Core 21 issues
Locked
Librarian
Core 21 issues
Post by Librarian »
Hello,
Starting from last night I am having trouble with Core 21 for my GPU. I keep getting an error message when it tries to do a *21 WU. The popup dialog reads:
The procedure entry point clRetainDevice could not be located in the dynamic link library OpenCL.dll
I have gone and deleted the core and tried to redownload, no go. I reinstalled FAH 7.4.4 and it worked with a *18 WU then it got another *21 and again I get an error again. Any ideas or suggestions are appreciate it. I have made no changes to my system since December and until I did the reinstall, my computer has not done a reboot in months.
01:39:17:WU02:FS01:Starting
01:39:17:WU02:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/adam/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 2248 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
01:39:17:WU02:FS01:Started FahCore on PID 5528
01:39:17:Started thread 18 on PID 2248
01:39:17:WU02:FS01:Core PID:3080
01:39:17:WU02:FS01:FahCore 0x21 started
01:39:18:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
01:39:18:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
I am using the beta flag (for past month or so without issues). Thank you
Re: Core 21 issues
Please agree to the conditions for Beta Team membership if you want support in that forum.
viewtopic.php?f=2&t=10364
Librarian
Re: Core 21 issues
Post by Librarian »
Thank you for the quick reply Bruce, I certainly will do so.
Re: Core 21 issues
We're guessing that minimum version of drivers requirements are needing a bump for core 21 : viewtopic.php?p=278157#p278157
Librarian
Re: Core 21 issues
Post by Librarian »
hi toTow, you are correct. After Bruce had mentioned the Bea forum, I read it and saw that thread. Updated my drivers and so far so good. Thank you for helping.
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Re: Core 21 issues
Post by billford »
toTOW wrote:We're guessing that minimum version of drivers requirements are needing a bump for core 21 : viewtopic.php?p=278157#p278157
I see from a post a couple before yours in that thread that ChristianVirtual seems to be running Core_21 OK with NV 346.46 drivers on Linux- is it likely to be a problem with Windows drivers only?
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Re: Core 21 issues
Post by jimerickson »
core 21 on nvidia 346.72 on fedora without problems here.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Core 21 issues
Post by billford »
I'm running Core_21 WUs fine with 346.46 on Mint, but only adv client, not beta. I'm not sure what may have changed- I think there's a later core?
jimerickson
Re: Core 21 issues
indeed there is. version 0.0.10 is what my log indicates.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Core 21 issues
Post by billford »
Ah, there's clearly more than "a" later core- mine is v0.0.3 :D
Re: Core 21 issues
Topic locked, further discussion of beta testing is for the Beta Forum.
Locked
