Total points not are received
The points are not credited to my account, only have the base points in all proyects.
http://www.linuxforge.net/bonuscalc2.php
In other case, the PPD not is real
Which contact?
Which contact?
Re: Total points not are received
Did you add a passkey yet to get the bonus points?
https://foldingathome.org/support/faq/points/passkey/
After that you need to complete 10 work units and then you get the bonus PPD.
where put it?
When i created the acount i have one passkey, i invented before to look or see https://foldingathome.org/support/faq/points/passkey/,
And have other passkey created by https://apps.foldingathome.org/getpasskey send in my email
But only i associated the first passkey in my user name.
i have two passkey, but, i put only the pass invented for my in user account, 32 hexacecimal characters, no the https://apps.foldingathome.org/getpasskey, this passkey , only is asociated in my email, no my usercount
i have 17 wu realised
Only have a one account
i read about the passkey.
The bonus points are in https://foldingathome.org/support/faq/points/
I dont know where put the password? i have 17 wu, i have only 150000 points.
DATA LOG:
15 APR 2019
19:40:13:WU01:FS01:Server responded WORK_ACK (400)
19:40:13:WU01:FS01:Final credit estimate, 39641.00 points
16 APRL 2019
00:22:36:WU02:FS01:Server responded WORK_ACK (400)
00:22:36:WU02:FS01:Final credit estimate, 42370.00 point
02:36:43:WU00:FS00:Server responded WORK_ACK (400)
02:36:43:WU00:FS00:Final credit estimate, 3104.00 points
05:53:32:WU01:FS01:Server responded WORK_ACK (400)
05:53:32:WU01:FS01:Final credit estimate, 70161.00 points
11:38:40:WU02:FS00:Server responded WORK_ACK (400)
11:38:40:WU02:FS00:Final credit estimate, 3338.00 points
13:05:16:WU00:FS01:Server responded WORK_ACK (400)
13:05:16:WU00:FS01:Final credit estimate, 74632.00 points
20:34:40:WU01:FS00:Server responded WORK_ACK (400)
20:34:40:WU01:FS00:Final credit estimate, 3445.00 points
17 APR 2019
01:22:56:WU02:FS01:Server responded WORK_ACK (400)
01:22:56:WU02:FS01:Final credit estimate, 121408.00 points
04:25:59:WU01:FS01:Server responded WORK_ACK (400)
04:25:59:WU01:FS01:Final credit estimate, 36548.00 points
05:29:47:WU00:FS00:Server responded WORK_ACK (400)
05:29:47:WU00:FS00:Final credit estimate, 3451.00 points
10:17:56:WU02:FS01:Server responded WORK_ACK (400)
10:17:56:WU02:FS01:Final credit estimate, 72711.00 points
14:22:16:WU00:FS01:Server responded WORK_ACK (400)
14:22:16:WU00:FS01:Final credit estimate, 44757.00 points
21:31:54:WU02:FS01:Server responded WORK_ACK (400)
21:31:54:WU02:FS01:Final credit estimate, 75026.00 points
18 APR 2019
00:41:28:WU01:FS00:Server responded WORK_ACK (400)
00:41:28:WU01:FS00:Final credit estimate, 5839.00 points
02:34:10:WU00:FS01:Server responded WORK_ACK (400)
02:34:10:WU00:FS01:Final credit estimate, 64846.00 points
06:25:38:WU01:FS01:Server responded WORK_ACK (400)
06:25:38:WU01:FS01:Final credit estimate, 50161.00 points
06:56:05:WU02:FS00:Server responded WORK_ACK (400)
06:56:05:WU02:FS00:Final credit estimate, 4089.00 points
11:25:46:WU01:FS00:Server responded WORK_ACK (400)
11:25:46:WU01:FS00:Final credit estimate, 1184.00 points
Just now
12:00:03:WU00:FS01:Server responded WORK_ACK (400)
12:00:03:WU00:FS01:Final credit estimate, 69742.00 points
19 WU uploads = 786453points
Only have less than 154695 in https://stats.foldingathome.org/donor/E ... an_Beltran
DATA LOG:
15 APR 2019
16 APRL 2019
17 APR 2019
18 APR 2019
Just now
It may take a day to get your points listed in your user statistics. So look again tomorrow.
SURE?foldy wrote:It may take a day to get your points listed in your user statistics. So look again tomorrow.
19WU in the statistics only 154695 of 785453
5 times less
Where I have put my pass for get the bonus points?
You need to enter the passkey that you got from the site that was sent to you by email. One you create yourself and enter will be ignored by the stats system, but the client has no means of checking that and will display an estimated points as if you have a valid, qualified passkey.
If you are using the Web Control, you enter the passkey using the Change Identity function. Using FAHControl you use Configure and enter it under the Identity tab.
Once you have a valid passkey, then after downloading and returning 10 WU's you will get the bonus on future WU's as long as you maintain an 80% return rate.
Ok I have delete the pass of my identity, and I have put the pass that has been send to my (email).
No have web control.
The Web Control is a standard part of the F@h install. The installer places document that is a link to the proper URL to display the Web Control in a browser, usually whichever is the default on your system.
I have a Client Advanced Control, and i open the web, client of Local Folding = client.foldingathome.org
And i see, the same points in two windows
If I don't receive all my points when I have 50WU, I will have to leave Folding at home, 3 days ago I sent an email to support, and they have not answered me yet.
In another side, i can see they take me away 7000 points for taking time to upload the work done (11:48 to 11:53) 5 minutes for upload 13.5MB, in my conecction of 8Mbps equals to 0.8MB/s for Donwload, but 3Mbps equals 0.3MB/s for Upload, The take me away 7000 points, 77000-7000= 70000 points but, in the log.txt, but only get base points in my account
This last part can be seen in the advanced client, as the points go down in time while the task goes up, is the period when you machine finish the task, and start upload.
The time a WU is being processed ends whenever the server receives it. The server does not know when computations ended, and if you delay the upload for some other reason, that's on you.
FAHClient estimates the PPD based on when the WU is finished, and technically, that's wrong but generally by a very small difference, depending on the speed of your internet connection. (This was a bigger deal in the days of dial-up internect connections.)
For the purpose of calculating the bonus, Start and Finish times are measured by the server's clock, not the clock on your computer (which could be manipulated).
Where did you send your email? This is FAH's support forum.
This is the suport? what is your email?
I need help
I see you do not know. I need help.
I am willing for an administrator to enter my computer and to contrast the information in my Log.txt with that of each server contacted so that it verifies the veracity and points me.
I know there is a delay of time to observe the credits, otherwise I would not be asking for help, because I would have already contrasted it myself.
What is not normal is that it has processed 30 WU and has only 200,000 points, when with 19WU it had 785,000 points.
I think it's not that hard to understand.
I need help
The veracityJoe_H wrote:Exactly what are these logs posted to show?
