Please add Radeon Pro WX Vega M GL
JohnJohn
Post by JohnJohn »
Hello,
Please add the Radeon Pro WX Vega M GL to the whitelist.
lspci:
0x1002:0x694f:1:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:Radeon Pro WX Vega M GL Graphics
GPU-Z:
Thanks!
Re: Please add Radeon Pro WX Vega M GL
Done
JohnJohn
Post by JohnJohn »
Thanks, Bruce! I appreciate your remarkably fast turnaround time on the request.
Pure luck. You caught me on-line.
JohnJohn
Post by JohnJohn »
I've been unable to get the card running in FAH when adding this as a GPU slot in the config menu; it is recognized in the FAH Control client as an OpenCL device. I tried a fresh reinstall a few times without success. It looks like the software downloads an FahCore_a4 exe in Windows 10 user AppData when the GPU is added, rather than a 0x21 core and then proceeds to give "No WUs available for this configuration" errors. The i7-8706G CPU folds normally running FahCore_a7. Any help is much appreciated.
02:47:05:WU01:FS00:0xa7:*********************** Log Started 2019-06-29T02:47:04Z ***********************
02:47:05:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:47:05:WU01:FS00:0xa7:       Type: 0xa7
02:47:05:WU01:FS00:0xa7:       Core: Gromacs
02:47:05:WU01:FS00:0xa7:    Website: https://foldingathome.org/
02:47:05:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
02:47:05:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:47:05:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4252 -checkpoint 15 -np 7
02:47:05:WU01:FS00:0xa7:     Config: <none>
02:47:05:WU01:FS00:0xa7:************************************ Build *************************************
02:47:05:WU01:FS00:0xa7:    Version: 0.0.17
02:47:05:WU01:FS00:0xa7:       Date: Apr 27 2018
02:47:05:WU01:FS00:0xa7:       Time: 16:19:36
02:47:05:WU01:FS00:0xa7: Repository: Git
02:47:05:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
02:47:05:WU01:FS00:0xa7:     Branch: master
02:47:05:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
02:47:05:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:47:05:WU01:FS00:0xa7:   Platform: win32 10
02:47:05:WU01:FS00:0xa7:       Bits: 64
02:47:05:WU01:FS00:0xa7:       Mode: Release
02:47:05:WU01:FS00:0xa7:       SIMD: avx_256
02:47:05:WU01:FS00:0xa7:************************************ System ************************************
02:47:05:WU01:FS00:0xa7:        CPU: Unknown
02:47:05:WU01:FS00:0xa7:     CPU ID:
02:47:05:WU01:FS00:0xa7:       CPUs: 8
02:47:05:WU01:FS00:0xa7:     Memory: 15.82GiB
02:47:05:WU00:FS01:Connecting to 65.254.110.245:8080
02:47:05:WU01:FS00:0xa7:Free Memory: 10.54GiB
02:47:05:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
02:47:05:WU01:FS00:0xa7: OS Version: 6.2
02:47:05:WU01:FS00:0xa7:Has Battery: true
02:47:05:WU01:FS00:0xa7: On Battery: false
02:47:05:WU01:FS00:0xa7: UTC Offset: -5
02:47:05:WU01:FS00:0xa7:        PID: 13124
02:47:05:WU01:FS00:0xa7:        CWD: C:\Users\John\AppData\Roaming\FAHClient\work
02:47:05:WU01:FS00:0xa7:         OS: Windows 10 Pro
02:47:05:WU01:FS00:0xa7:    OS Arch: AMD64
02:47:05:WU01:FS00:0xa7:********************************************************************************
02:47:05:WU01:FS00:0xa7:Project: 14153 (Run 16, Clone 276, Gen 80)
02:47:05:WU01:FS00:0xa7:Unit: 0x000000690002894b5c6e03b25004a31c
02:47:05:WU01:FS00:0xa7:Digital signatures verified
02:47:05:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
02:47:05:WU01:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -cpi state.cpt -cpt 15 -nt 6
02:47:05:WU01:FS00:0xa7:Steps: first=400000000 total=5000000
02:47:05:WU01:FS00:0xa7:Completed 1041442 out of 5000000 steps (20%)
02:47:05:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:47:05:WU00:FS01:Connecting to 18.218.241.186:80
02:47:06:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:47:06:ERROR:WU00:FS01:Exception: Could not get an assignment
02:47:42:Removing old file 'configs/config-20190629-001302.xml'
02:47:42:Saving configuration to config.xml
02:47:42:<config>
02:47:42:  <!-- Folding Core -->
02:47:42:  <core-priority v='low'/>
02:47:42:
02:47:42:  <!-- Folding Slot Configuration -->
02:47:42:  <cause v='CANCER'/>
02:47:42:
02:47:42:  <!-- Network -->
02:47:42:  <proxy v=':8080'/>
02:47:42:
02:47:42:  <!-- Slot Control -->
02:47:42:  <power v='FULL'/>
02:47:42:
02:47:42:  <!-- User Information -->
02:47:42:  <passkey v='/>
02:47:42:  <team v='X'/>
02:47:42:  <user v='John'/>
02:47:42:
02:47:42:  <!-- Folding Slots -->
02:47:42:  <slot id='0' type='CPU'>
02:47:42:    <next-unit-percentage v='100'/>
02:47:42:  </slot>
02:47:42:  <slot id='1' type='GPU'/>
02:47:42:</config>
02:48:05:WU00:FS01:Connecting to 65.254.110.245:8080
02:48:06:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:48:06:WU00:FS01:Connecting to 18.218.241.186:80
02:48:06:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:48:06:ERROR:WU00:FS01:Exception: Could not get an assignment
You do not post the first 100 lines of the log where it shows what equipment and software the Client knows about. That would help.
WU01:FS00 is your CPU slot. It can run an a4 or an a7 core, you seem to be running an a7 in the log. There are some hints in the log that it is an 8 thread CPU newer than 2013. It seems fine. It knows you have a GPU, so folds on 6 threads, so there is CPU power to aid the GPU.
WU00:FS01 seems to be your GPU slot, nothing is working on that slot, so it is not clear what GPU the client thinks it has. (the configuration part of the log would help) Whatever you are sending the assignment server does not seem to be a GPU it has Work Units for.
JohnJohn
Post by JohnJohn »
Sorry for omitting the hardware info; here are the first 100 lines:
*********************** Log Started 2019-06-29T04:04:06Z ***********************
04:04:06:************************* Folding@home Client *************************
04:04:06:        Website: https://foldingathome.org/
04:04:06:      Copyright: (c) 2009-2018 foldingathome.org
04:04:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:04:06:           Args: --open-web-control
04:04:06:         Config: C:\Users\John\AppData\Roaming\FAHClient\config.xml
04:04:06:******************************** Build ********************************
04:04:06:        Version: 7.5.1
04:04:06:           Date: May 11 2018
04:04:06:           Time: 13:06:32
04:04:06:     Repository: Git
04:04:06:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:04:06:         Branch: master
04:04:06:       Compiler: Visual C++ 2008
04:04:06:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:04:06:       Platform: win32 10
04:04:06:           Bits: 32
04:04:06:           Mode: Release
04:04:06:******************************* System ********************************
04:04:06:            CPU: Intel(R) Core(TM) i7-8706G CPU @ 3.10GHz
04:04:06:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:04:06:           CPUs: 8
04:04:06:         Memory: 15.82GiB
04:04:06:    Free Memory: 10.50GiB
04:04:06:        Threads: WINDOWS_THREADS
04:04:06:     OS Version: 6.2
04:04:06:    Has Battery: true
04:04:06:     On Battery: false
04:04:06:     UTC Offset: -5
04:04:06:            PID: 11532
04:04:06:            CWD: C:\Users\John\AppData\Roaming\FAHClient
04:04:06:             OS: Windows 10 Enterprise
04:04:06:        OS Arch: AMD64
04:04:06:           GPUs: 1
04:04:06:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 [Radeon WX Vega M GL]
04:04:06:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:04:06:                 specified module could not be found.
04:04:06:
04:04:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2580.6
04:04:06:  Win32 Service: false
04:04:06:***********************************************************************
04:04:06:<config>
04:04:06:  <!-- Folding Core -->
04:04:06:  <core-priority v='low'/>
04:04:06:
04:04:06:  <!-- Folding Slot Configuration -->
04:04:06:  <cause v='CANCER'/>
04:04:06:
04:04:06:  <!-- Network -->
04:04:06:  <proxy v=':8080'/>
04:04:06:
04:04:06:  <!-- Slot Control -->
04:04:06:  <power v='FULL'/>
04:04:06:
04:04:06:  <!-- User Information -->
04:04:06:  <passkey v='X'/>
04:04:06:  <team v='X'/>
04:04:06:  <user v='John'/>
04:04:06:
04:04:06:  <!-- Folding Slots -->
04:04:06:  <slot id='0' type='CPU'>
04:04:06:    <next-unit-percentage v='100'/>
04:04:06:  </slot>
04:04:06:  <slot id='1' type='GPU'/>
04:04:06:</config>
04:04:06:Trying to access database...
04:04:06:Successfully acquired database lock
04:04:06:Enabled folding slot 00: READY cpu:7
04:04:06:Enabled folding slot 01: READY gpu:0:[Radeon WX Vega M GL]
04:04:06:WU01:FS00:Starting
04:04:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 11532 -checkpoint 15 -np 7
04:04:06:WU01:FS00:Started FahCore on PID 10212
04:04:06:WU01:FS00:Core PID:8396
04:04:06:WU01:FS00:FahCore 0xa7 started
04:04:06:WU00:FS01:Connecting to 65.254.110.245:8080
04:04:06:WU01:FS00:0xa7:*********************** Log Started 2019-06-29T04:04:06Z ***********************
04:04:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:04:06:WU01:FS00:0xa7:       Type: 0xa7
04:04:06:WU01:FS00:0xa7:       Core: Gromacs
04:04:06:WU01:FS00:0xa7:    Website: https://foldingathome.org/
04:04:06:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
04:04:06:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:04:06:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 10212 -checkpoint 15 -np
04:04:06:WU01:FS00:0xa7:             7
04:04:06:WU01:FS00:0xa7:     Config: <none>
04:04:06:WU01:FS00:0xa7:************************************ Build *************************************
04:04:06:WU01:FS00:0xa7:    Version: 0.0.17
04:04:06:WU01:FS00:0xa7:       Date: Apr 27 2018
04:04:06:WU01:FS00:0xa7:       Time: 16:19:36
04:04:06:WU01:FS00:0xa7: Repository: Git
04:04:06:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
04:04:06:WU01:FS00:0xa7:     Branch: master
04:04:06:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:04:06:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:04:06:WU01:FS00:0xa7:   Platform: win32 10
04:04:06:WU01:FS00:0xa7:       Bits: 64
04:04:06:WU01:FS00:0xa7:       Mode: Release
04:04:06:WU01:FS00:0xa7:       SIMD: avx_256
04:04:06:WU01:FS00:0xa7:************************************ System ************************************
04:04:06:WU01:FS00:0xa7:        CPU: Unknown
04:04:06:WU01:FS00:0xa7:     CPU ID:
04:04:06:WU01:FS00:0xa7:       CPUs: 8
04:04:06:WU01:FS00:0xa7:     Memory: 15.82GiB
04:04:06:WU01:FS00:0xa7:Free Memory: 10.49GiB
04:04:06:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:04:06:WU01:FS00:0xa7: OS Version: 6.2
04:04:06:WU01:FS00:0xa7:Has Battery: true
04:04:06:WU01:FS00:0xa7: On Battery: false
04:04:06:WU01:FS00:0xa7: UTC Offset: -5
04:04:06:WU01:FS00:0xa7:        PID: 8396
04:04:06:WU01:FS00:0xa7:        CWD: C:\Users\John\AppData\Roaming\FAHClient\work
04:04:06:WU01:FS00:0xa7:         OS: Windows 10 Pro
04:04:06:WU01:FS00:0xa7:    OS Arch: AMD64
04:04:06:WU01:FS00:0xa7:********************************************************************************
04:04:06:WU01:FS00:0xa7:Project: 14153 (Run 16, Clone 276, Gen 80)
04:04:06:WU01:FS00:0xa7:Unit: 0x000000690002894b5c6e03b25004a31c
04:04:06:WU01:FS00:0xa7:Digital signatures verified
04:04:06:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
04:04:06:WU01:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -cpi state.cpt -cpt 15 -nt 6
04:04:06:WU01:FS00:0xa7:Steps: first=400000000 total=5000000
04:04:07:WU01:FS00:0xa7:Completed 2002042 out of 5000000 steps (40%)
04:04:07:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:04:07:WU00:FS01:Connecting to 18.218.241.186:80
04:04:07:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:04:07:ERROR:WU00:FS01:Exception: Could not get an assignment
04:04:07:WU00:FS01:Connecting to 65.254.110.245:8080
04:04:08:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available
The message "No WUs available for this configuration" gave me a clue. I checked the GPUs.txt file, and the Vega M GL is categorized as not having double precision processing available. Currently all, or at least almost all projects for GPU folding require mixed precision calculations, most processing is done with single precision but some operations are done in double to retain enough accuracy.
A brief search of sites for information on this GPU, a discrete AMD GPU chip packaged with an Intel i-series CPU, did not turn up any information on whether the Vega M GL does have double precision available. It may be following prior iGPU practices of not including double precision as it is not needed for gaming and similar applications. The only way possibly to be sure on this would be running one of the benchmarks such as FAHBench to see if double precision is available.
JohnJohn
Post by JohnJohn »
Thanks for the quick response, Joe and Jim!
It look likes double precision is working on the GPU. When running FAHBench with the following settings, these are the results:
Device: gfx804
Compute: OpenCL
Precision: double
WU: dhfr
Accuracy check: Enabled
NaN Check: 0-Disabled
Run length: 1 min
Score: 4.68
Atoms: 23558
The benchmark that I get here is between a GTX 1660 ti (8.65) and GTX 950 (2.71), which is why I'd really like to put it to work for folding, as it is more than capable of returning work units on or well ahead of a normal requested schedule.
Like Joe_H, I'm having trouble finding technical information about this device.
If you go to www.amd.com and select "Drivers and Support, which drivers are recommended?
If you run gpu-z what does it tell you about the device?
JohnJohn
Post by JohnJohn »
Hi Bruce,
The GPU-Z info is the same as what's in my original GPU whitelist request post, and it has a hardware detail lookup at:
https://www.techpowerup.com/gpu-specs/r ... m-gl.c3352
The detailed GPU slot download log files from FAHClient.exe are as follows:
08:27:38:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
08:27:39:WU00:FS00:Connecting to cores.foldingathome.org:80
08:27:39:WU00:FS00:FahCore a4: Downloading 2.89MiB
08:27:40:WU00:FS00:FahCore a4: Download complete
08:27:40:WU00:FS00:Valid core signature
08:27:40:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Failed to open 'cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Access is denied.
08:27:40:ERROR:WU00:FS00:: iostream stream error: Access is denied.
Hope this helps.
You may wish to remove this directive and see if that helps, there may simply be no WUs for AMD cards for Cancer at this moment.
Your tech power up link does show FP64 support (double precision) as well as GCN 1.2 support. So despite confusion about sometimes claiming to be Vega and sometimes claiming to be Polaris, it does seem capable of running F@H. (You may find your PC overheats, if so try deleting the CPU slot, it makes fewer PPD than the GPU slot)
This Wikipedia article says that while branded as Vega, it is Polaris 22. https://en.wikipedia.org/wiki/Graphics_ ... xt#Chips_4
https://www.reddit.com/r/Amd/comments/8 ... olaris_22/
JimboPalmer wrote:04:04:06: <!-- Folding Slot Configuration -->
If the AS code is working correctly, the cause setting should not be an issue. If there are no WU's for a specific cause, the client is supposed to be assigned one from other projects and causes. The real issue is that there was no work for a GPU categorized as not supporting double precision in the GPUs.txt file.
0x1002:0x694c:1:4:[Radeon RX Vega M XT]
0x1002:0x694e:1:4:[Radeon RX Vega M XL]
0x1002:0x694f:1:4:[Radeon WX Vega M GL]
The 4 before the colon separating it from the description field in the entry is for GPU's not known to support DP.
The Tech Power writeup is interesting, though they do list the performance as theoretical. The actual test with FAHBench showing double precision performance value is more useful as a confirmation. There have been a number of GPU chip families that support FP64, but when released in iGPU or mobile formats have had it disabled in hardware or the driver.
If the entry does get changed to show DP is available, it will be interesting to see how well it performs. As the Vega M is packaged by Intel with a Kaby Lake i5 or i7, video RAM and a bus chip to handle communications between them, the TDP for the package is 65 W. How that is divvied up between the CPU and GPU depends on Intel's thermal controls.
JohnJohn wrote:Hi Bruce,
Hope this helps.
This log section shows a different, possibly non-related issue. Core A4 is a CPU folding core, not for your GPU. The error messages point towards a permissions issue with your install or the account you were using at this time, Windows was not allowing the downloaded core to be placed where it needed to be for processing the WU that required it.
In fact, the 1002.694F GPU Polaris 22 MGL XL [Radeon Pro WX Vega M GL] is not supported by FAH.
FAH has never supported any GPUs with Intel drivers (including Intel OpenCL drivers) and it's not clear to me what AMD drivers might be used to make it look like a supportable AMD device. (I'm going to guess that this device contains a CPU device (supported by standard CPU drivers in your OS, possibly an Intel iGPU supported by Intel drivers, and possibly also an AMD GPU, supported by AMD drivers. A lot depends on how FAH detects those devices and whether you have options to run other drivers.
