Web Control can't load properly
kodoxic
Post by kodoxic »
I just started using Folding@home yesterday and may have already broken it. I let my computer lock and it seems as if the Web Control window cannot load properly, as it keeps loading, then refreshing, then loading again, you get the hint. This made it so that I cannot use Web Control, and possibly so that I cannot use Folding@home. If there is a way to fix this, please tell me. If I do not get an answer, I will reinstall the Folding@home client and see if that works. If you need video evidence, I am willing to find a way to record my screen so that I can provide it.
Re: Web Control can't load properly
If you are using Google Chrome, I would recommend trying a different browser. They changed something in Chrome a few months ago, the Web Control has not worked well in it since.
Clearing the browser cache may help.
You can also use the Advanced Control - FAHControl - to manage your folding. In either case, they do not need to be running for folding to continue.
raven562
Post by raven562 »
Same inoperative web-control in Opera browser
If Webcontrol is not working well, first workaround is to try to open it with another browser. Second option is to use FAHControl instead (Advanced Control from contextual menu after a right click on icon in Task Bar).
kodoxic
Post by kodoxic »
I was using Chrome. I tried another browser and it worked fine aside from something on the right not loading properly (probably my points). I'll use FAHControl for that.
Jenders97
Post by Jenders97 »
raven562 wrote:Same inoperative web-control in Opera browser
Opera is based on Chrome, so if the issue is deep in chrome opera would have the same issue. Firefox worked for me.
arne1612
Post by arne1612 »
Using Incognito Browsing Mode will also fix the problem on any browser. It probably has something to do with a corrupted cache version, but in incognito no cache versions of websites or parts of websites are used.
