:Project: 10495 (Run 28, Clone 19, Gen 71)
Stefan.Ervik
Post by Stefan.Ervik »
I have the problem on my Linux server that the gpu slot will not start. The Log looks like this:
13:22:24:WU01:FS01:Starting
13:22:24:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 1177 -checkpoint 3 -gpu 0 -gpu-vendor ati
13:22:24:WU01:FS01:Started FahCore on PID 3260
13:22:24:WU01:FS01:Core PID:3264
13:22:24:WU01:FS01:FahCore 0x21 started
13:22:25:WU01:FS01:0x21:*********************** Log Started 2015-12-09T13:22:24Z ***********************
13:22:25:WU01:FS01:0x21:Project: 10495 (Run 28, Clone 19, Gen 71)
13:22:25:WU01:FS01:0x21:Unit: 0x000000628ca304f555e5df79858c7d84
13:22:25:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
13:22:25:WU01:FS01:0x21:Machine: 1
13:22:25:WU01:FS01:0x21:Reading tar file core.xml
13:22:25:WU01:FS01:0x21:Reading tar file system.xml
13:22:25:WU01:FS01:0x21:Reading tar file integrator.xml
13:22:25:WU01:FS01:0x21:Reading tar file state.xml
13:22:26:WU01:FS01:0x21:Digital signatures verified
13:22:26:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
13:22:26:WU01:FS01:0x21:Version 0.0.14
13:22:26:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:23:24:WU01:FS01:Starting
13:23:24:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 1177 -checkpoint 3 -gpu 0 -gpu-vendor ati
13:23:24:WU01:FS01:Started FahCore on PID 3279
13:23:24:WU01:FS01:Core PID:3283
13:23:24:WU01:FS01:FahCore 0x21 started
13:23:25:WU01:FS01:0x21:*********************** Log Started 2015-12-09T13:23:24Z ***********************
13:23:25:WU01:FS01:0x21:Project: 10495 (Run 28, Clone 19, Gen 71)
13:23:25:WU01:FS01:0x21:Unit: 0x000000628ca304f555e5df79858c7d84
13:23:25:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
13:23:25:WU01:FS01:0x21:Machine: 1
13:23:25:WU01:FS01:0x21:Reading tar file core.xml
13:23:25:WU01:FS01:0x21:Reading tar file system.xml
13:23:25:WU01:FS01:0x21:Reading tar file integrator.xml
13:23:25:WU01:FS01:0x21:Reading tar file state.xml
13:23:26:WU01:FS01:0x21:Digital signatures verified
13:23:26:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
13:23:26:WU01:FS01:0x21:Version 0.0.14
13:23:26:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
The CPU slot works fine, but the gpu queue's status never changes from Ready.
I have a AMD Radeon HD 6990 GPU, and a AMD Phenom II X6 1090T CPU. The machine is running Kubuntu 15.10.
Driver version is 2.15.201-0ubuntu2~15.10.2
Sincerly Yours, Stefan
Re: FahCore returned: INTERRUPTED (102 = 0x66)
You'll get more help by posting your issue in a more appropriate place. The end of thread in a CPU forum is definitely not the best place for a GPU issue ...
Re: :Project: 10495 (Run 28, Clone 19, Gen 71)
Topic split; posts moved.
There's a pretty high probability that you're using the wrong drivers. Visit the ATI website and install the one they recommend rather than whatever was distributed with your Linux distro.
