Catalyst 14.12 Omega & 7970
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5043 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR/Sony Bravia 3(2024) EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.3 LTS Kernel 6.14.x HWE Generic UPS BX1500G
Post by DarkFoss »
Just a heads up about the latest Catalyst 14.12 Omega and older cards.
I have 2 7970's Windows 8.1x64 and the last day and a half I tried the 14.12's. They were roughly 4 minutes slower on the 1300 and 1301 Wu's average TPF was 10:45 or a bit higher,definitely a bug/regression with the OpenCl 2.0 update and my 7970's and or FAH.
I'm back on the 14.9.2 betas Folding is back to normal TPF 7:30 on WU 13000 (391, 1, 35) and TPF of 7:40 on WU 13001 (202, 0, 115).
If you have a newer R series you *may* be ok. I just know for me these and the previous 14.11 betas were a no go not for folding but random bsod's if watching movies in Firefox with Flash.
*Edit* I should note the 10466's and 9201's seems to be unaffected after looking through the logs roughly a TPF of 8:29 and 3;30 respectively.
cvsi3
Hardware configuration: Intel 2600K @ 4.7Ghz - Diamond 7970 Ref 1225/1600 - G.Skill 2133Mhz 9-9-9-21-1T. Corsair AX1200 PSU. CPU and GPU are watercooled.
Re: Catalyst 14.12 Omega & 7970
Post by cvsi3 »
I run a 7970 and 280x, which are technically the same cards, but I experience the same thing, went from 6:26 TPF to just under 10 minutes on 13000 and 13001 work units.
DarkFoss
Post by DarkFoss »
Thanks for the confirmation always good to know it's not just my system. :)
plimogz
Post by plimogz »
I just installed the 14.12 Omegas on my dual R9 290 Win7 (64bit) machine a couple of hours ago, and so far I'm not seeing any regression VS 14.9. This is based on a 9201 WU and a 13000 WU.
Though I guess I won't be installing the new driver on my 7950 machine.
Thanks for the heads-up!
JimF
Post by JimF »
Same on the HD 7790 and HD 7870. The 14.12 drivers are about 5% slower than the 14.9 drivers, which are the best for those cards on Folding (Win7 64-bit).
jrweiss
Post by jrweiss »
Updated from 14.4 to 14.9. On my 7750, TPF went from 33:55 to 32:32. Will upgrade the second system tomorrow.
Dr.G
Post by Dr.G »
Thanks for the thread @DarkFoss
I was also interested / excited to see what effect Catalyst 14.12 Omega would have on folding PPD.
I measured perfomance using FahBench
14.9 : 26 ns/day (explicit), 76 ns/day (implicit)
14.12 : 16 ns/day (explicit), 51 ns/day (implicit)
So sadly quite BIG drop in folding performance using the new Omega drivers. :e(
(This is my test-bench which only has an old 7850 with Win 7 home - not tried on my folding rigs with dual R2 290X's or dual 7970's )
Anyone else had any other experience?
Post by foldy »
I tested FAHbench with my HD7950 (or R9 280) @900Mhz
14.9.
Explicit 35
Implicit 122
14.12.
Explicit 35
Implicit 111
So this is a 10% performance decrease, but not a big thing.
DarkFoss
Post by DarkFoss »
@DrG, Your welcome.
@Foldy I respectfully disagree the performance drop on my HD7970's is a big deal. In the time it takes to render 2 frames with the 14.12 driver I could have rendered a 3rd and then some with the 14.9. , that adds 5 to 6 hours of time it takes to complete the WU. It also delays the science since the next one in order could have been issued that much sooner , not to mention the wasted electricity of folding that same WU when I could be 5 hours into the next WU.
Post by foldy »
@DarkFoss I meant not a big thing on my HD 7950 :-)
But i also checked my logfiles for the 13000 and 13001 WUs
and see no difference between 14.9 and 14.12
With my HD 7950 both take 10min per %.
I mean something like that in the logfile:
18:44:50:WU00:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
18:54:45:WU00:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
Did you check the logfile time between checkpoint % logs
or are you only referring to TPF?
Maybe the TPF display is not correct?
DarkFoss
Post by DarkFoss »
Hi foldy no worries, I misread I guess :lol:
I checked the logs with the 14.12 :
Project: 13001 (Run 379, Clone 2, Gen 84)
04:31:50:WU00:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
04:42:10:WU00:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
04:52:46:WU00:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
05:03:12:WU00:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
Project: 13000 (Run 632, Clone 0, Gen 46)
04:35:38:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
04:49:25:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
05:03:31:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
05:17:21:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
With the 14.9.2 beta
Project: 13001 (Run 351, Clone 3, Gen 79)
Project: 13001 (Run 522, Clone 7, Gen 72)
22:38:38:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
22:42:28:WU00:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
22:46:19:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
22:50:09:WU00:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
22:54:00:WU01:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
22:58:05:WU00:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
Post by foldy »
I found a workaround for the problem:
You can install the 14.12 driver and still use the 14.9 OpenCl runtime with FAH. 8-)
Just copy files OpenCL.dll and amdocl.dll from 14.9 driver to FAH core folder.
This will hide the slower 14.12 OpenCL 2.0 runtime and FahCore will use the faster 14.9. OpenCL 1.2 runtime.
1) Copy amdocl.dll and amd_opencl32.dll
from source folder
C:\AMD\AMD-Catalyst-14-9-win7-win8.1-64Bit-dd-ccc-whql\Packages\Drivers\Display\WB6A_INF\B176041
to target folder:
C:\ProgramData\FAHClient\cores\web.stanford.edu\~pande\Win32\AMD64\ATI\R600\Core_17.fah
2) Rename amd_opencl32.dll to OpenCL.dll
3) Pause and Resume the slot or FAH client.
:!: If you want to use this mod then don't forget that you have to redo it when FahCore changes,
and if you install an even newer driver in future e.g. AMD 15.3 then you have to remove the extra files
if you want to use the future AMD 15.3 OpenCL runtime.
@DarkFoss: I dont know if you are happy with 14.9. now, but if you want 14.12. you can try my runtime mod.
@FAHcore developers: Do you file a performance issue to AMD or do you adapt future FAHcore18 to not have this issue :?:
Comment directly to developers on the /r/foldingathome reddit page.
I didn't seen any performance change on my R9 290X with 14.12 drivers. I think it is even a little bit faster than 14.9 :D
Now it would be interesting to see how fahcore18 behave in these conditions ... the performance issue might be solved or at least improved.
MaddMutt
Hardware configuration: Gigabyte MA-790FXT(a) UD5
AMD P-II X6 1100t @3.7
2x Sapphire HD-6950 2Gb Toxic Edition Unlocked to 1536 Shaders
12Gb DDR-3 1600 Corsair
Seagate 500Gb Hard Drive
Post by MaddMutt »
Here are screen shoots to show the difference in the 14.9 and 14.12. Picture #1 was taken while running 14.12 Driver. Picture #2 was taken after doing a DDU and installing 14.9 to finish.
SORRY NO PICTURE UPLOAD.
Long Story Sort : Pic#1 has my ASUS R9-280x TOP (my best folder OCed) running @ 9:26 TPF on WU 13000
Pic#2 has my ASUS R9-280x TOP (my best folder OCed) running @ 6:49 TPF on WU 13000
To me, this is a BIG JUMP IN PERFORMANCE :D This also means that the 14.12 Drivers are crap for FAH
KOREAN WAR: When asked why Major General Oliver P. Smith's 1st Marine Division was retreating after being surrounded by 10 Chinese Division's
HE REPLIED: "Retreat, hell! We're not retreating, we're just advancing in a different direction."
