Hello,
I recently installed Adrenalin Edition 18.11.2 In my experience, this was the most problematic Radeon driver version for my particular config, which caused GPU slots to fail repeatedly. I test new drivers in hopes of better performance, less heat/power consumption, blah blah. However, now I'm back to Adrenalin 18.9.3 which is a solid performer.
Has anyone found 18.11.2 to be troublesome? I would like to know if this is a common experience.
Also, which driver version works best for you?
Thanks
Is Adrenalin 18.11.2 unstable F@H driver?
xystophyte
- Hardware configuration: Ryzen 5 1600 (3400 MHz) - MSI x370 SLI Plus - Win 10 Pro x64
Cryorig H5 Ultimate
Patriot Viper 16GB DDR5 (2800 Mhz)
2x Radeon RX 580 Graphics (Sapphire)
167GB Corsair Force 3 SSD (SSD) & 2TB Seagate Firecuda HDD - Location: Vernon BC Canada
Re: Is Adrenalin 18.11.2 unstable F@H driver?
No issues here, been running that drivers since they was released. I did clean install however because I had issued with relive after update. Maybe if you try clean install too? However there is 18.12.1 out already and most likely soon will be released big update so maybe wait for that.
xystophyte
Cryorig H5 Ultimate
Hi, I'm still on Adrenalin 18.9.3. I suspected that there might be something about my config and Adrenalin 18.11.2 causing issues. I haven't found any users to have a similar problem with 18.11.2. Thanks for your reply.
Vester
- Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
I am running 18.11.2 with my MSI R9 380 without problems. I am not overclocking and I am running Windows 10 Pro.
My stats
My stats
xystophyte
Cryorig H5 Ultimate
AMD Radeon Adrenalin 2019 release is supposedly near release. I will attempt that driver with a clean install. I'm not anticipating any issues, but we will see.
