Failed to Install and Startup
Initially, the software would not run because it could not find Opencl.dll, that problem was resolved. Now, after an uninstall and reinstalltion from a fresh download, it errors out with: 0x0000076
Re: Failed to Install and Startup
I can only guess about your installation. See below about posting FAHLog.
What GPU do you have? Where did you find Opencl.dll?
It's possible that you have installed Intel's OpenCL driver rather than one that can work with your AMD or nVidia GPU ... or maybe you don't have a supported GPU.
You still should already be folding with your CPUs. Right?
*********************** Log Started 2020-03-05T21:41:48Z ***********************
21:41:48:************************* Folding@home Client *************************
21:41:48: Website: https://foldingathome.org/
21:41:48: Copyright: (c) 2009-2018 foldingathome.org
21:41:48: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:41:48: Args: --open-web-control
21:41:48: Config: D:\FAH Data\config.xml
21:41:48:******************************** Build ********************************
21:41:48: Version: 7.5.1
21:41:48: Date: May 11 2018
21:41:48: Time: 13:06:32
21:41:48: Repository: Git
21:41:48: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:41:48: Branch: master
21:41:48: Compiler: Visual C++ 2008
21:41:48: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:41:48: Platform: win32 10
21:41:48: Bits: 32
21:41:48: Mode: Release
21:41:48:******************************* System ********************************
21:41:48: CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
21:41:48: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:41:48: CPUs: 8
21:41:48: Memory: 31.94GiB
21:41:48: Free Memory: 4.98GiB
21:41:48: Threads: WINDOWS_THREADS
21:41:48: OS Version: 6.2
21:41:48: Has Battery: false
21:41:48: On Battery: false
21:41:48: UTC Offset: -5
21:41:48: PID: 3532
21:41:48: CWD: D:\FAH Data
21:41:48: OS: Windows 10 Enterprise
21:41:48: OS Arch: AMD64
21:41:48: GPUs: 1
21:41:48: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM107 [Quadro K620]
21:41:48: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:9.1
21:41:48:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:391.74
21:41:48: Win32 Service: false
21:41:48:***********************************************************************
21:41:48:<config>
21:41:48: <!-- Folding Slots -->
21:41:48: <slot id='0' type='CPU'/>
21:41:48: <slot id='1' type='GPU'/>
21:41:48:</config>
21:41:48:Trying to access database...
21:41:48:Successfully acquired database lock
21:41:48:Enabled folding slot 00: READY cpu:6
21:41:48:Enabled folding slot 01: READY gpu:0:GM107 [Quadro K620]
21:41:49:WU01:FS01:Starting
21:41:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 3532 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:41:49:WU01:FS01:Started FahCore on PID 18076
21:41:49:WU01:FS01:Core PID:14516
21:41:49:WU01:FS01:FahCore 0x21 started
21:41:49:WU00:FS00:Starting
21:41:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 3532 -checkpoint 15 -np 6
21:41:49:WU00:FS00:Started FahCore on PID 17424
21:41:49:WU00:FS00:Core PID:844
21:41:49:WU00:FS00:FahCore 0xa7 started
21:41:49:WU00:FS00:0xa7:*********************** Log Started 2020-03-05T21:41:49Z ***********************
21:41:49:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:41:49:WU00:FS00:0xa7: Type: 0xa7
21:41:49:WU00:FS00:0xa7: Core: Gromacs
21:41:49:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 17424 -checkpoint 15 -np
21:41:49:WU00:FS00:0xa7: 6
21:41:49:WU00:FS00:0xa7:************************************ CBang *************************************
21:41:49:WU00:FS00:0xa7: Date: Oct 26 2019
21:41:49:WU00:FS00:0xa7: Time: 01:38:25
21:41:49:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:41:49:WU00:FS00:0xa7: Branch: master
21:41:49:WU00:FS00:0xa7: Compiler: Visual C++ 2008
21:41:49:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:41:49:WU00:FS00:0xa7: Platform: win32 10
21:41:49:WU00:FS00:0xa7: Bits: 64
21:41:49:WU00:FS00:0xa7: Mode: Release
21:41:49:WU00:FS00:0xa7:************************************ System ************************************
21:41:49:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
21:41:49:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:41:49:WU00:FS00:0xa7: CPUs: 8
21:41:49:WU00:FS00:0xa7: Memory: 31.94GiB
21:41:49:WU00:FS00:0xa7:Free Memory: 4.97GiB
21:41:49:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:41:49:WU00:FS00:0xa7: OS Version: 6.2
21:41:49:WU00:FS00:0xa7:Has Battery: false
21:41:49:WU00:FS00:0xa7: On Battery: false
21:41:49:WU00:FS00:0xa7: UTC Offset: -5
21:41:49:WU00:FS00:0xa7: PID: 844
21:41:49:WU00:FS00:0xa7: CWD: D:\FAH Data\work
21:41:49:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:41:49:WU00:FS00:0xa7: Version: 0.0.18
21:41:49:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:41:49:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
21:41:49:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
21:41:49:WU00:FS00:0xa7: Time: 01:52:30
21:41:49:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:41:49:WU00:FS00:0xa7:************************************ Build *************************************
21:41:49:WU00:FS00:0xa7: SIMD: avx_256
21:41:49:WU00:FS00:0xa7:********************************************************************************
21:41:49:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 456, Gen 115)
21:41:49:WU00:FS00:0xa7:Unit: 0x0000007e80fccb095dcad970de0f6ade
21:41:49:WU00:FS00:0xa7:Digital signatures verified
21:41:49:WU00:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -x frame115.xtc -cpi state.cpt -cpt 15 -nt 6
21:41:50:WU00:FS00:0xa7:Steps: first=14375000 total=125000
21:41:53:WU00:FS00:0xa7:Completed 3512 out of 125000 steps (2%)
21:42:24:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
The latest driver is version 442.50, you are running 391.74
https://www.nvidia.com/Download/driverR ... 7542/en-us
I hope that helps.
I hope that helps.
Installed the latest NVIDIA drivers, Web control page flashes with red "Stop Folding"
*********************** Log Started 2020-03-05T23:40:18Z ***********************
23:40:18:************************* Folding@home Client *************************
23:40:18: Website: https://foldingathome.org/
23:40:18: Copyright: (c) 2009-2018 foldingathome.org
23:40:18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:40:18: Args:
23:40:18: Config: D:\FAH Data\config.xml
23:40:18:******************************** Build ********************************
23:40:18: Version: 7.5.1
23:40:18: Date: May 11 2018
23:40:18: Time: 13:06:32
23:40:18: Repository: Git
23:40:18: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:40:18: Branch: master
23:40:18: Compiler: Visual C++ 2008
23:40:18: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:40:18: Platform: win32 10
23:40:18: Bits: 32
23:40:18: Mode: Release
23:40:18:******************************* System ********************************
23:40:18: CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
23:40:18: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:40:18: CPUs: 8
23:40:18: Memory: 31.94GiB
23:40:18: Free Memory: 23.47GiB
23:40:18: Threads: WINDOWS_THREADS
23:40:18: OS Version: 6.2
23:40:18: Has Battery: false
23:40:18: On Battery: false
23:40:18: UTC Offset: -5
23:40:18: PID: 13464
23:40:18: CWD: D:\FAH Data
23:40:18: OS: Windows 10 Enterprise
23:40:18: OS Arch: AMD64
23:40:18: GPUs: 1
23:40:18: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM107 [Quadro K620]
23:40:18: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:10.2
23:40:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
23:40:18: Win32 Service: false
23:40:18:***********************************************************************
23:40:18:<config>
23:40:18: <!-- Folding Slots -->
23:40:18: <slot id='0' type='CPU'/>
23:40:18: <slot id='1' type='GPU'/>
23:40:18:</config>
23:40:18:Trying to access database...
23:40:18:Successfully acquired database lock
23:40:18:Enabled folding slot 00: READY cpu:6
23:40:18:Enabled folding slot 01: READY gpu:0:GM107 [Quadro K620]
23:40:19:WU01:FS01:Starting
23:40:19:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 13464 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:40:19:WU01:FS01:Started FahCore on PID 5468
23:40:19:WU01:FS01:Core PID:14124
23:40:19:WU01:FS01:FahCore 0x21 started
23:40:19:WU00:FS00:Starting
23:40:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 13464 -checkpoint 15 -np 6
23:40:19:WU00:FS00:Started FahCore on PID 14268
23:40:20:WU00:FS00:Core PID:4824
23:40:20:WU00:FS00:FahCore 0xa7 started
23:40:21:WU00:FS00:0xa7:*********************** Log Started 2020-03-05T23:40:20Z ***********************
23:40:21:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:40:21:WU00:FS00:0xa7: Type: 0xa7
23:40:21:WU00:FS00:0xa7: Core: Gromacs
23:40:21:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 14268 -checkpoint 15 -np
23:40:21:WU00:FS00:0xa7: 6
23:40:21:WU00:FS00:0xa7:************************************ CBang *************************************
23:40:21:WU00:FS00:0xa7: Date: Oct 26 2019
23:40:21:WU00:FS00:0xa7: Time: 01:38:25
23:40:21:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:40:21:WU00:FS00:0xa7: Branch: master
23:40:21:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:40:21:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:40:21:WU00:FS00:0xa7: Platform: win32 10
23:40:21:WU00:FS00:0xa7: Bits: 64
23:40:21:WU00:FS00:0xa7: Mode: Release
23:40:21:WU00:FS00:0xa7:************************************ System ************************************
23:40:21:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
23:40:21:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:40:21:WU00:FS00:0xa7: CPUs: 8
23:40:21:WU00:FS00:0xa7: Memory: 31.94GiB
23:40:21:WU00:FS00:0xa7:Free Memory: 23.29GiB
23:40:21:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:40:21:WU00:FS00:0xa7: OS Version: 6.2
23:40:21:WU00:FS00:0xa7:Has Battery: false
23:40:21:WU00:FS00:0xa7: On Battery: false
23:40:21:WU00:FS00:0xa7: UTC Offset: -5
23:40:21:WU00:FS00:0xa7: PID: 4824
23:40:21:WU00:FS00:0xa7: CWD: D:\FAH Data\work
23:40:21:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:40:21:WU00:FS00:0xa7: Version: 0.0.18
23:40:21:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:40:21:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:40:21:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:40:21:WU00:FS00:0xa7: Time: 01:52:30
23:40:21:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:40:21:WU00:FS00:0xa7:************************************ Build *************************************
23:40:21:WU00:FS00:0xa7: SIMD: avx_256
23:40:21:WU00:FS00:0xa7:********************************************************************************
23:40:21:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 456, Gen 115)
23:40:21:WU00:FS00:0xa7:Unit: 0x0000007e80fccb095dcad970de0f6ade
23:40:21:WU00:FS00:0xa7:Digital signatures verified
23:40:21:WU00:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -x frame115.xtc -cpi state.cpt -cpt 15 -nt 6
23:40:21:WU00:FS00:0xa7:ERROR:Guru Meditation #66f50e9538076440.f728b89319e0e091 (93881.95083) '00/01/md.log'
23:40:21:WU00:FS00:0xa7:WARNING:Unexpected exit() call
23:40:21:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
23:40:21:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:40:21:WU00:FS00:0xa7:Saving result file frame115.trr
23:40:22:WU00:FS00:0xa7:Saving result file frame115.xtc
23:40:22:WU00:FS00:0xa7:Saving result file md.log
23:40:22:WU00:FS00:0xa7:ERROR:Guru Meditation #66f50e9538076440.f728b89319e0e091 (93881.95083) '00/01/md.log'
23:40:23:WU01:FS01:0x21:*********************** Log Started 2020-03-05T23:40:23Z ***********************
23:40:23:WU01:FS01:0x21:Project: 11714 (Run 0, Clone 16744, Gen 12)
23:40:23:WU01:FS01:0x21:Unit: 0x000000198ca304f15df3d3559cb83277
23:40:23:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:40:23:WU01:FS01:0x21:Machine: 1
23:40:23:WU01:FS01:0x21:Digital signatures verified
23:40:23:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:40:23:WU01:FS01:0x21:Version 0.0.20
23:40:23:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
23:40:23:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
23:40:24:WU00:FS00:Starting
23:40:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 13464 -checkpoint 15 -np 6
23:40:24:WU00:FS00:Started FahCore on PID 14548
23:40:24:WU00:FS00:Core PID:14572
23:40:24:WU00:FS00:FahCore 0xa7 started
23:40:24:WU00:FS00:0xa7:*********************** Log Started 2020-03-05T23:40:24Z ***********************
23:40:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:40:24:WU00:FS00:0xa7: Type: 0xa7
23:40:24:WU00:FS00:0xa7: Core: Gromacs
23:40:24:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 14548 -checkpoint 15 -np
23:40:24:WU00:FS00:0xa7: 6
23:40:24:WU00:FS00:0xa7:************************************ CBang *************************************
23:40:24:WU00:FS00:0xa7: Date: Oct 26 2019
23:40:24:WU00:FS00:0xa7: Time: 01:38:25
23:40:24:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:40:24:WU00:FS00:0xa7: Branch: master
23:40:24:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:40:24:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:40:24:WU00:FS00:0xa7: Platform: win32 10
23:40:24:WU00:FS00:0xa7: Bits: 64
23:40:24:WU00:FS00:0xa7: Mode: Release
23:40:24:WU00:FS00:0xa7:************************************ System ************************************
23:40:24:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
23:40:24:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:40:24:WU00:FS00:0xa7: CPUs: 8
23:40:24:WU00:FS00:0xa7: Memory: 31.94GiB
23:40:24:WU00:FS00:0xa7:Free Memory: 23.22GiB
23:40:24:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:40:24:WU00:FS00:0xa7: OS Version: 6.2
23:40:24:WU00:FS00:0xa7:Has Battery: false
23:40:24:WU00:FS00:0xa7: On Battery: false
23:40:24:WU00:FS00:0xa7: UTC Offset: -5
23:40:24:WU00:FS00:0xa7: PID: 14572
23:40:24:WU00:FS00:0xa7: CWD: D:\FAH Data\work
23:40:24:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:40:24:WU00:FS00:0xa7: Version: 0.0.18
23:40:24:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:40:24:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:40:24:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:40:24:WU00:FS00:0xa7: Time: 01:52:30
23:40:24:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:40:24:WU00:FS00:0xa7:************************************ Build *************************************
23:40:24:WU00:FS00:0xa7: SIMD: avx_256
23:40:24:WU00:FS00:0xa7:********************************************************************************
23:40:24:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 456, Gen 115)
23:40:24:WU00:FS00:0xa7:Unit: 0x0000007e80fccb095dcad970de0f6ade
23:40:24:WU00:FS00:0xa7:Digital signatures verified
23:40:24:WU00:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -x frame115.xtc -cpi state.cpt -cpt 15 -nt 6
23:40:24:WU00:FS00:0xa7:ERROR:Guru Meditation #66f50e9538076440.f728b89319e0e091 (93881.95083) '00/01/md.log'
23:40:24:WU00:FS00:0xa7:WARNING:Unexpected exit() call
23:40:24:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
23:40:24:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:40:24:WU00:FS00:0xa7:Saving result file frame115.trr
23:40:24:WU00:FS00:0xa7:Saving result file frame115.xtc
23:40:24:WU00:FS00:0xa7:Saving result file md.log
23:40:25:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
23:40:25:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
23:40:33:WU01:FS01:0x21:Completed 0 out of 7500000 steps (0%)
23:40:33:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:41:24:WU00:FS00:Starting
23:41:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\FAH Data\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 13464 -checkpoint 15 -np 6
23:41:24:WU00:FS00:Started FahCore on PID 18696
I would bet that if you removed the Opencl.dll file you manually installed, all would be well.
WebControl doesn't like Chrome. Use a different browser or use FAHControl.mlsills wrote:Web control page flashes with red "Stop Folding"
Is FAHControl available for Windows?
That would be interesting, how do you suggest I do that, simply deleting the existing Opencl.dll would leave me without it, correct?JimboPalmer wrote:I would bet that if you removed the Opencl.dll file you manually installed, all would be well.
Because you now have the latest drivers Nvidia's opencl.dll should be in the path somewhere. I worry that the manually loaded version is being found first.
The WIndows installation package includes FAHControl, FAHClient, and a non-working copy of FAHViewer (That can only display the Demo protein).mlsills wrote:Is FAHControl available for Windows?
The Opencl.dll inJimboPalmer wrote:Because you now have the latest drivers Nvidia's opencl.dll should be in the path somewhere. I worry that the manually loaded version is being found first.
System32 is signed by by NVIDIA and Kronos
According to the errors in the log your posted, your issue has something to do with permissions on the files used by FAH.
How did you install your client ? Do you start it under the same user that installed it ? Do you use the shortcut created by FAH installer ? Do you have some security software or policy the could mess with permissions ?
Thank you for your reply, my answers:
1: I downloaded the software, and installed it using as "administrator"
2: It was started by a user with administrator rights
3: It was started by the shortcut created by the installer
4: Norton Security is used, however, the firewall gives FAH permission
5: It will open properly with Microsoft Edge which is strange as it uses the same engine as Chrome
Mark
Mark
I'm not sure, but I think I read somewhere tat bruce was suggesting that it's better to install with the user account that will run the client and to select the option "install only for me" ...
bruce, can you confirm this ?
