CPU slot gets "Empty work server assignment"
I have 4 cpus that haven't been getting any work units since last night. When I noticed the first one stalled (the 3 others were still working) I finally uninstalled the cpu then reinstalled it, which made it work that one time. When I came back later, another cpu was stalled, and uninstalling and reinstalling it did no good at all. All 4 logs are now saying, basically (but obviously with different time codes), the same thing:
15:35:11:WU01:FS00:Connecting to 171.67.108.200:8080
15:35:11:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:35:11:WU01:FS00:Connecting to 171.67.108.204:80
15:35:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:35:12:ERROR:WU01:FS00:Exception: Could not get an assignment
15:35:12:WU01:FS00:Connecting to 171.67.108.200:8080
15:35:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:35:12:WU01:FS00:Connecting to 171.67.108.204:80
What's up with this?
Wild Penguin
CPU slot can not get assignment (171.64.65.124?)
Apologies if this is not on the right forum.
Intermittently, I can not get any assignment from the servers. This can last for hours, right now the computers CPU has just been sitting doing nothing for 11 hours. But that's just an example, it seems to happen several times in a week. I'm lucky if I can peg my CPU for more than 6 hours in a row. Is the project low on WUs currwently?
I changed max packet size to 'big' and client-type into advanced, in the hopes that would increase available WUs, but that does not seem to be the case.
AFAICT there is no specific server that I should be assigned to. But the last one I got a WU for the CPU slot from was 171.64.65.124.
As you can see from the log, this is on Linux, client ver 7.4.4., Core i7 (4 cores / 8 with HT).
Here's the log from the last run I got some WUs for the CPU slot:
CLIP (the whole log file was too large for the forum limit... here's the part where it fails):
etc.... From here on, I only get work on FS1 (GPU), and the occasional error from FS0 (CPU) trying to get work from the assignment server(s).
Any ideas? Something wrong on my setup, or problems with the server(s)?
*********************** Log Started 2015-05-20T20:02:48Z ***********************
20:02:48:************************* Folding@home Client *************************
20:02:48: Website: http://folding.stanford.edu/
20:02:48: Copyright: (c) 2009-2014 Stanford University
20:02:48: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:02:48: Args: --config /opt/fah/config.xml --exec-directory=/opt/fah
20:02:48: --data-directory=/opt/fah
20:02:48: Config: /opt/fah/config.xml
20:02:48:******************************** Build ********************************
20:02:48: Version: 7.4.4
20:02:48: Date: Mar 4 2014
20:02:48: Time: 12:02:38
20:02:48: SVN Rev: 4130
20:02:48: Branch: fah/trunk/client
20:02:48: Compiler: GNU 4.4.7
20:02:48: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
20:02:48: -fno-unsafe-math-optimizations -msse2
20:02:48: Platform: linux2 3.2.0-1-amd64
20:02:48: Bits: 64
20:02:48: Mode: Release
20:02:48:******************************* System ********************************
20:02:48: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
20:02:48: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:02:48: CPUs: 8
20:02:48: Memory: 15.62GiB
20:02:48:Free Memory: 855.28MiB
20:02:48: Threads: POSIX_THREADS
20:02:48: OS Version: 3.18
20:02:48:Has Battery: false
20:02:48: On Battery: false
20:02:48: UTC Offset: 3
20:02:48: PID: 29666
20:02:48: CWD: /opt/fah
20:02:48: OS: Linux 3.18.10-2-ArkkiVille x86_64
20:02:48: OS Arch: AMD64
20:02:48: GPUs: 1
20:02:48: GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
20:02:48: CUDA: 5.2
20:02:48:CUDA Driver: 7050
20:02:48:***********************************************************************
20:02:48:<config>
20:02:48: <!-- Folding Slot Configuration -->
20:02:48: <client-type v='advanced'/>
20:02:48: <max-packet-size v='big'/>
20:02:48:
20:02:48: <!-- Network -->
20:02:48: <proxy v=':8080'/>
20:02:48:
20:02:48: <!-- Slot Control -->
20:02:48: <power v='full'/>
20:02:48:
20:02:48: <!-- User Information -->
20:02:48: <passkey v='********************************'/>
20:02:48: <team v='31574'/>
20:02:48: <user v='Wild_Penguin'/>
20:02:48:
20:02:48: <!-- Folding Slots -->
20:02:48: <slot id='0' type='CPU'>
20:02:48: <paused v='true'/>
20:02:48: </slot>
20:02:48: <slot id='1' type='GPU'>
20:02:48: </slot>
20:02:48:</config>
20:02:48:Trying to access database...
20:02:48:Successfully acquired database lock
20:02:48:Enabled folding slot 00: PAUSED cpu:7 (by user)
20:02:48:Enabled folding slot 01: PAUSED gpu:0:GM204 [GeForce GTX 970] (by user)
20:02:52:FS00:Unpaused
20:02:52:FS01:Unpaused
20:02:52:WU02:FS01:Starting
20:02:52:WU02:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:02:52:WU02:FS01:Started FahCore on PID 29677
20:02:52:WU02:FS01:Core PID:29681
20:02:52:WU02:FS01:FahCore 0x17 started
20:02:53:WU02:FS01:0x17:*********************** Log Started 2015-05-20T20:02:52Z ***********************
20:02:53:WU02:FS01:0x17:Project: 9201 (Run 826, Clone 4, Gen 350)
20:02:53:WU02:FS01:0x17:Unit: 0x000001e46652edc45399f6889c8f0b4e
20:02:53:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:02:53:WU02:FS01:0x17:Machine: 1
20:02:53:WU02:FS01:0x17:Digital signatures verified
20:02:53:WU02:FS01:0x17: Found a checkpoint file
20:02:53:WU00:FS00:Connecting to 171.67.108.200:8080
20:02:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
20:02:54:WU00:FS00:Connecting to 171.67.108.204:80
20:02:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
20:02:55:ERROR:WU00:FS00:Exception: Could not get an assignment
20:02:55:WU00:FS00:Connecting to 171.67.108.200:8080
20:02:56:WU00:FS00:Assigned to work server 171.64.65.124
20:02:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 171.64.65.124
20:02:56:WU00:FS00:Connecting to 171.64.65.124:8080
20:02:57:WU00:FS00:Downloading 640.33KiB
20:02:58:WU00:FS00:Download complete
20:02:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9016 run:673 clone:12 gen:0 core:0xa4 unit:0x00000003ab40417c554ea06191c6a592
20:02:58:WU00:FS00:Starting
20:02:58:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -np 7
20:02:58:WU00:FS00:Started FahCore on PID 29697
20:02:58:WU00:FS00:Core PID:29701
20:02:58:WU00:FS00:FahCore 0xa4 started
20:02:59:WU00:FS00:0xa4:
20:02:59:WU00:FS00:0xa4:*------------------------------*
20:02:59:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
20:02:59:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:02:59:WU00:FS00:0xa4:Preparing to commence simulation
20:02:59:WU00:FS00:0xa4:- Looking at optimizations...
20:02:59:WU00:FS00:0xa4:- Created dyn
20:02:59:WU00:FS00:0xa4:- Files status OK
20:02:59:WU00:FS00:0xa4:- Expanded 655186 -> 1397548 (decompressed 213.3 percent)
20:02:59:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=655186 data_size=1397548, decompressed_data_size=1397548 diff=0
20:02:59:WU00:FS00:0xa4:- Digital signature verified
20:02:59:WU00:FS00:0xa4:Project: 9016 (Run 673, Clone 12, Gen 0)
20:02:59:WU00:FS00:0xa4:Assembly optimizations on if available.
20:02:59:WU00:FS00:0xa4:Entering M.D.
20:03:02:WU02:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
20:03:05:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
20:03:49:Removing old file 'configs/config-20150507-134844.xml'
20:03:49:Saving configuration to /opt/fah/config.xml
22:27:50:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
22:27:51:WU02:FS00:Connecting to 171.67.108.200:8080
22:27:52:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
22:27:52:WU02:FS00:Connecting to 171.67.108.204:80
22:27:53:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
22:27:53:ERROR:WU02:FS00:Exception: Could not get an assignment
22:27:53:WU02:FS00:Connecting to 171.67.108.200:8080
22:27:54:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
22:27:54:WU02:FS00:Connecting to 171.67.108.204:80
22:27:55:WU02:FS00:Assigned to work server 171.64.65.124
22:27:55:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
22:27:55:WU02:FS00:Connecting to 171.64.65.124:8080
22:27:56:WU02:FS00:Downloading 713.38KiB
22:27:57:WU02:FS00:Download complete
22:27:57:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9011 run:741 clone:4 gen:0 core:0xa4 unit:0x00000007ab40417c554e94a3d58354ae
22:28:37:WU01:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
22:29:05:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
22:29:05:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:29:15:WU00:FS00:0xa4:
22:29:15:WU00:FS00:0xa4:Finished Work Unit:
22:29:15:WU00:FS00:0xa4:- Reading up to 811488 from "00/wudata_01.trr": Read 811488
22:29:15:WU00:FS00:0xa4:trr file hash check passed.
22:29:15:WU00:FS00:0xa4:- Reading up to 745904 from "00/wudata_01.xtc": Read 745904
22:29:15:WU00:FS00:0xa4:xtc file hash check passed.
22:29:15:WU00:FS00:0xa4:edr file hash check passed.
22:29:15:WU00:FS00:0xa4:logfile size: 23873
22:29:15:WU00:FS00:0xa4:Leaving Run
22:29:20:WU00:FS00:0xa4:- Writing 1583753 bytes of core data to disk...
22:29:20:WU00:FS00:0xa4:Done: 1583241 -> 1537666 (compressed to 97.1 percent)
22:29:20:WU00:FS00:0xa4: ... Done.
22:29:23:WU00:FS00:0xa4:- Shutting down core
22:29:23:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:29:24:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:29:24:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9016 run:673 clone:12 gen:0 core:0xa4 unit:0x00000003ab40417c554ea06191c6a592
22:29:24:WU00:FS00:Uploading 1.47MiB to 171.64.65.124
22:29:24:WU00:FS00:Connecting to 171.64.65.124:8080
22:29:24:WU02:FS00:Starting
22:29:24:WU02:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 02 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -np 7
22:29:24:WU02:FS00:Started FahCore on PID 1767
22:29:24:WU02:FS00:Core PID:1771
22:29:24:WU02:FS00:FahCore 0xa4 started
22:29:24:WU02:FS00:0xa4:
22:29:24:WU02:FS00:0xa4:*------------------------------*
22:29:24:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
22:29:24:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:29:24:WU02:FS00:0xa4:Preparing to commence simulation
22:29:24:WU02:FS00:0xa4:- Looking at optimizations...
22:29:24:WU02:FS00:0xa4:- Created dyn
22:29:24:WU02:FS00:0xa4:- Files status OK
22:29:24:WU02:FS00:0xa4:- Expanded 729986 -> 1527780 (decompressed 209.2 percent)
22:29:24:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=729986 data_size=1527780, decompressed_data_size=1527780 diff=0
22:29:24:WU02:FS00:0xa4:- Digital signature verified
22:29:24:WU02:FS00:0xa4:Project: 9011 (Run 741, Clone 4, Gen 0)
22:29:24:WU02:FS00:0xa4:Assembly optimizations on if available.
22:29:24:WU02:FS00:0xa4:Entering M.D.
22:29:26:WU00:FS00:Upload complete
22:29:26:WU00:FS00:Server responded WORK_ACK (400)
22:29:26:WU00:FS00:Final credit estimate, 1621.00 points
22:29:26:WU00:FS00:Cleaning up
22:29:30:WU02:FS00:0xa4:Completed 0 out of 250000 steps (0%)
22:30:29:WU01:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
22:30:50:WU02:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
22:32:09:WU02:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
22:32:21:WU01:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
22:33:28:WU02:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
22:34:13:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
22:34:48:WU02:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
22:36:05:WU01:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
22:36:07:WU02:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
22:37:28:WU02:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
22:37:57:WU01:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
22:38:48:WU02:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
22:39:50:WU01:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
22:40:07:WU02:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
22:41:27:WU02:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
22:41:41:WU01:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
22:42:47:WU02:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
22:43:33:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
22:44:07:WU02:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
22:45:25:WU02:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
22:45:25:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
22:46:44:WU02:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
22:47:17:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
22:48:04:WU02:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
22:49:09:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
22:49:24:WU02:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
22:50:45:WU02:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
22:51:01:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
22:52:05:WU02:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
22:52:53:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
22:53:23:WU02:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
22:54:42:WU02:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
22:54:45:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
22:56:01:WU02:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
22:56:37:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
22:57:19:WU02:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
22:58:29:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
22:58:40:WU02:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
22:59:59:WU02:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
23:00:21:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
23:01:18:WU02:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
23:02:13:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
23:02:38:WU02:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
23:03:57:WU02:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
23:04:05:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
23:05:17:WU02:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
23:05:57:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
23:06:36:WU02:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
23:07:49:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
23:07:56:WU02:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
23:09:17:WU02:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
23:09:40:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
23:10:37:WU02:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
23:11:32:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
23:11:58:WU02:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
23:13:19:WU02:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
23:13:24:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
23:14:41:WU02:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
23:15:15:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
23:16:01:WU02:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
23:17:07:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
23:17:21:WU02:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
23:18:42:WU02:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
23:19:00:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
23:20:03:WU02:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
23:20:51:WU01:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
23:21:22:WU02:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
23:22:43:WU02:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
23:22:43:WU01:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
23:24:02:WU02:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
23:24:36:WU01:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
23:25:21:WU02:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
23:26:27:WU01:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
23:26:41:WU02:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
23:28:00:WU02:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
23:28:19:WU01:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
23:29:18:WU02:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
23:30:11:WU01:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
23:30:36:WU02:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
23:31:54:WU02:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
23:32:03:WU01:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
23:33:13:WU02:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
23:33:55:WU01:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
23:34:32:WU02:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
23:35:47:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
23:35:52:WU02:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
23:37:10:WU02:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
23:37:39:WU01:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
23:38:27:WU02:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
23:39:32:WU01:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
23:39:44:WU02:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
23:41:02:WU02:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
23:41:24:WU01:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
23:42:21:WU02:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
23:43:16:WU01:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
23:43:38:WU02:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
23:44:58:WU02:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
23:45:08:WU01:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
23:46:17:WU02:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
23:47:00:WU01:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
23:47:36:WU02:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
23:48:52:WU01:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
23:48:53:WU02:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
23:50:11:WU02:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
23:50:44:WU01:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
23:51:29:WU02:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
23:52:36:WU01:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
23:52:47:WU02:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
23:54:03:WU02:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
23:54:28:WU01:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
23:55:21:WU02:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
23:56:20:WU01:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
23:56:39:WU02:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
23:57:58:WU02:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
23:58:12:WU01:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
23:59:17:WU02:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
00:00:04:WU01:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
00:00:34:WU02:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
00:01:53:WU02:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
00:01:56:WU01:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
00:03:12:WU02:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
00:03:48:WU01:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
00:04:30:WU02:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
00:05:40:WU01:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
00:05:49:WU02:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
00:07:07:WU02:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
00:07:32:WU01:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
00:08:25:WU02:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
00:09:24:WU01:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
00:09:43:WU02:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
00:11:02:WU02:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
00:11:16:WU01:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
00:12:19:WU02:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
00:13:08:WU01:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
00:13:37:WU02:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
00:14:57:WU02:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
00:15:00:WU01:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
00:16:14:WU02:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
00:16:52:WU01:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
00:17:32:WU02:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
00:18:44:WU01:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
00:18:50:WU02:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
00:20:11:WU02:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
00:20:36:WU01:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
00:21:30:WU02:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
00:22:28:WU01:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
00:22:49:WU02:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
00:24:07:WU02:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
00:24:20:WU01:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
00:24:21:WU00:FS01:Connecting to 171.67.108.200:80
00:24:22:WU00:FS01:Assigned to work server 171.67.108.52
00:24:22:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
00:24:22:WU00:FS01:Connecting to 171.67.108.52:8080
00:24:23:WU00:FS01:Downloading 1.52MiB
00:24:25:WU00:FS01:Download complete
00:24:25:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:817 clone:2 gen:282 core:0x17 unit:0x000001956652edc45399f62ab492de34
00:25:25:WU02:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
00:26:12:WU01:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
00:26:14:WU01:FS01:0x17:Saving result file logfile_01.txt
00:26:14:WU01:FS01:0x17:Saving result file checkpointState.xml
00:26:14:WU01:FS01:0x17:Saving result file checkpt.crc
00:26:14:WU01:FS01:0x17:Saving result file log.txt
00:26:14:WU01:FS01:0x17:Saving result file positions.xtc
00:26:15:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
00:26:16:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:26:16:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9201 run:63 clone:8 gen:0 core:0x17 unit:0x000000006652edc4555cdd632d109126
00:26:16:WU01:FS01:Uploading 8.42MiB to 171.67.108.52
00:26:16:WU01:FS01:Connecting to 171.67.108.52:8080
00:26:16:WU00:FS01:Starting
00:26:16:WU00:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:26:16:WU00:FS01:Started FahCore on PID 4120
00:26:16:WU00:FS01:Core PID:4124
00:26:16:WU00:FS01:FahCore 0x17 started
00:26:16:WU00:FS01:0x17:*********************** Log Started 2015-05-21T00:26:16Z ***********************
00:26:16:WU00:FS01:0x17:Project: 9201 (Run 817, Clone 2, Gen 282)
00:26:16:WU00:FS01:0x17:Unit: 0x000001956652edc45399f62ab492de34
00:26:16:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:26:16:WU00:FS01:0x17:Machine: 1
00:26:16:WU00:FS01:0x17:Reading tar file state.xml
00:26:16:WU00:FS01:0x17:Reading tar file system.xml
00:26:16:WU00:FS01:0x17:Reading tar file integrator.xml
00:26:16:WU00:FS01:0x17:Reading tar file core.xml
00:26:16:WU00:FS01:0x17:Digital signatures verified
00:26:22:WU01:FS01:Upload complete
00:26:23:WU01:FS01:Server responded WORK_ACK (400)
00:26:23:WU01:FS01:Final credit estimate, 35273.00 points
00:26:23:WU01:FS01:Cleaning up
00:26:30:WU00:FS01:0x17:Completed 0 out of 5000000 steps (0%)
00:26:43:WU02:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
00:28:04:WU02:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
00:28:21:WU00:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
00:29:24:WU02:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
00:30:13:WU00:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
00:30:43:WU02:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
00:32:02:WU02:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
00:32:04:WU00:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
00:33:19:WU02:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
00:33:56:WU00:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
00:34:38:WU02:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
00:35:48:WU00:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
00:35:59:WU02:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
00:37:20:WU02:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
00:37:40:WU00:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
00:38:41:WU02:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
00:39:31:WU00:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
00:40:00:WU02:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
00:40:01:WU01:FS00:Connecting to 171.67.108.200:8080
00:40:02:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:40:02:WU01:FS00:Connecting to 171.67.108.204:80
00:40:03:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:40:03:ERROR:WU01:FS00:Exception: Could not get an assignment
00:40:03:WU01:FS00:Connecting to 171.67.108.200:8080
00:40:04:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:40:04:WU01:FS00:Connecting to 171.67.108.204:80
00:40:05:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:40:05:ERROR:WU01:FS00:Exception: Could not get an assignment
00:41:03:WU01:FS00:Connecting to 171.67.108.200:8080
00:41:04:WU01:FS00:Assigned to work server 171.64.65.124
00:41:04:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
00:41:04:WU01:FS00:Connecting to 171.64.65.124:8080
00:41:05:WU01:FS00:Downloading 640.47KiB
00:41:07:WU01:FS00:Download complete
00:41:07:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9016 run:621 clone:9 gen:0 core:0xa4 unit:0x00000006ab40417c554ea00d45c62533
00:41:20:WU02:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
00:41:20:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:41:23:WU00:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
00:41:30:WU02:FS00:0xa4:
00:41:30:WU02:FS00:0xa4:Finished Work Unit:
00:41:30:WU02:FS00:0xa4:- Reading up to 917280 from "02/wudata_01.trr": Read 917280
00:41:30:WU02:FS00:0xa4:trr file hash check passed.
00:41:30:WU02:FS00:0xa4:- Reading up to 840340 from "02/wudata_01.xtc": Read 840340
00:41:30:WU02:FS00:0xa4:xtc file hash check passed.
00:41:30:WU02:FS00:0xa4:edr file hash check passed.
00:41:30:WU02:FS00:0xa4:logfile size: 23811
00:41:30:WU02:FS00:0xa4:Leaving Run
00:41:35:WU02:FS00:0xa4:- Writing 1783919 bytes of core data to disk...
00:41:35:WU02:FS00:0xa4:Done: 1783407 -> 1723418 (compressed to 96.6 percent)
00:41:35:WU02:FS00:0xa4: ... Done.
00:41:39:WU02:FS00:0xa4:- Shutting down core
00:41:39:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
00:41:40:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:41:40:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9011 run:741 clone:4 gen:0 core:0xa4 unit:0x00000007ab40417c554e94a3d58354ae
00:41:40:WU02:FS00:Uploading 1.64MiB to 171.64.65.124
00:41:40:WU02:FS00:Connecting to 171.64.65.124:8080
00:41:40:WU01:FS00:Starting
00:41:40:WU01:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -np 7
00:41:40:WU01:FS00:Started FahCore on PID 4445
00:41:40:WU01:FS00:Core PID:4449
00:41:40:WU01:FS00:FahCore 0xa4 started
00:41:40:WU01:FS00:0xa4:
00:41:40:WU01:FS00:0xa4:*------------------------------*
00:41:40:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
00:41:40:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:41:40:WU01:FS00:0xa4:Preparing to commence simulation
00:41:40:WU01:FS00:0xa4:- Looking at optimizations...
00:41:40:WU01:FS00:0xa4:- Created dyn
00:41:40:WU01:FS00:0xa4:- Files status OK
00:41:40:WU01:FS00:0xa4:- Expanded 655325 -> 1397548 (decompressed 213.2 percent)
00:41:40:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=655325 data_size=1397548, decompressed_data_size=1397548 diff=0
00:41:40:WU01:FS00:0xa4:- Digital signature verified
00:41:40:WU01:FS00:0xa4:Project: 9016 (Run 621, Clone 9, Gen 0)
00:41:40:WU01:FS00:0xa4:Assembly optimizations on if available.
00:41:40:WU01:FS00:0xa4:Entering M.D.
00:41:42:WU02:FS00:Upload complete
00:41:42:WU02:FS00:Server responded WORK_ACK (400)
00:41:42:WU02:FS00:Final credit estimate, 1842.00 points
00:41:42:WU02:FS00:Cleaning up
00:41:46:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
00:42:55:WU01:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
00:43:14:WU00:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
00:44:01:WU01:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
00:45:05:WU00:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
00:45:10:WU01:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
00:46:19:WU01:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
00:46:57:WU00:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
00:47:28:WU01:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
00:48:36:WU01:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
00:48:49:WU00:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
00:49:43:WU01:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
00:50:40:WU00:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
00:50:53:WU01:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
00:52:01:WU01:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
00:52:32:WU00:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
00:53:11:WU01:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
00:54:18:WU01:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
00:54:24:WU00:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
00:55:27:WU01:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
00:56:16:WU00:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
00:56:36:WU01:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
00:57:43:WU01:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
00:58:08:WU00:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
00:58:53:WU01:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
00:59:59:WU00:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
01:00:02:WU01:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
01:01:09:WU01:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
01:01:51:WU00:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
01:02:17:WU01:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
01:03:26:WU01:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
01:03:43:WU00:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
01:04:35:WU01:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
01:05:35:WU00:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
01:05:44:WU01:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
01:06:54:WU01:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
01:07:27:WU00:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
01:08:01:WU01:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
01:09:11:WU01:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
01:09:19:WU00:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
01:10:20:WU01:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
01:11:10:WU00:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
01:11:29:WU01:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
01:12:39:WU01:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
01:13:02:WU00:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
01:13:48:WU01:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
01:14:54:WU00:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
01:14:56:WU01:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
01:16:04:WU01:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
01:16:45:WU00:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
01:17:12:WU01:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
01:18:19:WU01:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
01:18:37:WU00:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
01:19:28:WU01:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
01:20:29:WU00:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
01:20:37:WU01:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
01:21:46:WU01:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
01:22:21:WU00:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
01:22:55:WU01:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
01:24:04:WU01:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
01:24:13:WU00:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
01:25:12:WU01:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
01:26:05:WU00:FS01:0x17:Completed 1600000 out of 5000000 steps (32%)
01:26:20:WU01:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
01:27:29:WU01:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
01:27:56:WU00:FS01:0x17:Completed 1650000 out of 5000000 steps (33%)
01:28:39:WU01:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
01:29:48:WU00:FS01:0x17:Completed 1700000 out of 5000000 steps (34%)
01:29:48:WU01:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
01:30:58:WU01:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
01:31:39:WU00:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
01:32:07:WU01:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
01:33:15:WU01:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
01:33:31:WU00:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
01:34:24:WU01:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
01:35:23:WU00:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
01:35:33:WU01:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
01:36:42:WU01:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
01:37:14:WU00:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
01:37:51:WU01:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
01:39:00:WU01:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
01:39:06:WU00:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
01:40:07:WU01:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
01:40:58:WU00:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
01:41:14:WU01:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
01:42:23:WU01:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
01:42:49:WU00:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
01:43:32:WU01:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
01:44:40:WU01:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
01:44:41:WU00:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
01:45:49:WU01:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
01:46:33:WU00:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
01:46:57:WU01:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
01:48:03:WU01:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
01:48:25:WU00:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
01:49:10:WU01:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
01:50:17:WU00:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
01:50:18:WU01:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
01:51:26:WU01:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
01:52:09:WU00:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
01:52:33:WU01:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
01:53:41:WU01:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
01:54:00:WU00:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
01:54:50:WU01:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
01:55:52:WU00:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
01:55:57:WU01:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
01:57:05:WU01:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
01:57:44:WU00:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
01:58:13:WU01:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
01:59:21:WU01:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
01:59:36:WU00:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
02:00:28:WU01:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
02:01:28:WU00:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
02:01:35:WU01:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
02:02:44:WU01:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
******************************* Date: 2015-05-21 *******************************
02:03:20:WU00:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
02:03:51:WU01:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
02:04:58:WU01:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
02:05:12:WU00:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
02:06:05:WU01:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
02:07:04:WU00:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
02:07:13:WU01:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
02:08:21:WU01:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
02:08:56:WU00:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
02:09:30:WU01:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
02:10:39:WU01:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
02:10:47:WU00:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
02:11:48:WU01:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
02:12:39:WU00:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
02:12:56:WU01:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
02:14:05:WU01:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
02:14:31:WU00:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
02:15:15:WU01:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
02:16:22:WU00:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
02:16:24:WU01:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
02:17:33:WU01:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
02:18:14:WU00:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
02:18:41:WU01:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
02:19:50:WU01:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
02:20:05:WU00:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
02:20:59:WU01:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
02:21:57:WU00:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
02:22:07:WU01:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
02:23:18:WU01:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
02:23:48:WU00:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
02:24:27:WU01:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
02:25:37:WU01:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
02:25:40:WU00:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
02:26:44:WU01:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
02:27:32:WU00:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
02:27:52:WU01:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
02:29:00:WU01:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
02:29:24:WU00:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
02:30:09:WU01:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
02:31:15:WU00:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
02:31:18:WU01:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
02:32:25:WU01:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
02:33:07:WU00:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
02:33:33:WU01:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
02:34:40:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
02:34:42:WU02:FS00:Connecting to 171.67.108.200:8080
02:34:42:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:34:42:WU02:FS00:Connecting to 171.67.108.204:80
02:34:43:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:34:43:ERROR:WU02:FS00:Exception: Could not get an assignment
02:34:43:WU02:FS00:Connecting to 171.67.108.200:8080
02:34:44:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:34:44:WU02:FS00:Connecting to 171.67.108.204:80
02:34:45:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:34:45:ERROR:WU02:FS00:Exception: Could not get an assignment
02:34:59:WU00:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
02:35:44:WU02:FS00:Connecting to 171.67.108.200:8080
02:35:44:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:35:44:WU02:FS00:Connecting to 171.67.108.204:80
02:35:45:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:35:45:ERROR:WU02:FS00:Exception: Could not get an assignment
02:35:48:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
02:35:48:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:35:58:WU01:FS00:0xa4:
02:35:58:WU01:FS00:0xa4:Finished Work Unit:
02:35:58:WU01:FS00:0xa4:- Reading up to 811488 from "01/wudata_01.trr": Read 811488
02:35:58:WU01:FS00:0xa4:trr file hash check passed.
02:35:58:WU01:FS00:0xa4:- Reading up to 746008 from "01/wudata_01.xtc": Read 746008
02:35:58:WU01:FS00:0xa4:xtc file hash check passed.
02:35:58:WU01:FS00:0xa4:edr file hash check passed.
02:35:58:WU01:FS00:0xa4:logfile size: 23657
02:35:58:WU01:FS00:0xa4:Leaving Run
02:36:01:WU01:FS00:0xa4:- Writing 1583641 bytes of core data to disk...
02:36:01:WU01:FS00:0xa4:Done: 1583129 -> 1537841 (compressed to 97.1 percent)
02:36:01:WU01:FS00:0xa4: ... Done.
02:36:04:WU01:FS00:0xa4:- Shutting down core
02:36:04:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:36:05:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:36:05:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9016 run:621 clone:9 gen:0 core:0xa4 unit:0x00000006ab40417c554ea00d45c62533
02:36:05:WU01:FS00:Uploading 1.47MiB to 171.64.65.124
02:36:05:WU01:FS00:Connecting to 171.64.65.124:8080
02:36:07:WU01:FS00:Upload complete
02:36:07:WU01:FS00:Server responded WORK_ACK (400)
02:36:07:WU01:FS00:Final credit estimate, 1829.00 points
02:36:07:WU01:FS00:Cleaning up
02:36:50:WU00:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
02:37:21:WU02:FS00:Connecting to 171.67.108.200:8080
02:37:22:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:37:22:WU02:FS00:Connecting to 171.67.108.204:80
02:37:22:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:37:22:ERROR:WU02:FS00:Exception: Could not get an assignment
02:38:40:WU00:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
02:39:58:WU02:FS00:Connecting to 171.67.108.200:8080
02:39:59:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:39:59:WU02:FS00:Connecting to 171.67.108.204:80
02:40:00:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:40:00:ERROR:WU02:FS00:Exception: Could not get an assignment
02:40:30:WU00:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
02:42:20:WU00:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
02:44:10:WU00:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
02:44:12:WU02:FS00:Connecting to 171.67.108.200:8080
02:44:13:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:44:13:WU02:FS00:Connecting to 171.67.108.204:80
02:44:14:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:44:14:ERROR:WU02:FS00:Exception: Could not get an assignment
02:46:00:WU00:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
02:47:50:WU00:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
02:49:40:WU00:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
02:51:04:WU02:FS00:Connecting to 171.67.108.200:8080
02:51:04:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:51:04:WU02:FS00:Connecting to 171.67.108.204:80
02:51:05:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:51:05:ERROR:WU02:FS00:Exception: Could not get an assignment
02:51:30:WU00:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
02:53:20:WU00:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
02:55:10:WU00:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
02:57:00:WU00:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
02:58:50:WU00:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
03:00:40:WU00:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
03:02:09:WU02:FS00:Connecting to 171.67.108.200:8080
03:02:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
03:02:10:WU02:FS00:Connecting to 171.67.108.204:80
03:02:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
03:02:11:ERROR:WU02:FS00:Exception: Could not get an assignment
03:02:30:WU00:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
03:04:20:WU00:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
03:06:10:WU00:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
03:08:00:WU00:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
03:09:50:WU00:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
03:11:40:WU00:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
03:13:30:WU00:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
03:15:20:WU00:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
03:17:10:WU00:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
03:19:00:WU00:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
03:20:07:WU02:FS00:Connecting to 171.67.108.200:8080
03:20:08:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
03:20:08:WU02:FS00:Connecting to 171.67.108.204:80
03:20:08:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
03:20:08:ERROR:WU02:FS00:Exception: Could not get an assignment
03:20:50:WU00:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
03:22:40:WU00:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
03:24:30:WU00:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
03:26:20:WU00:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
03:28:10:WU00:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
03:30:00:WU00:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
03:30:00:WU01:FS01:Connecting to 171.67.108.200:80
03:30:02:WU01:FS01:Assigned to work server 171.67.108.52
03:30:02:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
03:30:02:WU01:FS01:Connecting to 171.67.108.52:8080
03:30:03:WU01:FS01:Downloading 1.52MiB
03:30:05:WU01:FS01:Download complete
03:30:05:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:345 clone:4 gen:379 core:0x17 unit:0x000002126652edc45399e3a2e8136b83
03:31:50:WU00:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
03:31:51:WU00:FS01:0x17:Saving result file logfile_01.txt
03:31:51:WU00:FS01:0x17:Saving result file checkpointState.xml
03:31:51:WU00:FS01:0x17:Saving result file checkpt.crc
03:31:51:WU00:FS01:0x17:Saving result file log.txt
03:31:51:WU00:FS01:0x17:Saving result file positions.xtc
03:31:52:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:31:52:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:31:52:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:817 clone:2 gen:282 core:0x17 unit:0x000001956652edc45399f62ab492de34
03:31:52:WU00:FS01:Uploading 8.35MiB to 171.67.108.52
03:31:52:WU00:FS01:Connecting to 171.67.108.52:8080
03:31:52:WU01:FS01:Starting
03:31:52:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 29666 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:31:52:WU01:FS01:Started FahCore on PID 8277
03:31:52:WU01:FS01:Core PID:8281
03:31:52:WU01:FS01:FahCore 0x17 started
03:31:53:WU01:FS01:0x17:*********************** Log Started 2015-05-21T03:31:52Z ***********************
03:31:53:WU01:FS01:0x17:Project: 9201 (Run 345, Clone 4, Gen 379)
03:31:53:WU01:FS01:0x17:Unit: 0x000002126652edc45399e3a2e8136b83
03:31:53:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
03:31:53:WU01:FS01:0x17:Machine: 1
03:31:53:WU01:FS01:0x17:Reading tar file state.xml
03:31:53:WU01:FS01:0x17:Reading tar file system.xml
03:31:53:WU01:FS01:0x17:Reading tar file integrator.xml
03:31:53:WU01:FS01:0x17:Reading tar file core.xml
03:31:53:WU01:FS01:0x17:Digital signatures verified
03:32:00:WU00:FS01:Upload complete
03:32:00:WU00:FS01:Server responded WORK_ACK (400)
03:32:00:WU00:FS01:Final credit estimate, 35392.00 points
03:32:00:WU00:FS01:Cleaning up
03:32:02:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
03:33:52:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
03:35:43:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
03:37:33:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
03:39:24:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
03:41:14:WU01:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
03:43:05:WU01:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
03:44:55:WU01:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
03:46:46:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
03:48:36:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
03:49:08:WU02:FS00:Connecting to 171.67.108.200:8080
03:49:09:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
03:49:09:WU02:FS00:Connecting to 171.67.108.204:80
03:49:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
03:49:10:ERROR:WU02:FS00:Exception: Could not get an assignment
03:50:27:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
03:52:17:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
03:54:08:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
03:55:58:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
03:57:49:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)Any ideas? Something wrong on my setup, or problems with the server(s)?
Re: 171.67.108.200 [and .204] - Internal Server Error
I've been having a problem with this server, which is empty and has no jobs to provide since last night, also with *.204, that is in the same condition. So, I have 2 cpus that have been idle for well over 12 hours now because there are, apparently no jobs in these servers for distribution. Seems a waste. A few weeks ago this was occurring over a weekend, which is somewhat understandable, but in the middle of a week?
Re: CPU slot can not get assignment (171.64.65.124?)
Welcome to foldingforum.org, Wild Penguin.
The Mods and the PG are aware of a problem when a system is configured to use 7 CPU threads. I hope that this will be resolved soon but as a temporary measure, I recommend adjusting the cpus setting to 6.
Re: Empty work server assignment
Welcome to foldingforum.org, RABishop.
I've moved your posts to a different topic. You posted in a discussion of the error message "INTERNAL_SERVER_ERROR" and you're seeing the message "Empty work server assignment" which is an entirely different issue.
Wild Penguin
Re: CPU slot gets "Empty work server assignment"
Bruce,
Thanks for your reply!
I had indeed not found the right search words. After posting, I noticed another thread which instructed to decrease the threads number as you said, and tried it. As a workaround, it works for me!
16:41:38:ERROR:WU00:FS00:Exception: Could not get an assignment
17:29:16:WARNING:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: No address associated with hostname
17:29:16:ERROR:WU00:FS00:Exception: Could not get an assignment
18:44:42:WU00:FS00:Connecting to 171.67.108.200:8080
18:44:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
18:44:43:WU00:FS00:Connecting to 171.67.108.204:80
18:47:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection timed out
18:47:53:ERROR:WU00:FS00:Exception: Could not get an assignment
I also get no WU's on a dedicated 24 core workstation:
Edit: This workstation runs Fedora 14 (as requested on viewtopic.php?f=18&t=27725)
22:38:50:Enabled folding slot 00: READY cpu:24
22:38:51:WU00:FS00:Connecting to 171.67.108.200:8080
22:38:52:WU00:FS00:Connecting to 171.67.108.200:8080
ESC[93m22:38:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignmentESC[0m
22:38:53:WU00:FS00:Connecting to 171.67.108.204:80
ESC[93m22:38:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignmentESC[0m
ESC[91m22:38:54:ERROR:WU00:FS00:Exception: Could not get an assignmentESC[0m
Ditto, has been off/on the last cpl days on both semi-dedicated 24 core workstations - since late last night totally off...
I could get it back folding last cpl days by closing / re-opening client, now it's a no-go, nada, zilch...
Just an FYI
Just an FYI
The Pande Group is working this problem. It appears that there really were two or three different problems all causing the same results. For 7 cpus, I was able to get an assignment. Ditto for other settings for not-too-big CPU counts.
For 32 or 64 CPUs, there seems to also be a shortage of a different set of projects and that remains to be solved.
Please let me know if your observations disagree with those statements.
I'm also able to get work with SMP 7 slots, so this issue seems fixed for the time being.
Temporary workaround for machines with quite a high number of CPUs when they can't get work : instead of running one 32 core slot, try to split it into two 16 cores slots or four 8 cores slots ...
Wild Penguin
I'm just wondering, why not make the client automatically split the work if there is no WUs available for a higher core count? Of course that does not fix the issue if there's an error in delegating the right WUs (that are available).
This problem reportedly has been resolved. Please post if you find otherwise.bruce wrote:For 32 or 64 CPUs, there seems to also be a shortage of a different set of projects and that remains to be solved.
For those of you who split your machine into more than one CPU slot, click on FINISH and as slots complete their WU, you can increase the size of the remaining slot -- although if you make a large change in CPU-count to a slot with a small protein, you may run into trouble.
