Nvidia GeForce 344.11 WHQL drivers
http://www.geforce.com/whats-new/articl ... r-released
Nvidia has released 344.11 WHQL drivers on their website.
Re: Nvidia GeForce 344.11 WHQL drivers
On a pair of 780s, I'm still seeing the 5-10% slowdown I was seeing on previous 34x drivers vs. what I do on 337.88.
On the first WU I got it looks like it is doing a little better. I'm using 1300x for comparison. On first glance it looks like previous 34x may have lost closer to -10% and 344.11 closer to -5%. But I haven't really run enough WUs to say with any confidence.
I am folding on one pair of 780 ti and I got 5% increase in PPD, and I got 5% reduction in CPU usage. 13000 and 13001 tested.
On two GTX 750 Ti's running under Win7 64-bit, I see a decrease in PPD from about 66k to 59k, or a 10% loss (P9201). I am going back to the 340.52 drivers.
- Hardware configuration: GTX770 / Win 8.1/64
i5-3570k / Win 8.1/64
i5 Apple / OS X
Xeon 4c / ESXi-Linux/64
C2D / Ubuntu/64 - Location: Sweden
344.11 still has the slowdown seen since 327.23 on GK104, on project 9201 / GTX 770 / 0x17 v. 0.0.52.
/dnadan
/dnadan
T H E R E I S N O D A R K S I D E O F T H E M O O N R E A L L Y
9 AMD GPU folding slots
31 Nvidia GPU folding slots
50 total folding slots
344.11 is slower on p13000 work units on two different systems, each with two EVGA 780ti SC, clocked the same (1175 boost) versus 337.88 drivers:
On the Gigabyte Z97X-Gaming G1 WIFI-BK with a i7-4790K @ 4GHz, the slowdown averages 12 seconds per frame (TPF: 5:17 with 337.88, and 5:29 with 344.11)
On the ASUS P8Z77-V LK with a i7 3770K @ 3.50GHz the slowdown is less, averaging 4 seconds per frame (TPF: 5:15 with 337.88, and 5:19 with 344.11)
Both systems are running Win7 x64, 16GB @1600, SSD drives and measured over ~75 frames using HFM v0.9.2, using Process Lasso to dedicate 4 cores (2 physical, 2 hyperthread) to both GPUs and the other 4 cores dedicated to an SMP work unit. Systems are both dedicated to folding with no other applications running.
Please be sure to note which version of the fahcore_17 you are running when posting stats.
Both systems: 0x17:Version 0.0.52
Exactly the same setup, slowdown and corrective action here. Core 0x17:Version 0.0.52JimF wrote:On two GTX 750 Ti's running under Win7 64-bit, I see a decrease in PPD from about 66k to 59k, or a 10% loss (P9201). I am going back to the 340.52 drivers.
- Hardware configuration: I7-3970X Extreme, 6 core (overclocked to 4.5Mhz all cores ) 32Gb 1888mhz Ram, Intel 730 480Gb SSD, Two Zortac Amp! GTX 780 Ti's (overclocked to 1175 Mhz) Water cooled Windows 8.1
I agree with PS3EdOlkkola, I also am running two (2) GTX 780 Ti's and 344.11 is about 10% slower on both gpu's so I rolled it back and the 10% came back
X17 13001 work units
- Hardware configuration: HP z600-dual 5650 xeons (6 cores-2.67 x2) , 32g ram, gtx780
gtx780 driver update now less PPD
Hi guys,
Updated to the new version driver from nvidia the other day and i now find im doing less points, like 40k less, what driver version do you recommend?
Re: gtx780 driver update now less PPD
previous, roll it back
thanksVeixES wrote:previous, roll it back
how do i go about rolling it back?
