GPU not folding
Krispy
GPU not folding
Post by Krispy »
Hi, first of all sorry if I miss something here, but I just joined Folding@home for the first time. Anyways, my problem is that my CPU is folding all fine but I'd also like to utilize my GPU but it won't start folding at all. On the advanced control panel in the work queue there's a download with the same ID as the GPU, but it won't even start the download.
Here's the log:
*********************** Log Started 2020-03-14T11:03:26Z ***********************
11:03:26:************************* Folding@home Client *************************
11:03:26:        Website: https://foldingathome.org/
11:03:26:      Copyright: (c) 2009-2018 foldingathome.org
11:03:26:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:03:26:           Args: --open-web-control
11:03:26:         Config: C:\Users\jonsk\AppData\Roaming\FAHClient\config.xml
11:03:26:******************************** Build ********************************
11:03:26:        Version: 7.5.1
11:03:26:           Date: May 11 2018
11:03:26:           Time: 13:06:32
11:03:26:     Repository: Git
11:03:26:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:03:26:         Branch: master
11:03:26:       Compiler: Visual C++ 2008
11:03:26:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:03:26:       Platform: win32 10
11:03:26:           Bits: 32
11:03:26:           Mode: Release
11:03:26:******************************* System ********************************
11:03:26:            CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
11:03:26:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
11:03:26:           CPUs: 4
11:03:26:         Memory: 15.96GiB
11:03:26:    Free Memory: 11.99GiB
11:03:26:        Threads: WINDOWS_THREADS
11:03:26:     OS Version: 6.2
11:03:26:    Has Battery: false
11:03:26:     On Battery: false
11:03:26:     UTC Offset: 2
11:03:26:            PID: 15880
11:03:26:            CWD: C:\Users\jonsk\AppData\Roaming\FAHClient
11:03:26:             OS: Windows 10 Home
11:03:26:        OS Arch: AMD64
11:03:26:           GPUs: 1
11:03:26:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
11:03:26:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
11:03:26:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
11:03:26:  Win32 Service: false
11:03:26:***********************************************************************
11:03:31:<config>
11:03:31:  <!-- Network -->
11:03:31:  <proxy v=':8080'/>
11:03:31:
11:03:31:  <!-- Slot Control -->
11:03:31:  <pause-on-battery v='false'/>
11:03:31:  <power v='FULL'/>
11:03:31:
11:03:31:  <!-- User Information -->
11:03:31:  <passkey v='********************************'/>
11:03:31:  <user v='Krispy'/>
11:03:31:
11:03:31:  <!-- Folding Slots -->
11:03:31:  <slot id='0' type='CPU'/>
11:03:31:  <slot id='1' type='GPU'/>
11:03:31:</config>
11:03:32:Trying to access database...
11:03:32:Successfully acquired database lock
11:03:32:Enabled folding slot 00: READY cpu:3
11:03:32:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
11:03:32:WU00:FS00:Starting
11:03:32:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
11:03:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jonsk\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15880 -checkpoint 15 -np 2
11:03:32:WU00:FS00:Started FahCore on PID 9664
11:03:35:WU00:FS00:Core PID:16880
11:03:35:WU00:FS00:FahCore 0xa7 started
11:03:35:WU01:FS01:Connecting to 65.254.110.245:8080
11:03:35:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T11:03:35Z ***********************
11:03:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:03:36:WU00:FS00:0xa7:       Type: 0xa7
11:03:36:WU00:FS00:0xa7:       Core: Gromacs
11:03:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9664 -checkpoint 15 -np 2
11:03:36:WU00:FS00:0xa7:************************************ CBang *************************************
11:03:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:03:36:WU00:FS00:0xa7:       Date: Oct 26 2019
11:03:36:WU01:FS01:Connecting to 18.218.241.186:80
11:03:36:WU00:FS00:0xa7:       Time: 01:38:25
11:03:36:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:03:36:WU00:FS00:0xa7:     Branch: master
11:03:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:03:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:03:36:WU00:FS00:0xa7:   Platform: win32 10
11:03:36:WU00:FS00:0xa7:       Bits: 64
11:03:36:WU00:FS00:0xa7:       Mode: Release
11:03:36:WU00:FS00:0xa7:************************************ System ************************************
11:03:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
11:03:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
11:03:36:WU00:FS00:0xa7:       CPUs: 4
11:03:36:WU00:FS00:0xa7:     Memory: 15.96GiB
11:03:36:WU00:FS00:0xa7:Free Memory: 11.95GiB
11:03:37:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:03:37:WU00:FS00:0xa7: OS Version: 6.2
11:03:37:WU00:FS00:0xa7:Has Battery: false
11:03:37:WU00:FS00:0xa7: On Battery: false
11:03:37:WU00:FS00:0xa7: UTC Offset: 2
11:03:37:WU00:FS00:0xa7:        PID: 16880
11:03:37:WU00:FS00:0xa7:        CWD: C:\Users\jonsk\AppData\Roaming\FAHClient\work
11:03:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:03:37:WU00:FS00:0xa7:    Version: 0.0.18
11:03:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:03:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:03:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:03:37:WU00:FS00:0xa7:       Date: Oct 26 2019
11:03:37:WU00:FS00:0xa7:       Time: 01:52:30
11:03:37:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:03:37:WU00:FS00:0xa7:     Branch: master
11:03:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:03:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:03:37:WU00:FS00:0xa7:   Platform: win32 10
11:03:37:WU00:FS00:0xa7:       Bits: 64
11:03:37:WU00:FS00:0xa7:       Mode: Release
11:03:37:WU00:FS00:0xa7:************************************ Build *************************************
11:03:37:WU00:FS00:0xa7:       SIMD: avx_256
11:03:37:WU00:FS00:0xa7:********************************************************************************
11:03:37:WU00:FS00:0xa7:Project: 14329 (Run 0, Clone 2094, Gen 4)
11:03:37:WU00:FS00:0xa7:Unit: 0x000000049bf7a4d65e694d2801610b13
11:03:37:WU00:FS00:0xa7:Digital signatures verified
11:03:37:WU00:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpi state.cpt -cpt 15 -nt 2
11:03:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:03:37:ERROR:WU01:FS01:Exception: Could not get an assignment
11:03:38:WU01:FS01:Connecting to 65.254.110.245:8080
11:03:38:WU00:FS00:0xa7:Steps: first=1000000 total=250000
11:03:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:03:38:WU01:FS01:Connecting to 18.218.241.186:80
11:03:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:03:38:ERROR:WU01:FS01:Exception: Could not get an assignment
11:03:41:WU00:FS00:0xa7:Completed 12842 out of 250000 steps (5%)
11:04:38:WU01:FS01:Connecting to 65.254.110.245:8080
11:04:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:04:38:WU01:FS01:Connecting to 18.218.241.186:80
11:04:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:04:39:ERROR:WU01:FS01:Exception: Could not get an assignment
Re: GPU not folding
Subject: Temporary server outages
may explain your problem
TigerBazooka
Hardware configuration: Main unit: Custom rig Core i9 9900k, NVidia RTX2080Ti
Secondary unit: HP Elite 8200 Core i5 3470
Tertiary unit: Dell Inspiron Tower Core i3 3240
Quaternary unit: Lenovo Yoga Core i5 4300U
Re: GPU not folding
Post by TigerBazooka »
Thanks for posting that - I was on the verge of another reinstall.
Thugislife
Re: GPU not folding
Post by Thugislife »
Are there still server outages?
Re: GPU not folding
Yes, the researchers went home Friday at 5 PM, Monday after 9 AM they should all be back to help start new Work Units. (Unless the school is on COVID-19 lock down) Note that there are many Universitys involved so 9 AM is a mobile target. Stanford is on Pacific time.
TitanXp
Re: GPU not folding
Post by TitanXp »
GPU is still looking for work. CPU is just fine.
mw7301
Re: GPU not folding
Post by mw7301 »
I'm having the same problem. My CPU folds pretty much nonstop but my GPU folds for a awhile, finishes, then sits there for hours doing nothing. I notice that while the GPU is idle it is the Collection and Work server with the IP addresses of 0.0.0.0, it has multiple attempts and it says its waiting on "WS Assignment". Is this normal behavior? I have another system with two GPU's in it and the GRP's are busy almost all the time but those GPU's are much less powerful than the one that is going idle so much.
Re: GPU not folding
Welcome to the F@H Forum mw7301,
It just means that the GPU is waiting on getting a WU assigned to it. Currently, the F@H Servers are under load (viewtopic.php?f=24&t=33193) so if you leave it as is, it will eventually be assigned WUs :)
mw7301
Re: GPU not folding
Post by mw7301 »
Thanks for the response. Its just strange that I have two systems sitting side by side and one of them is getting GPU work units and the other is not.
jonkloske
Re: GPU not folding
Post by jonkloske »
Yeah agreed - CPU WUs are now fine, but the GPU stuff is just sitting idle most of the time. I didn't realise they ran on totally separate hardware or systems.
Re: GPU not folding
For the last 24 hours, I have managed to get a GPU WU within the first 10 attempts... that's a lot better than earlier in the week... however, now that I have mentioned it, I may have jinxed myself :P
scott@bjorn3d
Re: GPU not folding
Post by scott@bjorn3d »
Problem is they have cut down the number of Core 22 servers in favor or CPU folding. Had 9 servers doing Core 22 and had a problem getting work every now and then. It is currently at 6 servers and getting no work anymore.
Kjetil
Re: GPU not folding
Post by Kjetil »
https://apps.foldingathome.org/serverstats
Jepp, 15 a7, 6 core 22?
16:30:39:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:30:39:WU00:FS01:Connecting to 18.218.241.186:80
16:30:40:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:30:40:ERROR:WU00:FS01:Exception: Could not get an assignment
16:59:41:WU00:FS01:Connecting to 65.254.110.245:8080
16:59:41:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:59:41:WU00:FS01:Connecting to 18.218.241.186:80.
Now is 8 core 22 and 14 a7 :D .
MrFrizzy
Re: GPU not folding
Post by MrFrizzy »
I too am having issues getting GPU projects. My second rig hasn't had a project in over 24 hours even with restarting the client a few times to reset the timer. My primary rig has exceeded 10 attempts on a few occasions in the last few days as well.
It wasn't bad when there were beta core22 projects to fold, but they have all been moved to advanced or full FAH so not even my beta team membership is helping now. I just hope they can bring some extra infrastructure online soon, gonna have to turn my heater on here before too long!
S1: AMD R5 3600 & Sapphire RX 5700 XT Reference @2.1GHz under water
S2: Intel Xeon E5-2620v3 & MSI GTX 1650
RX 5700 XT Project & PPD Tracking Spreadsheet
mmzen
Re: GPU not folding
Post by mmzen »
Hi,
same here...
30 GPU doing nothing, only 1 or 2 working...
