Project: 4709 (Run 2, Clone 50, Gen 15)
bgd73
Post by bgd73 »
[07:06:48] Folding@home Core Shutdown: EARLY_UNIT_END
[07:30:09] ompleted 14%
[13:18:26] Completed 100%
[13:19:26]
[13:19:26] Finished Work Unit:
[13:19:26] - Reading up to 2705016 from "work/wudata_06.trr": Read 2705016
[13:19:26] - Checksum of file (work/wudata_06.trr) read from disk doesn't match
[13:19:26]
[13:19:26] Folding@home Core Shutdown: FILE_IO_ERROR
[13:19:30] CoreStatus = 75 (117)
[13:19:30] Error opening or reading from a file.
[13:19:30] Deleting current work unit & continuing...
This is another error I encountered. Part of it was my fault, as I had a script that stuck in a loop while the gpu client was running.. but anyway.I rebooted, all seemed well. File I/o error seems excuseless..instead of letting it continue to the end like it did, maybe check it before then for errors? Another evening of energy wasted...it ran another 6 hours after when I know most likely after error occured.
Re: Project: 4709 (Run 2, Clone 50, Gen 15)
There have been a few error reports associated with the .trr file and I'm pretty sure the developers are working on a bug fix (. . . although your error may or may not be the same issue.)
