No visualisation for GPU folding?
folding_user123
Post by folding_user123 »
Hi there - I recently installed the standard windows client and my machine has been happily folding away on both the CPU and GPU slots.
I used to run the PS3 client and enjoyed the visualisation that came with it - however I notice that visualisation only seems to be available for the CPU slot and not the GPU slot - when I try to visualise the GPU folding I get the visualisation window but no graphics. Is it not able to work on the GPU slot?
I have posted screenshots here:
http://imgur.com/a/V4qwX
Specs:
GPU: GTX980
OS: Windows 10 Pro
CPU: i7-2600k
Thanks
Re: No visualisation for GPU folding?
If you wait for a while, does it change from Loading to displaying something ? Or does it revert to displaying the CPU slot ?
As I recall, the viewer has had issues reported on displaying WU's using the newer GPU cores.
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Post by jimerickson »
if i recall correctly no tdr files are produced for gpus hence no visualizations. i think proteneer mentioned something about this once but its been awhile i could be mistaken.
No viewer support yet for GPU cores newer than Core_16.
folding_user123
toTOW wrote:If you wait for a while, does it change from Loading to displaying something ? Or does it revert to displaying the CPU slot ?
It displays and updates everything in the viewer minus any visualisation, as in the screenshots posted :(
7im wrote:No viewer support yet for GPU cores newer than Core_16.
How do you know it's Core_16? Where is this information displayed?
Thanks for your responses.
*edit spelling
This information is displayed in the log, when the WU is started. You can also check in your Task Manger which FahCore process is running.
Duce H_K_
Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w
Post by Duce H_K_ »
I've just manually opened positions.xtc & viewerFrame##.json in my FAH work\Slot ID dir with FAHViewer and saw something. But I don't think it attached to current folding simulation process 'cause viewer not connecting to my localhost client in this mode. And I don't wait for vis feature further fixed for v7 clients
