FAH won't see second GPU card (Fixed)
ChrisS
Post by ChrisS »
Help!!
I had a PC quite happily running a GTX 960 card, then I added a GTX 970 card. Now FAH won't see the 960 card!
Logically I need to manually add a second GPU slot, but when Itry, it doesn't matter what figures I enter or where,all I get is a second -CPU slot. GPU-Z confirms the 960 card is idle.
So, what do I need to do to get FAH to see both cards??
Re: FAH won't see second GPU card
Many Programs, (F@H included) do a much better job finding hardware during install than durng start up.
I would uninstall F@H and reinstall it.
If that does not work, post the first 100 lines of the log so we can make informed guesses.
ChrisS
Post by ChrisS »
Ok thanks, I'll look into that.
ChrisS
Post by ChrisS »
It seems that FAH is seeing the card but not using it as there isn't a GPU slot for it. As I thought I need to add one somehow?
Folding slots
00 running CPU 20
01 running GPU 0
Work queue
00 running
01 ready
02 running
*********************** Log Started 2019-01-29T15:51:45Z ***********************
15:51:45:************************* Folding@home Client *************************
15:51:45:        Website: https://foldingathome.org/
15:51:45:      Copyright: (c) 2009-2018 foldingathome.org
15:51:45:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:51:45:           Args: --open-web-control
15:51:45:         Config: C:\Users\user\AppData\Roaming\FAHClient\config.xml
15:51:45:******************************** Build ********************************
15:51:45:        Version: 7.5.1
15:51:45:           Date: May 11 2018
15:51:45:           Time: 13:06:32
15:51:45:     Repository: Git
15:51:45:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:51:45:         Branch: master
15:51:45:       Compiler: Visual C++ 2008
15:51:45:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:51:45:       Platform: win32 10
15:51:45:           Bits: 32
15:51:45:           Mode: Release
15:51:45:******************************* System ********************************
15:51:45:            CPU: Intel(R) Xeon(R) CPU X5670 @ 2.93GHz
15:51:45:         CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
15:51:45:           CPUs: 24
15:51:45:         Memory: 23.98GiB
15:51:45:    Free Memory: 20.83GiB
15:51:45:        Threads: WINDOWS_THREADS
15:51:45:     OS Version: 6.1
15:51:45:    Has Battery: false
15:51:45:     On Battery: false
15:51:45:     UTC Offset: 0
15:51:45:            PID: 3440
15:51:45:            CWD: C:\Users\user\AppData\Roaming\FAHClient
15:51:45:             OS: Windows 7 Professional
15:51:45:        OS Arch: AMD64
15:51:45:           GPUs: 2
15:51:45:          GPU 0: Bus:15 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970]
15:51:45:          GPU 1: Bus:66 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
15:51:45:  CUDA Device 0: Platform:0 Device:0 Bus:15 Slot:0 Compute:5.2 Driver:10.0
15:51:45:  CUDA Device 1: Platform:0 Device:1 Bus:66 Slot:0 Compute:5.2 Driver:10.0
15:51:45:OpenCL Device 0: Platform:0 Device:0 Bus:15 Slot:0 Compute:1.2 Driver:417.71
15:51:45:OpenCL Device 1: Platform:0 Device:1 Bus:66 Slot:0 Compute:1.2 Driver:417.71
15:51:45:  Win32 Service: false
15:51:45:***********************************************************************
15:51:45:<config>
15:51:45:  <!-- Network -->
15:51:45:  <proxy v=':8080'/>
15:51:45:
15:51:45:  <!-- Slot Control -->
15:51:45:  <power v='FULL'/>
15:51:45:
15:51:45:  <!-- User Information -->
15:51:45:  <passkey v='********************************'/>
15:51:45:  <team v='234111'/>
15:51:45:  <user v='ChristopherS'/>
15:51:45:
15:51:45:  <!-- Folding Slots -->
15:51:45:  <slot id='0' type='CPU'>
15:51:45:    <cpus v='20'/>
15:51:45:  </slot>
15:51:45:  <slot id='1' type='GPU'/>
15:51:45:</config>
15:51:45:Trying to access database...
15:51:45:Successfully acquired database lock
15:51:45:Enabled folding slot 00: READY cpu:20
15:51:45:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970]
15:51:45:WU02:FS00:Starting
15:51:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\user\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 3440 -checkpoint 15 -np 20
15:51:45:WU02:FS00:Started FahCore on PID 5040
15:51:45:WU02:FS00:Core PID:5464
15:51:45:WU02:FS00:FahCore 0xa7 started
15:51:46:WU02:FS00:0xa7:*********************** Log Started 2019-01-29T15:51:46Z ***********************
15:51:46:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:51:46:WU02:FS00:0xa7:       Type: 0xa7
15:51:46:WU02:FS00:0xa7:       Core: Gromacs
15:51:46:WU02:FS00:0xa7:    Website: https://foldingathome.org/
15:51:46:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
15:51:46:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:51:46:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 5040 -checkpoint 15 -np
15:51:46:WU02:FS00:0xa7:             20
15:51:46:WU02:FS00:0xa7:     Config: <none>
15:51:46:WU02:FS00:0xa7:************************************ Build *************************************
15:51:46:WU02:FS00:0xa7:    Version: 0.0.17
15:51:46:WU02:FS00:0xa7:       Date: Apr 27 2018
15:51:46:WU02:FS00:0xa7:       Time: 16:19:35
15:51:46:WU02:FS00:0xa7: Repository: Git
15:51:46:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
15:51:46:WU02:FS00:0xa7:     Branch: master
15:51:46:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
15:51:46:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:51:46:WU02:FS00:0xa7:   Platform: win32 10
15:51:46:WU02:FS00:0xa7:       Bits: 64
15:51:46:WU02:FS00:0xa7:       Mode: Release
15:51:46:WU02:FS00:0xa7:       SIMD: sse2
15:51:46:WU02:FS00:0xa7:************************************ System ************************************
15:51:46:WU02:FS00:0xa7:        CPU: Unknown
15:51:46:WU02:FS00:0xa7:     CPU ID:
15:51:46:WU02:FS00:0xa7:       CPUs: 24
15:51:46:WU02:FS00:0xa7:     Memory: 23.98GiB
15:51:46:WU02:FS00:0xa7:Free Memory: 20.78GiB
15:51:46:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
15:51:46:WU02:FS00:0xa7: OS Version: 6.1
15:51:46:WU02:FS00:0xa7:Has Battery: false
15:51:46:WU02:FS00:0xa7: On Battery: false
15:51:46:WU02:FS00:0xa7: UTC Offset: 0
15:51:46:WU02:FS00:0xa7:        PID: 5464
15:51:46:WU02:FS00:0xa7:        CWD: C:\Users\user\AppData\Roaming\FAHClient\work
15:51:46:WU02:FS00:0xa7:         OS: Windows 7 Professional Service Pack 1
15:51:46:WU02:FS00:0xa7:    OS Arch: AMD64
15:51:46:WU02:FS00:0xa7:********************************************************************************
15:51:46:WU02:FS00:0xa7:Project: 14116 (Run 16, Clone 15, Gen 29)
15:51:46:WU02:FS00:0xa7:Unit: 0x000000260002894c5b8400b818c6720c
15:51:46:WU02:FS00:0xa7:Digital signatures verified
15:51:46:WU02:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpi state.cpt -cpt 15 -nt 20
15:51:46:WU02:FS00:0xa7:Steps: first=72500000 total=2500000
15:51:47:WU00:FS01:Starting
15:51:47:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\user\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3440 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:51:47:WU00:FS01:Started FahCore on PID 5928
15:51:47:WU00:FS01:Core PID:5940
15:51:47:WU00:FS01:FahCore 0x21 started
15:51:48:WU02:FS00:0xa7:Completed 1766012 out of 2500000 steps (70%)
15:51:48:WU00:FS01:0x21:*********************** Log Started 2019-01-29T15:51:48Z ***********************
15:51:48:WU00:FS01:0x21:Project: 14152 (Run 27, Clone 41, Gen 38)
15:51:48:WU00:FS01:0x21:Unit: 0x0000004b0002894c5c069ccbc16a35fa
15:51:48:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:51:48:WU00:FS01:0x21:Machine: 1
15:51:48:WU00:FS01:0x21:Digital signatures verified
15:51:48:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:51:48:WU00:FS01:0x21:Version 0.0.18
15:51:48:WU00:FS01:0x21:  Found a checkpoint file
15:51:56:16:127.0.0.1:New Web connection
15:52:24:WU00:FS01:0x21:Completed 600000 out of 1250000 steps (48%)
15:52:25:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:54:32:WU02:FS00:0xa7:Completed 1775000 out of 2500000 steps (71%)
15:55:36:WU00:FS01:0x21:Completed 612500 out of 1250000 steps (49%)
15:58:46:WU00:FS01:0x21:Completed 625000 out of 1250000 steps (50%)
16:01:57:WU00:FS01:0x21:Completed 637500 out of 1250000 steps (51%)
16:02:05:WU02:FS00:0xa7:Completed 1800000 out of 2500000 steps (72%)
16:05:07:WU00:FS01:0x21:Completed 650000 out of 1250000 steps (52%)
16:08:28:WU00:FS01:0x21:Completed 662500 out of 1250000 steps (53%)
16:09:38:WU02:FS00:0xa7:Completed 1825000 out of 2500000 steps (73%)
16:11:39:WU00:FS01:0x21:Completed 675000 out of 1250000 steps (54%)
16:14:50:WU00:FS01:0x21:Completed 687500 out of 1250000 steps (55%)
16:17:11:WU02:FS00:0xa7:Completed 1850000 out of 2500000 steps (74%)
Mod edit: added Code tags to log
Mactin
Post by Mactin »
I have been folding with two GPUs for many years. The second GPU has a "dummy plug" in it simulating a basic 480x640 screen.
Post by foldy »
Plugin not needed. Just edit FAH config and add 2nd GPU slot or simply uninstall FAH and install again then 2nd GPU slot gets auto detected.
I am going to wildly speculate.
I bet you chose to retain your data, and, of course, the reason you are reinstalling is to NOT retain your data. If they ask, do not retain any data, so you get a an all new install.
kiore
Post by kiore »
foldy wrote:Plugin not needed. Just edit FAH config and add 2nd GPU slot or simply uninstall FAH and install again then 2nd GPU slot gets auto detected.
Yes do this. Do worry if the system indicates the cards by the wrong names, just see 2 and all is well.
ChrisS
Post by ChrisS »
Ok guys, the second card is now seen. I re-installed FAH twice to no avail, so I tried just one more time erasing the program and a fresh install. The third time it worked, and both cards are now seen and running. All three uninstalls and reinstalls were the same but only one worked.
Nope,. no answer to it, other than FAH doesn't like different cards it prefers 2 or 3 of the same type. But happy to have ended up on the right side. Perseverance is the name of the game it seems :-)
Thanks for all the offers of help, appreciated.
Glad you got it working!
Holdolin
Post by Holdolin »
Glad to hear you got it working. I would imagine that for some reason the first 2 re-installs failed to remove config files. I guess it matters not as you are now folding on both cards :)
It's still much easier to go to advanced control and to add a GPU slot than to go though the pain of uninstalling/reinstalling/reconfiguring the client ...
kiore
Post by kiore »
toTOW wrote:It's still much easier to go to advanced control and to add a GPU slot than to go though the pain of uninstalling/reinstalling/reconfiguring the client ...
Yes configure 2nd card and restart does it for me.
