GPU's sitting idle
Dhamon
GPU's sitting idle
Post by Dhamon »
Hey guys! Just read about this this morning and want to help out, I currently have two GTX 1080tis, they are detected in the web client and under advanced control, but they are sitting idle while my CPU is doing everything. In the log it is stating my GPUS are "Not configured" is there some additional config I need to do?
Below is my log:
*********************** Log Started 2020-03-14T13:24:01Z ***********************
13:24:01:************************* Folding@home Client *************************
13:24:01:        Website: https://foldingathome.org/
13:24:01:      Copyright: (c) 2009-2018 foldingathome.org
13:24:01:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:24:01:           Args: --open-web-control
13:24:01:         Config: <none>
13:24:01:******************************** Build ********************************
13:24:01:        Version: 7.5.1
13:24:01:           Date: May 11 2018
13:24:01:           Time: 13:06:32
13:24:01:     Repository: Git
13:24:01:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:24:01:         Branch: master
13:24:01:       Compiler: Visual C++ 2008
13:24:01:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:24:01:       Platform: win32 10
13:24:01:           Bits: 32
13:24:01:           Mode: Release
13:24:01:******************************* System ********************************
13:24:01:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
13:24:01:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:24:01:           CPUs: 8
13:24:01:         Memory: 31.93GiB
13:24:01:    Free Memory: 24.64GiB
13:24:01:        Threads: WINDOWS_THREADS
13:24:01:     OS Version: 6.2
13:24:01:    Has Battery: false
13:24:01:     On Battery: false
13:24:01:     UTC Offset: -4
13:24:01:            PID: 16776
13:24:01:            CWD: C:\Users\Chris\AppData\Roaming\FAHClient
13:24:01:             OS: Windows 10 Enterprise
13:24:01:        OS Arch: AMD64
13:24:01:           GPUs: 0
13:24:01:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
13:24:01:  CUDA Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:6.1 Driver:10.2
13:24:01:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
13:24:01:OpenCL Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:442.50
13:24:01:  Win32 Service: false
13:24:01:***********************************************************************
13:24:01:<config>
13:24:01:  <!-- Folding Slots -->
13:24:01:</config>
13:24:01:Connecting to assign1.foldingathome.org:8080
13:24:01:Updated GPUs.txt
13:24:01:Read GPUs.txt
13:24:01:Trying to access database...
13:24:01:Successfully acquired database lock
13:24:01:Enabled folding slot 00: PAUSED cpu:5 (not configured)
13:24:01:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (not configured)
13:24:01:Enabled folding slot 02: PAUSED gpu:1:GP102 [GeForce GTX 1080 Ti] 11380 (not configured)
13:24:04:10:127.0.0.1:New Web connection
13:25:02:Saving configuration to config.xml
13:25:02:<config>
13:25:02:  <!-- Folding Slots -->
13:25:02:  <slot id='0' type='CPU'/>
13:25:02:  <slot id='1' type='GPU'/>
13:25:02:  <slot id='2' type='GPU'/>
13:25:02:</config>
13:25:02:Set client configured
13:25:02:WU00:FS00:Connecting to 65.254.110.245:8080
13:25:02:WU00:FS00:Assigned to work server 128.252.203.10
13:25:02:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 128.252.203.10
13:25:02:WU00:FS00:Connecting to 128.252.203.10:8080
13:25:02:WU01:FS01:Connecting to 65.254.110.245:8080
13:25:02:WU00:FS00:Downloading 1.06MiB
Re: GPU's sitting idle
In the log the message that they are not configured is followed by folding slots being configured for them.
What you may have run into was this - Subject: Temporary server outages
