No work Units downloaded since yesterday (Sunday)
silverpulser
Post by silverpulser »
My GPU using one core is working OK but my other CPU shows Ready but no work unit is being downloaded. The log file shows:
*********************** Log Started 2015-09-28T07:22:31Z ***********************
07:22:31:************************* Folding@home Client *************************
07:22:31:      Website: http://folding.stanford.edu/
07:22:31:    Copyright: (c) 2009-2014 Stanford University
07:22:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:22:31:         Args:
07:22:31:       Config: C:/Users/User/AppData/Roaming/FAHClient/config.xml
07:22:31:******************************** Build ********************************
07:22:31:      Version: 7.4.4
07:22:31:         Date: Mar 4 2014
07:22:31:         Time: 20:26:54
07:22:31:      SVN Rev: 4130
07:22:31:       Branch: fah/trunk/client
07:22:31:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
07:22:31:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
07:22:31:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
07:22:31:     Platform: win32 XP
07:22:31:         Bits: 32
07:22:31:         Mode: Release
07:22:31:******************************* System ********************************
07:22:31:          CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
07:22:31:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
07:22:31:         CPUs: 2
07:22:31:       Memory: 3.98GiB
07:22:31:  Free Memory: 2.80GiB
07:22:31:      Threads: WINDOWS_THREADS
07:22:31:   OS Version: 6.2
07:22:31:  Has Battery: false
07:22:31:   On Battery: false
07:22:31:   UTC Offset: 1
07:22:31:          PID: 5908
07:22:31:          CWD: C:/Users/User/AppData/Roaming/FAHClient
07:22:31:           OS: Windows 10 Pro
07:22:31:      OS Arch: AMD64
07:22:31:         GPUs: 1
07:22:31:        GPU 0: NVIDIA:2 GF119 [GeForce GT 520]
07:22:31:         CUDA: 2.1
07:22:31:  CUDA Driver: 7050
07:22:31:Win32 Service: false
07:22:31:***********************************************************************
07:22:31:<config>
07:22:31:  <!-- Slot Control -->
07:22:31:  <power v='FULL'/>
07:22:31:
07:22:31:  <!-- User Information -->
07:22:31:  <user v='Silverpulser'/>
07:22:31:
07:22:31:  <!-- Folding Slots -->
07:22:31:  <slot id='0' type='CPU'/>
07:22:31:  <slot id='1' type='GPU'/>
07:22:31:</config>
07:22:31:Trying to access database...
07:22:31:Successfully acquired database lock
07:22:31:Enabled folding slot 00: READY cpu:1
07:22:31:Enabled folding slot 01: READY gpu:0:GF119 [GeForce GT 520]
07:22:31:WU02:FS01:Starting
07:22:31:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 5908 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
07:22:32:WU02:FS01:Started FahCore on PID 2120
07:22:35:WU02:FS01:Core PID:1392
07:22:35:WU02:FS01:FahCore 0x18 started
07:22:36:WU00:FS00:Connecting to 171.67.108.200:8080
07:22:37:WU02:FS01:0x18:*********************** Log Started 2015-09-28T07:22:36Z ***********************
07:22:37:WU02:FS01:0x18:Project: 9412 (Run 23, Clone 4, Gen 103)
07:22:37:WU02:FS01:0x18:Unit: 0x0000007bab40413a5535e1b98add7d28
07:22:37:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
07:22:37:WU02:FS01:0x18:Machine: 1
07:22:37:WU02:FS01:0x18:Digital signatures verified
07:22:37:WU02:FS01:0x18:Folding@home GPU core18
07:22:37:WU02:FS01:0x18:Version 0.0.4
07:22:37:WU02:FS01:0x18:  Found a checkpoint file
07:22:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:22:38:WU00:FS00:Connecting to 171.67.108.204:80
07:22:39:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:22:39:ERROR:WU00:FS00:Exception: Could not get an assignment
07:22:39:WU00:FS00:Connecting to 171.67.108.200:8080
07:22:40:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:22:40:WU00:FS00:Connecting to 171.67.108.204:80
07:22:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:22:41:ERROR:WU00:FS00:Exception: Could not get an assignment
07:22:49:WU02:FS01:0x18:Completed 1300000 out of 16000000 steps (8%)
07:22:49:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:23:39:WU00:FS00:Connecting to 171.67.108.200:8080
07:23:40:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:23:40:WU00:FS00:Connecting to 171.67.108.204:80
07:23:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:23:41:ERROR:WU00:FS00:Exception: Could not get an assignment
07:25:17:WU00:FS00:Connecting to 171.67.108.200:8080
07:25:17:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:25:17:WU00:FS00:Connecting to 171.67.108.204:80
07:25:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:25:18:ERROR:WU00:FS00:Exception: Could not get an assignment
07:27:54:WU00:FS00:Connecting to 171.67.108.200:8080
07:27:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:27:54:WU00:FS00:Connecting to 171.67.108.204:80
07:27:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:27:55:ERROR:WU00:FS00:Exception: Could not get an assignment
07:30:59:16:127.0.0.1:New Web connection
07:32:08:WU00:FS00:Connecting to 171.67.108.200:8080
07:32:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:32:09:WU00:FS00:Connecting to 171.67.108.204:80
07:32:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:32:09:ERROR:WU00:FS00:Exception: Could not get an assignment
07:38:59:WU00:FS00:Connecting to 171.67.108.200:8080
07:39:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:39:00:WU00:FS00:Connecting to 171.67.108.204:80
07:39:01:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:39:01:ERROR:WU00:FS00:Exception: Could not get an assignment
07:50:05:WU00:FS00:Connecting to 171.67.108.200:8080
07:50:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:50:06:WU00:FS00:Connecting to 171.67.108.204:80
07:50:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:50:06:ERROR:WU00:FS00:Exception: Could not get an assignment
What should I do?
Mod edit: added Code tags to log
ChristianVirtual
Re: No work Units downloaded since yesterday (Sunday)
Post by ChristianVirtual »
With CPU:1 you have a high chance of low/no supply of WU. There is not much you can do. If you want to avoid the warning message you can pause or remove the CPU slot.
silverpulser
OK, thanks for the info. I tried installing FAH on my Core 2 duo laptop with the same result. presumably that is for the same reason then?
rpmouton
Hardware configuration: 1-MSI 990FXA-GD65V2 AM3+, AMD FX-8120 8-Core Black Edition-3.1 GHz, Mushkin Enhanced Blackline 8GB (2 x 4GB) 1600 MHz and ASUS GeForce GTX 550 Ti. Win 7 64x, 7.1x client with SMP and GPU slots ~14k ppd
2-ASUS M2NE-SLI AM2, AMD Phenom 4 @ 2.3 GHZ, 4 GB @ 800 MHz and ASUS GeForce GTX 550 Ti. Win Vista 64x, 7.1x client with SMP and GPU slots ~10k ppd
3-MSI 785GTM-E45 AM2+, AMD Phenom 4 Propus @ 3 GHZ, 4GB @ 800 MHZ, Win 7 64x, 7.1x client with SMP slots ~4k ppd
4-DELL 2950 Gen III, 2 Xeon E5405 Quad core @ 2GHz, 8 GB @ 669MHz, Ubuntu 12.04, 7.1 client with one SMP slot (bigadv) ~12k ppd
Post by rpmouton »
It is not just CPU1, my CPU3 instance is held up since early this morning, both 171.67.108.200 and .208 are empty?
Is there a setting we can use to get better availability?
Is there more work for higher core count clients?
thanks,
Roger
Hughesy26
Post by Hughesy26 »
I've got a 6 core cpu and getting a similar problem;
Failed to get assignment from '171.67.108.200:8080':Empty work server assignment
silverpulser
All back to normal as of yesterday evening.
Choco31415
Empty Work Sever Assignment
Post by Choco31415 »
Hi! I have encountered an error running Folding@Home after starting it up from a few months of dormancy. Basically, I'm not getting any work assignments. Here are two screenshots showing what is happening:
My internet is working, and Folding@Home used to work earlier.
I am using a 2012 Macbook Air running OS X 10.11.1. I have reinstalled Folding@Home about 10 minutes ago.
Any idea on what is happening? Thank you for any thoughts! I am willing to share more information if it is helpful.
Re: Empty Work Sever Assignment
Unfortunately, the management at Pande Group cannot seem to keep enough servers and projects running so that CPU:1 configurations can get work. There are many threads just like this one the last few days where clients that were once working well have stopped contributing to the project. More projects are reportedly on the way, and should be available "soon" but no exact ETA is available.
I could be wrong, but I believe all of the Macbook Air series have dual-core CPUs. Go to the Advanced Control (FAHControl) and in the Config tab, change CPU:-1 (or maybe CPU:1) to CPU:2.
Choco31415
I was hoping to keep it at one core so that I wouldn't put so much CPU load on my computer (alongside what I do), but I guess I can wiggle it up to two cores without too many downsides. Thank you for the quick feedback 7zim and bruce! I can imagine this forum is getting quite a few posts like mine with the same question.
Yes, considering single core donations has been the bread and butter of folding since it started 15 years ago.
One option if you only want to use the resources of a single core is the NaCl client for Chrome. You can set it to a percentage of total CPU available such as 50% or 25%.
ptschnack
Post by ptschnack »
I see the same thing with CPU:7, so it's not just single-core setups not getting work.
ptschnack wrote:I see the same thing with CPU:7, so it's not just single-core setups not getting work.
However that is being discussed in another topic. Temporary solution to that situation is running at CPU:6.
Shortages of CPU:1 and shortages of CPU:7 are only the same problem if there's a single server that happens to be the only source of those two types of WUs and if that server is off-line.
