linux 4.9.0-11-amd64 x86_64
02:59:56:      OS Arch: AMD64
02:59:56:         GPUs: 1
02:59:56:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF116 [GeForce GT 635]
02:59:56:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:9.1
02:59:56:       OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
02:59:56:               libOpenCL.so: cannot open shared object file: No such file or
02:59:56:               directory
02:59:56:***********************************************************************
02:59:56:<config>
02:59:56:  <!-- Client Control -->
02:59:56:  <fold-anon v='true'/>
02:59:56:
02:59:56:  <!-- Folding Slot Configuration -->
02:59:56:  <gpu v='false'/>
02:59:56:
02:59:56:  <!-- Network -->
02:59:56:  <proxy v=':8080'/>
02:59:56:
02:59:56:  <!-- User Information -->
02:59:56:  <passkey v='********************************'/>
02:59:56:  <team v='45104'/>
02:59:56:  <user v='dooley'/>
02:59:56:
02:59:56:  <!-- Folding Slots -->
02:59:56:  <slot id='0' type='CPU'>
02:59:56:    <cpus v='6'/>
02:59:56:    <next-unit-percentage v='100'/>
02:59:56:  </slot>
02:59:56:  <slot id='1' type='GPU'>
02:59:56:    <opencl-index v='0'/>
02:59:56:  </slot>
02:59:56:</config>
Re: Project 13831 is S..L..O..W
Thank you for reporting this. Something went wrong on the server when it generated this WU, the correct number of steps should have been 125,000 and not 13 million.
I will pass on this report to the project's researcher.
justinrporter
Pande Group Member
Post by justinrporter »
Thanks for reporting--I'm looking in to it now.
justinrporter
Pande Group Member
Figured out the problem, I'll have to disable the project until I figure out how to solve it. Thanks for the bug report. : /
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Had trouble with another 13831 job: Project: 13831 (Run 857, Clone 1, Gen 104)
First it was claiming a completion run in ~6 days, then it went up to ~14 days or something like that. I deleted it.
For what it is worth, have a log with it trying to run below. Glad to see the job had an error, not my PC was getting that old/slow from current production.
Robby
*********************** Log Started 2020-03-15T00:30:37Z ***********************
00:30:37:************************* Folding@home Client *************************
00:30:37:        Website: https://foldingathome.org/
00:30:37:      Copyright: (c) 2009-2018 foldingathome.org
00:30:37:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:30:37:           Args:
00:30:37:         Config: C:\Users\bobb1\AppData\Roaming\FAHClient\config.xml
00:30:37:******************************** Build ********************************
00:30:37:        Version: 7.5.1
00:30:37:           Date: May 11 2018
00:30:37:           Time: 13:06:32
00:30:37:     Repository: Git
00:30:37:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:30:37:         Branch: master
00:30:37:       Compiler: Visual C++ 2008
00:30:37:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:30:37:       Platform: win32 10
00:30:37:           Bits: 32
00:30:37:           Mode: Release
00:30:37:******************************* System ********************************
00:30:37:            CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:30:37:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:30:37:           CPUs: 8
00:30:37:         Memory: 15.89GiB
00:30:37:    Free Memory: 14.45GiB
00:30:37:        Threads: WINDOWS_THREADS
00:30:37:     OS Version: 6.2
00:30:37:    Has Battery: true
00:30:37:     On Battery: false
00:30:37:     UTC Offset: -5
00:30:37:            PID: 3792
00:30:37:            CWD: C:\WINDOWS\system32
00:30:37:             OS: Windows 10 Home
00:30:37:        OS Arch: AMD64
00:30:37:           GPUs: 0
00:30:37:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
00:30:37:                 specified module could not be found.
00:30:37:
00:30:37:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
00:30:37:  Win32 Service: true
00:30:37:***********************************************************************
00:30:37:<config>
00:30:37:  <!-- Folding Slot Configuration -->
00:30:37:  <cause v='ALZHEIMERS'/>
00:30:37:
00:30:37:  <!-- Slot Control -->
00:30:37:  <power v='full'/>
00:30:37:
00:30:37:  <!-- User Information -->
00:30:37:  <passkey v='********************************'/>
00:30:37:  <team v='1'/>
00:30:37:  <user v='Robby'/>
00:30:37:
00:30:37:  <!-- Folding Slots -->
00:30:37:  <slot id='0' type='CPU'/>
00:30:37:</config>
00:30:37:Trying to access database...
00:30:37:Successfully acquired database lock
00:30:37:Enabled folding slot 00: READY cpu:8
00:30:37:ERROR:Exception: Failed to register systray icon: Unspecified error
00:30:37:WU01:FS00:Starting
00:30:37:WARNING:WU01:FS00:AS lowered CPUs from 8 to 7
00:30:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 3792 -checkpoint 15 -np 7 -service
00:30:37:WU01:FS00:Started FahCore on PID 4940
00:30:37:WU01:FS00:Core PID:5016
00:30:37:WU01:FS00:FahCore 0xa7 started
00:30:39:WU01:FS00:0xa7:*********************** Log Started 2020-03-15T00:30:39Z ***********************
00:30:39:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:30:39:WU01:FS00:0xa7:       Type: 0xa7
00:30:39:WU01:FS00:0xa7:       Core: Gromacs
00:30:39:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4940 -checkpoint 15 -np 7
00:30:39:WU01:FS00:0xa7:             -service
00:30:39:WU01:FS00:0xa7:************************************ CBang *************************************
00:30:39:WU01:FS00:0xa7:       Date: Oct 26 2019
00:30:39:WU01:FS00:0xa7:       Time: 01:38:25
00:30:39:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:30:39:WU01:FS00:0xa7:     Branch: master
00:30:39:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:30:39:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:30:39:WU01:FS00:0xa7:   Platform: win32 10
00:30:39:WU01:FS00:0xa7:       Bits: 64
00:30:39:WU01:FS00:0xa7:       Mode: Release
00:30:39:WU01:FS00:0xa7:************************************ System ************************************
00:30:39:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:30:39:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:30:39:WU01:FS00:0xa7:       CPUs: 8
00:30:39:WU01:FS00:0xa7:     Memory: 15.89GiB
00:30:39:WU01:FS00:0xa7:Free Memory: 14.34GiB
00:30:39:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:30:39:WU01:FS00:0xa7: OS Version: 6.2
00:30:39:WU01:FS00:0xa7:Has Battery: true
00:30:39:WU01:FS00:0xa7: On Battery: false
00:30:39:WU01:FS00:0xa7: UTC Offset: -5
00:30:39:WU01:FS00:0xa7:        PID: 5016
00:30:39:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
00:30:39:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
00:30:39:WU01:FS00:0xa7:    Version: 0.0.18
00:30:39:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:30:39:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:30:39:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
00:30:39:WU01:FS00:0xa7:       Time: 01:52:30
00:30:39:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:30:39:WU01:FS00:0xa7:************************************ Build *************************************
00:30:39:WU01:FS00:0xa7:       SIMD: avx_256
00:30:39:WU01:FS00:0xa7:********************************************************************************
00:30:39:WU01:FS00:0xa7:Project: 13831 (Run 857, Clone 1, Gen 104)
00:30:39:WU01:FS00:0xa7:Unit: 0x0000007e80fccb095d693a50bd23cd90
00:30:39:WU01:FS00:0xa7:Digital signatures verified
00:30:39:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
00:30:39:WU01:FS00:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -cpi state.cpt -cpt 15 -nt 6
00:30:55:WU01:FS00:0xa7:Steps: first=13000000 total=13000000
00:30:58:WU01:FS00:0xa7:Completed 554422 out of 13000000 steps (4%)
03:58:19:WU01:FS00:0xa7:Completed 650000 out of 13000000 steps (5%)
******************************* Date: 2020-03-15 *******************************
08:23:18:WU01:FS00:0xa7:Completed 780000 out of 13000000 steps (6%)
12:44:58:WU01:FS00:0xa7:Completed 910000 out of 13000000 steps (7%)
12:47:24:11:127.0.0.1:New Web connection
13:12:02:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
13:12:03:WU01:FS00:Starting
13:12:03:WARNING:WU01:FS00:AS lowered CPUs from 8 to 7
13:12:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 3792 -checkpoint 15 -np 7 -service
13:12:03:WU01:FS00:Started FahCore on PID 9448
13:12:03:WU01:FS00:Core PID:3280
13:12:03:WU01:FS00:FahCore 0xa7 started
13:12:04:WU01:FS00:0xa7:*********************** Log Started 2020-03-15T13:12:03Z ***********************
13:12:04:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:12:04:WU01:FS00:0xa7:       Type: 0xa7
13:12:04:WU01:FS00:0xa7:       Core: Gromacs
13:12:04:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 9448 -checkpoint 15 -np 7
13:12:04:WU01:FS00:0xa7:             -service
13:12:04:WU01:FS00:0xa7:************************************ CBang *************************************
13:12:04:WU01:FS00:0xa7:       Date: Oct 26 2019
13:12:04:WU01:FS00:0xa7:       Time: 01:38:25
13:12:04:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:12:04:WU01:FS00:0xa7:     Branch: master
13:12:04:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
13:12:04:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:12:04:WU01:FS00:0xa7:   Platform: win32 10
13:12:04:WU01:FS00:0xa7:       Bits: 64
13:12:04:WU01:FS00:0xa7:       Mode: Release
13:12:04:WU01:FS00:0xa7:************************************ System ************************************
13:12:04:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
13:12:04:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:12:04:WU01:FS00:0xa7:       CPUs: 8
13:12:04:WU01:FS00:0xa7:     Memory: 15.89GiB
13:12:04:WU01:FS00:0xa7:Free Memory: 8.73GiB
13:12:04:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
13:12:04:WU01:FS00:0xa7: OS Version: 6.2
13:12:04:WU01:FS00:0xa7:Has Battery: true
13:12:04:WU01:FS00:0xa7: On Battery: false
13:12:04:WU01:FS00:0xa7: UTC Offset: -5
13:12:04:WU01:FS00:0xa7:        PID: 3280
13:12:04:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
13:12:04:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:12:04:WU01:FS00:0xa7:    Version: 0.0.18
13:12:04:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:12:04:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:12:04:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
13:12:04:WU01:FS00:0xa7:       Time: 01:52:30
13:12:04:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:12:04:WU01:FS00:0xa7:************************************ Build *************************************
13:12:04:WU01:FS00:0xa7:       SIMD: avx_256
13:12:04:WU01:FS00:0xa7:********************************************************************************
13:12:04:WU01:FS00:0xa7:Project: 13831 (Run 857, Clone 1, Gen 104)
13:12:04:WU01:FS00:0xa7:Unit: 0x0000007e80fccb095d693a50bd23cd90
13:12:04:WU01:FS00:0xa7:Digital signatures verified
13:12:04:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
13:12:04:WU01:FS00:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -cpi state.cpt -cpt 15 -nt 6
13:12:05:WU01:FS00:0xa7:Steps: first=13000000 total=13000000
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
justinrporter
Pande Group Member
Do you remember when you downloaded the work unit? The project should have been disabled since about the time I posted yesterday, but any 13831 unit downloaded before that has the potential to be messed up. There are probably a bunch out in the wild still...
Robby_Firefox
Hi justinporter,
Have been having lots of trouble with the FAH client since that 13831 job. As such, have deleted the client (including data), so am sorry do not have exact times that one was downloaded. I am thinking it came in on either Fri the 13, or Sat the 14th. I did notice very long times for it to complete over the past weekend. I think that you have stopped that bad work unit, after getting notified about it.
Before writing this, I reinstalled the FAH client and tried to get folding again on my main computer. So far it has failed, somehow with no jobs to retrieve. Have heard of job shortages from posts over the past couple of days; is it still occurring? My laptop that is running FAH on a part time basis is getting data in fine. I am going to do a system restart after sending this. Then will try installing FAH again. Am using an I-7 Quad-Core processor on a homemade system with 16 GB of RAM. It is CPU only only at this time, have not bought one of those nice but expensive video cards yet.
Robby_Firefox
A followup...
Seems the laptop has been idle since ~3 AM CDT. It has not received a work unit since then. Same here with the new install of FAH on the faster desktop. I hope more work is coming out soon..
- Robby
