Project 9430
LikZ
Project 9430
Post by LikZ »
I got a Project 9430 this Morning on the GTX 970 and it turns out to run around 90 k PPD. Is it supposed to be running that bad on Maxwell as it is Core 18?
The Core 17 are running arround 300k PPD in comparison
Best Regards Likz
Re: Project 9430
This project just recently moved from beta to advanced. During beta testing some WU's were reported to run more slowly. More information on what WU's you see this with would be needed to see if there is a pattern.
Also, you should be running with updated video drivers. Which OS was this run on, and which version of the folding core?
cxh
Pande Group Member
Re: Project 9430
Post by cxh »
I suspect the issue is from running v0.0.3 of core18.
coredump4
Re: Project 9430
Post by coredump4 »
For comparison, I just got my first core 18, proj 9430 WU on a GTX 750 Ti SC. So far, TPF is 13:55 with PPD of 73.2k.
System is an AMD E-350 APU running Debian Wheezy with kernel 3.2.0-4, Nvidia driver 346.35.
cxh
Pande Group Member
Re: Project 9430
Post by cxh »
@coredump4: what version of core18 are you running?
JimF
Re: Project 9430
Post by JimF »
I just got two core 18 on two machines, both Win7 64-bit. These are the first for these machines, so the difference in the core versions is curious.
On a GTX 960 card with Version 0.0.4 of Core 18, I am getting 164 k PPD, which is a nice increase from the usual 156 kPPD on most Core 17's.
But on a GTX 750 Ti with Version 0.0.3 of Core 18, I am getting only 34 k PPD, down from the usual 66 k PPD on Core 17.
Neither card is overclocked by me or the factory to any significant degree. The driver on both cards is 352.86.
Re: Project 9430
cxh posted - viewtopic.php?f=66&t=27651&p=276747#p276747 - that the settings have been just changed to require a core update when running WU's from this project. If you get another 9430 on your system with the 750ti, could you let us know if that does happen?
JimF
Re: Project 9430
Post by JimF »
Joe_H wrote:If you get another 9430 on your system with the 750ti, could you let us know if that does happen?
Certainly, though this one won't finish for another 23 hours; I could dump it if that would be of use to you.
LikZ
Re: Project 9430
Post by LikZ »
The Wu didn't finish properly and i had to restart . Because of that i can't say anything about the specific wu. Right now its back to Core 17 but if i get another one i will report it here.
System ist W7 + newest Graphic drivers.
cxh
Pande Group Member
Re: Project 9430
Post by cxh »
JimF: feel free to dump the WU, if you'd like.
On second thought: bollix47 suggested that you could pause the WU, delete the core, and then start the WU again. This would give you almost immediate feedback as to whether the old core version was the culprit.
JimF
Re: Project 9430
Post by JimF »
OK, I picked up another P9430, and got Version 0.0.4 of Core 18 this time.
My GTX 750 Ti is now getting 66.5 k PPD; very nice.
(I just hope that PG can develop a blood-pressure treatment before going through this process again.)
coredump4
Re: Project 9430
Post by coredump4 »
cxh wrote:@coredump4: what version of core18 are you running?
It's v0.0.4. AFAIK that's the first version for Linux...
cxh
Pande Group Member
Re: Project 9430
Post by cxh »
@coredump4: I would suggest you update your Nvidia drivers to the latest version (or at least 349.12). My understanding is that this patch was made fairly recently and reliant upon the latest driver version at that time.
LikZ
Re: Project 9430
Post by LikZ »
06:26:53:Trying to access database...
06:26:53:Successfully acquired database lock
06:26:53:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 970]
06:26:53:WU01:FS00:Starting
06:26:53:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/-Rev0-/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 5304 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:26:53:WU01:FS00:Started FahCore on PID 5380
06:26:54:WU01:FS00:Core PID:5420
06:26:54:WU01:FS00:FahCore 0x18 started
06:26:54:WU01:FS00:0x18:*********************** Log Started 2015-06-02T06:26:54Z ***********************
06:26:54:WU01:FS00:0x18:Project: 9430 (Run 104, Clone 3, Gen 2)
06:26:54:WU01:FS00:0x18:Unit: 0x00000003ab40413855474d3e52b86ef2
06:26:54:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
06:26:54:WU01:FS00:0x18:Machine: 0
06:26:54:WU01:FS00:0x18:Digital signatures verified
06:26:54:WU01:FS00:0x18:Folding@home GPU core18
06:26:54:WU01:FS00:0x18:Version 0.0.4
06:26:54:WU01:FS00:0x18:  Found a checkpoint file
06:27:01:WU01:FS00:0x18:Completed 14400000 out of 16000000 steps (90%)
06:27:01:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:28:50:WU01:FS00:0x18:ERROR:exception: Error downloading array velm: clEnqueueReadBuffer (-5)
06:28:50:WU01:FS00:0x18:Saving result file logfile_01.txt
06:28:50:WU01:FS00:0x18:Saving result file log.txt
06:28:50:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
06:28:51:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:28:51:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9430 run:104 clone:3 gen:2 core:0x18 unit:0x00000003ab40413855474d3e52b86ef2
06:28:51:WU01:FS00:Uploading 3.31KiB to 171.64.65.56
06:28:51:WU01:FS00:Connecting to 171.64.65.56:8080
06:28:51:WU01:FS00:Upload complete
06:28:51:WU00:FS00:Connecting to 171.67.108.200:80
06:28:52:WU01:FS00:Server responded WORK_ACK (400)
06:28:52:WU01:FS00:Cleaning up
06:28:52:WU00:FS00:Assigned to work server 171.64.65.56
06:28:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
06:28:52:WU00:FS00:Connecting to 171.64.65.56:8080
06:28:53:WU00:FS00:Downloading 1.51MiB
06:28:58:WU00:FS00:Download complete
06:28:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9430 run:106 clone:8 gen:1 core:0x18 unit:0x00000002ab40413855474d4e91c0a20f
06:28:58:WU00:FS00:Starting
06:28:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/-Rev0-/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 5304 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:28:58:WU00:FS00:Started FahCore on PID 2492
06:28:58:WU00:FS00:Core PID:4912
06:28:58:WU00:FS00:FahCore 0x18 started
06:28:59:WU00:FS00:0x18:*********************** Log Started 2015-06-02T06:28:58Z ***********************
06:28:59:WU00:FS00:0x18:Project: 9430 (Run 106, Clone 8, Gen 1)
06:28:59:WU00:FS00:0x18:Unit: 0x00000002ab40413855474d4e91c0a20f
06:28:59:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
06:28:59:WU00:FS00:0x18:Machine: 0
06:28:59:WU00:FS00:0x18:Reading tar file state.xml
06:28:59:WU00:FS00:0x18:Reading tar file system.xml
06:28:59:WU00:FS00:0x18:Reading tar file integrator.xml
06:28:59:WU00:FS00:0x18:Reading tar file core.xml
06:28:59:WU00:FS00:0x18:Digital signatures verified
06:28:59:WU00:FS00:0x18:Folding@home GPU core18
06:28:59:WU00:FS00:0x18:Version 0.0.4
06:29:07:WU00:FS00:0x18:Completed 0 out of 16000000 steps (0%)
06:29:07:WU00:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:30:52:WU00:FS00:0x18:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-5)
06:30:52:WU00:FS00:0x18:Saving result file logfile_01.txt
06:30:52:WU00:FS00:0x18:Saving result file log.txt
06:30:52:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
06:30:53:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:30:53:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9430 run:106 clone:8 gen:1 core:0x18 unit:0x00000002ab40413855474d4e91c0a20f
06:30:53:WU00:FS00:Uploading 2.53KiB to 171.64.65.56
06:30:53:WU00:FS00:Connecting to 171.64.65.56:8080
06:30:53:WU01:FS00:Connecting to 171.67.108.200:80
06:30:54:WU00:FS00:Upload complete
06:30:54:WU00:FS00:Server responded WORK_ACK (400)
06:30:54:WU00:FS00:Cleaning up
06:30:54:WU01:FS00:Assigned to work server 171.64.65.56
06:30:54:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
06:30:54:WU01:FS00:Connecting to 171.64.65.56:8080
06:30:55:WU01:FS00:Downloading 1.51MiB
06:31:00:WU01:FS00:Download complete
06:31:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9430 run:215 clone:1 gen:0 core:0x18 unit:0x00000000ab404138554750348dbdf2be
06:31:00:WU01:FS00:Starting
06:31:00:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/-Rev0-/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 5304 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:31:00:WU01:FS00:Started FahCore on PID 6440
06:31:00:WU01:FS00:Core PID:6444
06:31:00:WU01:FS00:FahCore 0x18 started
06:31:00:WU01:FS00:0x18:*********************** Log Started 2015-06-02T06:31:00Z ***********************
06:31:00:WU01:FS00:0x18:Project: 9430 (Run 215, Clone 1, Gen 0)
06:31:00:WU01:FS00:0x18:Unit: 0x00000000ab404138554750348dbdf2be
06:31:00:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
06:31:00:WU01:FS00:0x18:Machine: 0
06:31:00:WU01:FS00:0x18:Reading tar file system.xml
06:31:00:WU01:FS00:0x18:Reading tar file integrator.xml
06:31:00:WU01:FS00:0x18:Reading tar file state.xml
06:31:00:WU01:FS00:0x18:Reading tar file core.xml
06:31:00:WU01:FS00:0x18:Digital signatures verified
06:31:00:WU01:FS00:0x18:Folding@home GPU core18
06:31:00:WU01:FS00:0x18:Version 0.0.4
06:31:08:WU01:FS00:0x18:Completed 0 out of 16000000 steps (0%)
06:31:08:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:31:15:FS00:Paused
06:31:15:FS00:Shutting core down
06:31:15:WU01:FS00:0x18:WARNING:Console control signal 1 on PID 6444
06:31:15:WU01:FS00:0x18:Exiting, please wait. . .
06:31:16:WU01:FS00:0x18:Lost lifeline PID 6440, exiting
06:31:16:WU01:FS00:0x18:ERROR:103: Lost client lifeline
06:31:16:WU01:FS00:0x18:Folding@home Core Shutdown: CLIENT_DIED
06:31:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:31:58:Removing old file 'configs/config-20150519-215700.xml'
06:31:58:Saving configuration to config.xml
06:31:58:<config>
06:31:58:  <!-- Network -->
06:31:58:  <proxy v=':8080'/>
06:31:58:
06:31:58:  <!-- Slot Control -->
06:31:58:  <power v='full'/>
06:31:58:
06:31:58:  <!-- User Information -->
06:31:58:  <passkey v='********************************'/>
06:31:58:  <team v='70911'/>
06:31:58:  <user v='LikZ'/>
06:31:58:
06:31:58:  <!-- Folding Slots -->
06:31:58:  <slot id='0' type='GPU'>
06:31:58:    <client-type v='advanced'/>
06:31:58:    <paused v='true'/>
06:31:58:  </slot>
06:31:58:</config>
I was just checking and it was running perfect till 90 % than crashed. the PPD was good at about 315k and it was 0.0.4
JimF
Re: Project 9430
Post by JimF »
LikZ wrote:I was just checking and it was running perfect till 90 % than crashed. the PPD was good at about 315k and it was 0.0.4
For a 970, it would appear that you are overclocking the card. (What works for games may not work for Folding; reduce the clock.)
