FAHmon problem
awsum140
FAHmon problem
Post by awsum140 »
OK, so I'm not actually a "new" user but I can't seem to get FAHmon running. The client machine is a Win7 machine and I've tried every directory in the FAHclient program data location with no luck. Any advice would be appreciated.
awsum140
Re: FAHmon problem
Post by awsum140 »
I suspect that FAHmon is not compatible with FAH client version 7. There is no "FAHlog.txt" that I can find on either of my machines running FAH.
Re: FAHmon problem
FAHmon has not been updated for ages, so it doesn't support v7 clients.
Try HFM.net instead : viewtopic.php?f=14&t=9903 (browse to the last page to get the last version : 0.9.5).
awsum140
Re: FAHmon problem
Post by awsum140 »
Thanks! You confirmed what I suspected I found out.
I keep getting the download blocked with HFM on Win10. I'll give it a shot on my Win7 machine. It would be nice if the "3rd Party Software" thread had updates or notes, I went nuts trying to get FAHmon working.
Re: FAHmon problem
Since we're no longer talking about the "FAHmon problem" I'm moving your questions about HFM to the topic discussing HFM. Maybe somebody there can tell you how to have HFM look in a different directory.
awsum140 wrote:It would be nice if the "3rd Party Software" thread had updates or notes, I went nuts trying to get FAHmon working.
This site is based on Donor participation. I'm interested in your not going nuts, but if you want some "updates or notes" there, feel free to contribute them to that topic.
Also note that the final post (from the author of the software) says
uncle_fungus wrote:I don't currently have time to fix whatever is broken I'm afraid :(
