Unsure why I'm not receiving QRB
superduck10
I've recently got back into running folding at home now that I have a powerful computer that sits idle through most of the day. Unfortunately I am not yet receiving QRB and I'm not entirely sure why because I'm new to the QRB system. I just recently started using a passkey while folding and I don't know if work I did years ago without a passkey has an affect on my current completion rate. As far as I know, after using a passkey I have completed 13 work units with a 100% return rate. Is there a way to check what my current stats are? Can I check what work units are QRB eligible? Do I need to fold on my CPU rather than my GPU? It says I'm running core 21, does that have an impact on my issue? I've seen a few people have posted about not receiving bonus points for project 14180 and I have completed 3 work units for that project. Does that have an impact? I'm probably missing something somewhere, do let me know!
Re: Unsure why I'm not receiving QRB
Yes. Use https://apps.foldingathome.org/bonus
Each pair of (donor_name,passkey) is unique. WUs completed with a blank passkey don't count against the return rate calculations of your new pair with a passkey.
There have been some recent difficulties with the reporting of bonuses. Possibly you're seeing that problem, too.
superduck10
I do believe I am seeing that problem. I have a 100% finished, 0% expired, and I have done 43 work units that have the bonus active and only 13 that don't.
You are misinterpreting the information you have looked up. The last WU you turned in did not get bonus points, it appears to be associated with a passkey and username combination that is not yet qualified for the bonus.
Looking up superduck10, there are 3 different passkeys shown. One has 43 WU's and an 100% return rate. Using that passkey you would get bonus points. The other two passkeys have 4 and 9 WU's returned respectively, and are not eligible for the QRB as 10 WU's have not been completed.
superduck10
Oh I see now. Thanks for the help!
