Nvidia Quadro K5100M not folding
InHooman
Post by InHooman »
Title.
Logs:
12:01:20:WU00:FS01:Connecting to 65.254.110.245:8080
12:01:21:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:01:21:WU00:FS01:Connecting to 18.218.241.186:80
12:01:22:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:01:22:ERROR:WU00:FS01:Exception: Could not get an assignment
I'm new to this, so i don't know much. Please help.
Re: Nvidia Quadro K5100M not folding
A quick search on this GPU did not turn up information on whether it supports double precision calculations. The GPU folding projects currently active require some use of double precision at critical points in the simulation. So that may be why you did not get any assignment.
If it does support DP, then there is also this - Subject: Temporary server outages
_r2w_ben
Post by _r2w_ben »
K5100M is Kepler based and should support double precision.
https://www.techpowerup.com/gpu-specs/q ... 100m.c2425
Yes, being Kepler based it could have DP support. But not all of the mobile chips enabled that, just used the SP calculating capacity. In this case it appears from your link that DP is available on the K5100M.
Thanks for the confirmation.
