And log:
*********************** Log Started 2017-03-10T20:27:36Z ***********************
20:27:36:************************* Folding@home Client *************************
20:27:36: Website: http://folding.stanford.edu/
20:27:36: Copyright: (c) 2009-2014 Stanford University
20:27:36: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:27:36: Args:
20:27:36: Config: C:/Users/john/AppData/Roaming/FAHClient/config.xml
20:27:36:******************************** Build ********************************
20:27:36: Version: 7.4.4
20:27:36: Date: Mar 4 2014
20:27:36: Time: 20:26:54
20:27:36: SVN Rev: 4130
20:27:36: Branch: fah/trunk/client
20:27:36: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:27:36: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:27:36: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:27:36: Platform: win32 XP
20:27:36: Bits: 32
20:27:36: Mode: Release
20:27:36:******************************* System ********************************
20:27:36: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
20:27:36: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
20:27:36: CPUs: 8
20:27:36: Memory: 31.93GiB
20:27:36: Free Memory: 28.43GiB
20:27:36: Threads: WINDOWS_THREADS
20:27:36: OS Version: 6.2
20:27:36: Has Battery: false
20:27:36: On Battery: false
20:27:36: UTC Offset: 0
20:27:36: PID: 11096
20:27:36: CWD: C:/Users/john/AppData/Roaming/FAHClient
20:27:36: OS: Windows 10 Pro
20:27:36: OS Arch: AMD64
20:27:36: GPUs: 1
20:27:36: GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
20:27:36: CUDA: 6.1
20:27:36: CUDA Driver: 8000
20:27:36:Win32 Service: false
20:27:36:***********************************************************************
20:27:36:<config>
20:27:36: <!-- Network -->
20:27:36: <proxy v=':8080'/>
20:27:36:
20:27:36: <!-- User Information -->
20:27:36: <passkey v='********************************'/>
20:27:36: <team v='35947'/>
20:27:36: <user v='scorpuk'/>
20:27:36:
20:27:36: <!-- Folding Slots -->
20:27:36: <slot id='0' type='GPU'>
20:27:36: <client-type v='beta'/>
20:27:36: </slot>
20:27:36:</config>
20:27:36:Trying to access database...
20:27:36:Successfully acquired database lock
20:27:36:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 970]
20:27:36:WU01:FS00:Starting
20:27:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/john/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11096 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:27:36:WU01:FS00:Started FahCore on PID 10368
20:27:36:WU01:FS00:Core PID:11088
20:27:36:WU01:FS00:FahCore 0x21 started
20:27:37:WU01:FS00:0x21:*********************** Log Started 2017-03-10T20:27:37Z ***********************
20:27:37:WU01:FS00:0x21:Project: 11707 (Run 153, Clone 1, Gen 18)
20:27:37:WU01:FS00:0x21:Unit: 0x000000198ca304f358aa13fb206eeaed
20:27:37:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:27:37:WU01:FS00:0x21:Machine: 0
20:27:37:WU01:FS00:0x21:Digital signatures verified
20:27:37:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:27:37:WU01:FS00:0x21:Version 0.0.18
20:27:40:WU01:FS00:0x21:Completed 0 out of 7500000 steps (0%)
20:27:40:WU01:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:29:16:WU01:FS00:0x21:Completed 75000 out of 7500000 steps (1%)
20:30:51:WU01:FS00:0x21:Completed 150000 out of 7500000 steps (2%)
20:32:27:WU01:FS00:0x21:Completed 225000 out of 7500000 steps (3%)
20:34:04:WU01:FS00:0x21:Completed 300000 out of 7500000 steps (4%)
20:35:39:WU01:FS00:0x21:Completed 375000 out of 7500000 steps (5%)
20:36:05:WU01:FS00:0x21:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-5)
20:36:05:WU01:FS00:0x21:Saving result file logfile_01.txt
20:36:05:WU01:FS00:0x21:Saving result file log.txt
20:36:05:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:07:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:07:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11707 run:153 clone:1 gen:18 core:0x21 unit:0x000000198ca304f358aa13fb206eeaed
20:36:07:WU01:FS00:Uploading 3.02KiB to 140.163.4.243
20:36:07:WU01:FS00:Connecting to 140.163.4.243:8080
20:36:08:WU01:FS00:Upload complete
20:36:08:WU01:FS00:Server responded WORK_ACK (400)
20:36:08:WU01:FS00:Cleaning up
20:36:08:WU00:FS00:Connecting to 171.67.108.45:80
20:36:08:WU00:FS00:Assigned to work server 171.67.108.157
20:36:08:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.157
20:36:08:WU00:FS00:Connecting to 171.67.108.157:8080
20:36:09:WU00:FS00:Downloading 5.18MiB
20:36:15:WU00:FS00:Download 94.06%
20:36:15:WU00:FS00:Download complete
20:36:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9415 run:19 clone:0 gen:318 core:0x21 unit:0x00000167ab436c9d585e06c9f081943a
20:36:15:WU00:FS00:Starting
20:36:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/john/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 11096 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:36:15:WU00:FS00:Started FahCore on PID 8604
20:36:15:WU00:FS00:Core PID:8472
20:36:15:WU00:FS00:FahCore 0x21 started
20:36:16:WU00:FS00:0x21:*********************** Log Started 2017-03-10T20:36:16Z ***********************
20:36:16:WU00:FS00:0x21:Project: 9415 (Run 19, Clone 0, Gen 318)
20:36:16:WU00:FS00:0x21:Unit: 0x00000167ab436c9d585e06c9f081943a
20:36:16:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:36:16:WU00:FS00:0x21:Machine: 0
20:36:16:WU00:FS00:0x21:Reading tar file core.xml
20:36:16:WU00:FS00:0x21:Reading tar file integrator.xml
20:36:16:WU00:FS00:0x21:Reading tar file state.xml
20:36:16:WU00:FS00:0x21:Reading tar file system.xml
20:36:16:WU00:FS00:0x21:Digital signatures verified
20:36:16:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:36:16:WU00:FS00:0x21:Version 0.0.18
20:36:18:WU00:FS00:0x21:Completed 0 out of 6250000 steps (0%)
20:36:18:WU00:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:37:03:WU00:FS00:0x21:Completed 62500 out of 6250000 steps (1%)
One thing to note about the log is that I have a GTX970 in the box too and it's only because of that being in the box that I am able to fold on the GTX 1080 Ti. Without the GTX970 FAH refused to add a GPU card to fold on! It is currently reporting the GTX970 as the card that is folding:
I can confirm that the 1080 Ti is folding and NOT the GTX970 from MSI Afterburner
